[GRASS-SVN] r57244 - in grass/trunk/gui/wxpython: mapdisp mapswipe vdigit
svn_grass at osgeo.org
Mon Jul 22 05:07:59 PDT 2013
Author: wenzeslaus
Date: 2013-07-22 05:07:59 -0700 (Mon, 22 Jul 2013)
New Revision: 57244
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapdisp/mapwindow.py
grass/trunk/gui/wxpython/mapswipe/mapwindow.py
grass/trunk/gui/wxpython/vdigit/mapwindow.py
wxGUI/mapwindow: removing unused tree variables from BufferedWindow
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2013-07-22 06:48:57 UTC (rev 57243)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2013-07-22 12:07:59 UTC (rev 57244)
@@ -148,8 +148,8 @@
# Init map display (buffered DC & set default cursor)
self.MapWindow2D = BufferedWindow(self, giface = self._giface, id = wx.ID_ANY,
- Map = self.Map, frame = self, tree = self.tree,
- lmgr = self._layerManager, overlays = self.decorations)
+ Map=self.Map, frame=self,
+ overlays=self.decorations)
self.MapWindow2D.mapQueried.connect(self.Query)
# enable or disable zoom history tool
self.MapWindow2D.zoomHistoryAvailable.connect(
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-07-22 06:48:57 UTC (rev 57243)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-07-22 12:07:59 UTC (rev 57244)
@@ -56,13 +56,21 @@
SaveToFile() method.
def __init__(self, parent, giface, Map, frame,
- id = wx.ID_ANY, tree = None, lmgr = None, overlays = None,
+ id=wx.ID_ANY, overlays=None,
style = wx.NO_FULL_REPAINT_ON_RESIZE, **kwargs):
+ @param parent parent window
+ @param giface grass interface instance
+ @param Map map instance
+ @param frame map frame instance (to be removed)
+ @param id wx window id
+ @param style wx window style
+ @param kwargs keyword arguments passed to MapWindow and wx.Window
MapWindow.__init__(self, parent = parent, giface = giface, Map = Map,
frame = frame, **kwargs)
wx.Window.__init__(self, parent = parent, id = id, style = style, **kwargs)
- self.tree = tree
# flags
self.resize = False # indicates whether or not a resize event has taken place
self.dragimg = None # initialize variable for map panning
Modified: grass/trunk/gui/wxpython/mapswipe/mapwindow.py
--- grass/trunk/gui/wxpython/mapswipe/mapwindow.py 2013-07-22 06:48:57 UTC (rev 57243)
+++ grass/trunk/gui/wxpython/mapswipe/mapwindow.py 2013-07-22 12:07:59 UTC (rev 57244)
@@ -36,10 +36,9 @@
Enables to draw the image translated.
Special mouse events with changed coordinates are used.
- def __init__(self, parent, giface, Map, frame,
- tree = None, **kwargs):
+ def __init__(self, parent, giface, Map, frame, **kwargs):
BufferedWindow.__init__(self, parent = parent, giface = giface,
- Map = Map, frame = frame, tree = tree, **kwargs)
+ Map=Map, frame=frame, **kwargs)
Debug.msg(2, "SwipeBufferedWindow.__init__()")
self.specialSize = super(SwipeBufferedWindow, self).GetClientSize()
Modified: grass/trunk/gui/wxpython/vdigit/mapwindow.py
--- grass/trunk/gui/wxpython/vdigit/mapwindow.py 2013-07-22 06:48:57 UTC (rev 57243)
+++ grass/trunk/gui/wxpython/vdigit/mapwindow.py 2013-07-22 12:07:59 UTC (rev 57244)
@@ -31,10 +31,10 @@
"""!A Buffered window extended for vector digitizer.
+ id=wx.ID_ANY, lmgr=None,
BufferedWindow.__init__(self, parent = parent, giface = giface, id = id, Map = Map,
- frame = frame, tree = tree, style = style, **kwargs)
+ frame=frame, style=style, **kwargs)
self.lmgr = lmgr
self.pdcVector = wx.PseudoDC()
self.toolbar = self.parent.GetToolbar('vdigit')
