[GRASS-SVN] r57247 - grass-addons/grass7/vector/v.area.weigh
svn_grass at osgeo.org
Mon Jul 22 12:34:25 PDT 2013
Author: mmetz
Date: 2013-07-22 12:34:25 -0700 (Mon, 22 Jul 2013)
New Revision: 57247
Added:
grass-addons/grass7/vector/v.area.weigh/Makefile
grass-addons/grass7/vector/v.area.weigh/v.area.weigh.html
grass-addons/grass7/vector/v.area.weigh/v.area.weigh.py
v.area.weigh: mass-preserving area interpolation with known weights
Added: grass-addons/grass7/vector/v.area.weigh/Makefile
--- grass-addons/grass7/vector/v.area.weigh/Makefile (rev 0)
+++ grass-addons/grass7/vector/v.area.weigh/Makefile 2013-07-22 19:34:25 UTC (rev 57247)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM=v.area.weigh
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/vector/v.area.weigh/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/vector/v.area.weigh/v.area.weigh.html
--- grass-addons/grass7/vector/v.area.weigh/v.area.weigh.html (rev 0)
+++ grass-addons/grass7/vector/v.area.weigh/v.area.weigh.html 2013-07-22 19:34:25 UTC (rev 57247)
@@ -0,0 +1,49 @@
+<h2>DESCRIPTION</h2>
+<em>v.area.weigh</em> rasterizes vector areas using known cell weights.
+In the output raster, the sum off all cells falling into a given area
+is identical to the area attribute value used to rasterize the area.
+<p>
+<em>v.area.weigh</em> can add spatial detail to larger areas, if more
+detailed information is available from other sources. For example,
+population counts are typically available for administrative areas such
+as provinces, counties or countries. At the same time, the location of
+urban areas might be known and can be used to refine spatial detail
+using <em>v.area.weigh</em>.
+TODO: add reasonable example
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+# set computational region to raster ...
+g.region -p rast=...
+# extract urban areas
+r.mapcalc "urban = if(...)"
+# smooth a bit
+r.neighbors input=urban output=urban_ngbr5 size=5 method=average
+# refine
+v.area.weigh vector=... column=... weight=urban_ngbr5 out=...
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.surf.mass.html">v.surf.mass</a>,
+<a href="v.to.rast.html">v.to.rast</a>,
+<a href="r.statistics2.html">r.statistics2</a>
+</em>
+<h2>AUTHOR</h2>
+Markus Metz
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/vector/v.area.weigh/v.area.weigh.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/vector/v.area.weigh/v.area.weigh.py
--- grass-addons/grass7/vector/v.area.weigh/v.area.weigh.py (rev 0)
+++ grass-addons/grass7/vector/v.area.weigh/v.area.weigh.py 2013-07-22 19:34:25 UTC (rev 57247)
@@ -0,0 +1,107 @@
+#!/usr/bin/env python
+# MODULE: v.area.weigh
+# AUTHOR(S): Markus Metz
+# PURPOSE: Rasterize vector areas using cell weights
+# COPYRIGHT: (C) 2013 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Rasterize vector areas using weights
+#% keywords: vector
+#% keywords: interpolation
+#% keywords: raster
+#%end
+#%option G_OPT_V_INPUT
+#% key: vector
+#%end
+#%option G_OPT_V_FIELD
+#%end
+#%option G_OPT_DB_COLUMN
+#% description: Name of attribute column to use as area values (must be numeric)
+#%end
+#%option G_OPT_R_INPUT
+#% key: weight
+#% description: Name of input raster with weights per cell
+#%end
+#%option G_OPT_R_OUTPUT
+#%end
+import sys
+import os
+import atexit
+import grass.script as grass
+def cleanup():
+ if rastertmp1:
+ grass.run_command('g.remove', rast = rastertmp1, quiet = True)
+ if rastertmp2:
+ grass.run_command('g.remove', rast = rastertmp2, quiet = True)
+ if rastertmp3:
+ grass.run_command('g.remove', rast = rastertmp3, quiet = True)
+def main():
+ global tmp, tmpname, rastertmp1, rastertmp2, rastertmp3
+ rastertmp1 = False
+ rastertmp2 = False
+ rastertmp3 = False
+ #### setup temporary files
+ tmp = grass.tempfile()
+ # we need a random name
+ tmpname = grass.basename(tmp)
+ vector = options['vector']
+ layer = options['layer']
+ column = options['column']
+ weight = options['weight']
+ output = options['output']
+ # is column numeric?
+ coltype = grass.vector_columns(vector, layer)[column]['type']
+ if coltype not in ('INTEGER', 'DOUBLE PRECISION'):
+ grass.fatal(_("Column must be numeric"))
+ # rasterize with cats (will be base layer)
+ rastertmp1 = "%s_%s_1" % (vector, tmpname)
+ if grass.run_command('v.to.rast', input = vector, output = rastertmp1,
+ use = 'cat', quiet = True) != 0:
+ grass.fatal(_("An error occurred while converting vector to raster"))
+ # rasterize with column
+ rastertmp2 = "%s_%s_2" % (vector, tmpname)
+ if grass.run_command('v.to.rast', input = vector, output = rastertmp2,
+ use = 'attr', layer = layer, attrcolumn = column, quiet = True) != 0:
+ # zonal statistics
+ rastertmp3 = "%s_%s_3" % (vector, tmpname)
+ if grass.run_command('r.statistics2', base = rastertmp1, cover = weight,
+ method = 'sum', output = rastertmp3, quiet = True) != 0:
+ grass.fatal(_("An error occurred while calculating zonal statistics"))
+ # weighted interpolation
+ exp = "$output = if($sumweight == 0, if(isnull($area_val), null(), 0), double($area_val) * $weight / $sumweight)"
+ grass.mapcalc(exp,
+ output = output,
+ sumweight = rastertmp3,
+ area_val = rastertmp2,
+ weight = weight)
+ sys.exit(0)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ main()
Property changes on: grass-addons/grass7/vector/v.area.weigh/v.area.weigh.py
+ text/x-python
+ native
