[GRASS-SVN] r57252 - grass/trunk/lib/python/pygrass/modules/interface
Tue Jul 23 02:59:35 PDT 2013
Author: huhabla
Date: 2013-07-23 02:59:33 -0700 (Tue, 23 Jul 2013)
New Revision: 57252
   grass/trunk/lib/python/pygrass/modules/interface/module.py
Dont wait for the process to terminate in case finish_==False
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py	2013-07-22 21:15:47 UTC (rev 57251)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py	2013-07-23 09:59:33 UTC (rev 57252)
@@ -269,6 +269,16 @@
         return args
     def run(self, node=None):
+        """!Run the module
+           This function will wait for the process to terminate
+           in case finish_==True and sets up stdout and stderr.
+           If finish_==False this function will return after starting
+           the process. Use self.popen.communicate() of self.popen.wait()
+           to wait for the process termination. The handling
+           of stdout and stderr must then be done outside of this
+           function.
         if self.inputs['stdin'].value:
             self.stdin = self.inputs['stdin'].value
             self.stdin_ = subprocess.PIPE
@@ -283,8 +293,6 @@
                                       stderr=self.stderr_,
                                       env=self.env_)
         if self.finish_:
-            self.popen.wait()
-        stdout, stderr = self.popen.communicate(input=self.stdin)
-        self.outputs['stdout'].value = stdout if stdout else ''
-        self.outputs['stderr'].value = stderr if stderr else ''
+            stdout, stderr = self.popen.communicate(input=self.stdin)
+            self.outputs['stdout'].value = stdout if stdout else ''
+            self.outputs['stderr'].value = stderr if stderr else ''
