[GRASS-SVN] r57262 - grass-addons/grass7/vector/v.surf.mass
svn_grass at osgeo.org
Wed Jul 24 08:47:25 PDT 2013
Author: mmetz
Date: 2013-07-24 08:47:25 -0700 (Wed, 24 Jul 2013)
New Revision: 57262
grass-addons/grass7/vector/v.surf.mass/main.c
v.surf.mass optimization
Modified: grass-addons/grass7/vector/v.surf.mass/main.c
--- grass-addons/grass7/vector/v.surf.mass/main.c 2013-07-24 15:25:20 UTC (rev 57261)
+++ grass-addons/grass7/vector/v.surf.mass/main.c 2013-07-24 15:47:25 UTC (rev 57262)
@@ -26,6 +26,9 @@
#include "globals.h"
#define SEGSIZE 64
+/* activate to use the original algorithm of Tobler 1979
+#define TOBLER_STRICT
int main(int argc, char *argv[])
@@ -352,19 +355,18 @@
while (doit) {
int l_row = -1, l_col = -1;
maxadj = 0;
+ G_percent(iter, maxiter, 1);
iter++;
- G_message(_("Pass %d"), iter);
for (i = 1; i <= nareas; i++) {
areas[i].interp = .0;
areas[i].adj = .0;
areas[i].avgdiff = .0;
+ areas[i].count_neg = 0;
/* Step 1 */
for (row = 0; row < nrows; row++) {
- G_percent(row, nrows, 2);
for (col = 0; col < ncols; col++) {
int count = 0;
@@ -398,21 +400,23 @@
/* relax */
/* value /= 8; */
thiscell.adj = value;
- if (thiscell.area && !negative &&
- areas[thiscell.area].value == 0) {
- thiscell.adj = 0;
+ if (thiscell.area && !negative) {
+ if (areas[thiscell.area].value == 0)
+ thiscell.adj = 0;
+ if (thiscell.interp + thiscell.adj < 0)
+ thiscell.adj = -thiscell.interp;
segment_put(&out_seg, &thiscell, row, col);
- if (thiscell.area)
- areas[thiscell.area].adj += value;
+ if (thiscell.area) {
+ areas[thiscell.area].adj += thiscell.adj;
+ areas[thiscell.area].interp += thiscell.interp + thiscell.adj;
+#ifdef TOBLER_STRICT
/* Step 2 */
if (areas[i].count)
@@ -424,7 +428,6 @@
/* Step 3 */
segment_get(&out_seg, &thiscell, row, col);
if (!Rast_is_d_null_value(&thiscell.interp)) {
@@ -451,7 +454,6 @@
/* Step 4 */
@@ -462,7 +464,6 @@
/* Step 5 */
@@ -474,10 +475,8 @@
@@ -503,13 +502,44 @@
+#else
+ /* deviation from Tobler 1979: less steps, faster convergence */
+ /* Step 2 */
+ areas[0].adj = 1;
+ for (i = 1; i <= nareas; i++) {
+ areas[i].adj = 1;
+ if (areas[i].interp != 0)
+ areas[i].adj = areas[i].value / areas[i].interp;
+ /* Step 3 */
+ for (row = 0; row < nrows; row++) {
+ for (col = 0; col < ncols; col++) {
+ segment_get(&out_seg, &thiscell, row, col);
+ if (!Rast_is_d_null_value(&thiscell.interp)) {
+ /* multiplication with area scale factor */
+ thiscell.interp = areas[thiscell.area].adj *
+ (thiscell.interp + thiscell.adj);
+ segment_put(&out_seg, &thiscell, row, col);
+ value = thiscell.adj;
+ if (maxadj < value * value) {
+ maxadj = value * value;
+ l_row = row;
+ l_col = col;
+#endif
G_verbose_message(_("Largest squared adjustment: %g"), maxadj);
G_verbose_message(_("Largest row, col: %d %d"), l_row, l_col);
if (iter >= maxiter || maxadj < threshold)
doit = 0;
+ G_percent(maxiter, maxiter, 1);
/* write output */
G_message(_("Writing output <%s>"), out_opt->answer);
