[GRASS-SVN] r57264 - grass/branches/releasebranch_6_4/db/base
svn_grass at osgeo.org
Wed Jul 24 12:56:47 PDT 2013
Author: neteler
Date: 2013-07-24 12:56:47 -0700 (Wed, 24 Jul 2013)
New Revision: 57264
grass/branches/releasebranch_6_4/db/base/describe.c
db.describe: tell user more when failing, fix #1866 (backport from trunk, r57260)
Modified: grass/branches/releasebranch_6_4/db/base/describe.c
--- grass/branches/releasebranch_6_4/db/base/describe.c 2013-07-24 17:20:56 UTC (rev 57263)
+++ grass/branches/releasebranch_6_4/db/base/describe.c 2013-07-24 19:56:47 UTC (rev 57264)
@@ -47,6 +47,11 @@
dbString stmt;
parse_command_line(argc, argv);
+ if (!db_table_exists(parms.driver, parms.database, parms.table)) {
+ G_message(_("Table <%s> not found in database <%s> using driver <%s>"),
+ parms.table, parms.database, parms.driver);
+ exit(EXIT_SUCCESS);
driver = db_start_driver(parms.driver);
if (driver == NULL)
G_fatal_error(_("Unable to start driver <%s>"), parms.driver);
