[GRASS-SVN] r57268 - grass/trunk/vector/v.voronoi
svn_grass at osgeo.org
Thu Jul 25 04:14:07 PDT 2013
Author: mmetz
Date: 2013-07-25 04:14:07 -0700 (Thu, 25 Jul 2013)
New Revision: 57268
grass/trunk/vector/v.voronoi/main.c
grass/trunk/vector/v.voronoi/sw_geometry.c
v.voronoi: fix #957, #1682
Modified: grass/trunk/vector/v.voronoi/main.c
--- grass/trunk/vector/v.voronoi/main.c 2013-07-25 10:30:27 UTC (rev 57267)
+++ grass/trunk/vector/v.voronoi/main.c 2013-07-25 11:14:07 UTC (rev 57268)
@@ -187,7 +187,7 @@
G_set_verbose(0);
Vect_build_partial(&Out, GV_BUILD_BASE);
G_set_verbose(verbose);
ncoor = 0;
acoor = 100;
coor = (COOR *) G_malloc(sizeof(COOR) * acoor);
@@ -410,7 +410,7 @@
if (err_nocentr || err_centr_dupl || err_centr_out) {
int nmod;
- G_important_message(_("Output needs topological cleaning"));
+ G_important_message(_("Cleaning output topology"));
Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL);
do {
Vect_break_lines(&Out, GV_BOUNDARY, NULL);
Modified: grass/trunk/vector/v.voronoi/sw_geometry.c
--- grass/trunk/vector/v.voronoi/sw_geometry.c 2013-07-25 10:30:27 UTC (rev 57267)
+++ grass/trunk/vector/v.voronoi/sw_geometry.c 2013-07-25 11:14:07 UTC (rev 57268)
@@ -1,5 +1,6 @@
#include <stdlib.h>
#include <math.h>
+#include <grass/gis.h>
#include "sw_defs.h"
int geominit(void)
@@ -32,12 +33,22 @@
newedge->ep[0] = (struct Site *)NULL;
newedge->ep[1] = (struct Site *)NULL;
- dx = s2->coord.x - s1->coord.x;
- dy = s2->coord.y - s1->coord.y;
+ if (s1->coord.x < s2->coord.x ||
+ (s1->coord.x == s2->coord.x && s1->coord.y < s2->coord.y)) {
+ dx = s2->coord.x - s1->coord.x;
+ dy = s2->coord.y - s1->coord.y;
+ newedge->c =
+ s1->coord.x * dx + s1->coord.y * dy + (dx * dx + dy * dy) * 0.5;
+ else {
+ dx = s1->coord.x - s2->coord.x;
+ dy = s1->coord.y - s2->coord.y;
+ newedge->c =
+ s2->coord.x * dx + s2->coord.y * dy + (dx * dx + dy * dy) * 0.5;
adx = dx > 0 ? dx : -dx;
ady = dy > 0 ? dy : -dy;
- newedge->c =
- s1->coord.x * dx + s1->coord.y * dy + (dx * dx + dy * dy) * 0.5;
if (adx > ady) {
newedge->a = 1.0;
newedge->b = dy / dx;
@@ -55,12 +66,27 @@
return (newedge);
+/* single precision ULP */
+static double d_ulp(double d)
+ int exp;
+ if (d == 0)
+ return GRASS_EPSILON;
+ d = frexp(d, &exp);
+ exp -= 22;
+ d = ldexp(d, exp);
+ return d;
struct Site *intersect(struct Halfedge *el1, struct Halfedge *el2)
struct Edge *e1, *e2, *e;
struct Halfedge *el;
- double d, xint, yint;
+ double d, dt, xint, yint;
int right_of_site;
struct Site *v;
@@ -72,9 +98,21 @@
return ((struct Site *)NULL);
d = e1->a * e2->b - e1->b * e2->a;
- if (-1.0e-10 < d && d < 1.0e-10)
+ if (fabs(e1->a * e2->b) > fabs(e1->b * e2->a)) {
+ dt = fabs(e1->a * e2->b);
+ else
+ dt = fabs(e1->b * e2->a);
+ if (dt != dt)
+ dt = d_ulp(dt);
+ G_debug(4, "dt = %g", dt);
+ if (-dt < d && d < dt)
+ return ((struct Site *)NULL);
xint = (e1->c * e2->b - e2->c * e1->b) / d;
yint = (e2->c * e1->a - e1->c * e2->a) / d;
