[GRASS-SVN] r57282 - grass/trunk/raster/r.to.vect
svn_grass at osgeo.org
Fri Jul 26 06:39:49 PDT 2013
Author: mmetz
Date: 2013-07-26 06:39:48 -0700 (Fri, 26 Jul 2013)
New Revision: 57282
grass/trunk/raster/r.to.vect/lines_io.c
r.to.vect: fix another memory leak
Modified: grass/trunk/raster/r.to.vect/lines_io.c
--- grass/trunk/raster/r.to.vect/lines_io.c 2013-07-26 13:36:03 UTC (rev 57281)
+++ grass/trunk/raster/r.to.vect/lines_io.c 2013-07-26 13:39:48 UTC (rev 57282)
@@ -99,12 +99,16 @@
static int write_ln(struct COOR *begin, struct COOR *end, /* start and end point of line */
int n)
{ /* number of points to write */
- struct line_pnts *points = Vect_new_line_struct();
+ static struct line_pnts *points = NULL;
double x, y;
struct COOR *p, *last;
int i, cat, field;
static int count = 1;
+ if (!points)
+ points = Vect_new_line_struct();
+ Vect_reset_line(points);
field = 1;
++n;
