[GRASS-SVN] r57306 - in grass/trunk: imagery imagery/i.biomass imagery/i.eb.eta imagery/i.eb.h_sebal01 raster raster/r.latlong
Sat Jul 27 13:34:59 PDT 2013
Author: neteler
Date: 2013-07-27 13:34:58 -0700 (Sat, 27 Jul 2013)
New Revision: 57306
Added:
   grass/trunk/raster/r.latlong/
   grass/trunk/raster/r.latlong/r.latlong.html
Removed:
   grass/trunk/imagery/i.latlong/
   grass/trunk/raster/r.latlong/i.latlong.html
   grass/trunk/imagery/Makefile
   grass/trunk/imagery/i.biomass/i.biomass.html
   grass/trunk/imagery/i.eb.eta/i.eb.eta.html
   grass/trunk/imagery/i.eb.h_sebal01/i.eb.h_sebal01.html
   grass/trunk/raster/Makefile
   grass/trunk/raster/r.latlong/Makefile
   grass/trunk/raster/r.latlong/main.c
i.latlong: renamed to r.latlong for consistency
Modified: grass/trunk/imagery/Makefile
--- grass/trunk/imagery/Makefile	2013-07-27 19:56:37 UTC (rev 57305)
+++ grass/trunk/imagery/Makefile	2013-07-27 20:34:58 UTC (rev 57306)
@@ -24,7 +24,6 @@
 	i.his.rgb \
 	i.landsat.toar \
 	i.landsat.acca \
-	i.latlong \
 	i.maxlik \
 	i.modis.qc \
 	i.ortho.photo \
Modified: grass/trunk/imagery/i.biomass/i.biomass.html
--- grass/trunk/imagery/i.biomass/i.biomass.html	2013-07-27 19:56:37 UTC (rev 57305)
+++ grass/trunk/imagery/i.biomass/i.biomass.html	2013-07-27 20:34:58 UTC (rev 57306)
@@ -6,7 +6,7 @@
 <ul>
  <li>fPAR, the modified Photosynthetic Active Radiation for crops.
  <li>Light Use Efficiency [0.0-1.0], in Uzbekistan cotton is at 1.9 most of the time.
- <li>Latitude [0.0-90.0], from i.latlong.
+ <li>Latitude [0.0-90.0], from r.latlong.
  <li>DOY [1-366].
  <li>Transmissivity of the Atmosphere single-way [0.0-1.0], mostly around 0.7+ in clear sky.
  <li>Water availability [0.0-1.0], possibly using direct output from i.eb.evapfr.
Modified: grass/trunk/imagery/i.eb.eta/i.eb.eta.html
--- grass/trunk/imagery/i.eb.eta/i.eb.eta.html	2013-07-27 19:56:37 UTC (rev 57305)
+++ grass/trunk/imagery/i.eb.eta/i.eb.eta.html	2013-07-27 20:34:58 UTC (rev 57306)
@@ -8,7 +8,7 @@
 <h2>NOTES</h2>
 Full ETa processing will need those:
 <ul>
-  <li>i.vi, i.albedo, i.latlong, i.emissivity
+  <li>i.vi, i.albedo, r.latlong, i.emissivity
   <li>i.evapo.potrad
   <li>i.eb.netrad, i.eb.soilheatflux, i.eb.h_sebal01
   <li>i.eb.evapfr, i.eb.eta
Modified: grass/trunk/imagery/i.eb.h_sebal01/i.eb.h_sebal01.html
--- grass/trunk/imagery/i.eb.h_sebal01/i.eb.h_sebal01.html	2013-07-27 19:56:37 UTC (rev 57305)
+++ grass/trunk/imagery/i.eb.h_sebal01/i.eb.h_sebal01.html	2013-07-27 20:34:58 UTC (rev 57306)
@@ -8,7 +8,7 @@
 Full process will need those:
 <ul>
   <li>i.evapo.potrad (Addon)
Modified: grass/trunk/raster/Makefile
--- grass/trunk/raster/Makefile	2013-07-27 19:56:37 UTC (rev 57305)
+++ grass/trunk/raster/Makefile	2013-07-27 20:34:58 UTC (rev 57306)
@@ -40,6 +40,7 @@
 	r.in.xyz \
 	r.info \
 	r.kappa \
+	r.latlong \
 	r.lake \
 	r.li \
 	r.los \
Modified: grass/trunk/raster/r.latlong/Makefile
--- grass/trunk/imagery/i.latlong/Makefile	2013-07-27 19:56:37 UTC (rev 57305)
+++ grass/trunk/raster/r.latlong/Makefile	2013-07-27 20:34:58 UTC (rev 57306)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = i.latlong
+PGM = r.latlong
 LIBES = $(GPROJLIB) $(RASTERLIB) $(GISLIB) $(PROJLIB)
 DEPENDENCIES = $(GPROJDEP) $(RASTERDEP) $(GISDEP)
Deleted: grass/trunk/raster/r.latlong/i.latlong.html
--- grass/trunk/imagery/i.latlong/i.latlong.html	2013-07-27 19:56:37 UTC (rev 57305)
+++ grass/trunk/raster/r.latlong/i.latlong.html	2013-07-27 20:34:58 UTC (rev 57306)
@@ -1,32 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>i.latlong</em> creates a latitude (degree decimal) map, or longitude
-if the -l flag is used, from any map in any projection using PROJ.4 library.
-This is an input to <em>r.sun</em> and <em>i.evapo.potrad</em>.
-<h2>NOTES</h2>
-The PROJ.4 <a href="http://trac.osgeo.org/proj/">website</a>.
-<h2>TODO</h2>
-Datum transform is not implemented, the same datum is taken as output.
-<h2>EXAMPLE</h2>
-<div class="code"><pre>
-g.region rast=elevation -p
-i.latlong input=elevation output=latitude
-</pre></div>
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.sun.html">r.sun</a>,
-<a href="r.sunhours.html">r.sunhours</a>
-</em>
-<h2>AUTHORS</h2>
-Yann Chemin, International Rice Research Institute, The Philippines
-<p><i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.latlong/main.c
--- grass/trunk/imagery/i.latlong/main.c	2013-07-27 19:56:37 UTC (rev 57305)
+++ grass/trunk/raster/r.latlong/main.c	2013-07-27 20:34:58 UTC (rev 57306)
@@ -1,6 +1,6 @@
- * MODULE:       i.latlong
+ * MODULE:       r.latlong
  * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
  * PURPOSE:      Calculates the longitude of the pixels in the map.
@@ -53,7 +53,7 @@
     G_gisinit(argv[0]);
     module = G_define_module();
-    G_add_keyword(_("imagery"));
+    G_add_keyword(_("raster"));
     G_add_keyword(_("latitude"));
     G_add_keyword(_("longitude"));
     G_add_keyword(_("projection"));
Copied: grass/trunk/raster/r.latlong/r.latlong.html (from rev 57305, grass/trunk/imagery/i.latlong/i.latlong.html)
--- grass/trunk/raster/r.latlong/r.latlong.html	                        (rev 0)
+++ grass/trunk/raster/r.latlong/r.latlong.html	2013-07-27 20:34:58 UTC (rev 57306)
@@ -0,0 +1,32 @@
+<h2>DESCRIPTION</h2>
+<em>r.latlong</em> creates a latitude (degree decimal) map, or longitude
+if the -l flag is used, from any map in any projection using PROJ.4 library.
+This is an input to <em>r.sun</em> and <em>i.evapo.potrad</em>.
+<h2>NOTES</h2>
+The PROJ.4 <a href="http://trac.osgeo.org/proj/">website</a>.
+<h2>TODO</h2>
+Datum transform is not implemented, the same datum is taken as output.
+<h2>EXAMPLE</h2>
+<div class="code"><pre>
+g.region rast=elevation -p
+r.latlong input=elevation output=latitude
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.sun.html">r.sun</a>,
+<a href="r.sunhours.html">r.sunhours</a>
+</em>
+<h2>AUTHORS</h2>
+Yann Chemin, International Rice Research Institute, The Philippines
+<p><i>Last changed: $Date$</i>
