[GRASS-SVN] r57314 - grass/trunk
svn_grass at osgeo.org
Sun Jul 28 10:32:01 PDT 2013
Author: martinl
Date: 2013-07-28 10:32:01 -0700 (Sun, 28 Jul 2013)
New Revision: 57314
grass/trunk/configure
grass/trunk/configure.in
configure.in: enable `pwd -W` (testing in progress)
Modified: grass/trunk/configure
--- grass/trunk/configure 2013-07-28 16:00:47 UTC (rev 57313)
+++ grass/trunk/configure 2013-07-28 17:32:01 UTC (rev 57314)
@@ -1203,9 +1203,14 @@
fi
+if test "$MINGW32" = yes ; then
+ winpwd="$pwd -W"
+else
+ winpwd="$pwd"
+fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1209: checking for source directory" >&5
+echo "configure:1214: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1216,9 +1221,10 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1220: checking for build directory" >&5
+echo "configure:1225: checking for build directory" >&5
DSTDIR=`$pwd`
+WINDSTDIR=`$winpwd`
echo "$ac_t"""$DSTDIR"" 1>&6
@@ -1260,7 +1266,7 @@
# Set GISBASE and GRASS_BIN
-GISBASE="${DSTDIR}/dist.${ARCH}"
+GISBASE="${WINDSTDIR}/dist.${ARCH}"
GRASS_BIN="${DSTDIR}/bin.${ARCH}"
@@ -1283,7 +1289,7 @@
# Extract the first word of "svnversion", so it can be a program name with args.
set dummy svnversion; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:1287: checking for $ac_word" >&5
+echo "configure:1293: checking for $ac_word" >&5
case "$SVN_VERSION" in
@@ -1342,7 +1348,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1346: checking for MacOSX App" >&5
+echo "configure:1352: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1354,7 +1360,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1358: checking for MacOSX architectures" >&5
+echo "configure:1364: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1383,7 +1389,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1387: checking for MacOSX SDK" >&5
+echo "configure:1393: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1393,7 +1399,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1397: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1403: checking for $with_macosx_sdk/SDKSettings.plist" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1437,7 +1443,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1441: checking how to build libraries" >&5
+echo "configure:1447: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -2334,7 +2340,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2338: checking for additional include dirs" >&5
+echo "configure:2344: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2357,7 +2363,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2361: checking for additional library dirs" >&5
+echo "configure:2367: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2391,7 +2397,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2395: checking for a BSD compatible install" >&5
+echo "configure:2401: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2444,7 +2450,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:2448: checking for $ac_word" >&5
+echo "configure:2454: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2475,13 +2481,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2479: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2485: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 2485 "configure"
+#line 2491 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2492,7 +2498,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2517,7 +2523,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2521: checking for $ac_word" >&5
+echo "configure:2527: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2557,7 +2563,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2561: checking for $ac_word" >&5
+echo "configure:2567: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2588,7 +2594,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2592: checking for $ac_word" >&5
+echo "configure:2598: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2626,7 +2632,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2630: checking for $ac_word" >&5
+echo "configure:2636: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2655,7 +2661,7 @@
-echo "configure:2659: checking for $ac_word" >&5
+echo "configure:2665: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2686,7 +2692,7 @@
-echo "configure:2690: checking for $ac_word" >&5
+echo "configure:2696: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2715,7 +2721,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2719: checking for $ac_word" >&5
+echo "configure:2725: checking for $ac_word" >&5
case "$PERL" in
@@ -2746,7 +2752,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2750: checking how to run the C preprocessor" >&5
+echo "configure:2756: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2759,13 +2765,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2763 "configure"
+#line 2769 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2769: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2775: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2776,13 +2782,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2780 "configure"
+#line 2786 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2786: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2792: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2793,13 +2799,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2797 "configure"
+#line 2803 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2803: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2809: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2823,10 +2829,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2827: checking for ANSI C header files" >&5
+echo "configure:2833: checking for ANSI C header files" >&5
-#line 2830 "configure"
+#line 2836 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2834,7 +2840,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2844: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2851,7 +2857,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2855 "configure"
+#line 2861 "configure"
#include <string.h>
EOF
@@ -2869,7 +2875,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2873 "configure"
+#line 2879 "configure"
#include <stdlib.h>
EOF
@@ -2890,7 +2896,7 @@
else
-#line 2894 "configure"
+#line 2900 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2901,7 +2907,7 @@
exit (0); }
EOF
-if { (eval echo configure:2905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2928,15 +2934,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2932: checking for $ac_hdr" >&5
+echo "configure:2938: checking for $ac_hdr" >&5
-#line 2935 "configure"
+#line 2941 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2940: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2946: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2965,15 +2971,15 @@
do
-echo "configure:2969: checking for $ac_hdr" >&5
+echo "configure:2975: checking for $ac_hdr" >&5
-#line 2972 "configure"
+#line 2978 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2977: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2983: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3002,15 +3008,15 @@
do
-echo "configure:3006: checking for $ac_hdr" >&5
+echo "configure:3012: checking for $ac_hdr" >&5
-#line 3009 "configure"
+#line 3015 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3014: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3020: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3039,15 +3045,15 @@
do
-echo "configure:3043: checking for $ac_hdr" >&5
+echo "configure:3049: checking for $ac_hdr" >&5
-#line 3046 "configure"
+#line 3052 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3051: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3057: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3076,15 +3082,15 @@
do
-echo "configure:3080: checking for $ac_hdr" >&5
+echo "configure:3086: checking for $ac_hdr" >&5
-#line 3083 "configure"
+#line 3089 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3094: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3110,10 +3116,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3114: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3120: checking whether time.h and sys/time.h may both be included" >&5
-#line 3117 "configure"
+#line 3123 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3122,7 +3128,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3126: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3132: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3142,10 +3148,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3146: checking for off_t" >&5
+echo "configure:3152: checking for off_t" >&5
-#line 3149 "configure"
+#line 3155 "configure"
#if STDC_HEADERS
@@ -3172,10 +3178,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3176: checking for uid_t in sys/types.h" >&5
+echo "configure:3182: checking for uid_t in sys/types.h" >&5
-#line 3179 "configure"
+#line 3185 "configure"
EOF
@@ -3203,10 +3209,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3207: checking return type of signal handlers" >&5
+echo "configure:3213: checking return type of signal handlers" >&5
-#line 3210 "configure"
+#line 3216 "configure"
#include <signal.h>
@@ -3223,7 +3229,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3227: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3233: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3241,10 +3247,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3245: checking for Cygwin environment" >&5
+echo "configure:3251: checking for Cygwin environment" >&5
-#line 3248 "configure"
+#line 3254 "configure"
int main() {
@@ -3255,7 +3261,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3259: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3265: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3273,10 +3279,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3277: checking for $ac_func" >&5
+echo "configure:3283: checking for $ac_func" >&5
-#line 3280 "configure"
+#line 3286 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3299,7 +3305,7 @@
; return 0; }
EOF
-if { (eval echo configure:3303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3325,10 +3331,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3329: checking for $ac_func" >&5
+echo "configure:3335: checking for $ac_func" >&5
-#line 3332 "configure"
+#line 3338 "configure"
@@ -3351,7 +3357,7 @@
; return 0; }
EOF
-if { (eval echo configure:3355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3377,10 +3383,10 @@
for ac_func in drand48
do
-echo "configure:3381: checking for $ac_func" >&5
+echo "configure:3387: checking for $ac_func" >&5
-#line 3384 "configure"
+#line 3390 "configure"
@@ -3403,7 +3409,7 @@
; return 0; }
EOF
-if { (eval echo configure:3407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3429,10 +3435,10 @@
for ac_func in putenv setenv
do
-echo "configure:3433: checking for $ac_func" >&5
+echo "configure:3439: checking for $ac_func" >&5
-#line 3436 "configure"
+#line 3442 "configure"
@@ -3455,7 +3461,7 @@
; return 0; }
EOF
-if { (eval echo configure:3459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3481,10 +3487,10 @@
for ac_func in nanosleep
do
-echo "configure:3485: checking for $ac_func" >&5
+echo "configure:3491: checking for $ac_func" >&5
-#line 3488 "configure"
+#line 3494 "configure"
@@ -3507,7 +3513,7 @@
; return 0; }
EOF
-if { (eval echo configure:3511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3532,13 +3538,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3536: checking whether setpgrp takes no argument" >&5
+echo "configure:3542: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3542 "configure"
+#line 3548 "configure"
#ifdef HAVE_UNISTD_H
@@ -3558,7 +3564,7 @@
EOF
-if { (eval echo configure:3562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3586,16 +3592,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3590: checking for long long int" >&5
+echo "configure:3596: checking for long long int" >&5
-#line 3592 "configure"
+#line 3598 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3599: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3605: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -3615,7 +3621,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3619: checking for W11" >&5
+echo "configure:3625: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3643,7 +3649,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3647: checking for X" >&5
+echo "configure:3653: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3703,12 +3709,12 @@
# First, try using that file with no special directory specified.
-#line 3707 "configure"
+#line 3713 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3712: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3718: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3777,14 +3783,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3781 "configure"
+#line 3787 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3889,17 +3895,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3893: checking whether -R must be followed by a space" >&5
+echo "configure:3899: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3896 "configure"
+#line 3902 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3915,14 +3921,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3919 "configure"
+#line 3925 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3954,13 +3960,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3958: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3964: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3964 "configure"
+#line 3970 "configure"
@@ -3971,7 +3977,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3992,13 +3998,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3996: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4002: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 4002 "configure"
+#line 4008 "configure"
@@ -4009,7 +4015,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4037,10 +4043,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4041: checking for gethostbyname" >&5
+echo "configure:4047: checking for gethostbyname" >&5
-#line 4044 "configure"
+#line 4050 "configure"
which can conflict with char gethostbyname(); below. */
@@ -4063,7 +4069,7 @@
; return 0; }
EOF
-if { (eval echo configure:4067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4083,13 +4089,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4087: checking for gethostbyname in -lnsl" >&5
+echo "configure:4093: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4093 "configure"
+#line 4099 "configure"
@@ -4100,7 +4106,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4129,10 +4135,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4133: checking for connect" >&5
+echo "configure:4139: checking for connect" >&5
-#line 4136 "configure"
+#line 4142 "configure"
which can conflict with char connect(); below. */
@@ -4155,7 +4161,7 @@
; return 0; }
EOF
-if { (eval echo configure:4159: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4175,13 +4181,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4179: checking for connect in -lsocket" >&5
+echo "configure:4185: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4185 "configure"
+#line 4191 "configure"
@@ -4192,7 +4198,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4196: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4215,10 +4221,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4219: checking for remove" >&5
+echo "configure:4225: checking for remove" >&5
-#line 4222 "configure"
+#line 4228 "configure"
which can conflict with char remove(); below. */
@@ -4241,7 +4247,7 @@
; return 0; }
EOF
-if { (eval echo configure:4245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4261,13 +4267,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4265: checking for remove in -lposix" >&5
+echo "configure:4271: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4271 "configure"
+#line 4277 "configure"
@@ -4278,7 +4284,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4301,10 +4307,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4305: checking for shmat" >&5
+echo "configure:4311: checking for shmat" >&5
-#line 4308 "configure"
+#line 4314 "configure"
which can conflict with char shmat(); below. */
@@ -4327,7 +4333,7 @@
; return 0; }
EOF
-if { (eval echo configure:4331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4347,13 +4353,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4351: checking for shmat in -lipc" >&5
+echo "configure:4357: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4357 "configure"
+#line 4363 "configure"
@@ -4364,7 +4370,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4396,13 +4402,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4400: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4406: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4406 "configure"
+#line 4412 "configure"
@@ -4413,7 +4419,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4453,12 +4459,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4457: checking for library containing cuserid" >&5
+echo "configure:4463: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4462 "configure"
+#line 4468 "configure"
@@ -4469,7 +4475,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4480,7 +4486,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4484 "configure"
+#line 4490 "configure"
@@ -4491,7 +4497,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4517,10 +4523,10 @@
for ac_func in asprintf
do
-echo "configure:4521: checking for $ac_func" >&5
+echo "configure:4527: checking for $ac_func" >&5
-#line 4524 "configure"
+#line 4530 "configure"
@@ -4543,7 +4549,7 @@
; return 0; }
EOF
-if { (eval echo configure:4547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4570,10 +4576,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4574: checking for atan" >&5
+echo "configure:4580: checking for atan" >&5
-#line 4577 "configure"
+#line 4583 "configure"
which can conflict with char atan(); below. */
@@ -4596,7 +4602,7 @@
; return 0; }
EOF
-if { (eval echo configure:4600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4614,13 +4620,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4618: checking for atan in -lm" >&5
+echo "configure:4624: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4624 "configure"
+#line 4630 "configure"
@@ -4631,7 +4637,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4658,10 +4664,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4662: checking for dlsym" >&5
+echo "configure:4668: checking for dlsym" >&5
-#line 4665 "configure"
+#line 4671 "configure"
which can conflict with char dlsym(); below. */
@@ -4684,7 +4690,7 @@
; return 0; }
EOF
-if { (eval echo configure:4688: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4702,13 +4708,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4706: checking for dlsym in -ldl" >&5
+echo "configure:4712: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4712 "configure"
+#line 4718 "configure"
@@ -4719,7 +4725,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4746,10 +4752,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4750: checking for iconv" >&5
+echo "configure:4756: checking for iconv" >&5
-#line 4753 "configure"
+#line 4759 "configure"
which can conflict with char iconv(); below. */
@@ -4772,7 +4778,7 @@
; return 0; }
EOF
-if { (eval echo configure:4776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4790,13 +4796,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4794: checking for iconv in -liconv" >&5
+echo "configure:4800: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4800 "configure"
+#line 4806 "configure"
@@ -4807,7 +4813,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4826,13 +4832,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4830: checking for iconv in -lgiconv" >&5
+echo "configure:4836: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4836 "configure"
+#line 4842 "configure"
@@ -4843,7 +4849,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4862,10 +4868,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4866: checking for libiconv" >&5
+echo "configure:4872: checking for libiconv" >&5
-#line 4869 "configure"
+#line 4875 "configure"
which can conflict with char libiconv(); below. */
@@ -4888,7 +4894,7 @@
; return 0; }
EOF
-if { (eval echo configure:4892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -4906,13 +4912,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4910: checking for libiconv in -liconv" >&5
+echo "configure:4916: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4916 "configure"
+#line 4922 "configure"
@@ -4923,7 +4929,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4942,13 +4948,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4946: checking for libiconv in -lgiconv" >&5
+echo "configure:4952: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4952 "configure"
+#line 4958 "configure"
@@ -4959,7 +4965,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4996,10 +5002,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5000: checking for socket" >&5
+echo "configure:5006: checking for socket" >&5
-#line 5003 "configure"
+#line 5009 "configure"
which can conflict with char socket(); below. */
@@ -5022,7 +5028,7 @@
; return 0; }
EOF
-if { (eval echo configure:5026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5040,13 +5046,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5044: checking for socket in -lsocket" >&5
+echo "configure:5050: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5050 "configure"
+#line 5056 "configure"
@@ -5057,7 +5063,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5105,7 +5111,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5109: checking for location of zlib includes" >&5
+echo "configure:5115: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5131,15 +5137,15 @@
do
-echo "configure:5135: checking for $ac_hdr" >&5
+echo "configure:5141: checking for $ac_hdr" >&5
-#line 5138 "configure"
+#line 5144 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5143: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5173,7 +5179,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5177: checking for location of zlib library" >&5
+echo "configure:5183: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5198,13 +5204,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5202: checking for deflate in -lz" >&5
+echo "configure:5208: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5208 "configure"
+#line 5214 "configure"
@@ -5215,7 +5221,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5263,7 +5269,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5267: checking for location of External PROJ.4 includes" >&5
+echo "configure:5273: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5289,15 +5295,15 @@
do
-echo "configure:5293: checking for $ac_hdr" >&5
+echo "configure:5299: checking for $ac_hdr" >&5
-#line 5296 "configure"
+#line 5302 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5301: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5307: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5334,7 +5340,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5338: checking External PROJ.4 version" >&5
+echo "configure:5344: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5342,7 +5348,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 5346 "configure"
+#line 5352 "configure"
#include <stdio.h>
@@ -5354,7 +5360,7 @@
EOF
-if { (eval echo configure:5358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5379,7 +5385,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5383: checking for location of External PROJ.4 library" >&5
+echo "configure:5389: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5404,13 +5410,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5408: checking for pj_get_def in -lproj" >&5
+echo "configure:5414: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5414 "configure"
+#line 5420 "configure"
@@ -5421,7 +5427,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5455,7 +5461,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5459: checking for location of External PROJ.4 data files" >&5
+echo "configure:5465: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5479,14 +5485,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5483: checking for epsg" >&5
+echo "configure:5489: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5490: checking for $PROJSHARE/epsg" >&5
+echo "configure:5496: checking for $PROJSHARE/epsg" >&5
@@ -5518,7 +5524,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5522: checking for $ac_word" >&5
+echo "configure:5528: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5558,7 +5564,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5562: checking whether to use regex" >&5
+echo "configure:5568: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5578,7 +5584,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5582: checking for location of regex includes" >&5
+echo "configure:5588: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5604,15 +5610,15 @@
do
-echo "configure:5608: checking for $ac_hdr" >&5
+echo "configure:5614: checking for $ac_hdr" >&5
-#line 5611 "configure"
+#line 5617 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5622: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5646,7 +5652,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5650: checking for location of regex library" >&5
+echo "configure:5656: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5671,10 +5677,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5675: checking for regcomp" >&5
+echo "configure:5681: checking for regcomp" >&5
-#line 5678 "configure"
+#line 5684 "configure"
which can conflict with char regcomp(); below. */
@@ -5697,7 +5703,7 @@
; return 0; }
EOF
-if { (eval echo configure:5701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5724,13 +5730,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5728: checking for regcomp in -lregex" >&5
+echo "configure:5734: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5734 "configure"
+#line 5740 "configure"
@@ -5741,7 +5747,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5791,7 +5797,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5795: checking whether to use Readline" >&5
+echo "configure:5801: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5812,7 +5818,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5816: checking for location of Readline includes" >&5
+echo "configure:5822: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5838,15 +5844,15 @@
do
-echo "configure:5842: checking for $ac_hdr" >&5
+echo "configure:5848: checking for $ac_hdr" >&5
-#line 5845 "configure"
+#line 5851 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5850: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5882,15 +5888,15 @@
do
-echo "configure:5886: checking for $ac_hdr" >&5
+echo "configure:5892: checking for $ac_hdr" >&5
-#line 5889 "configure"
+#line 5895 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5894: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5924,7 +5930,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5928: checking for location of Readline library" >&5
+echo "configure:5934: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5949,13 +5955,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5953: checking for readline in -lreadline" >&5
+echo "configure:5959: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 5959 "configure"
+#line 5965 "configure"
@@ -5966,7 +5972,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:5970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6001,13 +6007,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6005: checking for add_history in -lhistory" >&5
+echo "configure:6011: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6011 "configure"
+#line 6017 "configure"
@@ -6018,7 +6024,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6060,7 +6066,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6064: checking whether to use GDAL" >&5
+echo "configure:6070: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6078,7 +6084,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6082: checking for $ac_word" >&5
+echo "configure:6088: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6133,14 +6139,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6137 "configure"
+#line 6143 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6149,14 +6155,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6153 "configure"
+#line 6159 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6188,7 +6194,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6192: checking whether to use libLAS" >&5
+echo "configure:6198: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6205,7 +6211,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6209: checking for $ac_word" >&5
+echo "configure:6215: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6253,14 +6259,14 @@
LIBS="$LIBS $LIBLAS_LIBS"
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6257 "configure"
+#line 6263 "configure"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6268,14 +6274,14 @@
rm -rf conftest*
-#line 6272 "configure"
+#line 6278 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6307,7 +6313,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6311: checking whether to use NetCDF" >&5
+echo "configure:6317: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -6324,7 +6330,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:6328: checking for $ac_word" >&5
+echo "configure:6334: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -6371,14 +6377,14 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6375 "configure"
+#line 6381 "configure"
#include <netcdf.h>
int main() {
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:6382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6386,14 +6392,14 @@
rm -rf conftest*
-#line 6390 "configure"
+#line 6396 "configure"
#include <netcdf.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -6424,7 +6430,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6428: checking whether to use GEOS" >&5
+echo "configure:6434: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -6442,7 +6448,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6446: checking for $ac_word" >&5
+echo "configure:6452: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6490,15 +6496,15 @@
do
-echo "configure:6494: checking for $ac_hdr" >&5
+echo "configure:6500: checking for $ac_hdr" >&5
-#line 6497 "configure"
+#line 6503 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6502: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6508: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6537,13 +6543,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6541: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6547: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6547 "configure"
+#line 6553 "configure"
@@ -6554,7 +6560,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6558: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6598,7 +6604,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6602: checking whether to use TIFF" >&5
+echo "configure:6608: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6618,7 +6624,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6622: checking for location of TIFF includes" >&5
+echo "configure:6628: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6644,15 +6650,15 @@
do
-echo "configure:6648: checking for $ac_hdr" >&5
+echo "configure:6654: checking for $ac_hdr" >&5
-#line 6651 "configure"
+#line 6657 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6656: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6686,7 +6692,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6690: checking for location of TIFF library" >&5
+echo "configure:6696: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6717,13 +6723,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6721: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6727: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6727 "configure"
+#line 6733 "configure"
@@ -6734,7 +6740,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6753,13 +6759,13 @@
-echo "configure:6757: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6763: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 6763 "configure"
+#line 6769 "configure"
@@ -6770,7 +6776,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6789,13 +6795,13 @@
-echo "configure:6793: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6799: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 6799 "configure"
+#line 6805 "configure"
@@ -6806,7 +6812,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6825,13 +6831,13 @@
-echo "configure:6829: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6835: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6835 "configure"
+#line 6841 "configure"
@@ -6842,7 +6848,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6861,13 +6867,13 @@
-echo "configure:6865: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6871: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 6871 "configure"
+#line 6877 "configure"
@@ -6878,7 +6884,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6897,13 +6903,13 @@
-echo "configure:6901: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6907: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6907 "configure"
+#line 6913 "configure"
@@ -6914,7 +6920,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6933,13 +6939,13 @@
-echo "configure:6937: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6943: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6943 "configure"
+#line 6949 "configure"
@@ -6950,7 +6956,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6969,13 +6975,13 @@
-echo "configure:6973: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6979: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6979 "configure"
+#line 6985 "configure"
@@ -6986,7 +6992,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7084,7 +7090,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7088: checking whether to use PNG" >&5
+echo "configure:7094: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7103,7 +7109,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7107: checking for location of PNG includes" >&5
+echo "configure:7113: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7129,15 +7135,15 @@
do
-echo "configure:7133: checking for $ac_hdr" >&5
+echo "configure:7139: checking for $ac_hdr" >&5
-#line 7136 "configure"
+#line 7142 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7171,7 +7177,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7175: checking for location of PNG library" >&5
+echo "configure:7181: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7196,13 +7202,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7200: checking for png_read_image in -lpng" >&5
+echo "configure:7206: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7206 "configure"
+#line 7212 "configure"
@@ -7213,7 +7219,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7255,7 +7261,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7259: checking whether to use PostgreSQL" >&5
+echo "configure:7265: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7282,7 +7288,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7286: checking for location of PostgreSQL includes" >&5
+echo "configure:7292: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7308,15 +7314,15 @@
do
-echo "configure:7312: checking for $ac_hdr" >&5
+echo "configure:7318: checking for $ac_hdr" >&5
-#line 7315 "configure"
+#line 7321 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7320: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7326: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7354,7 +7360,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7358: checking for location of PostgreSQL library" >&5
+echo "configure:7364: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7383,13 +7389,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7387: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7393: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7393 "configure"
+#line 7399 "configure"
@@ -7400,7 +7406,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7419,13 +7425,13 @@
-echo "configure:7423: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7429: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7429 "configure"
+#line 7435 "configure"
@@ -7436,7 +7442,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7455,13 +7461,13 @@
-echo "configure:7459: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7465: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7465 "configure"
+#line 7471 "configure"
@@ -7472,7 +7478,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7491,13 +7497,13 @@
-echo "configure:7495: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7501: checking for PQsetdbLogin in -lpq" >&5
ac_save_LIBS="$LIBS"
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7501 "configure"
+#line 7507 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7508,7 +7514,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7565,13 +7571,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7569: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7575: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7575 "configure"
+#line 7581 "configure"
@@ -7582,7 +7588,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7604,13 +7610,13 @@
-echo "configure:7608: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7614: checking for PQcmdTuples in -lpq" >&5
-#line 7614 "configure"
+#line 7620 "configure"
@@ -7621,7 +7627,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7664,7 +7670,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7668: checking whether to use MySQL" >&5
+echo "configure:7674: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7684,7 +7690,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7688: checking for location of MySQL includes" >&5
+echo "configure:7694: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7710,15 +7716,15 @@
do
-echo "configure:7714: checking for $ac_hdr" >&5
+echo "configure:7720: checking for $ac_hdr" >&5
-#line 7717 "configure"
+#line 7723 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7728: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7755,7 +7761,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7759: checking for location of MySQL library" >&5
+echo "configure:7765: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7786,13 +7792,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7790: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7796: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7796 "configure"
+#line 7802 "configure"
@@ -7803,7 +7809,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7822,13 +7828,13 @@
-echo "configure:7826: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7832: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7832 "configure"
+#line 7838 "configure"
@@ -7839,7 +7845,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7858,13 +7864,13 @@
-echo "configure:7862: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7868: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7868 "configure"
+#line 7874 "configure"
@@ -7875,7 +7881,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7894,13 +7900,13 @@
-echo "configure:7898: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7904: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7904 "configure"
+#line 7910 "configure"
@@ -7911,7 +7917,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7930,13 +7936,13 @@
-echo "configure:7934: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7940: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7940 "configure"
+#line 7946 "configure"
@@ -7947,7 +7953,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7966,13 +7972,13 @@
-echo "configure:7970: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7976: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7976 "configure"
+#line 7982 "configure"
@@ -7983,7 +7989,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8002,13 +8008,13 @@
-echo "configure:8006: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8012: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8012 "configure"
+#line 8018 "configure"
@@ -8019,7 +8025,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8038,13 +8044,13 @@
-echo "configure:8042: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8048: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8048 "configure"
+#line 8054 "configure"
@@ -8055,7 +8061,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8145,7 +8151,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8149: checking for $ac_word" >&5
+echo "configure:8155: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8194,10 +8200,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8198: checking for mysql_server_init" >&5
+echo "configure:8204: checking for mysql_server_init" >&5
-#line 8201 "configure"
+#line 8207 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -8223,7 +8229,7 @@
; return 0; }
EOF
-if { (eval echo configure:8227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8275,7 +8281,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8279: checking whether to use SQLite" >&5
+echo "configure:8285: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8295,7 +8301,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8299: checking for location of SQLite includes" >&5
+echo "configure:8305: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8321,15 +8327,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8325: checking for $ac_hdr" >&5
+echo "configure:8331: checking for $ac_hdr" >&5
-#line 8328 "configure"
+#line 8334 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8333: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8339: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8372,7 +8378,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8376: checking for location of SQLite library" >&5
+echo "configure:8382: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8401,13 +8407,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8405: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8411: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8411 "configure"
+#line 8417 "configure"
@@ -8418,7 +8424,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8437,13 +8443,13 @@
-echo "configure:8441: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8447: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8447 "configure"
+#line 8453 "configure"
@@ -8454,7 +8460,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8473,13 +8479,13 @@
-echo "configure:8477: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8483: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8483 "configure"
+#line 8489 "configure"
@@ -8490,7 +8496,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8509,13 +8515,13 @@
-echo "configure:8513: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8519: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8519 "configure"
+#line 8525 "configure"
@@ -8526,7 +8532,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8595,7 +8601,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8599: checking whether to use FFMPEG" >&5
+echo "configure:8605: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8615,7 +8621,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8619: checking for location of FFMPEG includes" >&5
+echo "configure:8625: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8641,15 +8647,15 @@
do
-echo "configure:8645: checking for $ac_hdr" >&5
+echo "configure:8651: checking for $ac_hdr" >&5
-#line 8648 "configure"
+#line 8654 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8653: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8659: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8685,15 +8691,15 @@
do
-echo "configure:8689: checking for $ac_hdr" >&5
+echo "configure:8695: checking for $ac_hdr" >&5
-#line 8692 "configure"
+#line 8698 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8703: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8729,15 +8735,15 @@
do
-echo "configure:8733: checking for $ac_hdr" >&5
+echo "configure:8739: checking for $ac_hdr" >&5
-#line 8736 "configure"
+#line 8742 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8741: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8747: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8780,7 +8786,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8784: checking for location of FFMPEG library" >&5
+echo "configure:8790: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8807,13 +8813,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8811: checking for av_free in -lavutil" >&5
+echo "configure:8817: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8817 "configure"
+#line 8823 "configure"
@@ -8824,7 +8830,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8843,13 +8849,13 @@
-echo "configure:8847: checking for av_free in -lavutil" >&5
+echo "configure:8853: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8853 "configure"
+#line 8859 "configure"
@@ -8860,7 +8866,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8905,13 +8911,13 @@
echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8909: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8915: checking for avcodec_register in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 8915 "configure"
+#line 8921 "configure"
@@ -8922,7 +8928,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8941,13 +8947,13 @@
-echo "configure:8945: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8951: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8951 "configure"
+#line 8957 "configure"
@@ -8958,7 +8964,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9003,13 +9009,13 @@
echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:9007: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9013: checking for avformat_alloc_context in -lavformat" >&5
ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 9013 "configure"
+#line 9019 "configure"
@@ -9020,7 +9026,7 @@
avformat_alloc_context()
; return 0; }
EOF
-if { (eval echo configure:9024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9039,13 +9045,13 @@
-echo "configure:9043: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9049: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9049 "configure"
+#line 9055 "configure"
@@ -9056,7 +9062,7 @@
; return 0; }
EOF
-if { (eval echo configure:9060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9115,7 +9121,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9119: checking whether to use OpenGL" >&5
+echo "configure:9125: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9149,7 +9155,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9153: checking for location of OpenGL includes" >&5
+echo "configure:9159: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9175,15 +9181,15 @@
do
-echo "configure:9179: checking for $ac_hdr" >&5
+echo "configure:9185: checking for $ac_hdr" >&5
-#line 9182 "configure"
+#line 9188 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9217,7 +9223,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9221: checking for location of OpenGL library" >&5
+echo "configure:9227: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9246,13 +9252,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9250: checking for glBegin in -lGL" >&5
+echo "configure:9256: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9256 "configure"
+#line 9262 "configure"
@@ -9263,7 +9269,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9282,13 +9288,13 @@
-echo "configure:9286: checking for glBegin in -lGL" >&5
+echo "configure:9292: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9292 "configure"
+#line 9298 "configure"
@@ -9299,7 +9305,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9318,13 +9324,13 @@
-echo "configure:9322: checking for glBegin in -lGL" >&5
+echo "configure:9328: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9328 "configure"
+#line 9334 "configure"
@@ -9335,7 +9341,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9345: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9354,13 +9360,13 @@
-echo "configure:9358: checking for glBegin in -lGL" >&5
+echo "configure:9364: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9364 "configure"
+#line 9370 "configure"
@@ -9371,7 +9377,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9381: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9433,13 +9439,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9437: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9443: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9443 "configure"
+#line 9449 "configure"
@@ -9450,7 +9456,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9469,13 +9475,13 @@
-echo "configure:9473: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9479: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9479 "configure"
+#line 9485 "configure"
@@ -9486,7 +9492,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9533,10 +9539,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9537: checking for glXCreatePbuffer" >&5
+echo "configure:9543: checking for glXCreatePbuffer" >&5
-#line 9540 "configure"
+#line 9546 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -9559,7 +9565,7 @@
; return 0; }
EOF
-if { (eval echo configure:9563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9596,10 +9602,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9600: checking for glXCreateGLXPixmap" >&5
+echo "configure:9606: checking for glXCreateGLXPixmap" >&5
-#line 9603 "configure"
+#line 9609 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9622,7 +9628,7 @@
; return 0; }
EOF
-if { (eval echo configure:9626: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9665,7 +9671,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9669: checking for location of OpenGL framework" >&5
+echo "configure:9675: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9689,15 +9695,15 @@
do
-echo "configure:9693: checking for $ac_hdr" >&5
+echo "configure:9699: checking for $ac_hdr" >&5
-#line 9696 "configure"
+#line 9702 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9701: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9733,10 +9739,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9737: checking for glBegin" >&5
+echo "configure:9743: checking for glBegin" >&5
-#line 9740 "configure"
+#line 9746 "configure"
which can conflict with char glBegin(); below. */
@@ -9759,7 +9765,7 @@
; return 0; }
EOF
-if { (eval echo configure:9763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9796,10 +9802,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9800: checking for gluBeginCurve" >&5
+echo "configure:9806: checking for gluBeginCurve" >&5
-#line 9803 "configure"
+#line 9809 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9822,7 +9828,7 @@
; return 0; }
EOF
-if { (eval echo configure:9826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9870,7 +9876,7 @@
-echo "configure:9874: checking for location of OpenGL includes" >&5
+echo "configure:9880: checking for location of OpenGL includes" >&5
@@ -9896,15 +9902,15 @@
do
-echo "configure:9900: checking for $ac_hdr" >&5
+echo "configure:9906: checking for $ac_hdr" >&5
-#line 9903 "configure"
+#line 9909 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9908: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9914: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9938,7 +9944,7 @@
-echo "configure:9942: checking for location of OpenGL library" >&5
+echo "configure:9948: checking for location of OpenGL library" >&5
@@ -9963,18 +9969,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9967: checking for OpenGL library" >&5
+echo "configure:9973: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9971 "configure"
+#line 9977 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9978: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -9998,18 +10004,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10002: checking for GLU library" >&5
+echo "configure:10008: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 10006 "configure"
+#line 10012 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:10013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10058,7 +10064,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10062: checking whether to use ODBC" >&5
+echo "configure:10068: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -10077,7 +10083,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10081: checking for location of ODBC includes" >&5
+echo "configure:10087: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10103,15 +10109,15 @@
do
-echo "configure:10107: checking for $ac_hdr" >&5
+echo "configure:10113: checking for $ac_hdr" >&5
-#line 10110 "configure"
+#line 10116 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10115: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10121: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10145,7 +10151,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10149: checking for location of ODBC library" >&5
+echo "configure:10155: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10170,13 +10176,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10174: checking for SQLConnect in -lodbc" >&5
+echo "configure:10180: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 10180 "configure"
+#line 10186 "configure"
@@ -10187,7 +10193,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10212,13 +10218,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10216: checking for SQLConnect in -liodbc" >&5
+echo "configure:10222: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 10222 "configure"
+#line 10228 "configure"
@@ -10229,7 +10235,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10254,11 +10260,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10258: checking for ODBC library" >&5
+echo "configure:10264: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 10262 "configure"
+#line 10268 "configure"
#include <windows.h>
#include <sql.h>
@@ -10266,7 +10272,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:10270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10315,7 +10321,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10319: checking whether to use FFTW" >&5
+echo "configure:10325: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -10334,7 +10340,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10338: checking for location of FFTW includes" >&5
+echo "configure:10344: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10360,15 +10366,15 @@
do
-echo "configure:10364: checking for $ac_hdr" >&5
+echo "configure:10370: checking for $ac_hdr" >&5
-#line 10367 "configure"
+#line 10373 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10372: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10378: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10396,15 +10402,15 @@
do
-echo "configure:10400: checking for $ac_hdr" >&5
+echo "configure:10406: checking for $ac_hdr" >&5
-#line 10403 "configure"
+#line 10409 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10408: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10432,15 +10438,15 @@
do
-echo "configure:10436: checking for $ac_hdr" >&5
+echo "configure:10442: checking for $ac_hdr" >&5
-#line 10439 "configure"
+#line 10445 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10444: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10486,7 +10492,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10490: checking for location of FFTW library" >&5
+echo "configure:10496: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10511,13 +10517,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10515: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10521: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10521 "configure"
+#line 10527 "configure"
@@ -10528,7 +10534,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:10532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10553,13 +10559,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10557: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10563: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 10563 "configure"
+#line 10569 "configure"
@@ -10570,7 +10576,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10574: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10595,13 +10601,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10599: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10605: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10605 "configure"
+#line 10611 "configure"
@@ -10612,7 +10618,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10616: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10669,7 +10675,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10673: checking whether to use BLAS" >&5
+echo "configure:10679: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10690,7 +10696,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10694: checking for location of BLAS includes" >&5
+echo "configure:10700: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10710,7 +10716,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10714: checking for location of BLAS library" >&5
+echo "configure:10720: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10736,15 +10742,15 @@
do
-echo "configure:10740: checking for $ac_hdr" >&5
+echo "configure:10746: checking for $ac_hdr" >&5
-#line 10743 "configure"
+#line 10749 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10748: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10779,13 +10785,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10783: checking for dnrm2_ in -lblas" >&5
+echo "configure:10789: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 10789 "configure"
+#line 10795 "configure"
@@ -10796,7 +10802,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10815,13 +10821,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10819: checking for dnrm2_ in -lblas" >&5
+echo "configure:10825: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10825 "configure"
+#line 10831 "configure"
@@ -10832,7 +10838,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10876,13 +10882,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10880: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10886: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 10886 "configure"
+#line 10892 "configure"
@@ -10893,7 +10899,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:10897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10908,13 +10914,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10912: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10918: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 10918 "configure"
+#line 10924 "configure"
@@ -10925,7 +10931,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10940,13 +10946,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10944: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10950: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10950 "configure"
+#line 10956 "configure"
@@ -10957,7 +10963,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:10961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11003,16 +11009,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11007: checking for sgemm in $vlib_flags" >&5
+echo "configure:11013: checking for sgemm in $vlib_flags" >&5
-#line 11009 "configure"
+#line 11015 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:11016: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -11030,13 +11036,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11034: checking for sgemm_ in -lblas" >&5
+echo "configure:11040: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 11040 "configure"
+#line 11046 "configure"
@@ -11047,7 +11053,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11062,13 +11068,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11066: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11072: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 11072 "configure"
+#line 11078 "configure"
@@ -11079,7 +11085,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:11083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11094,13 +11100,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11098: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11104: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 11104 "configure"
+#line 11110 "configure"
@@ -11111,7 +11117,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11145,13 +11151,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11149: checking for acosp in -lsunmath" >&5
+echo "configure:11155: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 11155 "configure"
+#line 11161 "configure"
@@ -11162,7 +11168,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:11166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11177,13 +11183,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11181: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11187: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 11187 "configure"
+#line 11193 "configure"
@@ -11194,7 +11200,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11224,13 +11230,13 @@
# Generic BLAS library
-echo "configure:11228: checking for sgemm_ in -lblas" >&5
+echo "configure:11234: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 11234 "configure"
+#line 11240 "configure"
@@ -11241,7 +11247,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11280,7 +11286,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11284: checking whether to use LAPACK" >&5
+echo "configure:11290: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -11305,7 +11311,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11309: checking for location of LAPACK includes" >&5
+echo "configure:11315: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11325,7 +11331,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11329: checking for location of LAPACK library" >&5
+echo "configure:11335: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11351,15 +11357,15 @@
do
-echo "configure:11355: checking for $ac_hdr" >&5
+echo "configure:11361: checking for $ac_hdr" >&5
-#line 11358 "configure"
+#line 11364 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11363: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11391,10 +11397,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11395: checking for dsegv_" >&5
+echo "configure:11401: checking for dsegv_" >&5
-#line 11398 "configure"
+#line 11404 "configure"
which can conflict with char dsegv_(); below. */
@@ -11417,7 +11423,7 @@
; return 0; }
EOF
-if { (eval echo configure:11421: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -11444,13 +11450,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11448: checking for desgv_ in -llapack" >&5
+echo "configure:11454: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 11454 "configure"
+#line 11460 "configure"
@@ -11461,7 +11467,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:11465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11493,13 +11499,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11497: checking for dgesv_ in -llapack" >&5
+echo "configure:11503: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 11503 "configure"
+#line 11509 "configure"
@@ -11510,7 +11516,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11529,13 +11535,13 @@
-echo "configure:11533: checking for dgesv_ in -llapack" >&5
+echo "configure:11539: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11539 "configure"
+#line 11545 "configure"
@@ -11546,7 +11552,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11550: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11602,7 +11608,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11606: checking whether to use Cairo" >&5
+echo "configure:11612: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11634,7 +11640,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11638: checking for location of cairo includes" >&5
+echo "configure:11644: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11660,15 +11666,15 @@
do
-echo "configure:11664: checking for $ac_hdr" >&5
+echo "configure:11670: checking for $ac_hdr" >&5
-#line 11667 "configure"
+#line 11673 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11678: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11704,7 +11710,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11708: checking for location of cairo library" >&5
+echo "configure:11714: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11724,7 +11730,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11728: checking for cairo linking flags" >&5
+echo "configure:11734: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11740,10 +11746,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11744: checking for cairo_create" >&5
+echo "configure:11750: checking for cairo_create" >&5
-#line 11747 "configure"
+#line 11753 "configure"
which can conflict with char cairo_create(); below. */
@@ -11766,7 +11772,7 @@
; return 0; }
EOF
-if { (eval echo configure:11770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -11800,10 +11806,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11804: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11810: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11807 "configure"
+#line 11813 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -11826,7 +11832,7 @@
; return 0; }
EOF
-if { (eval echo configure:11830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -11859,10 +11865,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11863: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11869: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11866 "configure"
+#line 11872 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -11885,7 +11891,7 @@
; return 0; }
EOF
-if { (eval echo configure:11889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -11927,7 +11933,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11931: checking whether to use FreeType" >&5
+echo "configure:11937: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -11946,7 +11952,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11950: checking for location of FreeType includes" >&5
+echo "configure:11956: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11972,15 +11978,15 @@
do
-echo "configure:11976: checking for $ac_hdr" >&5
+echo "configure:11982: checking for $ac_hdr" >&5
-#line 11979 "configure"
+#line 11985 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11984: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11990: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12014,7 +12020,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12018: checking for location of FreeType library" >&5
+echo "configure:12024: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12039,13 +12045,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12043: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12049: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 12049 "configure"
+#line 12055 "configure"
@@ -12056,7 +12062,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:12060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12097,7 +12103,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12101: checking whether to use NLS" >&5
+echo "configure:12107: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -12117,10 +12123,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12121: checking for gettext" >&5
+echo "configure:12127: checking for gettext" >&5
-#line 12124 "configure"
+#line 12130 "configure"
which can conflict with char gettext(); below. */
@@ -12143,7 +12149,7 @@
; return 0; }
EOF
-if { (eval echo configure:12147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -12161,13 +12167,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12165: checking for gettext in -lintl" >&5
+echo "configure:12171: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 12171 "configure"
+#line 12177 "configure"
@@ -12178,7 +12184,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:12182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12213,7 +12219,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12217: checking whether to use C++" >&5
+echo "configure:12223: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -12229,7 +12235,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:12233: checking for $ac_word" >&5
+echo "configure:12239: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12258,7 +12264,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12262: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12268: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12269,12 +12275,12 @@
cat > conftest.$ac_ext << EOF
-#line 12273 "configure"
+#line 12279 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:12278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -12300,19 +12306,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12304: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12310: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12309: checking whether we are using GNU C++" >&5
+echo "configure:12315: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12322: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -12330,7 +12336,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12334: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12340: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12371,7 +12377,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12375: checking whether to use openDWG" >&5
+echo "configure:12381: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12391,7 +12397,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12395: checking for location of openDGW includes" >&5
+echo "configure:12401: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12417,15 +12423,15 @@
do
-echo "configure:12421: checking for $ac_hdr" >&5
+echo "configure:12427: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 12424 "configure"
+#line 12430 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12429: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12435: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12459,7 +12465,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12463: checking for location of openDWG library" >&5
+echo "configure:12469: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12500,7 +12506,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12504: checking whether to use POSIX threads" >&5
+echo "configure:12510: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12520,7 +12526,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12524: checking for location of POSIX threads includes" >&5
+echo "configure:12530: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12546,15 +12552,15 @@
do
-echo "configure:12550: checking for $ac_hdr" >&5
+echo "configure:12556: checking for $ac_hdr" >&5
-#line 12553 "configure"
+#line 12559 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12558: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12564: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12588,7 +12594,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12592: checking for location of POSIX threads library" >&5
+echo "configure:12598: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12613,10 +12619,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12617: checking for pthread_create" >&5
+echo "configure:12623: checking for pthread_create" >&5
-#line 12620 "configure"
+#line 12626 "configure"
which can conflict with char pthread_create(); below. */
@@ -12639,7 +12645,7 @@
; return 0; }
EOF
-if { (eval echo configure:12643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12649: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12666,13 +12672,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12670: checking for pthread_create in -lpthread" >&5
+echo "configure:12676: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpthread $LIBS"
-#line 12676 "configure"
+#line 12682 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12683,7 +12689,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12733,7 +12739,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12737: checking whether to use OpenMP" >&5
+echo "configure:12743: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12754,7 +12760,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12758: checking for location of OpenMP includes" >&5
+echo "configure:12764: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12780,15 +12786,15 @@
do
-echo "configure:12784: checking for $ac_hdr" >&5
+echo "configure:12790: checking for $ac_hdr" >&5
-#line 12787 "configure"
+#line 12793 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12792: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12798: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12826,7 +12832,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12830: checking for location of OpenMP library" >&5
+echo "configure:12836: checking for location of OpenMP library" >&5
case "$with_openmp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12851,10 +12857,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12855: checking for GOMP_parallel_start" >&5
+echo "configure:12861: checking for GOMP_parallel_start" >&5
-#line 12858 "configure"
+#line 12864 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12877,7 +12883,7 @@
; return 0; }
EOF
-if { (eval echo configure:12881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12904,13 +12910,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12908: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12914: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 12914 "configure"
+#line 12920 "configure"
@@ -12921,7 +12927,7 @@
; return 0; }
EOF
-if { (eval echo configure:12925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12994,7 +13000,7 @@
echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:12998: checking whether to use OpenCL" >&5
+echo "configure:13004: checking whether to use OpenCL" >&5
echo "$ac_t"""$with_opencl"" 1>&6
case "$with_opencl" in
"no") USE_OPENCL= ;;
@@ -13014,7 +13020,7 @@
echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:13018: checking for location of OpenCL includes" >&5
+echo "configure:13024: checking for location of OpenCL includes" >&5
case "$with_opencl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -13041,15 +13047,15 @@
do
-echo "configure:13045: checking for $ac_hdr" >&5
+echo "configure:13051: checking for $ac_hdr" >&5
-#line 13048 "configure"
+#line 13054 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13053: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13059: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13089,10 +13095,10 @@
LIBS="-framework OpenCL $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:13093: checking for clGetPlatformInfo" >&5
+echo "configure:13099: checking for clGetPlatformInfo" >&5
-#line 13096 "configure"
+#line 13102 "configure"
which can conflict with char clGetPlatformInfo(); below. */
@@ -13115,7 +13121,7 @@
; return 0; }
EOF
-if { (eval echo configure:13119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_clGetPlatformInfo=yes"
else
@@ -13154,15 +13160,15 @@
do
-echo "configure:13158: checking for $ac_hdr" >&5
+echo "configure:13164: checking for $ac_hdr" >&5
-#line 13161 "configure"
+#line 13167 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13166: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13172: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13195,7 +13201,7 @@
# With OpenCL library directory
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13199: checking for location of OpenCL library" >&5
+echo "configure:13205: checking for location of OpenCL library" >&5
case "$with_opencl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13219,13 +13225,13 @@
echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13223: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13229: checking for clGetPlatformInfo in -lOpenCL" >&5
ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
LIBS="-lOpenCL $LIBS"
-#line 13229 "configure"
+#line 13235 "configure"
@@ -13236,7 +13242,7 @@
clGetPlatformInfo()
; return 0; }
EOF
-if { (eval echo configure:13240: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13296,7 +13302,7 @@
fi
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13300: checking for special C compiler options needed for large files" >&5
+echo "configure:13306: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13304,7 +13310,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13308 "configure"
+#line 13314 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13320,7 +13326,7 @@
; return 0; }
EOF
-if { (eval echo configure:13324: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13330: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -13329,7 +13335,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13333 "configure"
+#line 13339 "configure"
@@ -13345,7 +13351,7 @@
; return 0; }
EOF
-if { (eval echo configure:13349: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13355: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13372,11 +13378,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13376: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13382: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13380 "configure"
+#line 13386 "configure"
@@ -13392,14 +13398,14 @@
; return 0; }
EOF
-if { (eval echo configure:13396: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13402: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 13403 "configure"
+#line 13409 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13417,7 +13423,7 @@
; return 0; }
EOF
-if { (eval echo configure:13421: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13427: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13443,11 +13449,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13447: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13453: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13451 "configure"
+#line 13457 "configure"
@@ -13463,14 +13469,14 @@
; return 0; }
EOF
-if { (eval echo configure:13467: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13473: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13474 "configure"
+#line 13480 "configure"
#define _LARGE_FILES 1
@@ -13488,7 +13494,7 @@
; return 0; }
EOF
-if { (eval echo configure:13492: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13498: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13514,25 +13520,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13518: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13524: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13522 "configure"
+#line 13528 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13529: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13535: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13536 "configure"
+#line 13542 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13541,7 +13547,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13545: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13551: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13573,25 +13579,25 @@
ac_save_cflags=${CFLAGS}
CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13577: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13583: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13581 "configure"
+#line 13587 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13588: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13594: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13595 "configure"
+#line 13601 "configure"
#include <stdio.h>
@@ -13600,7 +13606,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13604: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13610: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13630,18 +13636,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13634: checking for fseeko" >&5
+echo "configure:13640: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13638 "configure"
+#line 13644 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13658,10 +13664,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13662: checking if system supports Large Files at all" >&5
+echo "configure:13668: checking if system supports Large Files at all" >&5
-#line 13665 "configure"
+#line 13671 "configure"
#include <stdio.h>
@@ -13693,7 +13699,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13697: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13703: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13724,7 +13730,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13728: checking whether to use wxWidgets" >&5
+echo "configure:13734: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -13745,7 +13751,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13749: checking for $ac_word" >&5
+echo "configure:13755: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -13793,7 +13799,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13797: checking wxWidgets version" >&5
+echo "configure:13803: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -13816,15 +13822,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13820: checking for $ac_hdr" >&5
+echo "configure:13826: checking for $ac_hdr" >&5
-#line 13823 "configure"
+#line 13829 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13828: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13834: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2013-07-28 16:00:47 UTC (rev 57313)
+++ grass/trunk/configure.in 2013-07-28 17:32:01 UTC (rev 57314)
@@ -64,11 +64,11 @@
AC_PATH_PROG(pwd, pwd, pwd)
-dnl if test "$MINGW32" = yes ; then
-dnl winpwd="$pwd -W"
-dnl else
-dnl winpwd="$pwd"
-dnl fi
+if test "$MINGW32" = yes ; then
+ winpwd="$pwd -W"
+else
+ winpwd="$pwd"
+fi
AC_MSG_CHECKING(for source directory)
@@ -83,7 +83,7 @@
AC_MSG_CHECKING(for build directory)
DSTDIR=`$pwd`
-dnl WINDSTDIR=`$winpwd`
+WINDSTDIR=`$winpwd`
AC_MSG_RESULT("$DSTDIR")
@@ -107,8 +107,7 @@
# Set GISBASE and GRASS_BIN
-dnl GISBASE="${WINDSTDIR}/dist.${ARCH}"
-GISBASE="${DSTDIR}/dist.${ARCH}"
+GISBASE="${WINDSTDIR}/dist.${ARCH}"
GRASS_BIN="${DSTDIR}/bin.${ARCH}"
AC_SUBST(GISBASE)
