[GRASS-SVN] r57319 - grass/branches/develbranch_6
Mon Jul 29 02:41:21 PDT 2013
Author: martinl
Date: 2013-07-29 02:41:20 -0700 (Mon, 29 Jul 2013)
New Revision: 57319
   grass/branches/develbranch_6/configure
   grass/branches/develbranch_6/configure.in
configure.in: enable `pwd -W` (revert unwanted change)
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure	2013-07-29 09:00:18 UTC (rev 57318)
+++ grass/branches/develbranch_6/configure	2013-07-29 09:41:20 UTC (rev 57319)
@@ -1201,9 +1201,14 @@
 fi
+if test "$MINGW32" = yes ; then
+  winpwd="$pwd -W"
+else
+  winpwd="$pwd"
+fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1207: checking for source directory" >&5
+echo "configure:1212: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1214,9 +1219,10 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1218: checking for build directory" >&5
+echo "configure:1223: checking for build directory" >&5
 DSTDIR=`$pwd`
+WINDSTDIR=`$winpwd`
 echo "$ac_t"""$DSTDIR"" 1>&6
@@ -1258,7 +1264,7 @@
 # Set GISBASE and GRASS_BIN
-GISBASE="${DSTDIR}/dist.${ARCH}"
+GISBASE="${WINDSTDIR}/dist.${ARCH}"
 GRASS_BIN="${DSTDIR}/bin.${ARCH}"
@@ -1281,7 +1287,7 @@
 # Extract the first word of "svnversion", so it can be a program name with args.
 set dummy svnversion; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:1285: checking for $ac_word" >&5
+echo "configure:1291: checking for $ac_word" >&5
 case "$SVN_VERSION" in
@@ -1340,7 +1346,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1344: checking for MacOSX App" >&5
+echo "configure:1350: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1352,7 +1358,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1356: checking for MacOSX architectures" >&5
+echo "configure:1362: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1381,7 +1387,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1385: checking for MacOSX SDK" >&5
+echo "configure:1391: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1391,7 +1397,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1395: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1401: checking for $with_macosx_sdk/SDKSettings.plist" >&5
 if test "$cross_compiling" = yes; then
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1435,7 +1441,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1439: checking how to build libraries" >&5
+echo "configure:1445: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1478,7 +1484,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:1482: checking for $ac_word" >&5
+echo "configure:1488: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -1503,7 +1509,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:1507: checking how to run the C preprocessor" >&5
+echo "configure:1513: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -1516,13 +1522,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
   cat > conftest.$ac_ext <<EOF
-#line 1520 "configure"
+#line 1526 "configure"
 #include "confdefs.h"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:1526: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1532: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -1533,13 +1539,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 1537 "configure"
+#line 1543 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1543: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1549: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1550,13 +1556,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 1554 "configure"
+#line 1560 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:1560: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:1566: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -1584,7 +1590,7 @@
     # Step 0.a: Enable 64 bit support?
     echo $ac_n "checking if 64bit support is requested""... $ac_c" 1>&6
-echo "configure:1588: checking if 64bit support is requested" >&5
+echo "configure:1594: checking if 64bit support is requested" >&5
     # Check whether --enable-64bit or --disable-64bit was given.
 if test "${enable_64bit+set}" = set; then
   enableval="$enable_64bit"
@@ -1604,7 +1610,7 @@
     # Step 0.b: Enable Solaris 64 bit VIS support?
     echo $ac_n "checking if 64bit Sparc VIS support is requested""... $ac_c" 1>&6
-echo "configure:1608: checking if 64bit Sparc VIS support is requested" >&5
+echo "configure:1614: checking if 64bit Sparc VIS support is requested" >&5
     # Check whether --enable-64bit-vis or --disable-64bit-vis was given.
 if test "${enable_64bit_vis+set}" = set; then
   enableval="$enable_64bit_vis"
@@ -1628,7 +1634,7 @@
     # there are a few systems, like Next, where this doesn't work.
     echo $ac_n "checking system version (for dynamic loading)""... $ac_c" 1>&6
-echo "configure:1632: checking system version (for dynamic loading)" >&5
+echo "configure:1638: checking system version (for dynamic loading)" >&5
     if test -f /usr/lib/NextStep/software_version; then
 	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
     else
@@ -1654,13 +1660,13 @@
     # Linux can use either -ldl or -ldld for dynamic loading.
     echo $ac_n "checking for dlopen in -ldl""... $ac_c" 1>&6
-echo "configure:1658: checking for dlopen in -ldl" >&5
+echo "configure:1664: checking for dlopen in -ldl" >&5
 ac_lib_var=`echo dl'_'dlopen | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-ldl  $LIBS"
-#line 1664 "configure"
+#line 1670 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1671,7 +1677,7 @@
 dlopen()
 ; return 0; }
 EOF
-if { (eval echo configure:1675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1718,7 +1724,7 @@
     # Extract the first word of "ar", so it can be a program name with args.
 set dummy ar; ac_word=$2
-echo "configure:1722: checking for $ac_word" >&5
+echo "configure:1728: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -1847,13 +1853,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1851: checking for gettimeofday in -lbsd" >&5
+echo "configure:1857: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 1857 "configure"
+#line 1863 "configure"
@@ -1864,7 +1870,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1905,13 +1911,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1909: checking for inet_ntoa in -lbind" >&5
+echo "configure:1915: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1915 "configure"
+#line 1921 "configure"
@@ -1922,7 +1928,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1983,13 +1989,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1987: checking for shl_load in -ldld" >&5
+echo "configure:1993: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1993 "configure"
+#line 1999 "configure"
@@ -2000,7 +2006,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2004: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2065,13 +2071,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:2069: checking for shl_load in -ldld" >&5
+echo "configure:2075: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 2075 "configure"
+#line 2081 "configure"
@@ -2082,7 +2088,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2204,15 +2210,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2208: checking for dld.h" >&5
+echo "configure:2214: checking for dld.h" >&5
-#line 2211 "configure"
+#line 2217 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2216: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2272,15 +2278,15 @@
 	    else
-echo "configure:2276: checking for dld.h" >&5
+echo "configure:2282: checking for dld.h" >&5
-#line 2279 "configure"
+#line 2285 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2284: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2290: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2377,9 +2383,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2381: checking for ELF" >&5
+echo "configure:2387: checking for ELF" >&5
-#line 2383 "configure"
+#line 2389 "configure"
 #ifdef __ELF__
@@ -2409,15 +2415,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2413: checking for dlfcn.h" >&5
+echo "configure:2419: checking for dlfcn.h" >&5
-#line 2416 "configure"
+#line 2422 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2421: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2441,9 +2447,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2445: checking for ELF" >&5
+echo "configure:2451: checking for ELF" >&5
-#line 2447 "configure"
+#line 2453 "configure"
 #ifdef __ELF__
@@ -2767,17 +2773,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2771: checking for ld accepts -Bexport flag" >&5
+echo "configure:2777: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2774 "configure"
+#line 2780 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2781: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -3575,7 +3581,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3579: checking for additional include dirs" >&5
+echo "configure:3585: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3598,7 +3604,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3602: checking for additional library dirs" >&5
+echo "configure:3608: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3632,7 +3638,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3636: checking for a BSD compatible install" >&5
+echo "configure:3642: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3685,7 +3691,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:3689: checking for $ac_word" >&5
+echo "configure:3695: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3716,13 +3722,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3720: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3726: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3726 "configure"
+#line 3732 "configure"
@@ -3733,7 +3739,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3758,7 +3764,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3762: checking for $ac_word" >&5
+echo "configure:3768: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3798,7 +3804,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3802: checking for $ac_word" >&5
+echo "configure:3808: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3829,7 +3835,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3833: checking for $ac_word" >&5
+echo "configure:3839: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3867,7 +3873,7 @@
-echo "configure:3871: checking for $ac_word" >&5
+echo "configure:3877: checking for $ac_word" >&5
@@ -3896,7 +3902,7 @@
-echo "configure:3900: checking for $ac_word" >&5
+echo "configure:3906: checking for $ac_word" >&5
@@ -3927,7 +3933,7 @@
-echo "configure:3931: checking for $ac_word" >&5
+echo "configure:3937: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3956,7 +3962,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3960: checking for $ac_word" >&5
+echo "configure:3966: checking for $ac_word" >&5
 case "$PERL" in
@@ -3987,10 +3993,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3991: checking for ANSI C header files" >&5
+echo "configure:3997: checking for ANSI C header files" >&5
-#line 3994 "configure"
+#line 4000 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -3998,7 +4004,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:4002: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4015,7 +4021,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 4019 "configure"
+#line 4025 "configure"
 #include <string.h>
 EOF
@@ -4033,7 +4039,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4037 "configure"
+#line 4043 "configure"
 #include <stdlib.h>
 EOF
@@ -4054,7 +4060,7 @@
 else
-#line 4058 "configure"
+#line 4064 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4065,7 +4071,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:4069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -4092,15 +4098,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4096: checking for $ac_hdr" >&5
+echo "configure:4102: checking for $ac_hdr" >&5
-#line 4099 "configure"
+#line 4105 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4104: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4110: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4129,15 +4135,15 @@
 do
-echo "configure:4133: checking for $ac_hdr" >&5
+echo "configure:4139: checking for $ac_hdr" >&5
-#line 4136 "configure"
+#line 4142 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4166,15 +4172,15 @@
 do
-echo "configure:4170: checking for $ac_hdr" >&5
+echo "configure:4176: checking for $ac_hdr" >&5
-#line 4173 "configure"
+#line 4179 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4184: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4203,15 +4209,15 @@
 do
-echo "configure:4207: checking for $ac_hdr" >&5
+echo "configure:4213: checking for $ac_hdr" >&5
-#line 4210 "configure"
+#line 4216 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4240,15 +4246,15 @@
 do
-echo "configure:4244: checking for $ac_hdr" >&5
+echo "configure:4250: checking for $ac_hdr" >&5
-#line 4247 "configure"
+#line 4253 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4274,10 +4280,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4278: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4284: checking whether time.h and sys/time.h may both be included" >&5
-#line 4281 "configure"
+#line 4287 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4286,7 +4292,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4290: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4296: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4306,10 +4312,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4310: checking for off_t" >&5
+echo "configure:4316: checking for off_t" >&5
-#line 4313 "configure"
+#line 4319 "configure"
 #if STDC_HEADERS
@@ -4336,10 +4342,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4340: checking for uid_t in sys/types.h" >&5
+echo "configure:4346: checking for uid_t in sys/types.h" >&5
-#line 4343 "configure"
+#line 4349 "configure"
 EOF
@@ -4367,10 +4373,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4371: checking return type of signal handlers" >&5
+echo "configure:4377: checking return type of signal handlers" >&5
-#line 4374 "configure"
+#line 4380 "configure"
 #include <signal.h>
@@ -4387,7 +4393,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4391: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4397: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4405,10 +4411,10 @@
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4409: checking for Cygwin environment" >&5
+echo "configure:4415: checking for Cygwin environment" >&5
-#line 4412 "configure"
+#line 4418 "configure"
 int main() {
@@ -4419,7 +4425,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4423: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4429: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4437,10 +4443,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4441: checking for $ac_func" >&5
+echo "configure:4447: checking for $ac_func" >&5
-#line 4444 "configure"
+#line 4450 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4463,7 +4469,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4489,10 +4495,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4493: checking for $ac_func" >&5
+echo "configure:4499: checking for $ac_func" >&5
-#line 4496 "configure"
+#line 4502 "configure"
@@ -4515,7 +4521,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4541,10 +4547,10 @@
 for ac_func in drand48
 do
-echo "configure:4545: checking for $ac_func" >&5
+echo "configure:4551: checking for $ac_func" >&5
-#line 4548 "configure"
+#line 4554 "configure"
@@ -4567,7 +4573,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4593,10 +4599,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4597: checking for $ac_func" >&5
+echo "configure:4603: checking for $ac_func" >&5
-#line 4600 "configure"
+#line 4606 "configure"
@@ -4619,7 +4625,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4645,10 +4651,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4649: checking for $ac_func" >&5
+echo "configure:4655: checking for $ac_func" >&5
-#line 4652 "configure"
+#line 4658 "configure"
@@ -4671,7 +4677,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4696,13 +4702,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4700: checking whether setpgrp takes no argument" >&5
+echo "configure:4706: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4706 "configure"
+#line 4712 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4722,7 +4728,7 @@
 EOF
-if { (eval echo configure:4726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4750,16 +4756,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4754: checking for long long int" >&5
+echo "configure:4760: checking for long long int" >&5
-#line 4756 "configure"
+#line 4762 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4763: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4769: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 echo "$ac_t""yes" 1>&6
@@ -4779,7 +4785,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4783: checking for W11" >&5
+echo "configure:4789: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4807,7 +4813,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4811: checking for X" >&5
+echo "configure:4817: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4867,12 +4873,12 @@
   # First, try using that file with no special directory specified.
-#line 4871 "configure"
+#line 4877 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4876: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4882: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4941,14 +4947,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4945 "configure"
+#line 4951 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -5053,17 +5059,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5057: checking whether -R must be followed by a space" >&5
+echo "configure:5063: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5060 "configure"
+#line 5066 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -5079,14 +5085,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5083 "configure"
+#line 5089 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -5118,13 +5124,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5122: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5128: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 5128 "configure"
+#line 5134 "configure"
@@ -5135,7 +5141,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5156,13 +5162,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5160: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5166: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5166 "configure"
+#line 5172 "configure"
@@ -5173,7 +5179,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5201,10 +5207,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5205: checking for gethostbyname" >&5
+echo "configure:5211: checking for gethostbyname" >&5
-#line 5208 "configure"
+#line 5214 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5227,7 +5233,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5247,13 +5253,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5251: checking for gethostbyname in -lnsl" >&5
+echo "configure:5257: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5257 "configure"
+#line 5263 "configure"
@@ -5264,7 +5270,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5293,10 +5299,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5297: checking for connect" >&5
+echo "configure:5303: checking for connect" >&5
-#line 5300 "configure"
+#line 5306 "configure"
     which can conflict with char connect(); below.  */
@@ -5319,7 +5325,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5339,13 +5345,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5343: checking for connect in -lsocket" >&5
+echo "configure:5349: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5349 "configure"
+#line 5355 "configure"
@@ -5356,7 +5362,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5379,10 +5385,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5383: checking for remove" >&5
+echo "configure:5389: checking for remove" >&5
-#line 5386 "configure"
+#line 5392 "configure"
     which can conflict with char remove(); below.  */
@@ -5405,7 +5411,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5425,13 +5431,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5429: checking for remove in -lposix" >&5
+echo "configure:5435: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5435 "configure"
+#line 5441 "configure"
@@ -5442,7 +5448,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5465,10 +5471,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5469: checking for shmat" >&5
+echo "configure:5475: checking for shmat" >&5
-#line 5472 "configure"
+#line 5478 "configure"
     which can conflict with char shmat(); below.  */
@@ -5491,7 +5497,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5511,13 +5517,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5515: checking for shmat in -lipc" >&5
+echo "configure:5521: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5521 "configure"
+#line 5527 "configure"
@@ -5528,7 +5534,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5560,13 +5566,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5564: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5570: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5570 "configure"
+#line 5576 "configure"
@@ -5577,7 +5583,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5615,7 +5621,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5619: checking whether to use Curses" >&5
+echo "configure:5625: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5634,15 +5640,15 @@
 do
-echo "configure:5638: checking for $ac_hdr" >&5
+echo "configure:5644: checking for $ac_hdr" >&5
-#line 5641 "configure"
+#line 5647 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5646: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5673,10 +5679,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5677: checking curses.h WINDOW structure component" >&5
+echo "configure:5683: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5680 "configure"
+#line 5686 "configure"
 #include <curses.h>
@@ -5685,7 +5691,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5689: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5695: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5694,7 +5700,7 @@
 fi
 rm -f conftest*
-#line 5698 "configure"
+#line 5704 "configure"
 #include <curses.h>
@@ -5703,7 +5709,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5707: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5713: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5719,13 +5725,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5723: checking for initscr in -lncurses" >&5
+echo "configure:5729: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5729 "configure"
+#line 5735 "configure"
@@ -5736,7 +5742,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5755,13 +5761,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5759: checking for initscr in -lcurses" >&5
+echo "configure:5765: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5765 "configure"
+#line 5771 "configure"
@@ -5772,7 +5778,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5801,13 +5807,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5805: checking for keypad in -lncurses" >&5
+echo "configure:5811: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5811 "configure"
+#line 5817 "configure"
@@ -5818,7 +5824,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5840,13 +5846,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5844: checking for keypad in -lcurses" >&5
+echo "configure:5850: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5850 "configure"
+#line 5856 "configure"
@@ -5857,7 +5863,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5887,13 +5893,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5891: checking for gtty in -lcompat" >&5
+echo "configure:5897: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5897 "configure"
+#line 5903 "configure"
@@ -5904,7 +5910,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5923,13 +5929,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5927: checking for gtty in -lbsd-compat" >&5
+echo "configure:5933: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5933 "configure"
+#line 5939 "configure"
@@ -5940,7 +5946,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5959,13 +5965,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5963: checking for gtty in -lbsd" >&5
+echo "configure:5969: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 5969 "configure"
+#line 5975 "configure"
@@ -5976,7 +5982,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6010,12 +6016,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:6014: checking for library containing cuserid" >&5
+echo "configure:6020: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 6019 "configure"
+#line 6025 "configure"
@@ -6026,7 +6032,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -6037,7 +6043,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 6041 "configure"
+#line 6047 "configure"
@@ -6048,7 +6054,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6052: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -6074,10 +6080,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:6078: checking for xdrmem_create" >&5
+echo "configure:6084: checking for xdrmem_create" >&5
-#line 6081 "configure"
+#line 6087 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -6100,7 +6106,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -6118,13 +6124,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6122: checking for xdrmem_create in -lsun" >&5
+echo "configure:6128: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 6128 "configure"
+#line 6134 "configure"
@@ -6135,7 +6141,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6154,13 +6160,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6158: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6164: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 6164 "configure"
+#line 6170 "configure"
@@ -6171,7 +6177,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6190,13 +6196,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6194: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6200: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6200 "configure"
+#line 6206 "configure"
@@ -6207,7 +6213,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6211: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6226,13 +6232,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6230: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6236: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6236 "configure"
+#line 6242 "configure"
@@ -6243,7 +6249,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6277,10 +6283,10 @@
 for ac_func in asprintf
 do
-echo "configure:6281: checking for $ac_func" >&5
+echo "configure:6287: checking for $ac_func" >&5
-#line 6284 "configure"
+#line 6290 "configure"
@@ -6303,7 +6309,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6330,10 +6336,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6334: checking for atan" >&5
+echo "configure:6340: checking for atan" >&5
-#line 6337 "configure"
+#line 6343 "configure"
     which can conflict with char atan(); below.  */
@@ -6356,7 +6362,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6374,13 +6380,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6378: checking for atan in -lm" >&5
+echo "configure:6384: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6384 "configure"
+#line 6390 "configure"
@@ -6391,7 +6397,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6418,10 +6424,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6422: checking for dlsym" >&5
+echo "configure:6428: checking for dlsym" >&5
-#line 6425 "configure"
+#line 6431 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6444,7 +6450,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6462,13 +6468,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6466: checking for dlsym in -ldl" >&5
+echo "configure:6472: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6472 "configure"
+#line 6478 "configure"
@@ -6479,7 +6485,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6506,10 +6512,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6510: checking for iconv" >&5
+echo "configure:6516: checking for iconv" >&5
-#line 6513 "configure"
+#line 6519 "configure"
     which can conflict with char iconv(); below.  */
@@ -6532,7 +6538,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6550,13 +6556,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6554: checking for iconv in -liconv" >&5
+echo "configure:6560: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6560 "configure"
+#line 6566 "configure"
@@ -6567,7 +6573,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6586,13 +6592,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6590: checking for iconv in -lgiconv" >&5
+echo "configure:6596: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6596 "configure"
+#line 6602 "configure"
@@ -6603,7 +6609,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6622,10 +6628,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6626: checking for libiconv" >&5
+echo "configure:6632: checking for libiconv" >&5
-#line 6629 "configure"
+#line 6635 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6648,7 +6654,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6666,13 +6672,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6670: checking for libiconv in -liconv" >&5
+echo "configure:6676: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6676 "configure"
+#line 6682 "configure"
@@ -6683,7 +6689,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6687: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6702,13 +6708,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6706: checking for libiconv in -lgiconv" >&5
+echo "configure:6712: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6712 "configure"
+#line 6718 "configure"
@@ -6719,7 +6725,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6723: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6756,10 +6762,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6760: checking for socket" >&5
+echo "configure:6766: checking for socket" >&5
-#line 6763 "configure"
+#line 6769 "configure"
     which can conflict with char socket(); below.  */
@@ -6782,7 +6788,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6800,13 +6806,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6804: checking for socket in -lsocket" >&5
+echo "configure:6810: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6810 "configure"
+#line 6816 "configure"
@@ -6817,7 +6823,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6865,7 +6871,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6869: checking for location of zlib includes" >&5
+echo "configure:6875: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6891,15 +6897,15 @@
 do
-echo "configure:6895: checking for $ac_hdr" >&5
+echo "configure:6901: checking for $ac_hdr" >&5
-#line 6898 "configure"
+#line 6904 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6903: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6933,7 +6939,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6937: checking for location of zlib library" >&5
+echo "configure:6943: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6958,13 +6964,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6962: checking for deflate in -lz" >&5
+echo "configure:6968: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6968 "configure"
+#line 6974 "configure"
@@ -6975,7 +6981,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7023,7 +7029,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:7027: checking for location of External PROJ.4 includes" >&5
+echo "configure:7033: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -7049,15 +7055,15 @@
 do
-echo "configure:7053: checking for $ac_hdr" >&5
+echo "configure:7059: checking for $ac_hdr" >&5
-#line 7056 "configure"
+#line 7062 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7061: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7094,7 +7100,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:7098: checking External PROJ.4 version" >&5
+echo "configure:7104: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -7102,7 +7108,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 7106 "configure"
+#line 7112 "configure"
 #include <stdio.h>
@@ -7114,7 +7120,7 @@
 EOF
-if { (eval echo configure:7118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -7139,7 +7145,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7143: checking for location of External PROJ.4 library" >&5
+echo "configure:7149: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7164,13 +7170,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7168: checking for pj_get_def in -lproj" >&5
+echo "configure:7174: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 7174 "configure"
+#line 7180 "configure"
@@ -7181,7 +7187,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:7185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7215,7 +7221,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7219: checking for location of External PROJ.4 data files" >&5
+echo "configure:7225: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7239,14 +7245,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7243: checking for epsg" >&5
+echo "configure:7249: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7250: checking for $PROJSHARE/epsg" >&5
+echo "configure:7256: checking for $PROJSHARE/epsg" >&5
@@ -7278,7 +7284,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:7282: checking for $ac_word" >&5
+echo "configure:7288: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7318,7 +7324,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7322: checking whether to use regex" >&5
+echo "configure:7328: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -7338,7 +7344,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7342: checking for location of regex includes" >&5
+echo "configure:7348: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7364,15 +7370,15 @@
 do
-echo "configure:7368: checking for $ac_hdr" >&5
+echo "configure:7374: checking for $ac_hdr" >&5
-#line 7371 "configure"
+#line 7377 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7376: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7382: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7406,7 +7412,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7410: checking for location of regex library" >&5
+echo "configure:7416: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7431,10 +7437,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7435: checking for regcomp" >&5
+echo "configure:7441: checking for regcomp" >&5
-#line 7438 "configure"
+#line 7444 "configure"
     which can conflict with char regcomp(); below.  */
@@ -7457,7 +7463,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -7484,13 +7490,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7488: checking for regcomp in -lregex" >&5
+echo "configure:7494: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 7494 "configure"
+#line 7500 "configure"
@@ -7501,7 +7507,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:7505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7551,7 +7557,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7555: checking whether to use Readline" >&5
+echo "configure:7561: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7572,7 +7578,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7576: checking for location of Readline includes" >&5
+echo "configure:7582: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7598,15 +7604,15 @@
 do
-echo "configure:7602: checking for $ac_hdr" >&5
+echo "configure:7608: checking for $ac_hdr" >&5
-#line 7605 "configure"
+#line 7611 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7610: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7642,15 +7648,15 @@
 do
-echo "configure:7646: checking for $ac_hdr" >&5
+echo "configure:7652: checking for $ac_hdr" >&5
-#line 7649 "configure"
+#line 7655 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7654: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7660: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7684,7 +7690,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7688: checking for location of Readline library" >&5
+echo "configure:7694: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7709,13 +7715,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7713: checking for readline in -lreadline" >&5
+echo "configure:7719: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 7719 "configure"
+#line 7725 "configure"
 #include "confdefs.h"
@@ -7726,7 +7732,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7730: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7761,13 +7767,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7765: checking for add_history in -lhistory" >&5
+echo "configure:7771: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7771 "configure"
+#line 7777 "configure"
@@ -7778,7 +7784,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7820,7 +7826,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7824: checking whether to use GDAL" >&5
+echo "configure:7830: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7838,7 +7844,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:7842: checking for $ac_word" >&5
+echo "configure:7848: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7893,14 +7899,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7897 "configure"
+#line 7903 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7909,14 +7915,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7913 "configure"
+#line 7919 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7948,7 +7954,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7952: checking whether to use GEOS" >&5
+echo "configure:7958: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -7966,7 +7972,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:7970: checking for $ac_word" >&5
+echo "configure:7976: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -8014,15 +8020,15 @@
 do
-echo "configure:8018: checking for $ac_hdr" >&5
+echo "configure:8024: checking for $ac_hdr" >&5
-#line 8021 "configure"
+#line 8027 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8026: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8032: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -8061,13 +8067,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8065: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8071: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lgeos_c  $LIBS"
-#line 8071 "configure"
+#line 8077 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -8078,7 +8084,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:8082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -8122,7 +8128,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8126: checking whether to use TIFF" >&5
+echo "configure:8132: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -8142,7 +8148,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8146: checking for location of TIFF includes" >&5
+echo "configure:8152: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8168,15 +8174,15 @@
 do
-echo "configure:8172: checking for $ac_hdr" >&5
+echo "configure:8178: checking for $ac_hdr" >&5
-#line 8175 "configure"
+#line 8181 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8180: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8186: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8210,7 +8216,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8214: checking for location of TIFF library" >&5
+echo "configure:8220: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8241,13 +8247,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8245: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8251: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8251 "configure"
+#line 8257 "configure"
@@ -8258,7 +8264,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8262: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8277,13 +8283,13 @@
-echo "configure:8281: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8287: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8287 "configure"
+#line 8293 "configure"
@@ -8294,7 +8300,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8313,13 +8319,13 @@
-echo "configure:8317: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8323: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8323 "configure"
+#line 8329 "configure"
@@ -8330,7 +8336,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8349,13 +8355,13 @@
-echo "configure:8353: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8359: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8359 "configure"
+#line 8365 "configure"
@@ -8366,7 +8372,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8385,13 +8391,13 @@
-echo "configure:8389: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8395: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 8395 "configure"
+#line 8401 "configure"
@@ -8402,7 +8408,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8421,13 +8427,13 @@
-echo "configure:8425: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8431: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 8431 "configure"
+#line 8437 "configure"
@@ -8438,7 +8444,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8457,13 +8463,13 @@
-echo "configure:8461: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8467: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 8467 "configure"
+#line 8473 "configure"
@@ -8474,7 +8480,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8493,13 +8499,13 @@
-echo "configure:8497: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8503: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 8503 "configure"
+#line 8509 "configure"
@@ -8510,7 +8516,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8514: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8608,7 +8614,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8612: checking whether to use PNG" >&5
+echo "configure:8618: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8627,7 +8633,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8631: checking for location of PNG includes" >&5
+echo "configure:8637: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8653,15 +8659,15 @@
 do
-echo "configure:8657: checking for $ac_hdr" >&5
+echo "configure:8663: checking for $ac_hdr" >&5
-#line 8660 "configure"
+#line 8666 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8665: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8671: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8695,7 +8701,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8699: checking for location of PNG library" >&5
+echo "configure:8705: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8720,13 +8726,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8724: checking for png_read_image in -lpng" >&5
+echo "configure:8730: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8730 "configure"
+#line 8736 "configure"
@@ -8737,7 +8743,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8741: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8779,7 +8785,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8783: checking whether to use PostgreSQL" >&5
+echo "configure:8789: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -8806,7 +8812,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8810: checking for location of PostgreSQL includes" >&5
+echo "configure:8816: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8832,15 +8838,15 @@
 do
-echo "configure:8836: checking for $ac_hdr" >&5
+echo "configure:8842: checking for $ac_hdr" >&5
-#line 8839 "configure"
+#line 8845 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8844: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8850: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8878,7 +8884,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8882: checking for location of PostgreSQL library" >&5
+echo "configure:8888: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8907,13 +8913,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8911: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8917: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8917 "configure"
+#line 8923 "configure"
@@ -8924,7 +8930,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8943,13 +8949,13 @@
-echo "configure:8947: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8953: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8953 "configure"
+#line 8959 "configure"
@@ -8960,7 +8966,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8979,13 +8985,13 @@
-echo "configure:8983: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8989: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 8989 "configure"
+#line 8995 "configure"
@@ -8996,7 +9002,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9015,13 +9021,13 @@
-echo "configure:9019: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9025: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9025 "configure"
+#line 9031 "configure"
@@ -9032,7 +9038,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9089,13 +9095,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9093: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9099: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9099 "configure"
+#line 9105 "configure"
@@ -9106,7 +9112,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9128,13 +9134,13 @@
-echo "configure:9132: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9138: checking for PQcmdTuples in -lpq" >&5
-#line 9138 "configure"
+#line 9144 "configure"
@@ -9145,7 +9151,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9188,7 +9194,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9192: checking whether to use MySQL" >&5
+echo "configure:9198: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9208,7 +9214,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9212: checking for location of MySQL includes" >&5
+echo "configure:9218: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9234,15 +9240,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9238: checking for $ac_hdr" >&5
+echo "configure:9244: checking for $ac_hdr" >&5
-#line 9241 "configure"
+#line 9247 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9246: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9279,7 +9285,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9283: checking for location of MySQL library" >&5
+echo "configure:9289: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9310,13 +9316,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9314: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9320: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9320 "configure"
+#line 9326 "configure"
@@ -9327,7 +9333,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9346,13 +9352,13 @@
-echo "configure:9350: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9356: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9356 "configure"
+#line 9362 "configure"
@@ -9363,7 +9369,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9382,13 +9388,13 @@
-echo "configure:9386: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9392: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9392 "configure"
+#line 9398 "configure"
@@ -9399,7 +9405,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9418,13 +9424,13 @@
-echo "configure:9422: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9428: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9428 "configure"
+#line 9434 "configure"
@@ -9435,7 +9441,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9454,13 +9460,13 @@
-echo "configure:9458: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9464: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9464 "configure"
+#line 9470 "configure"
@@ -9471,7 +9477,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9490,13 +9496,13 @@
-echo "configure:9494: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9500: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9500 "configure"
+#line 9506 "configure"
@@ -9507,7 +9513,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9526,13 +9532,13 @@
-echo "configure:9530: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9536: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9536 "configure"
+#line 9542 "configure"
@@ -9543,7 +9549,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9562,13 +9568,13 @@
-echo "configure:9566: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9572: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9572 "configure"
+#line 9578 "configure"
@@ -9579,7 +9585,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9669,7 +9675,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9673: checking for $ac_word" >&5
+echo "configure:9679: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -9710,10 +9716,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9714: checking for mysql_server_init" >&5
+echo "configure:9720: checking for mysql_server_init" >&5
-#line 9717 "configure"
+#line 9723 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -9736,7 +9742,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -9774,7 +9780,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9778: checking whether to use SQLite" >&5
+echo "configure:9784: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -9794,7 +9800,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9798: checking for location of SQLite includes" >&5
+echo "configure:9804: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9820,15 +9826,15 @@
 do
-echo "configure:9824: checking for $ac_hdr" >&5
+echo "configure:9830: checking for $ac_hdr" >&5
-#line 9827 "configure"
+#line 9833 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9832: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9871,7 +9877,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9875: checking for location of SQLite library" >&5
+echo "configure:9881: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9900,13 +9906,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9904: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9910: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 9910 "configure"
+#line 9916 "configure"
@@ -9917,7 +9923,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9936,13 +9942,13 @@
-echo "configure:9940: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9946: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 9946 "configure"
+#line 9952 "configure"
@@ -9953,7 +9959,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9972,13 +9978,13 @@
-echo "configure:9976: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9982: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9982 "configure"
+#line 9988 "configure"
@@ -9989,7 +9995,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10008,13 +10014,13 @@
-echo "configure:10012: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10018: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10018 "configure"
+#line 10024 "configure"
@@ -10025,7 +10031,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10094,7 +10100,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10098: checking whether to use FFMPEG" >&5
+echo "configure:10104: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10114,7 +10120,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10118: checking for location of FFMPEG includes" >&5
+echo "configure:10124: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10140,15 +10146,15 @@
 do
-echo "configure:10144: checking for $ac_hdr" >&5
+echo "configure:10150: checking for $ac_hdr" >&5
-#line 10147 "configure"
+#line 10153 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10158: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10184,15 +10190,15 @@
 do
-echo "configure:10188: checking for $ac_hdr" >&5
+echo "configure:10194: checking for $ac_hdr" >&5
-#line 10191 "configure"
+#line 10197 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10196: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10202: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10228,15 +10234,15 @@
 do
-echo "configure:10232: checking for $ac_hdr" >&5
+echo "configure:10238: checking for $ac_hdr" >&5
-#line 10235 "configure"
+#line 10241 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10240: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10246: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10279,7 +10285,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10283: checking for location of FFMPEG library" >&5
+echo "configure:10289: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10306,13 +10312,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10310: checking for av_free in -lavutil" >&5
+echo "configure:10316: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10316 "configure"
+#line 10322 "configure"
@@ -10323,7 +10329,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10342,13 +10348,13 @@
-echo "configure:10346: checking for av_free in -lavutil" >&5
+echo "configure:10352: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10352 "configure"
+#line 10358 "configure"
@@ -10359,7 +10365,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10363: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10404,13 +10410,13 @@
 echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:10408: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10414: checking for avcodec_register in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10414 "configure"
+#line 10420 "configure"
@@ -10421,7 +10427,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:10425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10440,13 +10446,13 @@
-echo "configure:10444: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10450: checking for avcodec_register in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10450 "configure"
+#line 10456 "configure"
@@ -10457,7 +10463,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:10461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10502,13 +10508,13 @@
 echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:10506: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10512: checking for avformat_alloc_context in -lavformat" >&5
 ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10512 "configure"
+#line 10518 "configure"
@@ -10519,7 +10525,7 @@
 avformat_alloc_context()
 ; return 0; }
 EOF
-if { (eval echo configure:10523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10538,13 +10544,13 @@
-echo "configure:10542: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10548: checking for avformat_alloc_context in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10548 "configure"
+#line 10554 "configure"
@@ -10555,7 +10561,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10614,7 +10620,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10618: checking whether to use OpenGL" >&5
+echo "configure:10624: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10648,7 +10654,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10652: checking for location of OpenGL includes" >&5
+echo "configure:10658: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10674,15 +10680,15 @@
 do
-echo "configure:10678: checking for $ac_hdr" >&5
+echo "configure:10684: checking for $ac_hdr" >&5
-#line 10681 "configure"
+#line 10687 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10692: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10719,15 +10725,15 @@
 do
-echo "configure:10723: checking for $ac_hdr" >&5
+echo "configure:10729: checking for $ac_hdr" >&5
-#line 10726 "configure"
+#line 10732 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10731: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10737: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10761,7 +10767,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10765: checking for location of OpenGL library" >&5
+echo "configure:10771: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10782,7 +10788,7 @@
 echo $ac_n "checking for location of Xmu library""... $ac_c" 1>&6
-echo "configure:10786: checking for location of Xmu library" >&5
+echo "configure:10792: checking for location of Xmu library" >&5
 case "$with_Xmu_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-Xmu-libs." 1>&2; exit 1; }
@@ -10811,13 +10817,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10815: checking for glBegin in -lGL" >&5
+echo "configure:10821: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10821 "configure"
+#line 10827 "configure"
@@ -10828,7 +10834,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10847,13 +10853,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10851: checking for glBegin in -lGL" >&5
+echo "configure:10857: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10857 "configure"
+#line 10863 "configure"
@@ -10864,7 +10870,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10883,13 +10889,13 @@
-echo "configure:10887: checking for glBegin in -lGL" >&5
+echo "configure:10893: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10893 "configure"
+#line 10899 "configure"
@@ -10900,7 +10906,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10919,13 +10925,13 @@
-echo "configure:10923: checking for glBegin in -lGL" >&5
+echo "configure:10929: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10929 "configure"
+#line 10935 "configure"
@@ -10936,7 +10942,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10940: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10998,13 +11004,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11002: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11008: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 11008 "configure"
+#line 11014 "configure"
@@ -11015,7 +11021,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11034,13 +11040,13 @@
-echo "configure:11038: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11044: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11044 "configure"
+#line 11050 "configure"
@@ -11051,7 +11057,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:11055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11095,10 +11101,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11099: checking for glXCreatePbuffer" >&5
+echo "configure:11105: checking for glXCreatePbuffer" >&5
-#line 11102 "configure"
+#line 11108 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11121,7 +11127,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11143,10 +11149,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11147: checking for glXCreateGLXPixmap" >&5
+echo "configure:11153: checking for glXCreateGLXPixmap" >&5
-#line 11150 "configure"
+#line 11156 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11169,7 +11175,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11208,7 +11214,7 @@
-echo "configure:11212: checking for location of OpenGL includes" >&5
+echo "configure:11218: checking for location of OpenGL includes" >&5
@@ -11234,15 +11240,15 @@
 do
-echo "configure:11238: checking for $ac_hdr" >&5
+echo "configure:11244: checking for $ac_hdr" >&5
-#line 11241 "configure"
+#line 11247 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11246: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11277,10 +11283,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11281: checking for glBegin" >&5
+echo "configure:11287: checking for glBegin" >&5
-#line 11284 "configure"
+#line 11290 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11303,7 +11309,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11318,10 +11324,10 @@
   echo "$ac_t""yes" 1>&6
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11322: checking for gluBeginCurve" >&5
+echo "configure:11328: checking for gluBeginCurve" >&5
-#line 11325 "configure"
+#line 11331 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11344,7 +11350,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11388,7 +11394,7 @@
-echo "configure:11392: checking for location of OpenGL includes" >&5
+echo "configure:11398: checking for location of OpenGL includes" >&5
@@ -11414,15 +11420,15 @@
 do
-echo "configure:11418: checking for $ac_hdr" >&5
+echo "configure:11424: checking for $ac_hdr" >&5
-#line 11421 "configure"
+#line 11427 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11426: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11432: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11456,7 +11462,7 @@
-echo "configure:11460: checking for location of OpenGL library" >&5
+echo "configure:11466: checking for location of OpenGL library" >&5
@@ -11481,18 +11487,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11485: checking for OpenGL library" >&5
+echo "configure:11491: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11489 "configure"
+#line 11495 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11516,18 +11522,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11520: checking for GLU library" >&5
+echo "configure:11526: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11524 "configure"
+#line 11530 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11576,7 +11582,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11580: checking whether to use Tcl/Tk" >&5
+echo "configure:11586: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11596,7 +11602,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11600: checking for location of Tcl/Tk includes" >&5
+echo "configure:11606: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11622,15 +11628,15 @@
 do
-echo "configure:11626: checking for $ac_hdr" >&5
+echo "configure:11632: checking for $ac_hdr" >&5
-#line 11629 "configure"
+#line 11635 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11634: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11640: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11667,15 +11673,15 @@
 do
-echo "configure:11671: checking for $ac_hdr" >&5
+echo "configure:11677: checking for $ac_hdr" >&5
-#line 11674 "configure"
+#line 11680 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11679: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11708,7 +11714,7 @@
 # Tcl/Tk version checks
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11712: checking Tcl version" >&5
+echo "configure:11718: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -11716,7 +11722,7 @@
 else
-#line 11720 "configure"
+#line 11726 "configure"
 #include <stdio.h>
@@ -11728,7 +11734,7 @@
 EOF
-if { (eval echo configure:11732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11746,7 +11752,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11750: checking Tk version" >&5
+echo "configure:11756: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11754,7 +11760,7 @@
 else
-#line 11758 "configure"
+#line 11764 "configure"
 #include <stdio.h>
@@ -11766,7 +11772,7 @@
 EOF
-if { (eval echo configure:11770: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -11797,7 +11803,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11801: checking for location of Tcl/Tk library" >&5
+echo "configure:11807: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11837,13 +11843,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11841: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11847: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 11847 "configure"
+#line 11853 "configure"
@@ -11854,7 +11860,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11873,13 +11879,13 @@
-echo "configure:11877: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11883: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11883 "configure"
+#line 11889 "configure"
@@ -11890,7 +11896,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11917,13 +11923,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11921: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11927: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11927 "configure"
+#line 11933 "configure"
@@ -11934,7 +11940,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11953,13 +11959,13 @@
-echo "configure:11957: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11963: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11963 "configure"
+#line 11969 "configure"
@@ -11970,7 +11976,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11997,13 +12003,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12001: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12007: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12007 "configure"
+#line 12013 "configure"
@@ -12014,7 +12020,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12018: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12033,13 +12039,13 @@
-echo "configure:12037: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12043: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12043 "configure"
+#line 12049 "configure"
@@ -12050,7 +12056,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12054: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12128,13 +12134,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12132: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12138: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12138 "configure"
+#line 12144 "configure"
@@ -12145,7 +12151,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12149: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12164,13 +12170,13 @@
-echo "configure:12168: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12174: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12174 "configure"
+#line 12180 "configure"
@@ -12181,7 +12187,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12208,13 +12214,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12212: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12218: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12218 "configure"
+#line 12224 "configure"
@@ -12225,7 +12231,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12235: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12244,13 +12250,13 @@
-echo "configure:12248: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12254: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12254 "configure"
+#line 12260 "configure"
@@ -12261,7 +12267,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12288,13 +12294,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12292: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12298: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12298 "configure"
+#line 12304 "configure"
@@ -12305,7 +12311,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12324,13 +12330,13 @@
-echo "configure:12328: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12334: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12334 "configure"
+#line 12340 "configure"
@@ -12341,7 +12347,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12345: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12431,13 +12437,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12435: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12441: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12441 "configure"
+#line 12447 "configure"
@@ -12448,7 +12454,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12497,7 +12503,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12501: checking whether to use ODBC" >&5
+echo "configure:12507: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12516,7 +12522,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12520: checking for location of ODBC includes" >&5
+echo "configure:12526: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12542,15 +12548,15 @@
 do
-echo "configure:12546: checking for $ac_hdr" >&5
+echo "configure:12552: checking for $ac_hdr" >&5
-#line 12549 "configure"
+#line 12555 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12554: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12560: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12584,7 +12590,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12588: checking for location of ODBC library" >&5
+echo "configure:12594: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12609,13 +12615,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12613: checking for SQLConnect in -lodbc" >&5
+echo "configure:12619: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12619 "configure"
+#line 12625 "configure"
@@ -12626,7 +12632,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12651,13 +12657,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12655: checking for SQLConnect in -liodbc" >&5
+echo "configure:12661: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12661 "configure"
+#line 12667 "configure"
@@ -12668,7 +12674,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12693,11 +12699,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12697: checking for ODBC library" >&5
+echo "configure:12703: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12701 "configure"
+#line 12707 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12705,7 +12711,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12754,7 +12760,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12758: checking whether to use FFTW" >&5
+echo "configure:12764: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12773,7 +12779,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12777: checking for location of FFTW includes" >&5
+echo "configure:12783: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12799,15 +12805,15 @@
 do
-echo "configure:12803: checking for $ac_hdr" >&5
+echo "configure:12809: checking for $ac_hdr" >&5
-#line 12806 "configure"
+#line 12812 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12811: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12817: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12835,15 +12841,15 @@
 do
-echo "configure:12839: checking for $ac_hdr" >&5
+echo "configure:12845: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 12842 "configure"
+#line 12848 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12847: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12853: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12871,15 +12877,15 @@
 do
-echo "configure:12875: checking for $ac_hdr" >&5
+echo "configure:12881: checking for $ac_hdr" >&5
-#line 12878 "configure"
+#line 12884 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12883: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12889: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12925,7 +12931,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12929: checking for location of FFTW library" >&5
+echo "configure:12935: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12950,13 +12956,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12954: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12960: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12960 "configure"
+#line 12966 "configure"
@@ -12967,7 +12973,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12992,13 +12998,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12996: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13002: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 13002 "configure"
+#line 13008 "configure"
@@ -13009,7 +13015,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:13013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13034,13 +13040,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13038: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13044: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13044 "configure"
+#line 13050 "configure"
@@ -13051,7 +13057,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:13055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13108,7 +13114,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13112: checking whether to use BLAS" >&5
+echo "configure:13118: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -13129,7 +13135,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13133: checking for location of BLAS includes" >&5
+echo "configure:13139: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13149,7 +13155,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13153: checking for location of BLAS library" >&5
+echo "configure:13159: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13175,15 +13181,15 @@
 do
-echo "configure:13179: checking for $ac_hdr" >&5
+echo "configure:13185: checking for $ac_hdr" >&5
-#line 13182 "configure"
+#line 13188 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13218,13 +13224,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13222: checking for dnrm2_ in -lblas" >&5
+echo "configure:13228: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 13228 "configure"
+#line 13234 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13235,7 +13241,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13254,13 +13260,13 @@
-echo "configure:13258: checking for dnrm2_ in -lblas" >&5
+echo "configure:13264: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13264 "configure"
+#line 13270 "configure"
@@ -13271,7 +13277,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13315,13 +13321,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13319: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13325: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 13325 "configure"
+#line 13331 "configure"
@@ -13332,7 +13338,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13347,13 +13353,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13351: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13357: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13357 "configure"
+#line 13363 "configure"
@@ -13364,7 +13370,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13379,13 +13385,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13383: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13389: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13389 "configure"
+#line 13395 "configure"
@@ -13396,7 +13402,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13442,16 +13448,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13446: checking for sgemm in $vlib_flags" >&5
+echo "configure:13452: checking for sgemm in $vlib_flags" >&5
-#line 13448 "configure"
+#line 13454 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13469,13 +13475,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13473: checking for sgemm_ in -lblas" >&5
+echo "configure:13479: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13479 "configure"
+#line 13485 "configure"
@@ -13486,7 +13492,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13501,13 +13507,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13505: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13511: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13511 "configure"
+#line 13517 "configure"
@@ -13518,7 +13524,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13533,13 +13539,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13537: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13543: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13543 "configure"
+#line 13549 "configure"
@@ -13550,7 +13556,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13584,13 +13590,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13588: checking for acosp in -lsunmath" >&5
+echo "configure:13594: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13594 "configure"
+#line 13600 "configure"
@@ -13601,7 +13607,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13605: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13616,13 +13622,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13620: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13626: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13626 "configure"
+#line 13632 "configure"
@@ -13633,7 +13639,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13637: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13663,13 +13669,13 @@
 # Generic BLAS library
-echo "configure:13667: checking for sgemm_ in -lblas" >&5
+echo "configure:13673: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13673 "configure"
+#line 13679 "configure"
@@ -13680,7 +13686,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13719,7 +13725,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13723: checking whether to use LAPACK" >&5
+echo "configure:13729: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13744,7 +13750,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13748: checking for location of LAPACK includes" >&5
+echo "configure:13754: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13764,7 +13770,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13768: checking for location of LAPACK library" >&5
+echo "configure:13774: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13790,15 +13796,15 @@
 do
-echo "configure:13794: checking for $ac_hdr" >&5
+echo "configure:13800: checking for $ac_hdr" >&5
-#line 13797 "configure"
+#line 13803 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13802: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13830,10 +13836,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13834: checking for dsegv_" >&5
+echo "configure:13840: checking for dsegv_" >&5
-#line 13837 "configure"
+#line 13843 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13856,7 +13862,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13883,13 +13889,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13887: checking for desgv_ in -llapack" >&5
+echo "configure:13893: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13893 "configure"
+#line 13899 "configure"
@@ -13900,7 +13906,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13904: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13932,13 +13938,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13936: checking for dgesv_ in -llapack" >&5
+echo "configure:13942: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13942 "configure"
+#line 13948 "configure"
@@ -13949,7 +13955,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13968,13 +13974,13 @@
-echo "configure:13972: checking for dgesv_ in -llapack" >&5
+echo "configure:13978: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13978 "configure"
+#line 13984 "configure"
@@ -13985,7 +13991,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14041,7 +14047,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14045: checking whether to use Motif" >&5
+echo "configure:14051: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -14060,7 +14066,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14064: checking for location of Motif includes" >&5
+echo "configure:14070: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14086,15 +14092,15 @@
 do
-echo "configure:14090: checking for $ac_hdr" >&5
+echo "configure:14096: checking for $ac_hdr" >&5
-#line 14093 "configure"
+#line 14099 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14098: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14104: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14128,7 +14134,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14132: checking for location of Motif library" >&5
+echo "configure:14138: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14153,13 +14159,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14157: checking for XmStringCreate in -lXm" >&5
+echo "configure:14163: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 14163 "configure"
+#line 14169 "configure"
@@ -14170,7 +14176,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:14174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14211,7 +14217,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14215: checking whether to use Cairo" >&5
+echo "configure:14221: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -14243,7 +14249,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14247: checking for location of cairo includes" >&5
+echo "configure:14253: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14269,15 +14275,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14273: checking for $ac_hdr" >&5
+echo "configure:14279: checking for $ac_hdr" >&5
-#line 14276 "configure"
+#line 14282 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14281: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14313,7 +14319,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14317: checking for location of cairo library" >&5
+echo "configure:14323: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14333,7 +14339,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14337: checking for cairo linking flags" >&5
+echo "configure:14343: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14349,10 +14355,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14353: checking for cairo_create" >&5
+echo "configure:14359: checking for cairo_create" >&5
-#line 14356 "configure"
+#line 14362 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -14375,7 +14381,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14409,10 +14415,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14413: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14419: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14416 "configure"
+#line 14422 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -14435,7 +14441,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14468,10 +14474,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14472: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14478: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14475 "configure"
+#line 14481 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -14494,7 +14500,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -14536,7 +14542,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14540: checking whether to use GLw" >&5
+echo "configure:14546: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14555,7 +14561,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14559: checking for location of GLw includes" >&5
+echo "configure:14565: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14581,15 +14587,15 @@
 do
-echo "configure:14585: checking for $ac_hdr" >&5
+echo "configure:14591: checking for $ac_hdr" >&5
-#line 14588 "configure"
+#line 14594 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14593: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14599: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14617,15 +14623,15 @@
 do
-echo "configure:14621: checking for $ac_hdr" >&5
+echo "configure:14627: checking for $ac_hdr" >&5
-#line 14624 "configure"
+#line 14630 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14629: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14635: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14665,7 +14671,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14669: checking for location of GLw library" >&5
+echo "configure:14675: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14690,13 +14696,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14694: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14700: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14700 "configure"
+#line 14706 "configure"
@@ -14707,7 +14713,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14732,13 +14738,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14736: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14742: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14742 "configure"
+#line 14748 "configure"
@@ -14749,7 +14755,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14774,13 +14780,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14778: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14784: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14784 "configure"
+#line 14790 "configure"
@@ -14791,7 +14797,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14816,13 +14822,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14820: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14826: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14826 "configure"
+#line 14832 "configure"
@@ -14833,7 +14839,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14858,13 +14864,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14862: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14868: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14868 "configure"
+#line 14874 "configure"
@@ -14875,7 +14881,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14900,13 +14906,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14904: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14910: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14910 "configure"
+#line 14916 "configure"
@@ -14917,7 +14923,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14944,13 +14950,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14948: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14954: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14954 "configure"
+#line 14960 "configure"
@@ -14961,7 +14967,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14980,13 +14986,13 @@
-echo "configure:14984: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14990: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14990 "configure"
+#line 14996 "configure"
@@ -14997,7 +15003,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15024,13 +15030,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15028: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15034: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 15034 "configure"
+#line 15040 "configure"
@@ -15041,7 +15047,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15060,13 +15066,13 @@
-echo "configure:15064: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15070: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15070 "configure"
+#line 15076 "configure"
@@ -15077,7 +15083,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15190,7 +15196,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15194: checking whether to use FreeType" >&5
+echo "configure:15200: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -15209,7 +15215,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15213: checking for location of FreeType includes" >&5
+echo "configure:15219: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15235,15 +15241,15 @@
 do
-echo "configure:15239: checking for $ac_hdr" >&5
+echo "configure:15245: checking for $ac_hdr" >&5
-#line 15242 "configure"
+#line 15248 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15247: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15277,7 +15283,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15281: checking for location of FreeType library" >&5
+echo "configure:15287: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15302,13 +15308,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15306: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15312: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 15312 "configure"
+#line 15318 "configure"
@@ -15319,7 +15325,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:15323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15360,7 +15366,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15364: checking whether to use NLS" >&5
+echo "configure:15370: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -15380,10 +15386,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15384: checking for gettext" >&5
+echo "configure:15390: checking for gettext" >&5
-#line 15387 "configure"
+#line 15393 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gettext(); below.  */
@@ -15406,7 +15412,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -15424,13 +15430,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15428: checking for gettext in -lintl" >&5
+echo "configure:15434: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 15434 "configure"
+#line 15440 "configure"
@@ -15441,7 +15447,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:15445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15476,7 +15482,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15480: checking whether to use C++" >&5
+echo "configure:15486: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -15492,7 +15498,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15496: checking for $ac_word" >&5
+echo "configure:15502: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15521,7 +15527,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15525: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15531: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15532,12 +15538,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15536 "configure"
+#line 15542 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15563,19 +15569,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15567: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15573: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15572: checking whether we are using GNU C++" >&5
+echo "configure:15578: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15579: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15585: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15593,7 +15599,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15597: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15603: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15634,7 +15640,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15638: checking whether to use openDWG" >&5
+echo "configure:15644: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15654,7 +15660,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15658: checking for location of openDGW includes" >&5
+echo "configure:15664: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15680,15 +15686,15 @@
 do
-echo "configure:15684: checking for $ac_hdr" >&5
+echo "configure:15690: checking for $ac_hdr" >&5
-#line 15687 "configure"
+#line 15693 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15692: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15698: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15722,7 +15728,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15726: checking for location of openDWG library" >&5
+echo "configure:15732: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15769,7 +15775,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15773: checking for special C compiler options needed for large files" >&5
+echo "configure:15779: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15777,7 +15783,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15781 "configure"
+#line 15787 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15793,7 +15799,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15797: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15803: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -15802,7 +15808,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15806 "configure"
+#line 15812 "configure"
@@ -15818,7 +15824,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15822: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15828: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15838,11 +15844,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15842: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15848: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15846 "configure"
+#line 15852 "configure"
@@ -15858,14 +15864,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15862: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15868: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 15869 "configure"
+#line 15875 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15883,7 +15889,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15887: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15893: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15902,11 +15908,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15906: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15912: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15910 "configure"
+#line 15916 "configure"
@@ -15922,14 +15928,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15926: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15932: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15933 "configure"
+#line 15939 "configure"
 #define _LARGE_FILES 1
@@ -15947,7 +15953,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15951: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15957: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15966,25 +15972,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15970: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15976: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15974 "configure"
+#line 15980 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15981: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15988 "configure"
+#line 15994 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15993,7 +15999,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15997: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16003: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -16014,10 +16020,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16018: checking if system supports Large Files at all" >&5
+echo "configure:16024: checking if system supports Large Files at all" >&5
-#line 16021 "configure"
+#line 16027 "configure"
 #include <stdio.h>
@@ -16049,7 +16055,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:16053: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16059: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -16078,7 +16084,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16082: checking whether to use Python" >&5
+echo "configure:16088: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -16098,7 +16104,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:16102: checking for $ac_word" >&5
+echo "configure:16108: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -16140,15 +16146,15 @@
 do
-echo "configure:16144: checking for $ac_hdr" >&5
+echo "configure:16150: checking for $ac_hdr" >&5
-#line 16147 "configure"
+#line 16153 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16158: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16218,7 +16224,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16222: checking whether to use wxWidgets" >&5
+echo "configure:16228: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -16239,7 +16245,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16243: checking for $ac_word" >&5
+echo "configure:16249: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16287,7 +16293,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16291: checking wxWidgets version" >&5
+echo "configure:16297: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16310,15 +16316,15 @@
 do
-echo "configure:16314: checking for $ac_hdr" >&5
+echo "configure:16320: checking for $ac_hdr" >&5
-#line 16317 "configure"
+#line 16323 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16322: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in	2013-07-29 09:00:18 UTC (rev 57318)
+++ grass/branches/develbranch_6/configure.in	2013-07-29 09:41:20 UTC (rev 57319)
@@ -64,11 +64,11 @@
 AC_PATH_PROG(pwd, pwd, pwd)
-dnl if test "$MINGW32" = yes ; then
-dnl   winpwd="$pwd -W"
-dnl else
-dnl   winpwd="$pwd"
-dnl fi
+if test "$MINGW32" = yes ; then
+  winpwd="$pwd -W"
+else
+  winpwd="$pwd"
+fi
 AC_MSG_CHECKING(for source directory)
@@ -83,7 +83,7 @@
 AC_MSG_CHECKING(for build directory)
 DSTDIR=`$pwd`
-dnl WINDSTDIR=`$winpwd`
+WINDSTDIR=`$winpwd`
 AC_MSG_RESULT("$DSTDIR")
@@ -107,8 +107,7 @@
 # Set GISBASE and GRASS_BIN
-dnl GISBASE="${WINDSTDIR}/dist.${ARCH}"
-GISBASE="${DSTDIR}/dist.${ARCH}"
+GISBASE="${WINDSTDIR}/dist.${ARCH}"
 GRASS_BIN="${DSTDIR}/bin.${ARCH}"
 AC_SUBST(GISBASE)
