[GRASS-SVN] r56525 - grass-addons/grass7/raster/r.crater
svn_grass at osgeo.org
Sat Jun 1 05:53:41 PDT 2013
Author: ychemin
Date: 2013-06-01 05:53:41 -0700 (Sat, 01 Jun 2013)
New Revision: 56525
grass-addons/grass7/raster/r.crater/crater.c
removed computation code for Copyright issue, in reimplementation from book Chapter 7 of Melosh
Modified: grass-addons/grass7/raster/r.crater/crater.c
--- grass-addons/grass7/raster/r.crater/crater.c 2013-06-01 09:23:27 UTC (rev 56524)
+++ grass-addons/grass7/raster/r.crater/crater.c 2013-06-01 12:53:41 UTC (rev 56525)
@@ -1,171 +1,2 @@
-INFORMATION FROM THE ORIGINAL FORTRAN CODE
-//program crater
-//Short program to evaluate the scaling equations to determine
-//the diameter of a transient crater given details on the nature
-//of the projectile, conditions of impact, and state of the
-//target. The diameter is evaluated by three independent methods,
-//yield scaling, pi-scaling and Gault's semi-empirical relations
-//supplemented by rules on how crater size depends on gravity and
-//angle of impact.
-//Updated Nov. 1997 to compute projectile size from a given
-//transient crater diameter. Projectile and crater diameter
-//computation functions merged into a single program April 1998.
-//See Melosh, Impact Cratering, chapter 7 for more details
-//Updated Oct. 1999 to take final crater diameters as well as
-//transient crater diameters into account.
-//Copyright 1996, 1997 and 1998 by H. J. Melosh
-The original code was translated to Python @EGU2013 (20130410),
-then to C version @TRENTO GRASS meeting (20130414),
-into GRASS GIS @TRENTO GRASS meeting (20130416).
-Public domain - Yann Chemin
-#include<stdio.h>
-#include<stdlib.h>
-#include<math.h>
-int crater(double v, double theta, double rhotarget, double g, int targtype, double rhoproj, double L, double Dt, double Dfinal, int scaling_law, int return_time, int comptype){
- double pi=3.1415926535897932384626433;
- double third=1./3.;
- /*constants for the Schmidt-Holsapple pi scaling & gravity conversion factors*/
- double Cd[3]={1.88,1.54,1.6};
- double beta[3]={0.22,0.165,0.22};
- double gearth=9.8;
- double gmoon=1.67;
- double rhomoon=2700.;
- double Dstarmoon=1.8*pow(10,4);
- double Dprmoon=1.4*pow(10,5);
- //convert units to SI and compute some auxiliary quantites
- v=1000.*v; /*km/sec to m/sec*/
- theta=theta*(pi/180.); /*degrees to radians*/
- double anglefac=pow((sin(theta)),third); /*impact angle factor*/
- double densfac=pow(rhoproj,0.16667)/sqrt(rhotarget);
- double pifac=(1.61*g)/(v*v); /*inverse froude length factor*/
- double Ct=0.80; /*coefficient for formation time*/
- if(targtype == 1){
- Ct=1.3;
- double Dstar=(gmoon*rhomoon*Dstarmoon)/(g*rhotarget); /*transition crater diameter*/
- double Dpr =(gmoon*rhomoon*Dprmoon )/(g*rhotarget); /*peak-ring crater diameter*/
- double Dstd, Lpiscale, Lyield, Lgault; /*Default mode*/
- /* computation for specified projectile diameter*/
- double m, W, pitwo, dscale, Dpiscale, Dyield, gsmall, Dgault, Tform, Dsimple, size;
- char *cratertype;
- if(comptype == 1){
- m=(pi/6.)*rhoproj*pow(L,3); /*projectile mass*/
- W=0.5*m*v*v; /*projectile kinetic energy*/
- pitwo=pifac*L; /*inverse froude number*/
- dscale=pow((m/rhotarget),third); /*scale for crater diameter*/
- if(scaling_law==0){
- //Pi Scaling (Schmidt and Holsapple 1987)
- Dpiscale=dscale*Cd[targtype-1]*pow(pitwo,(-beta[targtype-1]));
- Dpiscale=Dpiscale*anglefac;
- size=Dpiscale;
- } else if(scaling_law==2){
- //Yield Scaling (Nordyke 1962) with small correction for depth of projectile penetration
- Dyield=0.0133*pow(W,(1/3.4))+1.51*sqrt(rhoproj/rhotarget)*L;
- Dyield=Dyield*anglefac*pow((gearth/g),0.165);
- size=Dyield;
- } else {
- //Gault (1974) Semi-Empirical scaling
- gsmall=0.25*densfac*pow(W,0.29)*anglefac;
- if(targtype == 3){
- gsmall=0.015*densfac*pow(W,0.37)*pow(anglefac,2);
- if(gsmall < 100.){
- Dgault=gsmall;
- }else{
- Dgault=0.27*densfac*pow(W,0.28)*anglefac;
- Dgault=Dgault*pow((gmoon/g),0.165);
- size=Dgault;
- if(return_time){
- /*Compute crater formation time from Schmidt and Housen*/
- Tform=(Ct*L/v)*pow(pitwo,-0.61);
- /*Compute final crater type and diameter from pi-scaled transient dia.*/
- Dsimple=1.56*Dpiscale;
- /* TODO: Return category */
- if (Dsimple < Dstar){
- Dfinal=Dsimple;
- cratertype="Simple";
- }else{
- Dfinal=pow(Dsimple,1.18)/pow(Dstar,0.18);
- cratertype="Complex";
- if((Dsimple < Dstar*1.4) && (Dsimple > Dstar*0.71)){
- cratertype="Simple/Complex";
- if(Dfinal > Dpr){
- cratertype="Peak-ring";
- /*Print out results*/
-// printf("Three scaling laws yield the following *transient*', crater diameters:\n");
-// printf("(note that diameters are measured at the pre-impact surface.\n");
-// printf("Rim-to-rim diameters are about 1.25X larger!)\n");
-// printf("Yield Scaling Dyield =%f m\n", Dyield);
-// printf("Pi Scaling (Preferred method!) Dpiscale =%f m\n", Dpiscale);
-// printf("Gault Scaling Dgault =%f m\n", Dgault);
-// printf("Crater Formation Time Tform =%f sec\n", Tform);
-// printf("Using the Pi-scaled transient crater, the *final* crater has\n");
-// printf("rim-to-rim diameter =%f km, and is of type %s\n",Dfinal/1000.,cratertype);
- /* Default Mode: Estimate projectile size from crater diameter */
- else{
- /*convert input crater rim-to-rim diameter to transient crater diameter*/
- if(Dt == 0.){
- if(Dfinal < Dstar){
- Dt=0.64*Dfinal;
- }else{
- Dt=0.64*pow((Dfinal*pow(Dstar,0.18)),0.8475);
- dscale=pow(((6.*rhotarget)/(pi*rhoproj)),third);
- /*Pi Scaling (Schmidt and Holsapple 1987)*/
- Dstd=Dt/anglefac;
- Lpiscale=(Dstd*dscale*pow(pifac,beta[targtype-1]))/Cd[targtype-1];
- Lpiscale=pow(Lpiscale,(1./(1.-beta[targtype-1])));
- size=Lpiscale;
- /*Yield Scaling (Nordyke 1962) without correction for projectile penetration depth.*/
- Dstd=(Dt*pow((g/gearth),0.165))/anglefac;
- W=pow((Dstd/0.0133),3.4);
- Lyield=pow(((12.*W)/(pi*rhoproj*v*v)),third);
- size=Lyield;
- } else {
- /*Gault (1974) Semi-Empirical scaling*/
- Dstd=Dt*pow((g/gmoon),0.165);
- if((Dstd <= 10.) && (targtype == 3)){
- W=pow(((Dstd/0.015)/(densfac*pow(anglefac,2))),2.70);
- }else if(Dstd < 300.){
- W=pow(((Dstd/0.25)/(densfac*anglefac)),3.45);
- }else{
- W=pow(((Dstd/0.27)/(densfac*anglefac)),3.57);
- Lgault=pow(((12.*W)/(pi*rhoproj*pow(v,2))),third);
- size=Lgault;
- if(return_time){
- /*Compute crater formation time for Pi-scaled diameter*/
- Tform=(Ct*Lpiscale/v)*pow((pifac*Lpiscale),-0.61);
-// printf("Three scaling laws yield the following projectile diameters:\n");
-// printf("(note that diameters assume a spherical projectile)\n");
-// printf("Yield Scaling Lyield =%f m\n",Lyield);
-// printf("Pi Scaling (Preferred method!) Lpiscale =%f m\n",Lpiscale);
-// printf("Gault Scaling Lgault =%f m\n",Lgault);
-// printf("Crater Formation Time Tform =%f sec\n",Tform);
- if(return_time) return (Tform);
- else return (size);
+/* Removed because of copyright */
+/* in reimplementation from the Chapter 7: Scaling of crater dimensions, from Melosh*/
