[GRASS-SVN] r56565 - in grass/trunk: include/defs lib/imagery
Sun Jun 2 14:33:07 PDT 2013
Author: mmetz
Date: 2013-06-02 14:33:07 -0700 (Sun, 02 Jun 2013)
New Revision: 56565
Added:
   grass/trunk/lib/imagery/georef_tps.c
   grass/trunk/include/defs/imagery.h
imagery lib: add thin plate spline coordinate transformation
Modified: grass/trunk/include/defs/imagery.h
--- grass/trunk/include/defs/imagery.h	2013-06-02 18:59:10 UTC (rev 56564)
+++ grass/trunk/include/defs/imagery.h	2013-06-02 21:33:07 UTC (rev 56565)
@@ -35,6 +35,12 @@
 			       double *, double *, int);
 int I_georef(double, double, double *, double *, double *, double *, int);
+/* georef_tps.c */
+int I_compute_georef_equations_tps(struct Control_Points *, double **, double **,
+			       double **, double **);
+int I_georef_tps(double, double, double *, double *, double *, double *,
+                 struct Control_Points *, int);
 /* group.c */
 int I_get_group(char *);
 int I_put_group(const char *);
Copied: grass/trunk/lib/imagery/georef_tps.c (from rev 56523, grass/trunk/lib/imagery/georef.c)
--- grass/trunk/lib/imagery/georef_tps.c	                        (rev 0)
+++ grass/trunk/lib/imagery/georef_tps.c	2013-06-02 21:33:07 UTC (rev 56565)
@@ -0,0 +1,494 @@
+ * MODULE:       imagery library
+ * AUTHOR(S):    Markus Metz
+ * PURPOSE:      Image processing library
+ * COPYRIGHT:    (C) 2013 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/imagery.h>
+#include <grass/glocale.h>
+#include <signal.h>
+/* STRUCTURE FOR USE INTERNALLY WITH THESE FUNCTIONS.  THESE FUNCTIONS EXPECT
+   SQUARE MATRICES SO ONLY ONE VARIABLE IS GIVEN (N) FOR THE MATRIX SIZE */
+struct MATRIX
+    int n;			/* SIZE OF THIS MATRIX (N x N) */
+    double *v;
+/* CALCULATE OFFSET INTO ARRAY BASED ON R/C */
+#define M(row,col) m->v[(((row)-1)*(m->n))+(col)-1]
+#define MSUCCESS     1		/* SUCCESS */
+#define MNPTERR      0		/* NOT ENOUGH POINTS */
+#define MUNSOLVABLE -1		/* NOT SOLVABLE */
+#define MMEMERR     -2		/* NOT ENOUGH MEMORY */
+#define MPARMERR    -3		/* PARAMETER ERROR */
+#define MINTERR     -4		/* INTERNAL ERROR */
+#define MAXORDER 3    /* HIGHEST SUPPORTED ORDER OF TRANSFORMATION */
+#ifndef MAX
+#define MAX(x,y) ((x) > (y) ? (x) : (y))
+#endif
+#ifndef MIN
+#define MIN(x,y) ((x) < (y) ? (x) : (y))
+#endif
+  FUNCTION PROTOTYPES FOR STATIC (INTERNAL) FUNCTIONS
+static int calccoef(struct Control_Points *, double **, double **);
+static int calcls(struct Control_Points *, struct MATRIX *, double *,
+		  double *, double *, double *);
+static double tps_base_func(const double x1, const double y1,
+                           const double x2, const double y2);
+static int solvemat(struct MATRIX *, double *, double *, double *, double *);
+  TRANSFORM A SINGLE COORDINATE PAIR.
+int I_georef_tps(double e1,    /* EASTING TO BE TRANSFORMED */
+	         double n1,    /* NORTHING TO BE TRANSFORMED */
+	         double *e,    /* EASTING, TRANSFORMED */
+	         double *n,    /* NORTHING, TRANSFORMED */
+	         double *E,    /* EASTING COEFFICIENTS */
+	         double *N,    /* NORTHING COEFFICIENTS */
+		 struct Control_Points *cp,
+		 int fwd
+    int  i, j;
+    double dist, *pe, *pn;
+    if (fwd) {
+	pe = cp->e1;
+	pn = cp->n1;
+    else {
+	pe = cp->e2;
+	pn = cp->n2;
+    /* global affine (1st order poly) */
+    *e = E[0] + e1 * E[1] + n1 * E[2];
+    *n = N[0] + e1 * N[1] + n1 * N[2];
+    for (i = 0, j = 0; i < cp->count; i++) {
+	if (cp->status[i] > 0) {
+	    dist = tps_base_func(e1, n1, pe[i], pn[i]);
+	    *e += E[j + 3] * dist;
+	    *n += N[j + 3] * dist;
+	    j++;
+    return MSUCCESS;
+  COMPUTE THE FORWARD AND BACKWARD GEOREFFERENCING COEFFICIENTS
+  BASED ON A SET OF CONTROL POINTS
+int I_compute_georef_equations_tps(struct Control_Points *cp,
+                                   double **E12tps, double **N12tps,
+				   double **E21tps, double **N21tps)
+    double *tempptr;
+    int numactive;		/* NUMBER OF ACTIVE CONTROL POINTS */
+    int status, i;
+    double xmax, xmin, ymax, ymin;
+    double delx, dely;
+    double xx, yy;
+    double sumx, sumy, sumx2, sumy2, sumxy;
+    double SSxx, SSyy, SSxy;
+    /* CALCULATE THE NUMBER OF VALID CONTROL POINTS */
+    for (i = numactive = 0; i < cp->count; i++) {
+	    numactive++;
+    if (numactive < 3)
+	return MNPTERR;
+    if (numactive > 100000)    /* arbitrary, admittedly */
+	return MNPTERR;
+    xmin = xmax = cp->e1[0];
+    ymin = ymax = cp->n1[0];
+    sumx = sumy = sumx2 = sumy2 = sumxy = 0.0;
+    for (i = 0; i < cp->count; i++ ) {
+	    xx = cp->e1[i];
+	    yy = cp->n1[i];
+	    xmax = MAX(xmax, xx);
+	    xmin = MIN(xmin, xx);
+	    ymax = MAX(ymax, yy);
+	    ymin = MIN(ymin, yy);
+	    sumx  += xx;
+	    sumx2 += xx * xx;
+	    sumy  += yy;
+	    sumy2 += yy * yy;
+	    sumxy += xx * yy;
+    delx = xmax - xmin;
+    dely = ymax - ymin;
+    SSxx = sumx2 - sumx * sumx / numactive;
+    SSyy = sumy2 - sumy * sumy / numactive;
+    SSxy = sumxy - sumx * sumy / numactive;
+    if (delx < 0.001 * dely || dely < 0.001 * delx ||
+        fabs(SSxy * SSxy / (SSxx * SSyy)) > 0.99) {
+	    /* points are colinear */
+	    return MUNSOLVABLE;
+    xmin = xmax = cp->e2[0];
+    ymin = ymax = cp->n2[0];
+	    xx = cp->e2[i];
+	    yy = cp->n2[i];
+	    sumx  += xx;
+	    sumx2 += xx * xx;
+	    sumy  += yy;
+	    sumy2 += yy * yy;
+	    sumxy += xx * yy;
+    /* CALCULATE THE FORWARD TRANSFORMATION COEFFICIENTS */
+    G_message(_("Calculating forward transformation coefficients"));
+    status = calccoef(cp, E12tps, N12tps);
+    if (status != MSUCCESS)
+	return status;
+    /* SWITCH THE 1 AND 2 EASTING AND NORTHING ARRAYS */
+    tempptr = cp->e1;
+    cp->e1 = cp->e2;
+    cp->e2 = tempptr;
+    tempptr = cp->n1;
+    cp->n1 = cp->n2;
+    cp->n2 = tempptr;
+    /* CALCULATE THE BACKWARD TRANSFORMATION COEFFICIENTS */
+    G_message(_("Calculating backward transformation coefficients"));
+    status = calccoef(cp, E21tps, N21tps);
+    /* SWITCH THE 1 AND 2 EASTING AND NORTHING ARRAYS BACK */
+    tempptr = cp->e1;
+    cp->e1 = cp->e2;
+    cp->e2 = tempptr;
+    tempptr = cp->n1;
+    cp->n1 = cp->n2;
+    cp->n2 = tempptr;
+    return status;
+  COMPUTE THE GEOREFFERENCING COEFFICIENTS
+static int calccoef(struct Control_Points *cp, double **E, double **N)
+    struct MATRIX m;
+    double *a;
+    double *b;
+    int status, i;
+	    numactive++;
+    /* INITIALIZE MATRIX */
+    m.n = numactive + 3;
+    m.v = G_calloc(m.n * m.n, sizeof(double));
+    if (m.v == NULL)
+	G_fatal_error(_("%s: out of memory"), "I_compute_georef_equations_tps()");
+    a = G_calloc(m.n, sizeof(double));
+    if (a == NULL)
+    b = G_calloc(m.n, sizeof(double));
+    if (b == NULL)
+    /* equation coefficients */
+    *E = G_calloc(m.n, sizeof(double));
+    if (*E == NULL)
+    *N = G_calloc(m.n, sizeof(double));
+    if (*N == NULL)
+    status = calcls(cp, &m, a, b, *E, *N);
+    G_free(m.v);
+    G_free(a);
+    G_free(b);
+    return status;
+  CALCULATE THE TRANSFORMATION COEFFICIENTS FOR THIN PLATE SPLINE
+  INTERPOLATION.
+  THIS ROUTINE USES THE LEAST SQUARES METHOD TO COMPUTE THE COEFFICIENTS.
+static int calcls(struct Control_Points *cp, struct MATRIX *m,
+                  double a[], double b[],
+		  double E[],	/* EASTING COEFFICIENTS */
+		  double N[]	/* NORTHING COEFFICIENTS */
+    int i, j, n, o, numactive = 0;
+    double dist = 0.0, dx, dy, regularization;
+    /* INITIALIZE THE MATRIX AND THE TWO COLUMN VECTORS */
+    for (i = 1; i <= m->n; i++) {
+	for (j = i; j <= m->n; j++) {
+	    M(i, j) = 0.0;
+	    if (i != j)
+		M(j, i) = 0.0;
+	a[i - 1] = b[i - 1] = 0.0;
+    /* SUM THE UPPER HALF OF THE MATRIX AND THE COLUMN VECTORS ACCORDING TO
+       THE LEAST SQUARES METHOD OF SOLVING OVER DETERMINED SYSTEMS */
+    for (n = 0; n < cp->count; n++) {
+	if (cp->status[n] > 0) {
+	    a[numactive + 3] = cp->e2[n];
+	    b[numactive + 3] = cp->n2[n];
+	    numactive++;
+	    M(1, numactive + 3) = 1.0;
+	    M(2, numactive + 3) = cp->e1[n];
+	    M(3, numactive + 3) = cp->n1[n];
+	    M(numactive + 3, 1) = 1.0;
+	    M(numactive + 3, 2) = cp->e1[n];
+	    M(numactive + 3, 3) = cp->n1[n];
+    if (numactive < m->n - 3)
+	return MINTERR;
+    i = 0;
+	    i++;
+	    j = 0;
+	    for (o = 0; o <= n; o++) {
+		if (cp->status[o] > 0) {
+		    j++;
+		    M(i + 3, j + 3) = tps_base_func(cp->e1[n], cp->n1[n],
+		                                    cp->e1[o], cp->n1[o]);
+		    if (i != j)
+			M(j + 3, i + 3) = M(i + 3, j + 3);
+		    dx = cp->e1[n] - cp->e1[o];
+		    dy = cp->n1[n] - cp->n1[o];
+		    dist += sqrt(dx * dx + dy * dy);
+    /* regularization */
+    dist /= (numactive * numactive);
+    regularization = 0.01 * dist * dist;
+    /* set diagonal to regularization, but not the first 3x3 (global affine) */
+    return solvemat(m, a, b, E, N);
+  SOLVE FOR THE 'E' AND 'N' COEFFICIENTS BY USING A SOMEWHAT MODIFIED
+  GAUSSIAN ELIMINATION METHOD.
+  | M11 M12 ... M1n | | E0   |   | a0   |
+  | M21 M22 ... M2n | | E1   | = | a1   |
+  | Mn1 Mn2 ... Mnn | | En-1 |   | an-1 |
+  and
+  | M11 M12 ... M1n | | N0   |   | b0   |
+  | M21 M22 ... M2n | | N1   | = | b1   |
+  | Mn1 Mn2 ... Mnn | | Nn-1 |   | bn-1 |
+static int solvemat(struct MATRIX *m, double a[], double b[], double E[],
+		    double N[])
+    int i, j, i2, j2, imark;
+    double factor, temp;
+    double pivot;		/* ACTUAL VALUE OF THE LARGEST PIVOT CANDIDATE */
+	G_percent(i - 1, m->n, 4);
+	j = i;
+	/* find row with largest magnitude value for pivot value */
+	pivot = M(i, j);
+	imark = i;
+	for (i2 = i + 1; i2 <= m->n; i2++) {
+	    temp = fabs(M(i2, j));
+	    if (temp > fabs(pivot)) {
+		pivot = M(i2, j);
+		imark = i2;
+	/* if the pivot is very small then the points are nearly co-linear */
+	/* co-linear points result in an undefined matrix, and nearly */
+	/* co-linear points results in a solution with rounding error */
+	if (pivot == 0.0)
+	/* if row with highest pivot is not the current row, switch them */
+	if (imark != i) {
+	    for (j2 = 1; j2 <= m->n; j2++) {
+		temp = M(imark, j2);
+		M(imark, j2) = M(i, j2);
+		M(i, j2) = temp;
+	    temp = a[imark - 1];
+	    a[imark - 1] = a[i - 1];
+	    a[i - 1] = temp;
+	    temp = b[imark - 1];
+	    b[imark - 1] = b[i - 1];
+	    b[i - 1] = temp;
+	/* compute zeros above and below the pivot, and compute
+	   values for the rest of the row as well */
+	for (i2 = 1; i2 <= m->n; i2++) {
+	    if (i2 != i) {
+		factor = M(i2, j) / pivot;
+		for (j2 = j; j2 <= m->n; j2++)
+		    M(i2, j2) -= factor * M(i, j2);
+		a[i2 - 1] -= factor * a[i - 1];
+		b[i2 - 1] -= factor * b[i - 1];
+    G_percent(1, 1, 1);
+    /* SINCE ALL OTHER VALUES IN THE MATRIX ARE ZERO NOW, CALCULATE THE
+       COEFFICIENTS BY DIVIDING THE COLUMN VECTORS BY THE DIAGONAL VALUES. */
+	E[i - 1] = a[i - 1] / M(i, i);
+	N[i - 1] = b[i - 1] / M(i, i);
+    return MSUCCESS;
+    /* official: r * r * log(r) */
+    double dist;
+    if ((x1 == x2) && (y1 == y2))
+	    return 0.0;
+    dist  = (x2 - x1) * (x2 - x1) + (y2 - y1) * (y2 - y1);
+    return dist * log(dist) * 0.5;
