[GRASS-SVN] r56583 - grass/branches/releasebranch_6_4/gui/wxpython/gui_core
svn_grass at osgeo.org
Tue Jun 4 01:25:23 PDT 2013
Author: annakrat
Date: 2013-06-04 01:25:22 -0700 (Tue, 04 Jun 2013)
New Revision: 56583
grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py
wxGUI: fix next issue in #1987 (merge from trunk, r56582)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py 2013-06-04 08:18:46 UTC (rev 56582)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_core/gselect.py 2013-06-04 08:25:22 UTC (rev 56583)
@@ -167,29 +167,17 @@
|wx.TR_FULL_ROW_HIGHLIGHT)
self.seltree.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
self.seltree.Bind(wx.EVT_MOTION, self.OnMotion)
- self.seltree.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown)
- self.seltree.Bind(wx.EVT_TREE_ITEM_EXPANDING, self.mapsetExpanded)
- self.seltree.Bind(wx.EVT_TREE_ITEM_COLLAPSED, self.mapsetCollapsed)
- self.seltree.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.mapsetActivated)
- self.seltree.Bind(wx.EVT_TREE_SEL_CHANGED, self.mapsetSelected)
+ self.seltree.Bind(wx.EVT_LEFT_DOWN, self.OnLeftDown)
+ # the following dummy handler are needed to keep tree events
+ # from propagating up to the parent GIS Manager layer tree
+ self.seltree.Bind(wx.EVT_TREE_ITEM_EXPANDING, lambda x: None)
+ self.seltree.Bind(wx.EVT_TREE_ITEM_COLLAPSED, lambda x: None)
+ self.seltree.Bind(wx.EVT_TREE_ITEM_ACTIVATED, lambda x: None)
+ self.seltree.Bind(wx.EVT_TREE_SEL_CHANGED, lambda x: None)
self.seltree.Bind(wx.EVT_TREE_DELETE_ITEM, lambda x: None)
self.seltree.Bind(wx.EVT_TREE_BEGIN_DRAG, lambda x: None)
- # the following dummy handler are needed to keep tree events from propagating up to
- # the parent GIS Manager layer tree
- def mapsetExpanded(self, event):
- pass
+ self.seltree.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, lambda x: None)
- def mapsetCollapsed(self, event):
- pass
- def mapsetActivated(self, event):
- pass
- def mapsetSelected(self, event):
- pass
- # end of dummy events
def GetControl(self):
return self.seltree
