[GRASS-SVN] r56596 - in grass/trunk: lib/python/temporal temporal/t.rast.aggregate.ds temporal/t.rast.to.rast3 temporal/t.vect.observe.strds
svn_grass at osgeo.org
Wed Jun 5 01:36:44 PDT 2013
Author: huhabla
Date: 2013-06-05 01:36:44 -0700 (Wed, 05 Jun 2013)
New Revision: 56596
grass/trunk/lib/python/temporal/abstract_dataset.py
grass/trunk/lib/python/temporal/abstract_map_dataset.py
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/list.py
grass/trunk/lib/python/temporal/sampling.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/spatial_extent.py
grass/trunk/lib/python/temporal/spatio_temporal_relationships.py
grass/trunk/lib/python/temporal/stds_export.py
grass/trunk/lib/python/temporal/temporal_extent.py
grass/trunk/lib/python/temporal/temporal_granularity.py
grass/trunk/lib/python/temporal/unit_tests.py
grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh
Added spatial and temporal extent intersection, union and disjoint union. Renamed some functions.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -170,9 +170,34 @@
@param dataset The abstract dataset to check spatial overlapping
@return True if self and the provided dataset spatial overlap
+ raise ImplementationError("This method must be implemented in the subclasses")
+ def spatial_intersection(self, dataset):
+ """!Return the spatial intersection as spatial_extent
+ object or None in case no intersection was found.
+ @param dataset The abstract dataset to intersect with
+ @return The intersection spatial extent
+ def spatial_union(self, dataset):
+ """!Return the spatial union as spatial_extent
+ object or None in case the extents does not overlap or meet.
+ @param dataset The abstract dataset to create a union with
+ @return The union spatial extent
+ def spatial_disjoint_union(self, dataset):
+ """!Return the spatial union as spatial_extent object.
def spatial_relation(self, dataset):
"""!Return the spatial relationship between self and dataset
@@ -196,10 +221,7 @@
def set_id(self, ident):
self.base.set_id(ident)
- if self.is_time_absolute():
- self.absolute_time.set_id(ident)
- if self.is_time_relative():
- self.relative_time.set_id(ident)
+ self.temporal_extent.set_id(ident)
self.spatial_extent.set_id(ident)
self.metadata.set_id(ident)
@@ -221,7 +243,7 @@
return self.base.get_mapset()
- def get_valid_time(self):
+ def get_temporal_extent_as_tuple(self):
"""!Returns a tuple of the valid start and end time
Start and end time can be either of type datetime or of type integer,
@@ -229,17 +251,8 @@
@return A tuple of (start_time, end_time)
- start = None
- end = None
- start = self.absolute_time.get_start_time()
- end = self.absolute_time.get_end_time()
- start = self.relative_time.get_start_time()
- end = self.relative_time.get_end_time()
+ start = self.temporal_extent.get_start_time()
+ end = self.temporal_extent.get_end_time()
return (start, end)
def get_absolute_time(self):
@@ -309,14 +322,14 @@
return self.base.get_ttype()
- def get_spatial_extent(self):
+ def get_spatial_extent_as_tuple(self):
"""!Return the spatial extent as tuple
Top and bottom are set to 0 in case of a two dimensional spatial extent.
@return A the spatial extent as tuple (north, south, east, west, top, bottom)
- return self.spatial_extent.get_spatial_extent()
+ return self.spatial_extent.get_spatial_extent_as_tuple()
def select(self, dbif=None):
"""!Select temporal dataset entry from database and fill
@@ -332,10 +345,7 @@
dbif, connected = init_dbif(dbif)
self.base.select(dbif)
- self.absolute_time.select(dbif)
- self.relative_time.select(dbif)
+ self.temporal_extent.select(dbif)
self.spatial_extent.select(dbif)
self.metadata.select(dbif)
@@ -368,12 +378,7 @@
# Build the INSERT SQL statement
statement = self.base.get_insert_statement_mogrified(dbif)
- statement += self.absolute_time.get_insert_statement_mogrified(
- dbif)
- statement += self.relative_time.get_insert_statement_mogrified(
- dbif)
+ statement += self.temporal_extent.get_insert_statement_mogrified(dbif)
statement += self.spatial_extent.get_insert_statement_mogrified(dbif)
statement += self.metadata.get_insert_statement_mogrified(dbif)
@@ -403,12 +408,8 @@
# Build the UPDATE SQL statement
statement = self.base.get_update_statement_mogrified(dbif, ident)
- statement += self.absolute_time.get_update_statement_mogrified(
- dbif, ident)
- statement += self.relative_time.get_update_statement_mogrified(
- dbif, ident)
+ statement += self.temporal_extent.get_update_statement_mogrified(dbif,
+ ident)
statement += self.spatial_extent.get_update_statement_mogrified(dbif,
ident)
statement += self.metadata.get_update_statement_mogrified(dbif, ident)
@@ -439,12 +440,8 @@
statement = self.base.get_update_all_statement_mogrified(dbif, ident)
- statement += self.absolute_time.get_update_all_statement_mogrified(
- dbif, ident)
- statement += self.relative_time.get_update_all_statement_mogrified(
- dbif, ident)
+ statement += self.temporal_extent.get_update_all_statement_mogrified(dbif,
+ ident)
statement += self.spatial_extent.get_update_all_statement_mogrified(
dbif, ident)
statement += self.metadata.get_update_all_statement_mogrified(dbif, ident)
@@ -486,32 +483,55 @@
return self.base.get_ttype() == "relative"
else:
return None
+ def _get_temporal_extent(self):
+ """!Return the temporal extent of the correct internal type
+ if self.is_time_absolute():
+ return self.absolute_time
+ if self.is_time_relative():
+ return self.relative_time
+ return None
+ temporal_extent = property(fget=_get_temporal_extent)
def temporal_relation(self, dataset):
"""!Return the temporal relation of self and the provided dataset
@return The temporal relation as string
- if self.is_time_absolute() and dataset.is_time_absolute():
- return self.absolute_time.temporal_relation(dataset.absolute_time)
- if self.is_time_relative() and dataset.is_time_relative():
- return self.relative_time.temporal_relation(dataset.relative_time)
- return None
+ return self.temporal_extent.temporal_relation(dataset.temporal_extent)
def temporal_intersection(self, dataset):
- """!Intersect self with the provided datasetand
+ """!Intersect self with the provided dataset and
return a new temporal extent with the new start and end time
@param dataset The abstract dataset to temporal intersect with
@return The new temporal extent with start and end time,
or None in case of no intersection
- return self.absolute_time.intersect(dataset.absolute_time)
- return self.relative_time.intersect(dataset.relative_time)
- return None
+ return self.temporal_extent.intersect(dataset.temporal_extent)
+ def temporal_union(self, dataset):
+ """!Creates a union with the provided dataset and
+ return a new temporal extent with the new start and end time.
+ @param dataset The abstract dataset to create temporal union with
+ @return The new temporal extent with start and end time,
+ or None in case of no intersection
+ return self.temporal_extent.union(dataset.temporal_extent)
+ def temporal_disjoint_union(self, dataset):
+ return self.temporal_extent.disjoint_union(dataset.temporal_extent)
class AbstractDatasetComparisonKeyStartTime(object):
@@ -531,33 +551,33 @@
self.obj = obj
def __lt__(self, other):
- startA, endA = self.obj.get_valid_time()
- startB, endB = other.obj.get_valid_time()
+ startA, endA = self.obj.get_temporal_extent_as_tuple()
+ startB, endB = other.obj.get_temporal_extent_as_tuple()
return startA < startB
def __gt__(self, other):
return startA > startB
def __eq__(self, other):
return startA == startB
def __le__(self, other):
return startA <= startB
def __ge__(self, other):
return startA >= startB
def __ne__(self, other):
return startA != startB
@@ -579,33 +599,33 @@
self.obj = obj
return endA < endB
return endA > endB
return endA == endB
return endA <= endB
return endA >= endB
return endA != endB
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -219,10 +219,7 @@
print " +-------------------- Vector Dataset ----------------------------------------+"
print " | |"
self.base.print_info()
- self.absolute_time.print_info()
- self.relative_time.print_info()
+ self.temporal_extent.print_info()
if self.is_topology_build():
self.print_topology_info()
self.spatial_extent.print_info()
@@ -246,10 +243,7 @@
def print_shell_info(self):
"""!Print information about this object in shell style"""
self.base.print_shell_info()
- self.absolute_time.print_shell_info()
- self.relative_time.print_shell_info()
+ self.temporal_extent.print_shell_info()
self.spatial_extent.print_shell_info()
self.metadata.print_shell_info()
datasets = self.get_registered_datasets()
@@ -494,8 +488,8 @@
self.spatial_extent.set_spatial_extent(
- def check_valid_time(self):
- """!Check for correct valid time"""
+ def check_for_correct_time(self):
+ """!Check for correct time"""
start, end, tz = self.get_absolute_time()
else:
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -84,10 +84,7 @@
def print_self(self):
"""!Print the content of the internal structure to stdout"""
self.base.print_self()
- self.absolute_time.print_self()
- self.relative_time.print_self()
+ self.temporal_extent.print_self()
self.spatial_extent.print_self()
self.metadata.print_self()
@@ -108,10 +105,7 @@
print " +-------------------- Space Time Vector Dataset -----------------------------+"
print " | |"
self.metadata.print_info()
print " +----------------------------------------------------------------------------+"
@@ -119,10 +113,7 @@
"""!Print information about this class in shell style"""
@@ -241,15 +232,8 @@
@return The granularity
- temporal_type = self.get_temporal_type()
+ return self.temporal_extent.get_granularity()
- if temporal_type == "absolute":
- granularity = self.absolute_time.get_granularity()
- elif temporal_type == "relative":
- granularity = self.relative_time.get_granularity()
- return granularity
def set_granularity(self, granularity):
"""!Set the granularity
@@ -275,12 +259,12 @@
self.set_time_to_absolute()
- self.absolute_time.set_granularity(granularity)
self.set_time_to_relative()
- self.relative_time.set_granularity(granularity)
else:
core.fatal(_("Unknown temporal type \"%s\"") % (temporal_type))
+ self.temporal_extent.set_granularity(granularity)
def set_relative_time_unit(self, unit):
"""!Set the relative time unit which may be of type:
@@ -305,15 +289,8 @@
def get_map_time(self):
"""!Return the type of the map time, interval, point, mixed or invalid"""
+ return self.temporal_extent.get_map_time()
- map_time = self.absolute_time.get_map_time()
- map_time = self.relative_time.get_map_time()
- return map_time
def count_temporal_types(self, maps=None, dbif=None):
"""!Return the temporal type of the registered maps as dictionary
@@ -666,7 +643,7 @@
# Read the spatial extent
if spatial:
granule.spatial_extent.select(dbif)
- start, end = granule.get_valid_time()
+ start, end = granule.get_temporal_extent_as_tuple()
where = create_temporal_relation_sql_where_statement(
start, end, use_start,
@@ -762,7 +739,7 @@
if not check:
core.fatal(_("Wrong granularity: \"%s\"") % str(gran))
- start, end = self.get_valid_time()
+ start, end = self.get_temporal_extent_as_tuple()
if start is None or end is None:
return None
@@ -932,8 +909,8 @@
if i < len(maps) - 1:
relation = maps[i + 1].temporal_relation(maps[i])
if relation == "after":
- start1, end1 = maps[i].get_valid_time()
- start2, end2 = maps[i + 1].get_valid_time()
+ start1, end1 = maps[i].get_temporal_extent_as_tuple()
+ start2, end2 = maps[i + 1].get_temporal_extent_as_tuple()
end = start2
if end1 is not None:
start = end1
@@ -1133,7 +1110,7 @@
# in the middle of the update process when the increment
# results in wrong number of days in a month
for map in maps:
- start, end = map.get_valid_time()
+ start, end = map.get_temporal_extent_as_tuple()
start = increment_datetime_by_string(start, gran)
@@ -1172,8 +1149,8 @@
date_list = []
for i in range(len(maps) - 1):
- start, end = maps[i].get_valid_time()
- start_next, end = maps[i + 1].get_valid_time()
+ start, end = maps[i].get_temporal_extent_as_tuple()
+ start_next, end = maps[i + 1].get_temporal_extent_as_tuple()
# Maps with equal time stamps can not be snapped
if start != start_next:
@@ -1183,7 +1160,7 @@
date_list.append((start, end))
# Last map
- start, end = maps[-1].get_valid_time()
+ start, end = maps[-1].get_temporal_extent_as_tuple()
# We increment the start time with the dataset
# granularity if the end time is None
if end is None:
@@ -1391,7 +1368,7 @@
# First select all data from the database
map.select(dbif)
- if not map.check_valid_time():
+ if not map.check_for_correct_time():
if map.get_layer():
core.fatal(_("Map <%s> with layer %s has invalid time")
% (map.get_map_id(), map.get_layer()))
@@ -1874,26 +1851,15 @@
gran = None
# Set the map time type and update the time objects
- self.metadata.select(dbif)
- if self.metadata.get_number_of_maps() > 0:
- self.absolute_time.set_map_time(map_time)
- self.absolute_time.set_granularity(gran)
- else:
- self.absolute_time.set_map_time(None)
- self.absolute_time.set_granularity(None)
- self.absolute_time.update_all(dbif)
+ self.metadata.select(dbif)
+ if self.metadata.get_number_of_maps() > 0:
+ self.temporal_extent.set_map_time(map_time)
+ self.temporal_extent.set_granularity(gran)
else:
- self.relative_time.set_map_time(map_time)
- self.relative_time.set_granularity(gran)
- else:
- self.relative_time.set_map_time(None)
- self.relative_time.set_granularity(None)
- self.relative_time.update_all(dbif)
+ self.temporal_extent.set_map_time(None)
+ self.temporal_extent.set_granularity(None)
+ self.temporal_extent.update_all(dbif)
if connected:
dbif.close()
Modified: grass/trunk/lib/python/temporal/list.py
--- grass/trunk/lib/python/temporal/list.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/list.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -105,12 +105,12 @@
if isinstance(maps[0], list):
if len(maps[0]) > 0:
- first_time, dummy = maps[0][0].get_valid_time()
+ first_time, dummy = maps[0][0].get_temporal_extent_as_tuple()
else:
core.warning(_("Empty map list."))
return
else:
- first_time, dummy = maps[0].get_valid_time()
+ first_time, dummy = maps[0].get_temporal_extent_as_tuple()
for mymap in maps:
@@ -122,7 +122,7 @@
else:
map = mymap
if end:
delta = end - start
else:
Modified: grass/trunk/lib/python/temporal/sampling.py
--- grass/trunk/lib/python/temporal/sampling.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/sampling.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -122,7 +122,7 @@
string += "%s" % ("distance_from_begin")
print string
- first_time, dummy = mapmatrizes[0][0]["granule"].get_valid_time()
+ first_time, dummy = mapmatrizes[0][0]["granule"].get_temporal_extent_as_tuple()
for i in range(len(mapmatrizes[0])):
mapname_list = []
@@ -141,7 +141,7 @@
entry = mapmatrizes[0][i]
map = entry["granule"]
if end:
delta = end - start
else:
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -97,7 +97,7 @@
>>> rmap.get_stds_register()
>>> rmap.get_absolute_time()
(datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2012, 1, 1, 0, 0), None)
- >>> rmap.get_valid_time()
+ >>> rmap.get_temporal_extent_as_tuple()
(datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2012, 1, 1, 0, 0))
>>> rmap.get_name()
'strds_map_test_case'
@@ -105,7 +105,7 @@
True
>>> rmap.get_temporal_type()
'absolute'
- >>> rmap.get_spatial_extent()
+ >>> rmap.get_spatial_extent_as_tuple()
(80.0, 0.0, 120.0, 0.0, 0.0, 0.0)
>>> rmap.is_time_absolute()
True
@@ -146,14 +146,38 @@
def spatial_overlapping(self, dataset):
"""!Return True if the spatial extents 2d overlap"""
return self.spatial_extent.overlapping_2d(dataset.spatial_extent)
"""!Return the two dimensional spatial relation"""
return self.spatial_extent.spatial_relation_2d(dataset.spatial_extent)
+ """!Return the two dimensional intersection as spatial_extent
+ @return The intersection spatial extent or None
+ return self.spatial_extent.intersect_2d(dataset.spatial_extent)
+ """!Return the two dimensional union as spatial_extent
+ @return The union spatial extent or None
+ return self.spatial_extent.union_2d(dataset.spatial_extent)
+ """!Return the two dimensional union as spatial_extent object.
+ return self.spatial_extent.disjoint_union_2d(dataset.spatial_extent)
def get_np_array(self):
"""!Return this raster map as memmap numpy style array to access the raster
values in numpy style without loading the whole map in the RAM.
@@ -382,7 +406,6 @@
"""!Return True if the spatial extents overlap"""
if self.get_type() == dataset.get_type() or dataset.get_type() == "str3ds":
return self.spatial_extent.overlapping(dataset.spatial_extent)
else:
@@ -390,12 +413,46 @@
"""!Return the two or three dimensional spatial relation"""
return self.spatial_extent.spatial_relation(dataset.spatial_extent)
else:
+ """!Return the three or two dimensional intersection as spatial_extent
+ if self.get_type() == dataset.get_type() or dataset.get_type() == "str3ds":
+ return self.spatial_extent.intersect(dataset.spatial_extent)
+ else:
+ """!Return the three or two dimensional union as spatial_extent
+ return self.spatial_extent.union(dataset.spatial_extent)
+ else:
+ """!Return the three or two dimensional union as spatial_extent object.
+ return self.spatial_extent.disjoint_union(dataset.spatial_extent)
+ else:
"""!Return this 3D raster map as memmap numpy style array to access the 3D raster
@@ -638,6 +695,32 @@
def reset(self, ident):
"""!Reset the internal structure and set the identifier"""
self.base = VectorBase(ident=ident)
@@ -862,14 +945,38 @@
@@ -926,6 +1033,41 @@
else:
+ if self.get_type() == dataset.get_type() or dataset.get_type() == "raster3d":
+ else:
+ else:
+ else:
@@ -968,14 +1110,38 @@
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/spatial_extent.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -198,10 +198,10 @@
def intersect_2d(self, extent):
- object or None in case no intersection was found.
@param extent The spatial extent to intersect with
- @return The intersection spatial extent
if not self.overlapping_2d(extent):
@@ -342,7 +342,181 @@
new.set_bottom(nB)
return new
+ def union_2d(self, extent):
+ @param extent The spatial extent to create a union with
+ if not self.overlapping_2d(extent) and not self.meet_2d(extent):
+ return None
+ return self.disjoint_union_2d(extent)
+ def disjoint_union_2d(self, extent):
+ """!Return the two dimensional union as spatial_extent.
+ eN = extent.get_north()
+ eS = extent.get_south()
+ eE = extent.get_east()
+ eW = extent.get_west()
+ N = self.get_north()
+ S = self.get_south()
+ E = self.get_east()
+ W = self.get_west()
+ # Adjust the east and west in case of LL projection
+ if self.get_projection() == "LL":
+ while eE < W:
+ eE += 360.0
+ eW += 360.0
+ while eW > E:
+ eE -= 360.0
+ eW -= 360.0
+ # Compute the extent
+ nN = N
+ nS = S
+ nE = E
+ nW = W
+ if W > eW:
+ nW = eW
+ if E < eE:
+ nE = eE
+ if N < eN:
+ nN = eN
+ if S > eS:
+ nS = eS
+ new = SpatialExtent(north=nN, south=nS, east=nE, west=nW,
+ top=0, bottom=0, proj=self.get_projection())
+ return new
+ def union(self, extent):
+ """!Return the three dimensional union as spatial_extent
+ if not self.overlapping(extent) and not self.meet(extent):
+ return None
+ return self.disjoint_union(extent)
+ def disjoint_union(self, extent):
+ """!Return the three dimensional union as spatial_extent .
+ Usage:
+ @code
+ >>> A = SpatialExtent(north=80, south=20, east=60, west=10,
+ ... bottom=-50, top=50)
+ >>> B = SpatialExtent(north=80, south=20, east=60, west=10,
+ >>> C = A.disjoint_union(B)
+ >>> C.print_info()
+ +-------------------- Spatial extent ----------------------------------------+
+ | North:...................... 80.0
+ | South:...................... 20.0
+ | East:.. .................... 60.0
+ | West:....................... 10.0
+ | Top:........................ 50.0
+ | Bottom:..................... -50.0
+ >>> B = SpatialExtent(north=40, south=30, east=60, west=10,
+ >>> B = SpatialExtent(north=40, south=30, east=60, west=30,
+ ... bottom=-30, top=50)
+ ... bottom=-30, top=30)
+ >>> B = SpatialExtent(north=90, south=80, east=70, west=20,
+ ... bottom=-30, top=60)
+ | North:...................... 90.0
+ | East:.. .................... 70.0
+ | Top:........................ 60.0
+ @endcode
+ @param extent The spatial extent to create a disjoint union with
+ new = self.disjoint_union_2d(extent)
+ eT = extent.get_top()
+ eB = extent.get_bottom()
+ T = self.get_top()
+ B = self.get_bottom()
+ nT = T
+ nB = B
+ if B > eB:
+ nB = eB
+ if T < eT:
+ nT = eT
+ new.set_top(nT)
+ new.set_bottom(nB)
+ return new
def is_in_2d(self, extent):
"""!Return True if this extent (A) is located in the provided spatial
extent (B) in two dimensions.
@@ -1497,7 +1671,7 @@
area = self.get_area()
- bbox = self.get_spatial_extent()
+ bbox = self.get_spatial_extent_as_tuple()
z = abs(bbox[4] - bbox[5])
@@ -1513,14 +1687,14 @@
core.error(_("Area computation is not supported "
"for LL projections"))
y = abs(bbox[0] - bbox[1])
x = abs(bbox[2] - bbox[3])
return x * y
"""!Return a tuple (north, south, east, west, top, bottom)
of the spatial extent"""
@@ -1528,7 +1702,7 @@
self.north, self.south, self.east, self.west,
self.top, self.bottom)
- def get_spatial_extent_2d(self):
+ def get_spatial_extent_as_tuple_2d(self):
"""!Return a tuple (north, south, east, west,) of the 2d spatial extent
return (self.north, self.south, self.east, self.west)
Modified: grass/trunk/lib/python/temporal/spatio_temporal_relationships.py
--- grass/trunk/lib/python/temporal/spatio_temporal_relationships.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/spatio_temporal_relationships.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -162,7 +162,7 @@
rect = vector.RTreeAllocRect(tree)
- start, end = map_.get_valid_time()
+ start, end = map_.get_temporal_extent_as_tuple()
if not end:
end = start
@@ -174,11 +174,11 @@
if spatial is None:
vector.RTreeSetRect1D(rect, tree, float(start), float(end))
elif spatial == "2D":
- north, south, east, west, top, bottom = map_.get_spatial_extent()
+ north, south, east, west, top, bottom = map_.get_spatial_extent_as_tuple()
vector.RTreeSetRect3D(rect, tree, west, east, south, north,
elif spatial == "3D":
vector.RTreeSetRect4D(rect, tree, west, east, south, north,
bottom, top, float(start), float(end))
Modified: grass/trunk/lib/python/temporal/stds_export.py
--- grass/trunk/lib/python/temporal/stds_export.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/stds_export.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -320,7 +320,7 @@
if sp.is_time_relative():
string += "%s=%s\n" % ("relative_time_unit", sp.get_relative_time_unit())
string += "%s=%s\n" % ("number_of_maps", sp.metadata.get_number_of_maps())
- north, south, east, west, top, bottom = sp.get_spatial_extent()
+ north, south, east, west, top, bottom = sp.get_spatial_extent_as_tuple()
string += "%s=%s\n" % ("north", north)
string += "%s=%s\n" % ("south", south)
string += "%s=%s\n" % ("east", east)
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/temporal_extent.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -195,7 +195,186 @@
end = self.D["end_time"]
return AbstractTemporalExtent(start_time=start, end_time=end)
+ """!Creates a disjoint union with this temporal extent and the provided one.
+ Return a new temporal extent with the new start and end time.
+ @param extent The temporal extent to create a union with
+ Usage:
+ @code
+ >>> A = AbstractTemporalExtent(start_time=5, end_time=6 )
+ >>> inter = A.intersect(A)
+ >>> inter.print_info()
+ | Start time:................. 5
+ | End time:................... 6
+ >>> B = AbstractTemporalExtent(start_time=5, end_time=7 )
+ >>> inter = A.disjoint_union(B)
+ | End time:................... 7
+ >>> inter = B.disjoint_union(A)
+ >>> A = AbstractTemporalExtent(start_time=3, end_time=6 )
+ | Start time:................. 3
+ >>> A = AbstractTemporalExtent(start_time=3, end_time=8 )
+ >>> B = AbstractTemporalExtent(start_time=5, end_time=6 )
+ | End time:................... 8
+ >>> A = AbstractTemporalExtent(start_time=5, end_time=8 )
+ >>> B = AbstractTemporalExtent(start_time=3, end_time=6 )
+ >>> A = AbstractTemporalExtent(start_time=5, end_time=None )
+ >>> B = AbstractTemporalExtent(start_time=3, end_time=4 )
+ >>> B = AbstractTemporalExtent(start_time=3, end_time=None )
+ >>> B = AbstractTemporalExtent(start_time=3, end_time=8 )
+ | End time:................... 5
+ @endcoe
+ start = None
+ end = None
+ if self.D["start_time"] < extent.D["start_time"]:
+ start = self.D["start_time"]
+ else:
+ start = extent.D["start_time"]
+ # End time handling
+ if self.D["end_time"] is None and extent.D["end_time"] is None:
+ if self.D["start_time"] > extent.D["start_time"]:
+ end = self.D["start_time"]
+ else:
+ end = extent.D["start_time"]
+ elif self.D["end_time"] is None:
+ if self.D["start_time"] > extent.D["end_time"]:
+ else:
+ end = extent.D["end_time"]
+ elif extent.D["end_time"] is None:
+ if self.D["end_time"] > extent.D["start_time"]:
+ end = self.D["end_time"]
+ else:
+ elif self.D["end_time"] < extent.D["end_time"]:
+ else:
+ return AbstractTemporalExtent(start_time=start, end_time=end)
+ """!Creates a union with this temporal extent and the provided one.
+ or None in case the temporal extents are unrelated (before or after)
+ @code
+ >>> inter = A.intersect(B)
+ >>> print inter
+ None
+ >>> print inter
+ None
+ @endcode
+ relation = self.temporal_relation(extent)
+ if relation == "after" or relation == "before":
+ return None
def starts(self, extent):
"""!Return True if this temporal extent (A) starts at the start of the
provided temporal extent (B) and finishes within it
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -202,7 +202,7 @@
delta = []
# First we compute the timedelta of the intervals
for map in maps:
if start and end:
t = abs(end - start)
delta.append(int(t))
@@ -212,8 +212,8 @@
# Gaps are between intervals, intervals and
# points, points and points
if end1 and start2:
@@ -338,7 +338,7 @@
datetime_delta = []
for map in maps:
if start and end:
delta.append(end - start)
datetime_delta.append(compute_datetime_delta(start, end))
@@ -348,8 +348,8 @@
if end1 and start2:
Modified: grass/trunk/lib/python/temporal/unit_tests.py
--- grass/trunk/lib/python/temporal/unit_tests.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/lib/python/temporal/unit_tests.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -1495,11 +1495,11 @@
print "Original"
for _map in map_list:
- print _map.get_valid_time()[0], _map.get_valid_time()[1]
+ print _map.get_temporal_extent_as_tuple()[0], _map.get_temporal_extent_as_tuple()[1]
print "Sorted by start time"
new_list = sorted(map_list, key=AbstractDatasetComparisonKeyStartTime)
for _map in new_list:
if new_list[0] != map_list[1]:
core.fatal("Sorting by start time failed")
@@ -1511,7 +1511,7 @@
print "Sorted by end time"
new_list = sorted(map_list, key=AbstractDatasetComparisonKeyEndTime)
core.fatal("Sorting by end time failed")
Modified: grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
--- grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -121,12 +121,7 @@
"the same temporal type"))
# Check if intervals are present
- if sampler_sp.get_temporal_type() == "absolute":
- map_time = sampler_sp.absolute_time.get_map_time()
- else:
- map_time = sampler_sp.relative_time.get_map_time()
- if map_time != "interval":
+ if sample.temporal_extent.get_map_time() != "interval":
dbif.close()
grass.fatal(_("All registered maps of the aggregation dataset "
"must have time intervals"))
Modified: grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2013-06-05 08:36:44 UTC (rev 56596)
@@ -80,7 +80,7 @@
# Compatible temporal units are : days, hours, minutes and seconds
# Incompatible are years and moths
- start, end = sp.get_valid_time()
+ start, end = sp.get_temporal_extent_as_tuple()
if sp.is_time_absolute():
unit = granularity.split(" ")[1]
@@ -164,7 +164,7 @@
else:
id = output + "@" + mapset
r3ds = tgis.Raster3DDataset(id)
if r3ds.is_in_db():
Modified: grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh
--- grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh 2013-06-04 19:31:49 UTC (rev 56595)
+++ grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.sh 2013-06-05 08:36:44 UTC (rev 56596)
@@ -5,17 +5,19 @@
# The region setting should work for UTM and LL test locations
g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
-r.mapcalc --o expr="prec_1 = 100.0"
-r.mapcalc --o expr="prec_2 = 200.0"
-r.mapcalc --o expr="prec_3 = 300"
-r.mapcalc --o expr="prec_4 = 400"
-r.mapcalc --o expr="prec_5 = 500.0"
-r.mapcalc --o expr="prec_6 = 600.0"
+export GRASS_OVERWRITE=1
-v.random --o output=prec n=5 seed=1
-v.random --o -z output=test_1 column=test n=5 seed=1
+r.mapcalc expr="prec_1 = 100.0"
+r.mapcalc expr="prec_2 = 200.0"
+r.mapcalc expr="prec_3 = 300"
+r.mapcalc expr="prec_4 = 400"
+r.mapcalc expr="prec_5 = 500.0"
+r.mapcalc expr="prec_6 = 600.0"
-t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+v.random output=prec n=5 seed=1
+v.random -z output=test_1 column=test n=5 seed=1
+t.create type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
t.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
# The @test
