[GRASS-SVN] r56602 - in grass-addons/grass7/vector: . v.net.salesman2
Wed Jun 5 04:12:03 PDT 2013
Author: turek
Date: 2013-06-05 04:12:02 -0700 (Wed, 05 Jun 2013)
New Revision: 56602
Added:
   grass-addons/grass7/vector/v.net.salesman2/
   grass-addons/grass7/vector/v.net.salesman2/Makefile
   grass-addons/grass7/vector/v.net.salesman2/main.c
   grass-addons/grass7/vector/v.net.salesman2/v.net.salesman2.html
   grass-addons/grass7/vector/v.net.salesman2/vnetsalesman.png
   grass-addons/grass7/vector/v.net.salesman2/vnetsalesmantime.png
v.net.salesman2: dev version of v.net.salesman module with turns support
Added: grass-addons/grass7/vector/v.net.salesman2/Makefile
--- grass-addons/grass7/vector/v.net.salesman2/Makefile	                        (rev 0)
+++ grass-addons/grass7/vector/v.net.salesman2/Makefile	2013-06-05 11:12:02 UTC (rev 56602)
@@ -0,0 +1,17 @@
+MODULE_TOPDIR = ../..
+PGM = v.net.salesman2
+LIBES = $(VECTORLIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/vector/v.net.salesman2/main.c
--- grass-addons/grass7/vector/v.net.salesman2/main.c	                        (rev 0)
+++ grass-addons/grass7/vector/v.net.salesman2/main.c	2013-06-05 11:12:02 UTC (rev 56602)
@@ -0,0 +1,641 @@
+ *  MODULE:       v.net.salesman2
+ *  AUTHOR(S):    Radim Blazek, Markus Metz
+ *  PURPOSE:      Create a cycle connecting given nodes.
+ *  COPYRIGHT:    (C) 2001-2011, 2013 by the GRASS Development Team
+ *                This program is free software under the
+ *                GNU General Public License (>=v2).
+ *                Read the file COPYING that comes with GRASS
+ *                for details.
+#include <stdlib.h>
+#include <string.h>
+#include <time.h>
+#include <grass/gis.h>
+#include <grass/vector.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
+/* TODO: Use some better algorithm */
+typedef struct
+    int city;
+    double cost;
+} COST;
+int ncities;			/* number of cities */
+int nnodes;			/* number of nodes */
+int *cities;			/* array of cities */
+int *cused;			/* city is in cycle */
+COST **costs;			/* pointer to array of pointers to arrays of sorted forward costs */
+COST **bcosts;			/* pointer to array of pointers to arrays of sorted backward costs */
+int *cycle;			/* path */
+int ncyc = 0;			/* number of cities in cycle */
+int debug_level;
+int cmp(const void *, const void *);
+int cnode(int city)
+    return (cities[city]);
+void add_city(int city, int after)
+{				/* index !!! to cycle, after which to put it */
+    int i, j;
+    if (after == -1) {
+	cycle[0] = city;
+    else {
+	/* for a large number of cities this will become slow */
+	for (j = ncyc - 1; j > after; j--)
+	    cycle[j + 1] = cycle[j];
+	cycle[after + 1] = city;
+    cused[city] = 1;
+    ncyc++;
+    if (debug_level >= 2) {
+	G_debug(2, "Cycle:");
+	for (i = 0; i < ncyc; i++) {
+	    G_debug(2, "%d: %d: %d", i, cycle[i], cities[cycle[i]]);
+/* like Vect_list_append(), but allows duplicates */
+int tsp_list_append(struct ilist *list, int val)
+    size_t size;
+    if (list == NULL)
+	return 1;
+    if (list->n_values == list->alloc_values) {
+	size = (list->n_values + 1000) * sizeof(int);
+	list->value = (int *)G_realloc((void *)list->value, size);
+	list->alloc_values = list->n_values + 1000;
+    list->value[list->n_values] = val;
+    list->n_values++;
+    return 0;
+int main(int argc, char **argv)
+    int i, j, k, ret, city, city1;
+    int nlines, type, ltype, afield, nfield, tfield, tucfield, geo, cat;
+    int node, node1, node2, line;
+    double **cost_cache;	/* pointer to array of pointers to arrays of cached costs */
+    struct Option *map, *output, *afield_opt, *nfield_opt, *afcol, *abcol,
+	*seq, *type_opt, *term_opt, *tfield_opt, *tucfield_opt;
+    struct Flag *geo_f, *turntable_f;
+    struct GModule *module;
+    struct Map_info Map, Out;
+    struct ilist *TList;	/* list of terminal nodes */
+    struct ilist *List;
+    struct ilist *StArcs;	/* list of arcs on Steiner tree */
+    struct ilist *StNodes;	/* list of nodes on Steiner tree */
+    double cost, tmpcost, tcost;
+    struct cat_list *Clist;
+    struct line_cats *Cats;
+    struct line_pnts *Points;
+    const char *dstr;
+    const char *seqname;
+    int seq2stdout;
+    FILE *fp;
+    /* Initialize the GIS calls */
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    G_add_keyword(_("vector"));
+    G_add_keyword(_("network"));
+    G_add_keyword(_("salesman"));
+    module->label =
+	_
+	("Creates a cycle connecting given nodes (Traveling salesman problem).");
+    module->description =
+	_("Note that TSP is NP-hard, heuristic algorithm is used by "
+	  "this module and created cycle may be sub optimal");
+    map = G_define_standard_option(G_OPT_V_INPUT);
+    output = G_define_standard_option(G_OPT_V_OUTPUT);
+    type_opt = G_define_standard_option(G_OPT_V_TYPE);
+    type_opt->options = "line,boundary";
+    type_opt->answer = "line,boundary";
+    type_opt->description = _("Arc type");
+    afield_opt = G_define_standard_option(G_OPT_V_FIELD);
+    afield_opt->key = "alayer";
+    afield_opt->label = _("Arc layer");
+    nfield_opt = G_define_standard_option(G_OPT_V_FIELD);
+    nfield_opt->key = "nlayer";
+    nfield_opt->answer = "2";
+    nfield_opt->label = _("Node layer (used for cities)");
+    tfield_opt = G_define_standard_option(G_OPT_V_FIELD);
+    tfield_opt->key = "tlayer";
+    tfield_opt->answer = "3";
+    tfield_opt->label = _("Turntable layer");
+    tucfield_opt = G_define_standard_option(G_OPT_V_FIELD);
+    tucfield_opt->key = "tuclayer";
+    tucfield_opt->answer = "4";
+    tucfield_opt->label = _("Unique categories layer for turntable");
+    afcol = G_define_option();
+    afcol->key = "afcolumn";
+    afcol->type = TYPE_STRING;
+    afcol->required = NO;
+    afcol->description =
+	_("Arc forward/both direction(s) cost column (number)");
+    abcol = G_define_option();
+    abcol->key = "abcolumn";
+    abcol->type = TYPE_STRING;
+    abcol->required = NO;
+    abcol->description =
+	_("EXPERIMENTAL: Arc backward direction cost column (number)");
+    seq = G_define_standard_option(G_OPT_F_OUTPUT);
+    seq->key = "sequence";
+    seq->type = TYPE_STRING;
+    seq->required = NO;
+    seq->description =
+	_("Name for output file holding node sequence (\"-\" for stdout)");
+    term_opt = G_define_standard_option(G_OPT_V_CATS);
+    term_opt->key = "ccats";
+    term_opt->required = YES;
+    term_opt->description = _("Categories of points ('cities') on nodes "
+			      "(layer is specified by nlayer)");
+    geo_f = G_define_flag();
+    geo_f->key = 'g';
+    geo_f->description =
+	_("Use geodesic calculation for longitude-latitude locations");
+    turntable_f = G_define_flag();
+    turntable_f->key = 't';
+    turntable_f->description = _("Use turntable"
+				 "(otherwise tuclayer and tlayer are ignored)");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    Cats = Vect_new_cats_struct();
+    Points = Vect_new_line_struct();
+    type = Vect_option_to_types(type_opt);
+    TList = Vect_new_list();
+    List = Vect_new_list();
+    StArcs = Vect_new_list();
+    StNodes = Vect_new_list();
+    Clist = Vect_new_cat_list();
+    Vect_str_to_cat_list(term_opt->answer, Clist);
+    dstr = G__getenv("DEBUG");
+    if (dstr != NULL)
+	debug_level = atoi(dstr);
+    else
+	debug_level = 0;
+    if (debug_level >= 1) {
+	G_debug(1, "Input categories:");
+	for (i = 0; i < Clist->n_ranges; i++) {
+	    G_debug(1, "%d - %d", Clist->min[i], Clist->max[i]);
+    if (geo_f->answer)
+	geo = 1;
+    else
+	geo = 0;
+    Vect_check_input_output_name(map->answer, output->answer, G_FATAL_EXIT);
+    Vect_set_open_level(2);
+    Vect_open_old(&Map, map->answer, "");
+    afield = Vect_get_field_number(&Map, afield_opt->answer);
+    nfield = Vect_get_field_number(&Map, nfield_opt->answer);
+    tfield = Vect_get_field_number(&Map, tfield_opt->answer);
+    tucfield = Vect_get_field_number(&Map, tucfield_opt->answer);
+    nnodes = Vect_get_num_nodes(&Map);
+    nlines = Vect_get_num_lines(&Map);
+    /* Create list of terminals based on list of categories */
+    for (i = 1; i <= nlines; i++) {
+	ltype = Vect_get_line_type(&Map, i);
+	if (!(ltype & GV_POINT))
+	    continue;
+	Vect_read_line(&Map, Points, Cats, i);
+	node =
+	    Vect_find_node(&Map, Points->x[0], Points->y[0], Points->z[0], 0,
+			   0);
+	if (!node) {
+	    G_warning(_("Point is not connected to the network"));
+	    continue;
+	if (!(Vect_cat_get(Cats, nfield, &cat)))
+	    continue;
+	if (Vect_cat_in_cat_list(cat, Clist)) {
+	    tsp_list_append(TList, node);
+    ncities = TList->n_values;
+    G_message(_("Number of cities: [%d]"), ncities);
+    if (ncities < 2)
+	G_fatal_error(_("Not enough cities (< 2)"));
+    /* Alloc memory */
+    cities = (int *)G_malloc(ncities * sizeof(int));
+    cused = (int *)G_malloc(ncities * sizeof(int));
+    for (i = 0; i < ncities; i++) {
+	G_debug(1, "%d", TList->value[i]);
+	cities[i] = TList->value[i];
+	cused[i] = 0;		/* not in cycle */
+    costs = (COST **) G_malloc(ncities * sizeof(COST *));
+	costs[i] = (COST *) G_malloc(ncities * sizeof(COST));
+    cost_cache = (double **)G_malloc(ncities * sizeof(double *));
+	cost_cache[i] = (double *)G_malloc(ncities * sizeof(double));
+    if (abcol->answer) {
+	bcosts = (COST **) G_malloc(ncities * sizeof(COST *));
+	    bcosts[i] = (COST *) G_malloc(ncities * sizeof(COST));
+    else
+	bcosts = NULL;
+    cycle = (int *)G_malloc((ncities + 1) * sizeof(int));	/* + 1 is for output cycle */
+    /* Build graph */
+    if (turntable_f->answer)
+	Vect_net_ttb_build_graph(&Map, type, afield, 0, tfield, tucfield,
+				 afcol->answer, abcol->answer, NULL, geo, 0);
+    else
+	Vect_net_build_graph(&Map, type, afield, 0, afcol->answer,
+			     abcol->answer, NULL, geo, 0);
+    /* Create sorted lists of costs */
+    /* for a large number of cities this will become very slow, can not be fixed */
+    G_message(_("Creating cost cache..."));
+	G_percent(i, ncities, 2);
+	k = 0;
+	for (j = 0; j < ncities; j++) {
+	    cost_cache[i][j] = 0.0;
+	    if (i == j)
+		continue;
+		ret =
+		    Vect_net_ttb_shortest_path(&Map, cities[i], 0, cities[j],
+					       0, tfield, tucfield, NULL,
+					       &cost);
+	    else
+		ret =
+		    Vect_net_shortest_path(&Map, cities[i], cities[j], NULL,
+					   &cost);
+	    if (ret == -1) {
+		double coor_x, coor_y, coor_z;
+		int cat1, cat2;
+		Vect_get_node_coor(&Map, cities[i], &coor_x, &coor_y,
+				   &coor_z);
+		line =
+		    Vect_find_line(&Map, coor_x, coor_y, coor_z, GV_POINT, 0,
+				   0, 0);
+		if (!line)
+		    G_fatal_error(_("No point at node %d"), cities[i]);
+		Vect_read_line(&Map, Points, Cats, line);
+		if (!(Vect_cat_get(Cats, nfield, &cat1)))
+		    G_fatal_error(_("No category for point at node %d"),
+				  cities[i]);
+		Vect_get_node_coor(&Map, cities[j], &coor_x, &coor_y,
+				   &coor_z);
+		line =
+				   0, 0);
+		if (!line)
+		    G_fatal_error(_("No point at node %d"), cities[j]);
+		if (!(Vect_cat_get(Cats, nfield, &cat2)))
+				  cities[j]);
+		G_fatal_error(_("Destination node [cat %d] is unreachable "
+				"from node [cat %d]"), cat1, cat2);
+	    /* add to directional cost cache: from, to, cost */
+	    costs[i][k].city = j;
+	    costs[i][k].cost = cost;
+	    cost_cache[i][j] = cost;
+	    k++;
+	qsort((void *)costs[i], k, sizeof(COST), cmp);
+    G_percent(1, 1, 2);
+    if (bcosts) {
+	    /* this should be fast, no need for G_percent() */
+	    k = 0;
+		if (i == j)
+		    continue;
+		bcosts[i][k].city = j;
+		bcosts[i][k].cost = cost_cache[j][i];
+		k++;
+	    qsort((void *)bcosts[i], k, sizeof(COST), cmp);
+	/* debug: print sorted */
+	    for (j = 0; j < ncities - 1; j++) {
+		city = costs[i][j].city;
+		G_debug(2, "%d -> %d = %f", cities[i], cities[city],
+			costs[i][j].cost);
+    G_message(_("Searching for the shortest cycle..."));
+    /* find 2 cities with largest distance */
+    cost = city = -1;
+	tmpcost = costs[i][ncities - 2].cost;
+	if (tmpcost > cost) {
+	    cost = tmpcost;
+	    city = i;
+    G_debug(2, "biggest costs %d - %d", city, costs[city][ncities - 2].city);
+    /* add these 2 cities to array */
+    add_city(city, -1);
+    add_city(costs[city][ncities - 2].city, 0);
+    /* In each step, find not used city, with biggest cost to any used city, and insert
+     *  into cycle between 2 nearest nodes */
+    /* for a large number of cities this will become very slow, can be fixed */
+    for (i = 0; i < ncities - 2; i++) {
+	G_percent(i, ncities - 3, 1);
+	cost = -1;
+	G_debug(2, "---- city %d ----", i);
+	    if (cused[j] == 1)
+		continue;
+	    tmpcost = 0;
+	    for (k = 0; k < ncities - 1; k++) {
+		G_debug(2, "forward? %d (%d) - %d (%d)", j, cnode(j),
+			costs[j][k].city, cnode(costs[j][k].city));
+		if (!cused[costs[j][k].city])
+		    continue;	/* only used */
+		/* directional costs j -> k */
+		tmpcost += costs[j][k].cost;
+		break;		/* first nearest */
+	    /* forward/backward: tmpcost = min(fcost) + min(bcost) */
+	    if (bcosts) {
+		    G_debug(2, "backward? %d (%d) - %d (%d)", j, cnode(j),
+			    bcosts[j][k].city, cnode(bcosts[j][k].city));
+		    if (!cused[bcosts[j][k].city])
+		    /* directional costs k -> j */
+		    tmpcost += bcosts[j][k].cost;
+	    G_debug(2, "    cost = %f x %f", tmpcost, cost);
+		cost = tmpcost;
+		city = j;
+	G_debug(2, "add city %d", city);
+	/* add to cycle on lowest costs */
+	cycle[ncyc] = cycle[0];	/* temporarily close the cycle */
+	cost = PORT_DOUBLE_MAX;
+	city1 = 0;
+	for (j = 0; j < ncyc; j++) {
+	    /* cost from j to j + 1 (directional) */
+	    /* get cost from directional cost cache */
+	    tcost = cost_cache[cycle[j]][cycle[j + 1]];
+	    tmpcost = -tcost;
+	    /* check insertion of city between j and j + 1 */
+	    /* cost from j to city (directional) */
+	    tcost = cost_cache[cycle[j]][city];
+	    tmpcost += tcost;
+	    /* cost from city to j + 1 (directional) */
+	    tcost = cost_cache[city][cycle[j + 1]];
+	    tmpcost += tcost;
+	    /* tmpcost must always be > 0 */
+	    G_debug(2, "? %d - %d cost = %f x %f", node1, node2, tmpcost,
+		    cost);
+	    /* always true for j = 0 */
+	    if (tmpcost < cost) {
+		city1 = j;
+		cost = tmpcost;
+	add_city(city, city1);
+    /* TODO: optimize tour (some Lin–Kernighan method) */
+	/* debug print */
+    /* Create list of arcs */
+    cycle[ncities] = cycle[0];	/* close the cycle */
+    cost = 0.0;
+	node1 = cities[cycle[i]];
+	node2 = cities[cycle[i + 1]];
+	G_debug(2, " %d -> %d", node1, node2);
+	    ret =
+		Vect_net_ttb_shortest_path(&Map, node1, 0, node2, 0, tfield,
+					   tucfield, List, NULL);
+	else
+	    ret = Vect_net_shortest_path(&Map, node1, node2, List, NULL);
+	cost += cost_cache[cycle[i]][cycle[i + 1]];
+	for (j = 0; j < List->n_values; j++) {
+	    line = abs(List->value[j]);
+	    /* Vect_list_append() appends only if value not yet present !!!
+	     * this breaks the correct sequence */
+	    tsp_list_append(StArcs, line);
+	    Vect_get_line_nodes(&Map, line, &node1, &node2);
+	    tsp_list_append(StNodes, node1);
+	    tsp_list_append(StNodes, node2);
+    /* Write arcs to new map */
+    Vect_open_new(&Out, output->answer, Vect_is_3d(&Map));
+    Vect_hist_command(&Out);
+    G_verbose_message(_("Cycle with total cost %.3f"), cost);
+    G_debug(2, "Arcs' categories (layer %d, %d arcs):", afield,
+	    StArcs->n_values);
+    for (i = 0; i < StArcs->n_values; i++) {
+	line = StArcs->value[i];
+	ltype = Vect_read_line(&Map, Points, Cats, line);
+	Vect_write_line(&Out, ltype, Points, Cats);
+	Vect_cat_get(Cats, afield, &cat);
+	G_debug(2, "%d. arc: cat %d", i + 1, cat);
+    seq2stdout = 0;
+    seqname = NULL;
+    if (seq->answer) {
+	if (strcmp(seq->answer, "-")) {
+	    seqname = seq->answer;
+	else {
+	    seqname = G_tempfile();
+	    seq2stdout = 1;
+	fp = fopen(seqname, "w");
+	if (!fp)
+	    G_fatal_error(_("Unable to open file '%s' for writing"), seqname);
+	fprintf(fp, "sequence;category;cost_to_next\n");
+    else
+	fp = NULL;
+    k = 0;
+    /* this writes out only user-selected nodes, not all visited nodes */
+    G_debug(2, "Nodes' categories (layer %d, %d nodes):", nfield, ncities);
+	node = cities[cycle[i]];
+	Vect_get_node_coor(&Map, node, &coor_x, &coor_y, &coor_z);
+	line =
+	    Vect_find_line(&Map, coor_x, coor_y, coor_z, GV_POINT, 0, 0, 0);
+	if (!line)
+	    continue;
+	    continue;
+	    continue;
+	k++;
+	if (fp) {
+	    fprintf(fp, "%d;%d;%.3f\n", k, cat,
+		    cost_cache[cycle[i]][cycle[i + 1]]);
+	G_debug(2, "%d. node: cat %d", k, cat);
+    Vect_build(&Out);
+    /* Free, ... */
+    Vect_destroy_list(StArcs);
+    Vect_destroy_list(StNodes);
+    Vect_close(&Map);
+    Vect_close(&Out);
+    if (fp) {
+	fclose(fp);
+	if (seq2stdout) {
+	    char buf[2000];
+	    /* spacer to previous output to stderr */
+	    G_message(" ");
+	    fp = fopen(seqname, "r");
+	    while (G_getl2(buf, 2000, fp) != 0)
+		fprintf(stdout, "%s\n", buf);
+	    fclose(fp);
+	    remove(seqname);
+    exit(EXIT_SUCCESS);
+int cmp(const void *pa, const void *pb)
+    COST *p1 = (COST *) pa;
+    COST *p2 = (COST *) pb;
+    if (p1->cost < p2->cost)
+	return -1;
+    if (p1->cost > p2->cost)
+	return 1;
+    return 0;
Added: grass-addons/grass7/vector/v.net.salesman2/v.net.salesman2.html
--- grass-addons/grass7/vector/v.net.salesman2/v.net.salesman2.html	                        (rev 0)
+++ grass-addons/grass7/vector/v.net.salesman2/v.net.salesman2.html	2013-06-05 11:12:02 UTC (rev 56602)
@@ -0,0 +1,150 @@
+<h2>DESCRIPTION</h2>
+<em>v.net.salesman</em> calculates the optimal route to visit nodes on a
+vector network.
+<p>Costs may be either line lengths, or attributes saved in a database
+table. These attribute values are taken as costs of whole segments, not
+as costs to traverse a length unit (e.g. meter) of the segment.
+For example, if the speed limit is 100 km / h, the cost to traverse a
+10 km long road segment must be calculated as
+<br>
+length / speed = 10 km / (100 km/h) = 0.1 h.
+<br>
+Supported are cost assignments for arcs,
+and also different costs for both directions of a vector line.
+For areas, costs will be calculated along boundary lines.
+<p>The input vector needs to be prepared with <em>v.net operation=connect</em>
+in order to connect points representing center nodes to the network.
+<p>Points specified by category must be exactly on network nodes, and the
+input vector map needs to be prepared with <em>v.net operation=connect</em>.
+<p>There is the option of applying the <a href="v.net.turntable.html">v.net.turntable</a> module on the input layer first. This means the input layer is expanded by turntable with costs of every possible turn on any possible node (intersection) in both directions. Note that after this expansion it is required to apply the -t flag. This flag enables additional parameters tlayer and tuclayer that are otherwise ignored.
+<h2>NOTES</h2>
+Arcs can be closed using cost = -1.
+Turns support: The costs of turns on visiting nodes are not taken in account.
+<h2>EXAMPLE</h2>
+Traveling salesman for 6 digitized nodes (Spearfish):
+<p>Shortest path, along unimproved roads:
+<p><img src="vnetsalesman.png" alt="v.net.salesman example using distance" border="1">
+<p>Fastest path, along highways:
+<p><img src="vnetsalesmantime.png" alt="v.net.salesman example using time" border="1">
+<p>Searching for the shortest path using distance and the fastest path using
+traveling time according to the speed limits of different road types:
+<div class="code"><pre>
+# Spearfish
+g.copy vect=roads,myroads
+# we have 6 locations to visit on our trip
+echo "1|601653.5|4922869.2|a
+2|608284|4923776.6|b
+3|601845|4914981.9|c
+4|596270|4917456.3|d
+5|593330.8|4924096.6|e
+6|598005.5|4921439.2|f" | v.in.ascii in=- cat=1 x=2 y=3 out=centers col="cat integer, \
+                         east double precision, north double precision, label varchar(43)"
+# verify data preparation
+v.db.select centers
+v.category centers op=report
+# type       count        min        max
+# point          6          1          6
+# create lines map connecting points to network (on layer 2)
+v.net myroads points=centers out=myroads_net op=connect thresh=500
+v.category myroads_net op=report
+# Layer / table: 1 / myroads_net
+# line         837          1          5
+# Layer: 2
+# point          6          1          5
+# find the shortest path
+v.net.salesman myroads_net ccats=1-6 out=mysalesman_distance
+# set up costs as traveling time
+# create unique categories for each road in layer 3
+v.category in=myroads_net out=myroads_net_time opt=add cat=1 layer=3 type=line
+# add new table for layer 3
+v.db.addtable myroads_net_time layer=3 col="cat integer,label varchar(43),length double precision,speed double precision,cost double precision,bcost double precision"
+# copy road type to layer 3
+v.to.db myroads_net_time layer=3 qlayer=1 opt=query qcolumn=label columns=label
+# upload road length in miles
+v.to.db myroads_net_time layer=3 type=line option=length col=length unit=miles
+# set speed limits in miles / hour
+v.db.update myroads_net_time layer=3 col=speed val="5.0"
+v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='interstate'"
+v.db.update myroads_net_time layer=3 col=speed val="75.0" where="label='primary highway, hard surface'"
+v.db.update myroads_net_time layer=3 col=speed val="50.0" where="label='secondary highway, hard surface'"
+v.db.update myroads_net_time layer=3 col=speed val="25.0" where="label='light-duty road, improved surface'"
+v.db.update myroads_net_time layer=3 col=speed val="5.0" where="label='unimproved road'"
+# define traveling costs as traveling time in minutes:
+# set forward costs
+v.db.update myroads_net_time layer=3 col=cost val="length / speed * 60"
+# set backward costs
+v.db.update myroads_net_time layer=3 col=bcost val="length / speed * 60"
+# find the fastest path
+v.net.salesman myroads_net_time alayer=3 nlayer=2 afcol=cost abcol=bcost ccats=1-6 out=mysalesman_time
+</pre></div>
+To display the result, run for example:
+# Display the results
+g.region vect=myroads_net
+# shortest path
+d.mon x0
+d.vect myroads_net
+d.vect centers -c icon=basic/triangle
+d.vect mysalesman_distance col=green width=2
+d.font Vera
+d.vect centers col=red disp=attr attrcol=label lsize=12
+# fastest path
+d.mon x1
+d.vect myroads_net
+d.vect mysalesman_time col=green width=2
+d.font Vera
+</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="d.path.html">d.path</a></em>,
+<em><a href="v.net.html">v.net</a></em>,
+<em><a href="v.net.alloc.html">v.net.alloc</a></em>,
+<em><a href="v.net.iso.html">v.net.iso</a></em>,
+<em><a href="v.net.path.html">v.net.path</a></em>,
+<em><a href="v.net.steiner.html">v.net.steiner</a></em>
+<h2>AUTHOR</h2>
+Radim Blazek, ITC-Irst, Trento, Italy<br>
+Markus Metz<br>
+Documentation: Markus Neteler, Markus Metz
+<p><i>Last changed: $Date: 2013-05-23 21:59:24 +0200 (Thu, 23 May 2013) $</i>
Added: grass-addons/grass7/vector/v.net.salesman2/vnetsalesman.png
(Binary files differ)
Property changes on: grass-addons/grass7/vector/v.net.salesman2/vnetsalesman.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: grass-addons/grass7/vector/v.net.salesman2/vnetsalesmantime.png
Property changes on: grass-addons/grass7/vector/v.net.salesman2/vnetsalesmantime.png
