[GRASS-SVN] r56607 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Wed Jun 5 06:41:07 PDT 2013
Author: huhabla
Date: 2013-06-05 06:41:07 -0700 (Wed, 05 Jun 2013)
New Revision: 56607
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
Snapping and shifting of map lists implemented
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-06-05 13:38:38 UTC (rev 56606)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2013-06-05 13:41:07 UTC (rev 56607)
@@ -1084,17 +1084,107 @@
dbif.close()
return rows
+ @staticmethod
+ def shift_map_list(maps, gran):
+ """!Temporally shift each map in the list with the provided granularity
+ This method does not perform any temporal database operations.
+ @param maps A list of maps with initialized temporal extent
+ @param gran The granularity to be used for shifting
+ @return The modified map list, None if nothing to shift or wrong granularity
+ @code
+ >>> import grass.temporal as tgis
+ >>> maps = []
+ >>> for i in range(5):
+ ... map = tgis.RasterDataset(None)
+ ... if i%2 == 0:
+ ... check = map.set_relative_time(i, i + 1, 'years')
+ ... else:
+ ... check = map.set_relative_time(i, None, 'years')
+ ... maps.append(map)
+ >>> for map in maps:
+ ... map.temporal_extent.print_info()
+ +-------------------- Relative time -----------------------------------------+
+ | Start time:................. 0
+ | End time:................... 1
+ | Relative time unit:......... years
+ | Start time:................. 1
+ | End time:................... None
+ | Start time:................. 2
+ | End time:................... 3
+ | Start time:................. 3
+ | Start time:................. 4
+ | End time:................... 5
+ >>> maps = tgis.AbstractSpaceTimeDataset.shift_map_list(maps, 5)
+ | Start time:................. 5
+ | End time:................... 6
+ | Start time:................. 6
+ | Start time:................. 7
+ | End time:................... 8
+ | Start time:................. 8
+ | Start time:................. 9
+ | End time:................... 10
+ @endcode
+ if maps is None:
+ return None
+ if not check_granularity_string(gran, maps[-1].get_temporal_type()):
+ core.error(_("Wrong granularity format: %s"%(gran)))
+ return None
+ for map in maps:
+ start, end = map.get_temporal_extent_as_tuple()
+ if map.is_time_absolute():
+ start = increment_datetime_by_string(start, gran)
+ if end is not None:
+ end = increment_datetime_by_string(end, gran)
+ map.set_absolute_time(start, end)
+ elif map.is_time_relative():
+ start = start + int(gran)
+ end = end + int(gran)
+ map.set_relative_time(start, end, map.get_relative_time_unit())
+ return maps
def shift(self, gran, dbif=None):
"""!Temporally shift each registered map with the provided granularity
@param dbif The database interface to be used
- @return True something to shift, False nothing to shift or wrong granularity
+ @return True something to shift, False if nothing to shift or wrong granularity
if not check_granularity_string(gran, self.get_temporal_type()):
- self.error(_("Wrong granularity format: %s"%(gran)))
return False
dbif, connected = init_dbif(dbif)
@@ -1128,8 +1218,119 @@
if connected:
dbif.close()
- return True
+ @staticmethod
+ def snap_map_list(maps):
+ """!For each map in the list snap the end time to the start time of its
+ temporal nearest neighbor in the future.
+ Maps with equal time stamps are not snapped.
+ The granularity of the map list will be used to create the end time
+ of the last map in case it has a time instance as timestamp.
+ @return The modified map list, None nothing to shift or wrong granularity
+ Usage:
+ @code
+ >>> maps = []
+ ... if i%2 == 0:
+ ... else:
+ >>> maps = tgis.AbstractSpaceTimeDataset.snap_map_list(maps)
+ | End time:................... 2
+ | End time:................... 4
+ @endcode
+ if maps is None or len(maps) == 0:
+ return None
+ # We need to sort the maps temporally by start time
+ maps = sorted(maps, key=AbstractDatasetComparisonKeyStartTime)
+ for i in range(len(maps) - 1):
+ start, end = maps[i].get_temporal_extent_as_tuple()
+ start_next, end = maps[i + 1].get_temporal_extent_as_tuple()
+ # Maps with equal time stamps can not be snapped
+ if start != start_next:
+ if maps[i].is_time_absolute():
+ maps[i].set_absolute_time(start, start_next)
+ elif maps[i].is_time_relative():
+ maps[i].set_relative_time(start, start_next, maps[i].get_relative_time_unit())
+ else:
+ maps[i].set_absolute_time(start, end)
+ maps[i].set_relative_time(start, end, maps[i].get_relative_time_unit())
+ # Last map
+ start, end = maps[-1].get_temporal_extent_as_tuple()
+ # We increment the start time with the dataset
+ # granularity if the end time is None
+ if end is None:
+ if maps[-1].is_time_absolute():
+ gran = compute_absolute_time_granularity(maps)
+ end = increment_datetime_by_string(start, gran)
+ maps[-1].set_absolute_time(start, end)
+ elif maps[-1].is_time_relative():
+ gran = compute_relative_time_granularity(maps)
+ end = start + gran
+ maps[-1].set_relative_time(start, end, maps[-1].get_relative_time_unit())
+ return maps
def snap(self, dbif=None):
"""!For each registered map snap the end time to the start time of its
@@ -1863,3 +2064,9 @@
if connected:
dbif.close()
+if __name__ == "__main__":
+ import doctest
+ doctest.testmod()
