[GRASS-SVN] r56612 - grass/trunk/raster/r.shaded.relief2
svn_grass at osgeo.org
Wed Jun 5 08:06:58 PDT 2013
Author: mmetz
Date: 2013-06-05 08:06:57 -0700 (Wed, 05 Jun 2013)
New Revision: 56612
Added:
grass/trunk/raster/r.shaded.relief2/r.shaded.relief.html
Removed:
grass/trunk/raster/r.shaded.relief2/r.shaded.relief2.html
grass/trunk/raster/r.shaded.relief2/Makefile
r.shaded.relief2 -> r.shaded.relief
Modified: grass/trunk/raster/r.shaded.relief2/Makefile
--- grass/trunk/raster/r.shaded.relief2/Makefile 2013-06-05 15:04:46 UTC (rev 56611)
+++ grass/trunk/raster/r.shaded.relief2/Makefile 2013-06-05 15:06:57 UTC (rev 56612)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM = r.shaded.relief2
+PGM = r.shaded.relief
LIBES = $(RASTERLIB) $(GISLIB) $(MATHLIB)
DEPENDENCIES = $(RASTERDEP) $(GISDEP)
Copied: grass/trunk/raster/r.shaded.relief2/r.shaded.relief.html (from rev 56523, grass/trunk/raster/r.shaded.relief2/r.shaded.relief2.html)
--- grass/trunk/raster/r.shaded.relief2/r.shaded.relief.html (rev 0)
+++ grass/trunk/raster/r.shaded.relief2/r.shaded.relief.html 2013-06-05 15:06:57 UTC (rev 56612)
@@ -0,0 +1,88 @@
+<h2>DESCRIPTION</h2>
+<em>r.shaded.relief</em> creates a raster shaded relief map based on
+current resolution settings and on sun altitude, azimuth, and
+z-exaggeration values entered by the user. If no output shademap
+name is given, the new shaded relief map is named <em><input_map
+>.shade</em>. The map is assigned a grey-scale color table.
+<p>The parameters controlling the shading are:
+<ol>
+<li>A raster map layer to provide elevation values for the shaded
+relief map. Typically, this would be a map layer of elevation;
+however, any raster map layer can be named.
+<li>The <b>altitude</b> of the sun in degrees above the horizon
+(a value between 0 and 90 degrees).
+<li>The <b>azimuth</b> of the sun in degrees to the east of north
+(a value between 0 and 360 degrees).
+<li>The scaling parameter, which compensates for a different
+horizontal <b>scale</b> than vertical scale. If <b>scale</b> is a
+number, then the ewres and nsres are multiplied by that scale to
+calculate the shading. (Default=1.0 for equivalent horizontal and
+vertical scales.)
+<li>The <b>zmult</b> exaggeration factor that changes the apparent relief
+for the shaded relief map. This can be any positive (or negative) floating
+point value. (Default=1.0)
+<li>Horizontal distances are calculated in meters, using geodesic
+distances for a latitude-longitude projection. With an elevation map
+measured in feet, the <b>units</b> option can be set to automatically
+convert meters to international feet (0.3048 meters = 1 foot) or survey
+feet (1200 / 3937 meters = 1 foot). The <b>units</b> parameter overrides
+the <b>scale</b> parameter.
+</ol>
+<p><em>r.shaded.relief</em> assigns a grey-scale color table to the new
+shaded relief map.
+<h2>NOTES</h2>
+To visually improve the result of shade maps from low resolution elevation
+models, use <em>r.resamp.interp</em> with bilinear or bicubic method to
+resample the DEM at higher resolution. <em>r.shaded.relief</em> is then
+run on the resampled DEM.
+<h2>EXAMPLES</h2>
+In this example, the aspect map in the North Carolina sample
+dataset location is used to hillshade the elevation map:
+<div class="code"><pre>
+g.region rast=elevation -p
+r.shaded.relief input=elevation output=elevation.shaded
+</pre></div>
+<p>In Latitude-Longitude locations (or other non-metric locations), the
+<em>scale</em> factor has to be used:
+# Latitude-Longitude example
+r.shaded.relief input=srtm output=srtm.shaded scale=111120
+</pre></div>
+<h2>SEE ALSO</h2>
+<p><!-- RGB version not ported to GRASS 6 (why?):
+ <em><a href="shade.clr.sh.html">shade.clr.sh</a></em><br>
+<em>
+<a href="d.his.html">d.his</a>,
+<a href="g.region.html">g.region</a>,
+<a href="r.blend.html">r.blend</a>,
+<a href="r.colors.html">r.colors</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.resamp.interp.html">r.resamp.interp</a>
+</em>
+<h2>AUTHORS</h2>
+Jim Westervelt, U.S. Army Construction Engineering Research Laboratory
+<br>
+Markus Metz: GRASS GIS 7- enhanced fast C version of r.shaded.relief
+<p><i>Last changed: $Date$</i>
Deleted: grass/trunk/raster/r.shaded.relief2/r.shaded.relief2.html
--- grass/trunk/raster/r.shaded.relief2/r.shaded.relief2.html 2013-06-05 15:04:46 UTC (rev 56611)
+++ grass/trunk/raster/r.shaded.relief2/r.shaded.relief2.html 2013-06-05 15:06:57 UTC (rev 56612)
@@ -1,88 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.shaded.relief</em> creates a raster shaded relief map based on
-current resolution settings and on sun altitude, azimuth, and
-z-exaggeration values entered by the user. If no output shademap
-name is given, the new shaded relief map is named <em><input_map
->.shade</em>. The map is assigned a grey-scale color table.
-<p>The parameters controlling the shading are:
-<ol>
-<li>A raster map layer to provide elevation values for the shaded
-relief map. Typically, this would be a map layer of elevation;
-however, any raster map layer can be named.
-<li>The <b>altitude</b> of the sun in degrees above the horizon
-(a value between 0 and 90 degrees).
-<li>The <b>azimuth</b> of the sun in degrees to the east of north
-(a value between 0 and 360 degrees).
-<li>The scaling parameter, which compensates for a different
-horizontal <b>scale</b> than vertical scale. If <b>scale</b> is a
-number, then the ewres and nsres are multiplied by that scale to
-calculate the shading. (Default=1.0 for equivalent horizontal and
-vertical scales.)
-<li>The <b>zmult</b> exaggeration factor that changes the apparent relief
-for the shaded relief map. This can be any positive (or negative) floating
-point value. (Default=1.0)
-<li>Horizontal distances are calculated in meters, using geodesic
-distances for a latitude-longitude projection. With an elevation map
-measured in feet, the <b>units</b> option can be set to automatically
-convert meters to international feet (0.3048 meters = 1 foot) or survey
-feet (1200 / 3937 meters = 1 foot). The <b>units</b> parameter overrides
-the <b>scale</b> parameter.
-</ol>
-<p><em>r.shaded.relief</em> assigns a grey-scale color table to the new
-shaded relief map.
-<h2>NOTES</h2>
-To visually improve the result of shade maps from low resolution elevation
-models, use <em>r.resamp.interp</em> with bilinear or bicubic method to
-resample the DEM at higher resolution. <em>r.shaded.relief</em> is then
-run on the resampled DEM.
-<h2>EXAMPLES</h2>
-In this example, the aspect map in the North Carolina sample
-dataset location is used to hillshade the elevation map:
-<div class="code"><pre>
-g.region rast=elevation -p
-r.shaded.relief input=elevation output=elevation.shaded
-</pre></div>
-<p>In Latitude-Longitude locations (or other non-metric locations), the
-<em>scale</em> factor has to be used:
-# Latitude-Longitude example
-r.shaded.relief input=srtm output=srtm.shaded scale=111120
-</pre></div>
-<h2>SEE ALSO</h2>
-<p><!-- RGB version not ported to GRASS 6 (why?):
- <em><a href="shade.clr.sh.html">shade.clr.sh</a></em><br>
-<em>
-<a href="d.his.html">d.his</a>,
-<a href="g.region.html">g.region</a>,
-<a href="r.blend.html">r.blend</a>,
-<a href="r.colors.html">r.colors</a>,
-<a href="r.mapcalc.html">r.mapcalc</a>,
-<a href="r.resamp.interp.html">r.resamp.interp</a>
-</em>
-<h2>AUTHORS</h2>
-Jim Westervelt, U.S. Army Construction Engineering Research Laboratory
-<br>
-Markus Metz: GRASS GIS 7- enhanced fast C version of r.shaded.relief
-<p><i>Last changed: $Date$</i>
