[GRASS-SVN] r56617 - grass/trunk/gui/wxpython/modules
svn_grass at osgeo.org
Wed Jun 5 11:57:13 PDT 2013
Author: mmetz
Date: 2013-06-05 11:57:13 -0700 (Wed, 05 Jun 2013)
New Revision: 56617
grass/trunk/gui/wxpython/modules/vclean.py
wxGUI. v.clean interface cosmetics
Modified: grass/trunk/gui/wxpython/modules/vclean.py
--- grass/trunk/gui/wxpython/modules/vclean.py 2013-06-05 15:22:22 UTC (rev 56616)
+++ grass/trunk/gui/wxpython/modules/vclean.py 2013-06-05 18:57:13 UTC (rev 56617)
@@ -27,6 +27,7 @@
from core import globalvar
from gui_core.gselect import Select
from core.settings import UserSettings
+from grass.script import core as grass
class VectorCleaningFrame(wx.Frame):
@@ -131,6 +132,8 @@
label=_('Select output vector map:'))
self.selectionOutput = Select(parent=self.panel, id=wx.ID_ANY,
size=globalvar.DIALOG_GSELECT_SIZE,
+ mapsets=[grass.gisenv()['MAPSET'],],
+ fullyQualified = False,
type='vector')
self.overwrite = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
@@ -204,6 +207,8 @@
typeoptSizer = wx.BoxSizer(wx.HORIZONTAL)
for num in range(0, self.n_ftypes):
type_box = self.ftype_check[num]
+ if self.ftype[num] in ('point', 'line', 'area'):
+ type_box.SetValue(True);
typeoptSizer.Add(item=type_box, flag=wx.ALIGN_LEFT, border=1)
self.ftypeSizer.Add(item=typeoptSizer,
@@ -308,9 +313,6 @@
def AddTool(self):
snum = len(self.toolslines.keys())
num = snum + 1
- # tool number
- tool_no = wx.StaticText(parent=self.ct_panel, id=3000 + num,
- label=str(num) + '.')
# tool
tool_cbox = wx.ComboBox(parent=self.ct_panel, id=1000 + num,
size=(300, -1), choices=self.tool_desc_list,
@@ -323,20 +325,18 @@
style=wx.TE_NOHIDESEL)
self.Bind(wx.EVT_TEXT, self.OnThreshValue, txt_ctrl)
- # select
- select = wx.CheckBox(parent=self.ct_panel, id=num)
+ # select with tool number
+ select = wx.CheckBox(parent=self.ct_panel, id=num, label=str(num) + '.')
select.SetValue(False)
self.Bind(wx.EVT_CHECKBOX, self.OnSelect, select)
# start with row 1 and col 1 for nicer layout
- self.ct_sizer.Add(item=tool_no, pos=(num, 1),
- flag=wx.ALIGN_CENTER_VERTICAL, border=5)
+ self.ct_sizer.Add(item=select, pos=(num, 1),
+ flag=wx.ALIGN_CENTER | wx.RIGHT)
self.ct_sizer.Add(item=tool_cbox, pos=(num, 2),
flag=wx.ALIGN_CENTER | wx.RIGHT, border=5)
self.ct_sizer.Add(item=txt_ctrl, pos=(num, 3),
- self.ct_sizer.Add(item=select, pos=(num, 4),
- flag=wx.ALIGN_CENTER | wx.RIGHT)
self.toolslines[num] = {'tool_desc': '',
'tool': '',
