[GRASS-SVN] r56635 - grass/trunk/raster/r.in.gridatb
svn_grass at osgeo.org
Sat Jun 8 02:05:35 PDT 2013
Author: hamish
Date: 2013-06-08 02:05:35 -0700 (Sat, 08 Jun 2013)
New Revision: 56635
grass/trunk/raster/r.in.gridatb/main.c
use G_define_standard_option()s
Modified: grass/trunk/raster/r.in.gridatb/main.c
--- grass/trunk/raster/r.in.gridatb/main.c 2013-06-07 16:59:55 UTC (rev 56634)
+++ grass/trunk/raster/r.in.gridatb/main.c 2013-06-08 09:05:35 UTC (rev 56635)
@@ -45,24 +45,20 @@
G_add_keyword(_("raster"));
G_add_keyword(_("import"));
module->description =
- _("Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map");
+ _("Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map.");
- params.input = G_define_option();
- params.input->key = "input";
+ params.input = G_define_standard_option(G_OPT_F_INPUT);
params.input->description = _("GRIDATB i/o map file");
- params.input->type = TYPE_STRING;
params.input->required = YES;
+ params.input->gisprompt = "old,file,file";
- params.output = G_define_option();
- params.output->key = "output";
- params.output->description = _("Name for output raster map");
- params.output->type = TYPE_STRING;
+ params.output = G_define_standard_option(G_OPT_R_OUTPUT);
params.output->required = YES;
- params.output->gisprompt = "new,cell,raster";
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
file = params.input->answer;
oname = params.output->answer;
