[GRASS-SVN] r56648 - grass/branches/releasebranch_6_4/imagery/i.gensig
Sun Jun 9 05:37:33 PDT 2013
Author: neteler
Date: 2013-06-09 05:37:33 -0700 (Sun, 09 Jun 2013)
New Revision: 56648
   grass/branches/releasebranch_6_4/imagery/i.gensig/description.html
i.gensig: explain SIG file structure
Modified: grass/branches/releasebranch_6_4/imagery/i.gensig/description.html
--- grass/branches/releasebranch_6_4/imagery/i.gensig/description.html	2013-06-09 12:37:23 UTC (rev 56647)
+++ grass/branches/releasebranch_6_4/imagery/i.gensig/description.html	2013-06-09 12:37:33 UTC (rev 56648)
@@ -15,29 +15,21 @@
 <em>i.gensig</em> will then extract spectral signatures
 from an image based on the classification of the pixels in
 the training map and make these signatures available to
 <em><a href="i.maxlik.html">i.maxlik</a></em>.
 <p>
 The user would then execute the GRASS program
 to actually create the final classified map.
 <h2>OPTIONS</h2>
 <h3>Parameters</h3>
 <dl>
 <dt><b>trainingmap=</b><em>name</em>
 <dd>ground truth training map
 <p>
 This map must be prepared by the user in advance. Programs like
 <em><a href="v.digit.html">v.digit</a></em> or <em>
 <a href="r.digit.html">r.digit</a></em> can be
@@ -50,26 +42,19 @@
 specified in other options - see below).
 <dt><b>group=</b><em>name</em>
 <dd>imagery group
 <p>
 This is the name of the group that contains the band files
 which comprise the image to be analyzed. The <em>
 <a href="i.group.html">i.group</a> </em> command is
 used to construct groups of raster layers which comprise an
 image.
 <p>
 <A NAME="subgroup"><dt><b>subgroup=</b><em>name</em></a>
 <dd>subgroup containing image files
 <p>
 This names the subgroup within the group that selects a
 subset of the bands to be analyzed. The <em>
@@ -79,16 +64,12 @@
 <dt><b>signaturefile=</b><em>name</em>
 <dd>resultant signature file
 <p>
 This is the resultant signature file (containing the means
 and covariance matrices) for each class in the training map
 that is associated with the band files in the subgroup
 select (see <a href="#subgroup">above</a>).
 </dl>
 <h2>INTERACTIVE MODE</h2>
@@ -97,36 +78,54 @@
 <em>i.gensig</em>
 will interactively prompt for the names of these maps and files.
 <p>
 It should be noted that interactive mode here only means
 interactive prompting for maps and files.
 It does not mean visualization of the signatures that
 result from the process.
+<h2>NOTES</h2>
+The structure of the SIG files generated by <em>i.gensig</em> is
+as follows (ASCII file, used internally by <em>i.maxlik</em>):
+<br>
+<i>Note: the line numbers are not present in the file but have been
+added here for explanation only</i>:
+<p>
+SIG file "lsat7_2000_gensig":
+<div class="code"><pre>
+ 1 #
+ 2 #water
+ 3 4186
+ 4 67.9508 48.7346 37.8915 15.3129 13.8473 12.0855
+ 5 1.74334
+ 6 0.439504 2.07267
+ 7 0.662523 1.63501 4.21189
+ 8 0.530339 2.40757 5.52857 22.433
+ 9 0.561184 2.30762 5.18846 20.5364 20.4926
+10 0.393218 1.2184 2.63628 9.61528 9.36025 5.85314
+</pre></div>
+<ul>
+<li> Line 2: text label
+<li> Line 3: number of points in class
+<li> Line 4: mean values per band of the class
+<li> Line 5-10: (semi)-matrix of band-band covariance
+</ul>
 <h2>SEE ALSO</h2>
 <em><a href="i.group.html">i.group</a></em>
 for creating groups and subgroups.
 <p>
 and
 <em><a href="r.digit.html">r.digit</a></em>
 for interactively  creating the training map.
 <p>
 <em><a href="i.cluster.html">i.cluster</a></em>
 for unsupervised clustering as an alternative to
 <em>i.gensig</em> to create signatures.
 <p>
 <em><a href="i.class.html">i.class</a></em>
 for a graphic/interactive as an alternative to
