[GRASS-SVN] r56653 - in grass/trunk/imagery: i.cluster i.gensig i.gensigset i.maxlik i.smap
svn_grass at osgeo.org
Sun Jun 9 06:23:39 PDT 2013
Author: neteler
Date: 2013-06-09 06:23:39 -0700 (Sun, 09 Jun 2013)
New Revision: 56653
grass/trunk/imagery/i.cluster/open_files.c
grass/trunk/imagery/i.gensig/parse.c
grass/trunk/imagery/i.gensigset/parse.c
grass/trunk/imagery/i.maxlik/open.c
grass/trunk/imagery/i.smap/parse.c
i18n: more understandable error messages since I_find_group() only searches in the current mapset; re-use existing messages
Modified: grass/trunk/imagery/i.cluster/open_files.c
--- grass/trunk/imagery/i.cluster/open_files.c 2013-06-09 13:21:29 UTC (rev 56652)
+++ grass/trunk/imagery/i.cluster/open_files.c 2013-06-09 13:23:39 UTC (rev 56653)
@@ -15,7 +15,7 @@
G_strip(group);
if (!I_find_group(group))
- G_fatal_error(_("Group <%s> not found"), group);
+ G_fatal_error(_("Group <%s> not found in current mapset"), group);
G_strip(subgroup);
if (!I_find_subgroup(group, subgroup))
Modified: grass/trunk/imagery/i.gensig/parse.c
--- grass/trunk/imagery/i.gensig/parse.c 2013-06-09 13:21:29 UTC (rev 56652)
+++ grass/trunk/imagery/i.gensig/parse.c 2013-06-09 13:23:39 UTC (rev 56653)
@@ -36,10 +36,10 @@
G_fatal_error(_("Raster map <%s> not found"), parms->training_map);
if (!I_find_group(parms->group))
- G_fatal_error(_("Group <%s> not found"), parms->group);
+ G_fatal_error(_("Group <%s> not found in current mapset"), parms->group);
if (!I_find_subgroup(parms->group, parms->subgroup))
- G_fatal_error(_("Subgroup <%s> not found"), parms->subgroup);
+ G_fatal_error(_("Subgroup <%s> in group <%s> not found"), parms->subgroup, parms->group);
return 0;
Modified: grass/trunk/imagery/i.gensigset/parse.c
--- grass/trunk/imagery/i.gensigset/parse.c 2013-06-09 13:21:29 UTC (rev 56652)
+++ grass/trunk/imagery/i.gensigset/parse.c 2013-06-09 13:23:39 UTC (rev 56653)
@@ -42,10 +42,10 @@
if (!I_find_group(parms->group)) {
if (!I_find_subgroup(parms->group, parms->subgroup)) {
if (sscanf(maxsig->answer, "%d", &parms->maxsubclasses) != 1 ||
parms->maxsubclasses <= 0) {
Modified: grass/trunk/imagery/i.maxlik/open.c
--- grass/trunk/imagery/i.maxlik/open.c 2013-06-09 13:21:29 UTC (rev 56652)
+++ grass/trunk/imagery/i.maxlik/open.c 2013-06-09 13:23:39 UTC (rev 56653)
@@ -14,7 +14,7 @@
I_init_group_ref(&Ref);
Modified: grass/trunk/imagery/i.smap/parse.c
--- grass/trunk/imagery/i.smap/parse.c 2013-06-09 13:21:29 UTC (rev 56652)
+++ grass/trunk/imagery/i.smap/parse.c 2013-06-09 13:23:39 UTC (rev 56653)
@@ -58,10 +58,10 @@
/* check all the inputs */
if (sscanf(blocksize->answer, "%d", &parms->blocksize) != 1
|| parms->blocksize <= 8)
