[GRASS-SVN] r56675 - grass/trunk
svn_grass at osgeo.org
Mon Jun 10 05:31:58 PDT 2013
Author: neteler
Date: 2013-06-10 05:31:57 -0700 (Mon, 10 Jun 2013)
New Revision: 56675
grass/trunk/install-sh
install-sh: updated to newer version (source: https://svn.met.no/viewvc/fimex/branches/version0_28_x/install-sh, GPL)
Modified: grass/trunk/install-sh
--- grass/trunk/install-sh 2013-06-10 10:45:24 UTC (rev 56674)
+++ grass/trunk/install-sh 2013-06-10 12:31:57 UTC (rev 56675)
@@ -1,262 +1,520 @@
#!/bin/sh
+# install - install a program, script, or datafile
+scriptversion=2009-04-28.21; # UTC
+# This originates from X11R5 (mit/util/scripts/install.sh), which was
+# later released in X11R6 (xc/config/util/install.sh) with the
+# following copyright and license.
-# MODULE: GRASS Compilation
-# AUTHOR(S): Original author MIT (X11R5)
-# PURPOSE: This file is required by configure to create the config.cache
-# file.
-# COPYRIGHT: Please see below for details.
+# Copyright (C) 1994 X Consortium
+# Permission is hereby granted, free of charge, to any person obtaining a copy
+# of this software and associated documentation files (the "Software"), to
+# deal in the Software without restriction, including without limitation the
+# rights to use, copy, modify, merge, publish, distribute, sublicense, and/or
+# sell copies of the Software, and to permit persons to whom the Software is
+# furnished to do so, subject to the following conditions:
-# install - install a program, script, or datafile
-# This comes from X11R5 (mit/util/scripts/install.sh).
+# The above copyright notice and this permission notice shall be included in
+# all copies or substantial portions of the Software.
-# Copyright 1991 by the Massachusetts Institute of Technology
+# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+# X CONSORTIUM BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN
+# AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNEC-
+# TION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
-# Permission to use, copy, modify, distribute, and sell this software and its
-# documentation for any purpose is hereby granted without fee, provided that
-# the above copyright notice appear in all copies and that both that
-# copyright notice and this permission notice appear in supporting
-# documentation, and that the name of M.I.T. not be used in advertising or
-# publicity pertaining to distribution of the software without specific,
-# written prior permission. M.I.T. makes no representations about the
-# suitability of this software for any purpose. It is provided "as is"
-# without express or implied warranty.
+# Except as contained in this notice, the name of the X Consortium shall not
+# be used in advertising or otherwise to promote the sale, use or other deal-
+# ings in this Software without prior written authorization from the X Consor-
+# tium.
+# FSF changes to this file are in the public domain.
# Calling this script install-sh is preferred over install.sh, to prevent
# `make' implicit rules from creating a file called install from it
# when there is no Makefile.
# This script is compatible with the BSD install script, but was written
-# from scratch. It can only install one file at a time, a restriction
-# shared with many OS's install programs.
+# from scratch.
+nl='
+IFS=" "" $nl"
# set DOITPROG to echo to test this script
# Don't use :- since 4.3BSD and earlier shells don't like it.
-doit="${DOITPROG-}"
+doit=${DOITPROG-}
+if test -z "$doit"; then
+ doit_exec=exec
+else
+ doit_exec=$doit
+fi
+# Put in absolute file names if you don't have them in your path;
+# or use environment vars.
-# put in absolute paths if you don't have them in your path; or use env. vars.
+chgrpprog=${CHGRPPROG-chgrp}
+chmodprog=${CHMODPROG-chmod}
+chownprog=${CHOWNPROG-chown}
+cmpprog=${CMPPROG-cmp}
+cpprog=${CPPROG-cp}
+mkdirprog=${MKDIRPROG-mkdir}
+mvprog=${MVPROG-mv}
+rmprog=${RMPROG-rm}
+stripprog=${STRIPPROG-strip}
-mvprog="${MVPROG-mv}"
-cpprog="${CPPROG-cp}"
-chmodprog="${CHMODPROG-chmod}"
-chownprog="${CHOWNPROG-chown}"
-chgrpprog="${CHGRPPROG-chgrp}"
-stripprog="${STRIPPROG-strip}"
-rmprog="${RMPROG-rm}"
-mkdirprog="${MKDIRPROG-mkdir}"
+posix_glob='?'
+initialize_posix_glob='
+ test "$posix_glob" != "?" || {
+ if (set -f) 2>/dev/null; then
+ posix_glob=
+ else
+ posix_glob=:
+ fi
-transformbasename=""
-transform_arg=""
-instcmd="$mvprog"
-chmodcmd="$chmodprog 0755"
-chowncmd=""
-chgrpcmd=""
-stripcmd=""
+posix_mkdir=
+# Desired mode of installed file.
+mode=0755
+chgrpcmd=
+chmodcmd=$chmodprog
+chowncmd=
+mvcmd=$mvprog
rmcmd="$rmprog -f"
-mvcmd="$mvprog"
-src=""
-dst=""
-dir_arg=""
+stripcmd=
-while [ x"$1" != x ]; do
- case $1 in
- -c) instcmd="$cpprog"
- shift
- continue;;
+src=
+dst=
+dir_arg=
+dst_arg=
- -d) dir_arg=true
- shift
- continue;;
+copy_on_change=false
+no_target_directory=
- -m) chmodcmd="$chmodprog $2"
- shift
- shift
- continue;;
+usage="\
+Usage: $0 [OPTION]... [-T] SRCFILE DSTFILE
+ or: $0 [OPTION]... SRCFILES... DIRECTORY
+ or: $0 [OPTION]... -t DIRECTORY SRCFILES...
+ or: $0 [OPTION]... -d DIRECTORIES...
- -o) chowncmd="$chownprog $2"
- shift
- shift
- continue;;
+In the 1st form, copy SRCFILE to DSTFILE.
+In the 2nd and 3rd, copy all SRCFILES to DIRECTORY.
+In the 4th, create DIRECTORIES.
- -g) chgrpcmd="$chgrpprog $2"
- shift
- shift
- continue;;
+Options:
+ --help display this help and exit.
+ --version display version info and exit.
- -s) stripcmd="$stripprog"
- shift
- continue;;
+ -c (ignored)
+ -C install only if different (preserve the last data modification time)
+ -d create directories instead of installing files.
+ -g GROUP $chgrpprog installed files to GROUP.
+ -m MODE $chmodprog installed files to MODE.
+ -o USER $chownprog installed files to USER.
+ -s $stripprog installed files.
+ -t DIRECTORY install into DIRECTORY.
+ -T report an error if DSTFILE is a directory.
- -t=*) transformarg=`echo "$1" | sed 's/-t=//'`
- shift
- continue;;
+Environment variables override the default commands:
+ CHGRPPROG CHMODPROG CHOWNPROG CMPPROG CPPROG MKDIRPROG MVPROG
+ RMPROG STRIPPROG
- -b=*) transformbasename=`echo "$1" | sed 's/-b=//'`
- shift
- continue;;
+while test $# -ne 0; do
+ case $1 in
+ -c) ;;
- *) if [ x"$src" = x ]
- then
- src="$1"
- else
- # this colon is to work around a 386BSD /bin/sh bug
- dst="$1"
- fi
- shift
- continue;;
- esac
+ -C) copy_on_change=true;;
+ -d) dir_arg=true;;
+ -g) chgrpcmd="$chgrpprog $2"
+ shift;;
+ --help) echo "$usage"; exit $?;;
+ -m) mode=$2
+ case $mode in
+ echo "$0: invalid mode: $mode" >&2
+ exit 1;;
+ esac
+ shift;;
+ -o) chowncmd="$chownprog $2"
+ shift;;
+ -s) stripcmd=$stripprog;;
+ -t) dst_arg=$2
+ shift;;
+ -T) no_target_directory=true;;
+ --version) echo "$0 $scriptversion"; exit $?;;
+ --) shift
+ break;;
+ -*) echo "$0: invalid option: $1" >&2
+ exit 1;;
+ *) break;;
+ esac
+ shift
done
-if [ x"$src" = x ]
-then
- echo "install: no input file specified"
- exit 1
-else
- true
+if test $# -ne 0 && test -z "$dir_arg$dst_arg"; then
+ # When -d is used, all remaining arguments are directories to create.
+ # When -t is used, the destination is already specified.
+ # Otherwise, the last argument is the destination. Remove it from $@.
+ for arg
+ do
+ if test -n "$dst_arg"; then
+ # $@ is not empty: it contains at least $arg.
+ set fnord "$@" "$dst_arg"
+ shift # fnord
+ fi
+ shift # arg
+ dst_arg=$arg
+ done
fi
-if [ x"$dir_arg" != x ]; then
- dst="$src"
- src=""
- if [ -d "$dst" ]; then
- instcmd=:
- else
- instcmd=mkdir
- fi
-else
+if test $# -eq 0; then
+ if test -z "$dir_arg"; then
+ echo "$0: no input file specified." >&2
+ exit 1
+ fi
+ # It's OK to call `install-sh -d' without argument.
+ # This can happen when creating conditional directories.
+ exit 0
+fi
-# Waiting for this to be detected by the "$instcmd $src $dsttmp" command
-# might cause directories to be created, which would be especially bad
-# if $src (and thus $dsttmp) contains '*'.
+if test -z "$dir_arg"; then
+ trap '(exit $?); exit' 1 2 13 15
- if [ -f "$src" -o -d "$src" ]
- then
- true
- else
- echo "install: $src does not exist"
- exit 1
- fi
- if [ x"$dst" = x ]
- then
- echo "install: no destination specified"
- exit 1
- else
- true
- fi
+ # Set umask so as not to create temps with too-generous modes.
+ # However, 'strip' requires both read and write access to temps.
+ case $mode in
+ # Optimize common cases.
+ *644) cp_umask=133;;
+ *755) cp_umask=22;;
-# If destination is a directory, append the input filename; if your system
-# does not like double slashes in filenames, you may need to add some logic
- if [ -d "$dst" ]
- then
- dst="$dst"/`basename $src`
- else
- true
- fi
+ *[0-7])
+ if test -z "$stripcmd"; then
+ u_plus_rw=
+ else
+ u_plus_rw='% 200'
+ fi
+ cp_umask=`expr '(' 777 - $mode % 1000 ')' $u_plus_rw`;;
+ u_plus_rw=
+ else
+ u_plus_rw=,u+rw
+ fi
+ cp_umask=$mode$u_plus_rw;;
+ esac
fi
-## this sed command emulates the dirname command
-dstdir=`echo "$dst" | sed -e 's,[^/]*$,,;s,/$,,;s,^$,.,'`
+for src
+do
+ # Protect names starting with `-'.
+ case $src in
+ -*) src=./$src;;
+ esac
-# Make sure that the destination directory exists.
-# this part is taken from Noah Friedman's mkinstalldirs script
+ if test -n "$dir_arg"; then
+ dst=$src
+ dstdir=$dst
+ test -d "$dstdir"
+ dstdir_status=$?
+ else
-# Skip lots of stat calls in the usual case.
-if [ ! -d "$dstdir" ]; then
-defaultIFS='
-IFS="${IFS-${defaultIFS}}"
+ # Waiting for this to be detected by the "$cpprog $src $dsttmp" command
+ # might cause directories to be created, which would be especially bad
+ # if $src (and thus $dsttmp) contains '*'.
+ if test ! -f "$src" && test ! -d "$src"; then
+ echo "$0: $src does not exist." >&2
+ exit 1
+ fi
-oIFS="${IFS}"
-# Some sh's can't handle IFS=/ for some reason.
-IFS='%'
-set - `echo "${dstdir}" | sed -e 's@/@%@g' -e 's@^%@/@'`
-IFS="${oIFS}"
+ if test -z "$dst_arg"; then
+ echo "$0: no destination specified." >&2
+ exit 1
+ fi
-pathcomp=''
+ dst=$dst_arg
+ case $dst in
+ -*) dst=./$dst;;
+ esac
-while [ $# -ne 0 ] ; do
- pathcomp="${pathcomp}${1}"
- shift
+ # If destination is a directory, append the input filename; won't work
+ # if double slashes aren't ignored.
+ if test -d "$dst"; then
+ if test -n "$no_target_directory"; then
+ echo "$0: $dst_arg: Is a directory" >&2
+ exit 1
+ fi
+ dstdir=$dst
+ dst=$dstdir/`basename "$src"`
+ dstdir_status=0
+ else
+ # Prefer dirname, but fall back on a substitute if dirname fails.
+ dstdir=`
+ (dirname "$dst") 2>/dev/null ||
+ expr X"$dst" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+ X"$dst" : 'X\(//\)[^/]' \| \
+ X"$dst" : 'X\(//\)$' \| \
+ X"$dst" : 'X\(/\)' \| . 2>/dev/null ||
+ echo X"$dst" |
+ sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+ s//\1/
+ q
+ /^X\(\/\/\)[^/].*/{
+ s//\1/
+ q
+ /^X\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'
- if [ ! -d "${pathcomp}" ] ;
- then
- $mkdirprog "${pathcomp}"
+ test -d "$dstdir"
+ dstdir_status=$?
+ fi
+ fi
+ obsolete_mkdir_used=false
+ if test $dstdir_status != 0; then
+ case $posix_mkdir in
+ # Create intermediate dirs using mode 755 as modified by the umask.
+ # This is like FreeBSD 'install' as of 1997-10-28.
+ umask=`umask`
+ case $stripcmd.$umask in
+ *[2367][2367]) mkdir_umask=$umask;;
+ .*0[02][02] | .[02][02] | .[02]) mkdir_umask=22;;
+ *[0-7])
+ mkdir_umask=`expr $umask + 22 \
+ - $umask % 100 % 40 + $umask % 20 \
+ - $umask % 10 % 4 + $umask % 2
+ *) mkdir_umask=$umask,go-w;;
+ esac
+ # With -d, create the new directory with the user-specified mode.
+ # Otherwise, rely on $mkdir_umask.
+ mkdir_mode=-m$mode
else
- true
+ mkdir_mode=
fi
- pathcomp="${pathcomp}/"
-done
-fi
+ posix_mkdir=false
+ case $umask in
+ *[123567][0-7][0-7])
+ # POSIX mkdir -p sets u+wx bits regardless of umask, which
+ # is incompatible with FreeBSD 'install' when (umask & 300) != 0.
+ tmpdir=${TMPDIR-/tmp}/ins$RANDOM-$$
+ trap 'ret=$?; rmdir "$tmpdir/d" "$tmpdir" 2>/dev/null; exit $ret' 0
-then
- "$doit" "$instcmd" "$dst" &&
+ if (umask $mkdir_umask &&
+ exec $mkdirprog $mkdir_mode -p -- "$tmpdir/d") >/dev/null 2>&1
+ then
+ if test -z "$dir_arg" || {
+ # Check for POSIX incompatibilities with -m.
+ # HP-UX 11.23 and IRIX 6.5 mkdir -m -p sets group- or
+ # other-writeable bit of parent directory when it shouldn't.
+ # FreeBSD 6.1 mkdir -m -p sets mode of existing directory.
+ ls_ld_tmpdir=`ls -ld "$tmpdir"`
+ case $ls_ld_tmpdir in
+ d????-?r-*) different_mode=700;;
+ d????-?--*) different_mode=755;;
+ *) false;;
+ esac &&
+ $mkdirprog -m$different_mode -p -- "$tmpdir" && {
+ ls_ld_tmpdir_1=`ls -ld "$tmpdir"`
+ test "$ls_ld_tmpdir" = "$ls_ld_tmpdir_1"
+ then posix_mkdir=:
+ fi
+ rmdir "$tmpdir/d" "$tmpdir"
+ else
+ # Remove any dirs left behind by ancient mkdir implementations.
+ rmdir ./$mkdir_mode ./-p ./-- 2>/dev/null
+ fi
+ trap '' 0;;
+ esac;;
+ esac
- if [ x"$chowncmd" != x ]; then "$doit" "$chowncmd" "$dst"; else true ; fi &&
- if [ x"$chgrpcmd" != x ]; then "$doit" "$chgrpcmd" "$dst"; else true ; fi &&
- if [ x"$stripcmd" != x ]; then "$doit" "$stripcmd" "$dst"; else true ; fi &&
- if [ x"$chmodcmd" != x ]; then "$doit" "$chmodcmd" "$dst"; else true ; fi
-else
+ if
+ $posix_mkdir && (
+ umask $mkdir_umask &&
+ $doit_exec $mkdirprog $mkdir_mode -p -- "$dstdir"
+ then :
+ else
-# If we're going to rename the final executable, determine the name now.
+ # The umask is ridiculous, or mkdir does not conform to POSIX,
+ # or it failed possibly due to a race condition. Create the
+ # directory the slow way, step by step, checking for races as we go.
- if [ x"$transformarg" = x ]
- then
- dstfile=`basename "$dst"`
- else
- dstfile=`basename "$dst" "$transformbasename" |
- sed "$transformarg"`"$transformbasename"
- fi
+ case $dstdir in
+ /*) prefix='/';;
+ -*) prefix='./';;
+ *) prefix='';;
+ esac
-# don't allow the sed command to completely eliminate the filename
+ eval "$initialize_posix_glob"
- if [ x"$dstfile" = x ]
- then
+ oIFS=$IFS
+ IFS=/
+ $posix_glob set -f
+ set fnord $dstdir
+ shift
+ $posix_glob set +f
+ IFS=$oIFS
+ prefixes=
+ for d
+ do
+ test -z "$d" && continue
+ prefix=$prefix$d
+ if test -d "$prefix"; then
+ prefixes=
else
- true
+ if $posix_mkdir; then
+ (umask=$mkdir_umask &&
+ $doit_exec $mkdirprog $mkdir_mode -p -- "$dstdir") && break
+ # Don't fail if two instances are running concurrently.
+ test -d "$prefix" || exit 1
+ else
+ case $prefix in
+ *\'*) qprefix=`echo "$prefix" | sed "s/'/'\\\\\\\\''/g"`;;
+ *) qprefix=$prefix;;
+ esac
+ prefixes="$prefixes '$qprefix'"
+ fi
fi
+ prefix=$prefix/
+ done
-# Make a temp file name in the proper directory.
+ if test -n "$prefixes"; then
+ (umask $mkdir_umask &&
+ eval "\$doit_exec \$mkdirprog $prefixes") ||
+ test -d "$dstdir" || exit 1
+ obsolete_mkdir_used=true
+ fi
+ fi
+ fi
- dsttmp="$dstdir"/#inst.$$#
+ { test -z "$chowncmd" || $doit $chowncmd "$dst"; } &&
+ { test -z "$chgrpcmd" || $doit $chgrpcmd "$dst"; } &&
+ { test "$obsolete_mkdir_used$chowncmd$chgrpcmd" = false ||
+ test -z "$chmodcmd" || $doit $chmodcmd $mode "$dst"; } || exit 1
+ else
-# Move or copy the file name to the temp name
+ # Make a couple of temp file names in the proper directory.
+ dsttmp=$dstdir/_inst.$$_
+ rmtmp=$dstdir/_rm.$$_
- "$doit" "$instcmd" "$src" "$dsttmp" &&
+ # Trap to clean up those temp files at exit.
+ trap 'ret=$?; rm -f "$dsttmp" "$rmtmp" && exit $ret' 0
- trap 'rm -f "${dsttmp}"' 0 &&
+ # Copy the file name to the temp name.
+ (umask $cp_umask && $doit_exec $cpprog "$src" "$dsttmp") &&
-# and set any options; do chmod last to preserve setuid bits
+ # and set any options; do chmod last to preserve setuid bits.
+ # If any of these fail, we abort the whole thing. If we want to
+ # ignore errors from any of these, just make sure not to ignore
+ # errors from the above "$doit $cpprog $src $dsttmp" command.
+ { test -z "$chowncmd" || $doit $chowncmd "$dsttmp"; } &&
+ { test -z "$chgrpcmd" || $doit $chgrpcmd "$dsttmp"; } &&
+ { test -z "$stripcmd" || $doit $stripcmd "$dsttmp"; } &&
+ { test -z "$chmodcmd" || $doit $chmodcmd $mode "$dsttmp"; } &&
-# If any of these fail, we abort the whole thing. If we want to
-# ignore errors from any of these, just make sure not to ignore
-# errors from the above "$doit $instcmd $src $dsttmp" command.
+ # If -C, don't bother to copy if it wouldn't change the file.
+ if $copy_on_change &&
+ old=`LC_ALL=C ls -dlL "$dst" 2>/dev/null` &&
+ new=`LC_ALL=C ls -dlL "$dsttmp" 2>/dev/null` &&
- if [ x"$chowncmd" != x ]; then "$doit" "$chowncmd" "$dsttmp"; else true;fi &&
- if [ x"$chgrpcmd" != x ]; then "$doit" "$chgrpcmd" "$dsttmp"; else true;fi &&
- if [ x"$stripcmd" != x ]; then "$doit" "$stripcmd" "$dsttmp"; else true;fi &&
- if [ x"$chmodcmd" != x ]; then "$doit" "$chmodcmd" "$dsttmp"; else true;fi &&
+ eval "$initialize_posix_glob" &&
+ $posix_glob set -f &&
+ set X $old && old=:$2:$4:$5:$6 &&
+ set X $new && new=:$2:$4:$5:$6 &&
+ $posix_glob set +f &&
-# Now rename the file to the real destination.
+ test "$old" = "$new" &&
+ $cmpprog "$dst" "$dsttmp" >/dev/null 2>&1
+ then
+ rm -f "$dsttmp"
+ else
+ # Rename the file to the real destination.
+ $doit $mvcmd -f "$dsttmp" "$dst" 2>/dev/null ||
- "$doit" "$rmcmd" -f "$dstdir/$dstfile" &&
- "$doit" "$mvcmd" "$dsttmp" "$dstdir/$dstfile"
+ # The rename failed, perhaps because mv can't rename something else
+ # to itself, or perhaps because mv is so ancient that it does not
+ # support -f.
+ # Now remove or move aside any old file at destination location.
+ # We try this two ways since rm can't unlink itself on some
+ # systems and the destination file might be busy for other
+ # reasons. In this case, the final cleanup might fail but the new
+ # file should still install successfully.
+ test ! -f "$dst" ||
+ $doit $rmcmd -f "$dst" 2>/dev/null ||
+ { $doit $mvcmd -f "$dst" "$rmtmp" 2>/dev/null &&
+ { $doit $rmcmd -f "$rmtmp" 2>/dev/null; :; }
+ { echo "$0: cannot unlink or rename $dst" >&2
+ (exit 1); exit 1
-fi &&
+ # Now rename the file to the real destination.
+ $doit $mvcmd "$dsttmp" "$dst"
+ fi || exit 1
+ trap '' 0
+ fi
+done
-exit 0
+# Local variables:
+# eval: (add-hook 'write-file-hooks 'time-stamp)
+# time-stamp-start: "scriptversion="
+# time-stamp-format: "%:y-%02m-%02d.%02H"
+# time-stamp-time-zone: "UTC"
+# time-stamp-end: "; # UTC"
+# End:
