[GRASS-SVN] r56685 - grass/trunk/vector/v.colors
svn_grass at osgeo.org
Wed Jun 12 07:06:20 PDT 2013
Author: neteler
Date: 2013-06-12 07:06:20 -0700 (Wed, 12 Jun 2013)
New Revision: 56685
grass/trunk/vector/v.colors/thumbnails.py
thumbnails.py: convert tab to spaces
Modified: grass/trunk/vector/v.colors/thumbnails.py
--- grass/trunk/vector/v.colors/thumbnails.py 2013-06-12 08:16:27 UTC (rev 56684)
+++ grass/trunk/vector/v.colors/thumbnails.py 2013-06-12 14:06:20 UTC (rev 56685)
@@ -16,11 +16,11 @@
def cleanup():
if tmp_img:
- grass.try_remove(tmp_img)
+ grass.try_remove(tmp_img)
if tmp_grad_rel:
- grass.run_command('g.remove', rast = tmp_grad_rel, quiet = True)
+ grass.run_command('g.remove', rast = tmp_grad_rel, quiet = True)
if tmp_grad_abs:
- grass.run_command('g.remove', rast = tmp_grad_abs, quiet = True)
+ grass.run_command('g.remove', rast = tmp_grad_abs, quiet = True)
# def rotate(src, dst):
# grass.call(["convert", "-rotate", "90", src, dst])
@@ -32,17 +32,17 @@
i = 0
j = text.find('\n', i)
if text[i:j] != 'P6':
- raise IOError
+ raise IOError
i = j + 1
w, h = text[i:j].split()
if int(w) != width or int(h) != height:
- raise IOError
+ raise IOError
i = j + 1
maxval = text[i:j]
if int(maxval) != 255:
- raise IOError
+ raise IOError
i = j + 1
return array.array('B', text[i:])
@@ -57,35 +57,35 @@
def rotate_ppm(srcd):
dstd = array.array('B', len(srcd) * '\0')
for y in xrange(height):
- for x in xrange(width):
- for c in xrange(3):
- dstd[(x * height + (height - 1 - y)) * 3 + c] = srcd[(y * width + x) * 3 + c]
+ for x in xrange(width):
+ for c in xrange(3):
+ dstd[(x * height + (height - 1 - y)) * 3 + c] = srcd[(y * width + x) * 3 + c]
return dstd
def flip_ppm(srcd):
stride = width * 3
- dy = (height - 1 - y)
- dstd[dy * stride:(dy + 1) * stride] = srcd[y * stride:(y + 1) * stride]
+ dy = (height - 1 - y)
+ dstd[dy * stride:(dy + 1) * stride] = srcd[y * stride:(y + 1) * stride]
return dstd
def ppmtopng(dst, src):
if grass.find_program("g.ppmtopng", ["help"]):
- grass.run_command('g.ppmtopng', input = src, output = dst, quiet = True)
+ grass.run_command('g.ppmtopng', input = src, output = dst, quiet = True)
elif grass.find_program("pnmtopng"):
- fh = open(dst, 'wb')
- grass.call(["pnmtopng", src], stdout = fh)
- fh.close()
+ fh = open(dst, 'wb')
+ grass.call(["pnmtopng", src], stdout = fh)
+ fh.close()
elif grass.find_program("convert"):
- grass.call(["convert", src, dst])
+ grass.call(["convert", src, dst])
else:
- grass.fatal(_("Cannot find g.ppmtopng, pnmtopng or convert"))
+ grass.fatal(_("Cannot find g.ppmtopng, pnmtopng or convert"))
def convert_and_rotate(src, dst, flip = False):
ppm = read_ppm(src)
if flip:
- ppm = flip_ppm(ppm)
+ ppm = flip_ppm(ppm)
ppm = rotate_ppm(ppm)
write_ppm(tmp_img, ppm)
ppmtopng(dst, tmp_img)
@@ -98,41 +98,41 @@
lines = text.splitlines()
records = list()
for line in lines:
- if line.startswith("#"):
- # skip comments
- continue
- records.append(line.split())
+ if line.startswith("#"):
+ # skip comments
+ continue
+ records.append(line.split())
records = [record for record in records if record[0] != 'nv']
relative = False
absolute = False
for record in records:
- if record[0].endswith("%"):
- relative = True
- record[0] = record[0].rstrip("%")
- else:
- absolute = True
+ if record[0].endswith("%"):
+ relative = True
+ record[0] = record[0].rstrip("%")
+ else:
+ absolute = True
if absolute:
- if relative:
- minval = -0.04
- maxval = 0.04
- else:
- minval = float(records[0][0])
- maxval = float(records[-1][0])
- maxval = min(maxval, 2500000)
- grad = tmp_grad_abs
- grass.mapcalc("$grad = if(row()==1, float($min), float($max))",
- grad = tmp_grad_abs, min = minval, max = maxval, quiet = True)
+ if relative:
+ minval = -0.04
+ maxval = 0.04
+ else:
+ minval = float(records[0][0])
+ maxval = float(records[-1][0])
+ maxval = min(maxval, 2500000)
+ grad = tmp_grad_abs
+ grass.mapcalc("$grad = if(row()==1, float($min), float($max))",
+ grad = tmp_grad_abs, min = minval, max = maxval, quiet = True)
else:
- grad = tmp_grad_rel
+ grad = tmp_grad_rel
return grad
def make_image(output_dir, table, grad, discrete = False):
if discrete:
- lines, cols = height, 1
+ lines, cols = height, 1
else:
- lines, cols = None, None
+ lines, cols = None, None
grass.run_command("r.colors", map = grad, color = table, quiet = True)
grass.run_command("d.colortable", flags = 'n', map = grad, lines = lines, cols = cols, quiet = True)
outfile = os.path.join(output_dir, "Colortable_%s.png" % table)
@@ -147,7 +147,7 @@
output_dir = os.path.join(os.environ['GISBASE'], "docs", "html")
if not os.path.exists(output_dir):
- os.makedirs(output_dir)
+ os.makedirs(output_dir)
pid = os.getpid()
tmp_grad_abs = "tmp_grad_abs_%d" % pid
@@ -166,8 +166,8 @@
os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
for var in ['GRASS_LINE_WIDTH', 'GRASS_ANTIALIAS']:
- if var in os.environ:
- del os.environ[var]
+ if var in os.environ:
+ del os.environ[var]
grass.use_temp_region()
grass.run_command('g.region', rows = 100, cols = 100)
@@ -175,13 +175,13 @@
grass.mapcalc("$grad = row()/1.0", grad = tmp_grad_rel, quiet = True)
for table in os.listdir(color_dir):
- path = os.path.join(color_dir, table)
- grad = make_gradient(path)
- make_image(output_dir, table, grad)
+ path = os.path.join(color_dir, table)
+ grad = make_gradient(path)
+ make_image(output_dir, table, grad)
grass.mapcalc("$grad = row()", grad = tmp_grad_abs, quiet = True)
for table in ['grey.eq', 'grey.log', 'random']:
- make_image(output_dir, table, tmp_grad_abs, True)
+ make_image(output_dir, table, tmp_grad_abs, True)
if __name__ == "__main__":
atexit.register(cleanup)
