[GRASS-SVN] r56687 - grass/trunk/lib/python/pygrass
svn_grass at osgeo.org
Thu Jun 13 01:05:32 PDT 2013
Author: zarch
Date: 2013-06-13 01:05:32 -0700 (Thu, 13 Jun 2013)
New Revision: 56687
grass/trunk/lib/python/pygrass/functions.py
Add a function that return a list of files contained in a directory
Modified: grass/trunk/lib/python/pygrass/functions.py
--- grass/trunk/lib/python/pygrass/functions.py 2013-06-12 14:10:24 UTC (rev 56686)
+++ grass/trunk/lib/python/pygrass/functions.py 2013-06-13 08:05:32 UTC (rev 56687)
@@ -4,8 +4,8 @@
@author: pietro
import fnmatch
+import os
import grass.lib.gis as libgis
import grass.lib.raster as libraster
@@ -28,6 +28,22 @@
return fnmatch.filter(word_list, filter_string)
+def findfiles(dirpath, match=None):
+ """Return a list of the files"""
+ res = []
+ for f in sorted(os.listdir(dirpath)):
+ abspath = os.path.join(dirpath, f)
+ if os.path.isdir(abspath):
+ res.extend(findfiles(abspath, match))
+ if match:
+ if fnmatch.fnmatch(abspath, match):
+ res.append(abspath)
+ else:
+ return res
def remove(oldname, maptype):
"""Remove a map"""
grasscore.run_command('g.remove', quiet=True,
@@ -133,7 +149,7 @@
"""Query a raster map for each point feature of a vector
Example ::
>>> from grass.pygrass.vector import VectorTopo
>>> from grass.pygrass.raster import RasterRow
>>> ele = RasterRow('elevation')
