[GRASS-SVN] r56697 - grass/trunk/vector/v.split
svn_grass at osgeo.org
Fri Jun 14 02:15:29 PDT 2013
Author: mmetz
Date: 2013-06-14 02:15:29 -0700 (Fri, 14 Jun 2013)
New Revision: 56697
grass/trunk/vector/v.split/main.c
v.split: add option to not split lines when adding vertices
Modified: grass/trunk/vector/v.split/main.c
--- grass/trunk/vector/v.split/main.c 2013-06-14 08:35:33 UTC (rev 56696)
+++ grass/trunk/vector/v.split/main.c 2013-06-14 09:15:29 UTC (rev 56697)
@@ -35,13 +35,15 @@
int main(int argc, char *argv[])
struct GModule *module;
- struct Option *in_opt, *layer_opt, *out_opt, *length_opt, *units_opt, *vertices_opt;
+ struct Option *in_opt, *layer_opt, *out_opt, *length_opt,
+ *units_opt, *vertices_opt;
+ struct Flag *nosplit_flag;
struct Map_info In, Out;
- struct line_pnts *Points, *Points2;
+ struct line_pnts *Points, *Points2, *Points3;
struct line_cats *Cats;
- int line, nlines, layer;
+ int line, nlines, layer, nosplit;
double length = -1;
int vertices = 0;
double (*line_length) ();
@@ -82,6 +84,11 @@
vertices_opt->required = NO;
vertices_opt->multiple = NO;
vertices_opt->description = _("Maximum number of vertices in segment");
+ nosplit_flag = G_define_flag();
+ nosplit_flag->key = 'n';
+ nosplit_flag->label = _("Add new vertices, but do not split");
+ nosplit_flag->description = _("Applies only to 'length' option");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -146,6 +153,7 @@
if (vertices < 2)
G_fatal_error(_("Number of vertices must be at least 2"));
+ nosplit = nosplit_flag->answer;
Vect_set_open_level(2);
Vect_open_old2(&In, in_opt->answer, "", layer_opt->answer);
@@ -160,6 +168,7 @@
Points = Vect_new_line_struct();
Points2 = Vect_new_line_struct();
+ Points3 = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
nlines = Vect_get_num_lines(&In);
@@ -199,6 +208,9 @@
from = 0.;
G_debug(3, "n: %ld, step: %f", n, step);
+ if (nosplit)
+ Vect_reset_line(Points3);
for (i = 0; i < n; i++) {
int ret;
@@ -233,7 +245,13 @@
Points->z[Points->n_points - 1];
- Vect_write_line(&Out, ltype, Points2, Cats);
+ if (nosplit) {
+ if (Points3->n_points > 0)
+ Points3->n_points--;
+ Vect_append_points(Points3, Points2, GV_FORWARD);
+ else
+ Vect_write_line(&Out, ltype, Points2, Cats);
/* last point */
x = Points2->x[Points2->n_points - 1];
@@ -242,6 +260,8 @@
from += step;
+ if (nosplit)
+ Vect_write_line(&Out, ltype, Points3, Cats);
else {
