[GRASS-SVN] r56701 - grass/trunk/scripts/v.db.addtable
svn_grass at osgeo.org
Fri Jun 14 03:52:10 PDT 2013
Author: mmetz
Date: 2013-06-14 03:52:10 -0700 (Fri, 14 Jun 2013)
New Revision: 56701
grass/trunk/scripts/v.db.addtable/v.db.addtable.py
v.db.addtable: add schema to table name if schema exists
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2013-06-14 10:24:21 UTC (rev 56700)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2013-06-14 10:52:10 UTC (rev 56701)
@@ -87,6 +87,7 @@
kv = grass.db_connection()
database = kv['database']
driver = kv['driver']
+ schema = kv['schema']
# maybe there is already a table linked to the selected layer?
nuldev = file(os.devnull, 'w')
@@ -119,6 +120,8 @@
grass.fatal(_("Unable to create table <%s>") % table)
# connect the map to the DB:
+ if schema is not '':
+ table = '%s.%s' (schema, table)
grass.run_command('v.db.connect', quiet = True,
map = map_name, database = database, driver = driver,
layer = layer, table = table, key = key)
