[GRASS-SVN] r56706 - grass/trunk/raster/r.li
svn_grass at osgeo.org
Fri Jun 14 22:51:19 PDT 2013
Author: hamish
Date: 2013-06-14 22:51:19 -0700 (Fri, 14 Jun 2013)
New Revision: 56706
grass/trunk/raster/r.li/r.li.html
merge fixes from devbr6
Modified: grass/trunk/raster/r.li/r.li.html
--- grass/trunk/raster/r.li/r.li.html 2013-06-15 05:49:38 UTC (rev 56705)
+++ grass/trunk/raster/r.li/r.li.html 2013-06-15 05:51:19 UTC (rev 56706)
@@ -9,54 +9,67 @@
<img src="grass_logo.png" alt="GRASS logo"><hr align=center size=6 noshade>
<h2>NAME</h2>
<em><b>r.li</b></em> - Landscape structure analysis package overview.
<h2>KEYWORDS</h2>
-raster, landscape structure analysis, landscape metrics, landscape pattern, landscape analysis
+raster, landscape structure analysis, landscape metrics,
+landscape pattern, landscape analysis
<h2>DESCRIPTION</h2>
-The <em>r.li</em> suite is a toolset for multiscale analysis of landscape structure.
-It aims at replacing the <em>r.le</em> suite of modules through a client-server,
-multiprocess implementation. External software for quantitative measures of landscape
-structure is for example FRAGSTATS (McGarigal and Marks 1995).
-<p>The <em>r.li</em> suite offers a set of patch and diversity indices.
-It supports analysis of landscapes composed of a mosaic of
-patches, but, more generally, the modules work with any two-dimensional
-raster map whose cell values are integer (e.g., 1, 2) or floating point
-(e.g., 1.1, 3.2) values. The <em>r.li.setup</em> module has options for
-controlling the shape, size, number, and distribution of sampling
-areas used to collect information about the landscape structure.
-Sampling area shapes can be the entire map or a moving
-window of square, rectangular or with circular shape. The size of
-sampling areas can be changed, so that the landscape can be analyzed
-at a variety of spatial scales simultaneously. Sampling areas may be
-distributed across the landscape in a random, systematic, or
-stratified-random manner, or as a moving window.
-<p>The <em>r.li</em> modules can calculate a number of measures that produce
-single values as output (e.g. mean patch size in the sampling area),
-as well as measures that produce a distribution of values as output
-(e.g. frequency distribution of patch sizes in the sampling area). The
-results are stored as raster maps.
+The <em>r.li</em> suite is a toolset for multiscale analysis of landscape
+structure. It aims at replacing the <em>r.le</em> suite of modules
+through a client-server, multiprocess implementation. External software
+for quantitative measures of landscape structure is for example FRAGSTATS
+(McGarigal and Marks 1995).
+<p>
+The <em>r.li</em> suite offers a set of patch and diversity indices. It
+supports analysis of landscapes composed of a mosaic of patches, but,
+more generally, the modules work with any two-dimensional raster map
+whose cell values are integer (e.g., 1, 2) or floating point (e.g., 1.1,
+3.2) values. The <em>r.li.setup</em> module has options for controlling
+the shape, size, number, and distribution of sampling areas used to
+collect information about the landscape structure. Sampling area shapes
+can be the entire map or a moving window of square, rectangular or with
+circular shape. The size of sampling areas can be changed, so that the
+landscape can be analyzed at a variety of spatial scales simultaneously.
+Sampling areas may be distributed across the landscape in a random,
+systematic, or stratified-random manner, or as a moving window.
+<p>
+The <em>r.li</em> modules can calculate a number of measures that produce
+single values as output (e.g. mean patch size in the sampling area), as
+well as measures that produce a distribution of values as output (e.g.
+frequency distribution of patch sizes in the sampling area). The results
+are stored as raster maps.
-<p>The general procedure to calculate an index from a raster map is two-fold:
+<p>
+The general procedure to calculate an index from a raster map is
+two-fold:
<ol>
-<li>run <em>r.li.setup</em>: create a configuration file selecting the parts of
- raster to analyze.
+<li>run <em>r.li.setup</em>: create a configuration file selecting the
+ parts of raster to analyze.
-<li>run <em>r.li.'index'</em> (e.g., <em>r.li.patchdensity</em>) for calculate the selected
- index using on the areas selected on configuration file.
+<li>run <em>r.li.'index'</em> (e.g., <em>r.li.patchdensity</em>) for
+ calculate the selected index using on the areas selected on
+ configuration file.
</ol>
-<h2>NOTE</h2>
-Also the <em>r.li.daemon</em> has a main function and it can be run, but it is only a
-template for development of new indices.
+<h2>NOTES</h2>
+Also the <em>r.li.daemon</em> has a main function and it can be run, but
+it is only a template for development of new indices.
<!-- mhh ??: -->
-The function itself has no meaning, it can be used only for debug.
+The function itself has no meaning, it can only be used for debugging.
<h2>EXAMPLE</h2>
To calculate a patch density index on a whole 'geology' raster map in the
@@ -67,40 +80,42 @@
<ol>
<li> run
<div class="code"><pre>
- r.li.setup
+ r.li.setup
</pre></div>
<li> The main <em>r.li.setup</em> window is displayed, click on "New"
- <li> Now it is displayed the new configuration window,
- enter the configuration file name (e.g., "my_conf", do not use absolute paths)
- and the name of raster map (e.g., "geology").
- The other fields are not needed for this configuration.
+ <li> Now it is displayed the new configuration window, enter the
+ configuration file name (e.g., "my_conf", do not use absolute
+ paths) and the name of raster map (e.g., "geology"). The other
+ fields are not needed for this configuration.
<li> Click on "Setup sampling frame", select "Whole maplayer" and click "OK"
<li> Click on "Setup sampling areas", select "Moving window" and click "OK"
<li> Click on "Use keyboard to enter moving window dimension"
<li> Select "Rectangle" and enter 5 on "heigth" and "width" fields
<li> Click on "Save settings"
- <li> Close <em>r.li.setup</em> window
+ <li> Close the <em>r.li.setup</em> window
</ol>
<li> CALCULATE PATCHDENSITY INDEX
-<ol>
- <li> set region settings to geology raster map:
+ <ol>
+ <li> set the region settings to the "<tt>geology</tt>" raster map:
- g.region rast=geology -p
+ g.region rast=geology -p
</pre></div>
- <li> run <em>r.li.patchdensity</em>:
+ <li> run <em>r.li.patchdensity</em>:
- r.li.patchdensity map=geology conf=my_conf out=patchdens
+ r.li.patchdensity map=geology conf=my_conf out=patchdens
</pre></div>
</ol>
</ol>
-The resulting patch density is stored in "patchdens" raster map.
+The resulting patch density is stored in "<tt>patchdens</tt>" raster map.
You can verify the result for example with contour lines:
-r.contour in=patchdens out=patchdens step=5
-d.rast patchdens
-d.vect -c patchdens
+ r.contour in=patchdens out=patchdens step=5
+ d.rast patchdens
+ d.vect -c patchdens
</pre></div>
Note that if you want to run another index with the same area
@@ -112,6 +127,7 @@
configuration file on a 200x200 raster map, then the sample area is
10x10.
<h2>SEE ALSO</h2>
<b>Core modules</b>:
@@ -127,6 +143,7 @@
<li> <a href="r.li.patchdensity.html">r.li.patchdensity</a>: Calculates patch density index on a raster map, using a 4 neighbour algorithm</li>
<li> <a href="r.li.patchnum.html">r.li.patchnum</a>: Calculates patch number index on a raster map, using a 4 neighbour algorithm</li>
</ul>
<li>Indices based on patch dimension:
<ul>
<li> <a href="r.li.mps.html">r.li.mps</a>: Calculates mean patch size index on a raster map, using a 4 neighbour algorithm</li>
@@ -134,19 +151,23 @@
<li> <a href="r.li.padrange.html">r.li.padrange</a>: Calculates range of patch area size on a raster map</li>
<li> <a href="r.li.padsd.html">r.li.padsd</a>: Calculates standard deviation of patch area a raster map</li>
</ul>
<li>Indices based on patch shape:
<ul>
<li> <a href="r.li.shape.html">r.li.shape</a>: Calculates shape index on a raster map</li>
</ul>
<li>Indices based on patch edge: <!-- border? -->
<ul>
<li> <a href="r.li.edgedensity.html">r.li.edgedensity</a>: Calculates edge density index on a raster map, using a 4 neighbour algorithm</li>
</ul>
<li>Indices based on patch attributes:
<ul>
<li> <a href="r.li.cwed.html">r.li.cwed</a>: Calculates contrast Weighted Edge Density index on a raster map</li>
<li> <a href="r.li.mpa.html">r.li.mpa</a>: Calculates mean pixel attribute index on a raster map</li>
</ul>
</ul>
<b>Diversity indices</b>:
@@ -159,27 +180,45 @@
<li> <a href="r.li.simpson.html">r.li.simpson</a>: Calculates Simpson diversity index on a raster map</li>
</ul>
<h2>ADDING NEW INDICES</h2>
-New indices can be defined and implemented by any C programmer, without having to
-deal with all basic functions (IO etc.). The computing architecture and the functions
-are clearly separated, thus allowing an easy expandability. Every index is defined
-separately, placed in a directory along with its Makefile for compiling it and a file
-description.html which describes the index including a simple example of use.
+New indices can be defined and implemented by any C programmer, without
+having to deal with all basic functions (IO etc.). The computing
+architecture and the functions are clearly separated, thus allowing an
+easy expandability. Every index is defined separately, placed in a
+directory along with its Makefile for compiling it and a file
+<module_name>.html which describes the index including a simple
+example of use.
<h2>REFERENCES</h2>
McGarigal, K., and B. J. Marks. 1995. FRAGSTATS: spatial pattern
analysis program for quantifying landscape structure. USDA For. Serv.
-Gen. Tech. Rep. PNW-351 (<a href="http://www.fs.fed.us/pnw/pubs/gtr_351.pdf">PDF</a>).
+Gen. Tech. Rep. PNW-351
+ (<a href="http://www.fs.fed.us/pnw/pubs/gtr_351.pdf">PDF</a>).
<h2>AUTHORS</h2>
<a href="mailto:porta at cli.di.unipi.it">Claudio Porta</a> and
-<a href="mailto:spano at cli.di.unipi.it">Lucio Davide Spano</a>, students of Computer Science
-University of Pisa (Italy). <br>
+<a href="mailto:spano at cli.di.unipi.it">Lucio Davide Spano</a>,
+ students of Computer Science
+University of Pisa (Italy).<br>
Commission from Faunalia Pontedera (PI)<br>
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
<hr>
-<p><a href="index.html">Main index</a> - <a href="raster.html">Raster index</a> - <a href="topics.html">Topics index</a> - <a href="keywords.html">Keywords Index</a> - <a href="full_index.html">Full index</a>
+<p>
+<a href="index.html">Main index</a>
+ - <a href="raster.html">Raster index</a>
+ - <a href="topics.html">Topics index</a>
+ - <a href="keywords.html">Keywords Index</a>
+ - <a href="full_index.html">Full index</a>
</body>
</html>
