[GRASS-SVN] r56711 - grass/branches/develbranch_6/raster/r.li/r.li.setup
svn_grass at osgeo.org
Sat Jun 15 00:04:35 PDT 2013
Author: hamish
Date: 2013-06-15 00:04:35 -0700 (Sat, 15 Jun 2013)
New Revision: 56711
Added:
grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh
Removed:
grass/branches/develbranch_6/raster/r.li/r.li.setup/Makefile
grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.procedures.tcl
rename script to add extension
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/Makefile
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/Makefile 2013-06-15 07:01:57 UTC (rev 56710)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/Makefile 2013-06-15 07:04:35 UTC (rev 56711)
@@ -9,7 +9,7 @@
default: script
$(MKDIR) $(TARGET)
$(INSTALL) area_query $(TARGET)/area_query
- $(INSTALL) masked_area_selection $(TARGET)/masked_area_selection
+ $(INSTALL) masked_area_selection.sh $(TARGET)/masked_area_selection.sh
$(INSTALL) r.li.setup.main $(TARGET)/r.li.setup.main
$(INSTALL) r.li.setup.procedures.tcl $(TARGET)/r.li.setup.procedures.tcl
$(INSTALL) r.li.windows.tcl $(TARGET)/r.li.windows.tcl
Deleted: grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection 2013-06-15 07:01:57 UTC (rev 56710)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection 2013-06-15 07:04:35 UTC (rev 56711)
@@ -1,167 +0,0 @@
-#! /bin/sh -x
-#%Module
-#%description: Select a circular or polygonal area
-#%End
-#%option
-#% key: raster
-#% type: string
-#% description: raster map to to analyse
-#% required: yes
-#%end
-#%option
-#% key: vector
-#% type: string
-#% description: vector to overlay
-#% required: no
-#%end
-#%option
-#% key: site
-#% type: string
-#% description: site to overlay
-#% required: no
-#%end
-#%option
-#% key: conf
-#% type: string
-#% description: name of configuration file where insert areas
-#% required: yes
-#%end
-#%option
-#% key: north
-#% type: string
-#% description: nothern edge (use only with f flag)
-#% required: no
-#%end
-#%option
-#% key: south
-#% type: string
-#% description:south edge (use only with f flag)
-#% required: no
-#%end
-#%option
-#% key: east
-#% type: string
-#% description: east edge(use only with f flag)
-#% required: no
-#%end
-#%option
-#% key: west
-#% type: string
-#% description: west edge(use only with f flag)
-#% required: no
-#%end
-#%flag
-#% key: f
-#% description: sample frame yet selected
-#%end
-#%flag
-#% key: c
-#% description: take a circular area
-#%end
-# Where to find the others scripts
-f_path="$GISBASE/etc/r.li.setup"
-# Check if we have grass
-if test "$GISBASE" = ""; then
- echo "You must be in GRASS GIS to run this program." >&2
- exit 1
- fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
- exec g.parser "$0" "$@"
-fi
-#### set temporary files
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
- echo "ERROR: unable to create temporary files" 1>&2
- exit 1
-fi
-#### environment variables
-g.gisenv LOCATION_NAME > $TMP.var
-read LOCATION < $TMP.var
-g.gisenv GISDBASE > $TMP.var
-read GISDBASE < $TMP.var
-g.gisenv MAPSET > $TMP.var
-read MAPSET < $TMP.var
-# show the sampling frame
-if [ $GIS_FLAG_f -eq 1 ] ; then
- g.region n=$GIS_OPT_north s=$GIS_OPT_south e=$GIS_OPT_east w=$GIS_OPT_west
-else
- g.region rast=$GIS_OPT_raster
-fi
-# open x1 monitor
-d.mon stop=x1
-d.mon start=x1
-d.rast -o map=$GIS_OPT_raster
-if [ -n "$GIS_OPT_vector" ] ; then
- d.vect map=$GIS_OPT_vector
-fi
-if [ -n "$GIS_OPT_site" ] ; then
- d.vect map=$GIS_OPT_site
-fi
-#let draw area
-if [ $GIS_FLAG_c -eq 1 ] ; then
- cp $f_path/circle.txt $$.txt
- echo "$$" >> $$.txt
-else
- cp $f_path/polygon.txt $$.txt
-fi
-r.digit < $$.txt
-#show the selected area
-d.rast -o map=$$
-export name=$$.val
-$GRASS_WISH $f_path/area_query
- cat $name | cut -f1 -d ' ' > $name.var
- read ok < $name.var
- cat $name | cut -f2 -d' ' > $name.var
- r_name=""
- read r_name < $name.var
- if [ $ok -eq 1 ] ; then
- r.to.vect input="$$" output="v$$" feature=area
- g.region vect="v$$"
- v.to.rast input="v$$" output=$r_name value=1 use=val
- #write info in configuration file
- g.region -g| grep "n=" | cut -f2 -d'='> $name.var
- read north < $name.var
- g.region -g| grep "s=" | cut -f2 -d'=' > $name.var
- read south < $name.var
- g.region -g| grep "e=" | cut -f2 -d'=' > $name.var
- read east < $name.var
- g.region -g| grep "w=" | cut -f2 -d'=' > $name.var
- read west < $name.var
- echo "SAMPLEAREAMASKED $r_name $north|$south|$east|$west" >>\
- $GIS_OPT_conf
- #remove tmp raster and vector
- g.remove rast=$$
- g.remove vect=v$$
- #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cats/"$$"
- #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cell/"$$"
- #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cellhd/"$$"
- #rm -fR "$GISDBASE"/"$LOCATION"/"$MAPSET"/cell_misc/"$$"
- #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/colr/"$$"
- #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/hist/"$$"
- #rm -fR "$GISDBASE"/"$LOCATION"/"$MAPSET"/vector/"v$$"
- echo DROP TABLE "v$$" | db.execute
- if [ $GIS_FLAG_f -eq 1 ] ; then
- else
- fi
- else
- echo 0 >> $GIS_OPT_conf
- fi
-d.mon stop=x1
-#clean tmp files
-rm -f $$*
-rm -f $TMP*
Copied: grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh (from rev 56706, grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection)
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh (rev 0)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/masked_area_selection.sh 2013-06-15 07:04:35 UTC (rev 56711)
@@ -0,0 +1,167 @@
+#! /bin/sh -x
+#%Module
+#%description: Select a circular or polygonal area
+#%End
+#%option
+#% key: raster
+#% type: string
+#% description: raster map to to analyse
+#% required: yes
+#%end
+#%option
+#% key: vector
+#% type: string
+#% description: vector to overlay
+#% required: no
+#%end
+#%option
+#% key: site
+#% type: string
+#% description: site to overlay
+#% required: no
+#%end
+#%option
+#% key: conf
+#% type: string
+#% description: name of configuration file where insert areas
+#% required: yes
+#%end
+#%option
+#% key: north
+#% type: string
+#% description: nothern edge (use only with f flag)
+#% required: no
+#%end
+#%option
+#% key: south
+#% type: string
+#% description:south edge (use only with f flag)
+#% required: no
+#%end
+#%option
+#% key: east
+#% type: string
+#% description: east edge(use only with f flag)
+#% required: no
+#%end
+#%option
+#% key: west
+#% type: string
+#% description: west edge(use only with f flag)
+#% required: no
+#%end
+#%flag
+#% key: f
+#% description: sample frame yet selected
+#%end
+#%flag
+#% key: c
+#% description: take a circular area
+#%end
+# Where to find the others scripts
+f_path="$GISBASE/etc/r.li.setup"
+# Check if we have grass
+if test "$GISBASE" = ""; then
+ echo "You must be in GRASS GIS to run this program." >&2
+ exit 1
+ fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+ exec g.parser "$0" "$@"
+fi
+#### set temporary files
+TMP="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+ echo "ERROR: unable to create temporary files" 1>&2
+ exit 1
+fi
+#### environment variables
+g.gisenv LOCATION_NAME > $TMP.var
+read LOCATION < $TMP.var
+g.gisenv GISDBASE > $TMP.var
+read GISDBASE < $TMP.var
+g.gisenv MAPSET > $TMP.var
+read MAPSET < $TMP.var
+# show the sampling frame
+if [ $GIS_FLAG_f -eq 1 ] ; then
+ g.region n=$GIS_OPT_north s=$GIS_OPT_south e=$GIS_OPT_east w=$GIS_OPT_west
+else
+ g.region rast=$GIS_OPT_raster
+fi
+# open x1 monitor
+d.mon stop=x1
+d.mon start=x1
+d.rast -o map=$GIS_OPT_raster
+if [ -n "$GIS_OPT_vector" ] ; then
+ d.vect map=$GIS_OPT_vector
+fi
+if [ -n "$GIS_OPT_site" ] ; then
+ d.vect map=$GIS_OPT_site
+fi
+#let draw area
+if [ $GIS_FLAG_c -eq 1 ] ; then
+ cp $f_path/circle.txt $$.txt
+ echo "$$" >> $$.txt
+else
+ cp $f_path/polygon.txt $$.txt
+fi
+r.digit < $$.txt
+#show the selected area
+d.rast -o map=$$
+export name=$$.val
+$GRASS_WISH $f_path/area_query
+ cat $name | cut -f1 -d ' ' > $name.var
+ read ok < $name.var
+ cat $name | cut -f2 -d' ' > $name.var
+ r_name=""
+ read r_name < $name.var
+ if [ $ok -eq 1 ] ; then
+ r.to.vect input="$$" output="v$$" feature=area
+ g.region vect="v$$"
+ v.to.rast input="v$$" output=$r_name value=1 use=val
+ #write info in configuration file
+ g.region -g| grep "n=" | cut -f2 -d'='> $name.var
+ read north < $name.var
+ g.region -g| grep "s=" | cut -f2 -d'=' > $name.var
+ read south < $name.var
+ g.region -g| grep "e=" | cut -f2 -d'=' > $name.var
+ read east < $name.var
+ g.region -g| grep "w=" | cut -f2 -d'=' > $name.var
+ read west < $name.var
+ echo "SAMPLEAREAMASKED $r_name $north|$south|$east|$west" >>\
+ $GIS_OPT_conf
+ #remove tmp raster and vector
+ g.remove rast=$$
+ g.remove vect=v$$
+ #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cats/"$$"
+ #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cell/"$$"
+ #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/cellhd/"$$"
+ #rm -fR "$GISDBASE"/"$LOCATION"/"$MAPSET"/cell_misc/"$$"
+ #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/colr/"$$"
+ #rm -f "$GISDBASE"/"$LOCATION"/"$MAPSET"/hist/"$$"
+ #rm -fR "$GISDBASE"/"$LOCATION"/"$MAPSET"/vector/"v$$"
+ echo DROP TABLE "v$$" | db.execute
+ if [ $GIS_FLAG_f -eq 1 ] ; then
+ else
+ fi
+ else
+ echo 0 >> $GIS_OPT_conf
+ fi
+d.mon stop=x1
+#clean tmp files
+rm -f $$*
+rm -f $TMP*
Modified: grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.procedures.tcl
--- grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.procedures.tcl 2013-06-15 07:01:57 UTC (rev 56710)
+++ grass/branches/develbranch_6/raster/r.li/r.li.setup/r.li.setup.procedures.tcl 2013-06-15 07:04:35 UTC (rev 56711)
@@ -413,7 +413,7 @@
set ins [vectorInstruction]
tkwait window $ins
while { $i < $number } {
- catch { exec $env(F_PATH)/masked_area_selection -f north=$env(SF_N) south=$env(SF_S) west=$env(SF_W) east=$env(SF_E) raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$env(TMP).tmp }
+ catch { exec $env(F_PATH)/masked_area_selection.sh -f north=$env(SF_N) south=$env(SF_S) west=$env(SF_W) east=$env(SF_E) raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$env(TMP).tmp }
set ok ""
catch {set ok [exec cat $env(TMP).tmp | grep "SAMPLEAREAMASKED" | cut -f1 -d\ ]}
if { $ok == "SAMPLEAREAMASKED" } then {
@@ -507,7 +507,7 @@
set ins [circleInstruction]
tkwait window $ins
while { $i < $num } {
- catch { exec $env(F_PATH)/masked_area_selection -f -c north=$env(SF_N) south=$env(SF_S) west=$env(SF_W) east=$env(SF_E) raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$env(TMP).tmp }
+ catch { exec $env(F_PATH)/masked_area_selection.sh -f -c north=$env(SF_N) south=$env(SF_S) west=$env(SF_W) east=$env(SF_E) raster=$env(RASTER) vector=$env(VECTOR) site=$env(SITE) conf=$env(TMP).tmp }
set ok ""
@@ -596,7 +596,7 @@
tkwait window $ins
while { $i == 0 } {
set ok ""
