[GRASS-SVN] r56716 - grass/branches/releasebranch_6_4/raster/r.li/r.li.setup
svn_grass at osgeo.org
Sat Jun 15 03:31:36 PDT 2013
Author: hamish
Date: 2013-06-15 03:31:36 -0700 (Sat, 15 Jun 2013)
New Revision: 56716
grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/circle.txt
grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/masked_area_selection
grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/polygon.txt
fix some low-hanging bugs (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/circle.txt
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/circle.txt 2013-06-15 10:28:41 UTC (rev 56715)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/circle.txt 2013-06-15 10:31:36 UTC (rev 56716)
@@ -2,4 +2,4 @@
1
mask
y
-Q
+X
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/masked_area_selection
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/masked_area_selection 2013-06-15 10:28:41 UTC (rev 56715)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/masked_area_selection 2013-06-15 10:31:36 UTC (rev 56716)
@@ -107,13 +107,11 @@
#let draw area
if [ $GIS_FLAG_c -eq 1 ] ; then
cp $f_path/circle.txt $$.txt
- echo "$$" >> $$.txt
else
cp $f_path/polygon.txt $$.txt
fi
-r.digit < $$.txt
+r.digit output="$$" < "$$.txt"
#show the selected area
d.rast -o map=$$
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/polygon.txt
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/polygon.txt 2013-06-15 10:28:41 UTC (rev 56715)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/polygon.txt 2013-06-15 10:31:36 UTC (rev 56716)
@@ -2,4 +2,4 @@
1
mask
y
-Q
+X
