[GRASS-SVN] r56723 - grass-addons/grass6/raster/r.fuzzy
svn_grass at osgeo.org
Sat Jun 15 20:31:43 PDT 2013
Author: hamish
Date: 2013-06-15 20:31:43 -0700 (Sat, 15 Jun 2013)
New Revision: 56723
grass-addons/grass6/raster/r.fuzzy/main.c
if it has a default answer then it isn't required
Modified: grass-addons/grass6/raster/r.fuzzy/main.c
--- grass-addons/grass6/raster/r.fuzzy/main.c 2013-06-16 03:08:46 UTC (rev 56722)
+++ grass-addons/grass6/raster/r.fuzzy/main.c 2013-06-16 03:31:43 UTC (rev 56723)
@@ -67,7 +67,6 @@
par_side->options = "both,left,right";
par_side->answer = "both";
par_side->multiple = NO;
- par_side->required = YES;
par_side->description = _("Fuzzy range");
par_type = G_define_option();
@@ -76,7 +75,6 @@
par_type->options = "Linear,S-shaped,J-shaped,G-shaped";
par_type->answer = "S-shaped";
par_type->multiple = NO;
- par_type->required = YES;
par_type->description = _("Type of fuzzy boundaries");
par_type->guisection = _("Default options");
@@ -86,7 +84,6 @@
par_shape->options = "-1.0-1.0";
par_shape->answer = "0.";
par_shape->multiple = NO;
- par_shape->required = YES;
par_shape->description = _("Shape modifier: -1 to 1");
par_shape->guisection = _("Default options");
@@ -96,13 +93,13 @@
par_height->options = "0.0-1.0";
par_height->answer = "1";
par_height->multiple = NO;
- par_height->required = YES;
par_height->description = _("Membership height: 0 to 1");
par_height->guisection = _("Default options");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
input = par_input->answer;
output = par_output->answer;
