[GRASS-SVN] r56741 - in grass/branches/develbranch_6: lib/init mswindows
svn_grass at osgeo.org
Sun Jun 16 20:22:27 PDT 2013
Author: hamish
Date: 2013-06-16 20:22:27 -0700 (Sun, 16 Jun 2013)
New Revision: 56741
grass/branches/develbranch_6/lib/init/init.bat
grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl
grass/branches/develbranch_6/mswindows/env.bat
use more as the default pager on wingrass (#945)
Modified: grass/branches/develbranch_6/lib/init/init.bat
--- grass/branches/develbranch_6/lib/init/init.bat 2013-06-17 02:43:40 UTC (rev 56740)
+++ grass/branches/develbranch_6/lib/init/init.bat 2013-06-17 03:22:27 UTC (rev 56741)
@@ -7,14 +7,14 @@
rem PURPOSE: The source file for this batch script is lib/init/init.bat.
rem It sets up some environment variables, default GISRC file
rem if necessary, etc. prior to starting GRASS proper.
-rem It is intended to be a native Windows replacement for Init.bat,
+rem It is intended to be a native Windows replacement for Init.sh,
rem but does not (yet) contain all the same functionality.
rem
rem In particular also, GUI mode prints nothing to the terminal
rem and does not expect or provide an interactive terminal
rem running in addition to the GUI display.
rem
-rem COPYRIGHT: (C) 2006, 2011 by the GRASS Development Team
+rem COPYRIGHT: (C) 2006-2013 by the GRASS Development Team
rem
rem This program is free software under the GNU General Public
rem License (>=v2). Read the file COPYING that comes with GRASS
@@ -55,7 +55,6 @@
FOR /F "usebackq delims==" %%i IN (`"%GISBASE%\etc\winlocale"`) DO @set LANG=%%i
:langset
-set GRASS_PAGER=more
if "%GRASS_WISH%"=="" set GRASS_WISH=wish.exe
if "%GRASS_SH%"=="" set GRASS_SH=c:\msys\1.0\bin\sh.exe
Modified: grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl
--- grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl 2013-06-17 02:43:40 UTC (rev 56740)
+++ grass/branches/develbranch_6/mswindows/GRASS-Installer.nsi.tmpl 2013-06-17 03:22:27 UTC (rev 56741)
@@ -759,7 +759,7 @@
FileWrite $0 '# requires a source file because the definition of GISBASE$\r$\n'
FileWrite $0 '# is not known until compile time and is substituted from the$\r$\n'
FileWrite $0 '# Makefile. Any command line options are passed to Init.sh.$\r$\n'
- FileWrite $0 '# COPYRIGHT: (C) 2000-2010 by the GRASS Development Team$\r$\n'
+ FileWrite $0 '# COPYRIGHT: (C) 2000-2013 by the GRASS Development Team$\r$\n'
FileWrite $0 '#$\r$\n'
FileWrite $0 '# This program is free software under the GNU General Public$\r$\n'
FileWrite $0 '# License (>=v2). Read the file COPYING that comes with GRASS$\r$\n'
@@ -785,6 +785,10 @@
FileWrite $0 'PATH="$$GISBASE/extrabin:$$GISBASE/extralib:$$PATH"$\r$\n'
FileWrite $0 'PATH="$$GISBASE/tcl-tk/bin:$$GISBASE/sqlite/bin:$$PATH"$\r$\n'
FileWrite $0 'export PATH$\r$\n'
+ FileWrite $0 '$\r$\n'
+ FileWrite $0 'GRASS_PAGER=more$\r$\n'
+ FileWrite $0 'export GRASS_PAGER$\r$\n'
FileWrite $0 '# Set the PYTHONPATH variable$\r$\n'
FileWrite $0 'PYTHONPATH="$$GISBASE/etc/python:$$GISBASE/Python27:$$PYTHONPATH"$\r$\n'
FileWrite $0 'export PYTHONPATH$\r$\n'
@@ -795,7 +799,7 @@
FileWrite $0 ' export GRASS_PYTHON$\r$\n'
FileWrite $0 'fi$\r$\n'
- FileWrite $0 '# Set to default web browser$\r$\n'
+ FileWrite $0 '# Set the default web browser$\r$\n'
FileWrite $0 'GRASS_HTML_BROWSER=explorer$\r$\n'
FileWrite $0 'export GRASS_HTML_BROWSER$\r$\n'
Modified: grass/branches/develbranch_6/mswindows/env.bat
--- grass/branches/develbranch_6/mswindows/env.bat 2013-06-17 02:43:40 UTC (rev 56740)
+++ grass/branches/develbranch_6/mswindows/env.bat 2013-06-17 03:22:27 UTC (rev 56741)
@@ -5,6 +5,7 @@
set GRASS_PROJSHARE=%GISBASE%\proj
set GRASS_HTML_BROWSER=explorer
set GRASS_SH=%GISBASE%\msys\bin\sh.exe
+set GRASS_PAGER=more
set PYTHONHOME=%GISBASE%\Python27
set GDAL_DATA=%GISBASE%\share\gdal
