[GRASS-SVN] r56756 - grass-addons/grass7/raster/r.fuzzy/r.fuzzy.system
svn_grass at osgeo.org
Mon Jun 17 02:32:50 PDT 2013
Author: neteler
Date: 2013-06-17 02:32:50 -0700 (Mon, 17 Jun 2013)
New Revision: 56756
grass-addons/grass7/raster/r.fuzzy/r.fuzzy.system/r.fuzzy.system.html
r.fuzzy.system.html: indications about specifying map names added
Modified: grass-addons/grass7/raster/r.fuzzy/r.fuzzy.system/r.fuzzy.system.html
--- grass-addons/grass7/raster/r.fuzzy/r.fuzzy.system/r.fuzzy.system.html 2013-06-17 09:30:20 UTC (rev 56755)
+++ grass-addons/grass7/raster/r.fuzzy/r.fuzzy.system/r.fuzzy.system.html 2013-06-17 09:32:50 UTC (rev 56756)
@@ -2,10 +2,11 @@
<dl>
<dt><b>maps</b></dt>
-<dd>A text file containing maps name and fuzzy sets connected with map
-definition. Maps in text file must exist on a search path, except the output
-map. The name of output map name is the output name parameter. In map file
-outmput map is marked by special name <b>_OUTPUT_</b> If maps are in different
+<dd>A text file containing maps name and fuzzy sets connected with map
+definition. The input maps (indicated with % in text file) must be found
+in the search path.
+The output map name is the output name parameter. In map file
+output map is marked by special name <b>_OUTPUT_</b> If maps are in different
mapsets the name require @. Map names in database cannot contain following
symbols: <b> %,$ and #</b>. Every map name must start with map name
identifier:<b> %</b>. Every set definition connected with cetrain map must
@@ -250,6 +251,11 @@
rules. For this example:
<p>MAPS
+Note: the raster map names are specified with a "%" character (here
+"%elevation" and "%distance" are the input maps and "%flood" the
+output map:
<div class="code"><pre>
#flood.map
%elevation
