[GRASS-SVN] r56772 - grass-addons/grass6/raster/r.hazard.flood
Tue Jun 18 01:47:38 PDT 2013
Author: hamish
Date: 2013-06-18 01:47:37 -0700 (Tue, 18 Jun 2013)
New Revision: 56772
   grass-addons/grass6/raster/r.hazard.flood/r.hazard.flood.py
commented out check for r.area, grass.messageify
Modified: grass-addons/grass6/raster/r.hazard.flood/r.hazard.flood.py
--- grass-addons/grass6/raster/r.hazard.flood/r.hazard.flood.py	2013-06-18 08:11:22 UTC (rev 56771)
+++ grass-addons/grass6/raster/r.hazard.flood/r.hazard.flood.py	2013-06-18 08:47:37 UTC (rev 56772)
@@ -50,9 +50,9 @@
     import grass.script as grass
 except:
     try:
-	    from grass.script import core as grass
+        from grass.script import core as grass
     except:
-        sys.exit( "grass.script can't be imported.")
+        sys.exit("grass.script can't be imported.")
 if not os.environ.has_key("GISBASE"):
     print "You must be in GRASS GIS to run this program."
@@ -66,6 +66,11 @@
     r_flood_map = options['flood']
     r_mti = options['mti']
+    #FIXME: find_program() not working for modules
+    ## check if we have the r.area addon
+    #if not grass.find_program('r.area'):
+    #    grass.fatal(_("The r.area module is required, please install it from Addons first"))
     # Detect cellsize of the DEM
     info_region = grass.read_command('g.region', flags = 'p', rast = '%s' % (r_elevation))
     dict_region = grass.parse_key_val(info_region, ':')
@@ -130,7 +135,7 @@
     grass.run_command('g.remove', rast = 'r_flood_th')
     grass.run_command('g.remove', rast = 'r_flood')
-    grass.run_command('g.message' , message = 'Done!')
+    grass.message(_('Done.'))
 if __name__ == "__main__":
     options, flags = grass.parser()
