[GRASS-SVN] r56776 - grass-addons/grass6/raster/r.surf.nnbathy
svn_grass at osgeo.org
Tue Jun 18 02:00:47 PDT 2013
Author: hamish
Date: 2013-06-18 02:00:47 -0700 (Tue, 18 Jun 2013)
New Revision: 56776
grass-addons/grass6/raster/r.surf.nnbathy/description.html
line wrap
Modified: grass-addons/grass6/raster/r.surf.nnbathy/description.html
--- grass-addons/grass6/raster/r.surf.nnbathy/description.html 2013-06-18 08:55:45 UTC (rev 56775)
+++ grass-addons/grass6/raster/r.surf.nnbathy/description.html 2013-06-18 09:00:47 UTC (rev 56776)
@@ -1,37 +1,75 @@
<h2>DESCRIPTION</h2>
-<em>r.surf.nnbathy</em> is an Bourne Shell and Awk script. It is an interface between the external <em>nnbathy</em> utility and <em>GRASS</em>. <em>nnbathy</em> is a surface interpolation program provided with <a href="https://code.google.com/p/nn-c/"">nn</a> - a natural neighbor interpolation library, written by Pavel Sakov.
+<em>r.surf.nnbathy</em> is an Bourne Shell and Awk script. It is an
+interface between the external <em>nnbathy</em> utility and <em>GRASS</em>.
+<em>nnbathy</em> is a surface interpolation program provided with
+<a href="https://code.google.com/p/nn-c/"">nn</a> - a natural neighbor
+interpolation library, written by Pavel Sakov.
<p>
-<em>r.surf.nnbathy</em> provides 3 interpolation algorithms. According to <em>nn</em> library documentation these are: Delaunay interpolation (<b>alg=l</b>), Watson's algortithm for Sibson natural neighbor interpolation (<b>alg=nn</b>) and Belikov and Semenov's algorithm for non-Sibsonian natural neighbor interpolation (<b>alg=ns</b>). For performing the underlaying Delaunay triangulation in all cases <em>nnbathy</em> uses <em>triangle</em> software by <a href="http://www.cs.berkeley.edu/~jrs/">Jonathan Richard Shewchuk</a>.
+<em>r.surf.nnbathy</em> provides 3 interpolation algorithms. According to
+<em>nn</em> library documentation these are: Delaunay interpolation
+(<b>alg=l</b>), Watson's algortithm for Sibson natural neighbor
+interpolation (<b>alg=nn</b>) and Belikov and Semenov's algorithm for
+non-Sibsonian natural neighbor interpolation (<b>alg=ns</b>). For performing
+the underlaying Delaunay triangulation in all cases <em>nnbathy</em> uses
+<em>triangle</em> software by
+<a href="http://www.cs.berkeley.edu/~jrs/">Jonathan Richard Shewchuk</a>.
<p>
-The <b>output</b> raster map is a continous surface interpolated from the <b>input</b> raster map.
+The <b>output</b> raster map is a continous surface interpolated from the
+<b>input</b> raster map.
<p>
-<em>nnbathy</em>, if built with '-DNN_SERIAL' (default as of nn 1.85), is able to create a grid of virtually any size. It interpolates and writes one output point at a time only. This eliminates the necessity to hold the whole output array in memory. However, even then all the input cells are still held in the memory.
+<em>nnbathy</em>, if built with '-DNN_SERIAL' (default as of nn 1.85), is
+able to create a grid of virtually any size. It interpolates and writes one
+output point at a time only. This eliminates the necessity to hold the whole
+output array in memory. However, even then all the input cells are still
+held in the memory.
<h2>NOTES</h2>
<ul>
1. Requires <em>GRASS</em> 6.x and <em>nnbathy</em> 1.76 or greater.<br>
-2. Build <em>nnbathy</em> according to instructions provided with its source code and put it somewhere in your $PATH.<br>
-3. The output raster map extent and resolution match the region settings at which the script was started.<br>
-4. The output raster map non-NULL area is limited to the convex hull encompassing all the non-NULL input cells.<br>
+2. Build <em>nnbathy</em> according to instructions provided with its source
+code and put it somewhere in your $PATH.<br>
+3. The output raster map extent and resolution match the region settings at
+which the script was started.<br>
+4. The output raster map non-NULL area is limited to the convex hull
+encompassing all the non-NULL input cells.<br>
5. The output is double floating point raster map.<br>
-6. Natural neighbor is a an <em>exact</em> interpolation algorithm, so all non-NULL input cells have their value exactly preserved in the output.<br>
-7. There is circa 0.2 KB memory overhead per each <em>input</em> cell. However, the <em>output</em> grid can be of any size, if <em>nnbathy</em> is built with -DNN_SERIAL switch.<br>
-8. <em>r.surf.nnbathy</em> creates 3 temporary files: ASCII x,y,z lists of the input and output cells, and the output list converted into GRASS ASCII format. Then it makes a GRASS raster map from the latter - and only then it removes the 3 temp files, when the script terminates. Thus, at the script run time several times more disk space might be required, than the final GRASS raster map would actually occupy.<br>
+6. Natural neighbor is a an <em>exact</em> interpolation algorithm, so all
+non-NULL input cells have their value exactly preserved in the output.<br>
+7. There is circa 0.2 KB memory overhead per each <em>input</em> cell.
+However, the <em>output</em> grid can be of any size, if <em>nnbathy</em> is
+built with -DNN_SERIAL switch.<br>
+8. <em>r.surf.nnbathy</em> creates 3 temporary files: ASCII x,y,z lists of
+the input and output cells, and the output list converted into GRASS ASCII
+format. Then it makes a GRASS raster map from the latter - and only then it
+removes the 3 temp files, when the script terminates. Thus, at the script
+run time several times more disk space might be required, than the final
+GRASS raster map would actually occupy.<br>
<p>
-I'd like to thank Pavel Sakov for his help, and especially for implementing serial input processing.
+I'd like to thank Pavel Sakov for his help, and especially for implementing
+serial input processing.
</ul>
<h2>SEE ALSO</h2>
<em><a href="v.to.rast.html">v.to.rast</a></em>
<h2>AUTHOR</h2>
Maciej Sieczka
