[GRASS-SVN] r56784 - in grass/branches/releasebranch_6_4: gui/wxpython/core scripts/d.rast.edit
svn_grass at osgeo.org
Tue Jun 18 04:26:03 PDT 2013
Author: hamish
Date: 2013-06-18 04:26:03 -0700 (Tue, 18 Jun 2013)
New Revision: 56784
grass/branches/releasebranch_6_4/gui/wxpython/core/gcmd.py
grass/branches/releasebranch_6_4/scripts/d.rast.edit/d.rast.edit.tcl
don't require the aspect map on wingrass; attempt to work around path environment setting issue (#86, merge from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/core/gcmd.py
--- grass/branches/releasebranch_6_4/gui/wxpython/core/gcmd.py 2013-06-18 11:09:16 UTC (rev 56783)
+++ grass/branches/releasebranch_6_4/gui/wxpython/core/gcmd.py 2013-06-18 11:26:03 UTC (rev 56784)
@@ -525,7 +525,7 @@
self.startTime = time.time()
- # TODO: replace ugly hack bellow
+ # TODO: replace ugly hack below
args = self.cmd
if sys.platform == 'win32' and os.path.splitext(self.cmd[0])[1] == '.py':
# Python GUI script should be replaced by Shell scripts
@@ -535,8 +535,12 @@
self.cmd[0] in globalvar.grassScripts[globalvar.SCT_EXT]:
args[0] = self.cmd[0] + globalvar.SCT_EXT
env = copy.deepcopy(self.env)
- env['PATH'] = os.path.join(os.getenv('GISBASE').replace('/', '\\'), 'scripts') + \
- os.pathsep + env['PATH']
+ # FIXME: env is None? hmph. borrow sys.path instead.
+ #env['PATH'] = os.path.join(os.getenv('GISBASE').replace('/', '\\'), 'scripts') + \
+ # os.pathsep + env['PATH']
+ scriptdir = os.path.join(os.getenv('GISBASE').replace('/', '\\'), 'scripts')
+ if scriptdir not in sys.path:
+ sys.path.append(scriptdir)
else:
env = self.env
Modified: grass/branches/releasebranch_6_4/scripts/d.rast.edit/d.rast.edit.tcl
--- grass/branches/releasebranch_6_4/scripts/d.rast.edit/d.rast.edit.tcl 2013-06-18 11:09:16 UTC (rev 56783)
+++ grass/branches/releasebranch_6_4/scripts/d.rast.edit/d.rast.edit.tcl 2013-06-18 11:26:03 UTC (rev 56784)
@@ -12,7 +12,11 @@
set outmap $env(GIS_OPT_OUTPUT)
set inmap $env(GIS_OPT_INPUT)
-set aspect $env(GIS_OPT_ASPECT)
+if {[info exists env(GIS_OPT_ASPECT)]} {
+ set aspect $env(GIS_OPT_ASPECT)
+} else {
+ set aspect ""
set width $env(GIS_OPT_WIDTH)
set height $env(GIS_OPT_HEIGHT)
set size $env(GIS_OPT_SIZE)
