[GRASS-SVN] r56787 - grass/trunk/raster/r.colors
svn_grass at osgeo.org
Tue Jun 18 16:57:08 PDT 2013
Author: hamish
Date: 2013-06-18 16:57:08 -0700 (Tue, 18 Jun 2013)
New Revision: 56787
grass/trunk/raster/r.colors/Makefile
grass/trunk/raster/r.colors/thumbnails.py
fix thumbnails insert into help page (#2009), add header comments to .py script, trivial linewrap
Modified: grass/trunk/raster/r.colors/Makefile
--- grass/trunk/raster/r.colors/Makefile 2013-06-18 15:04:30 UTC (rev 56786)
+++ grass/trunk/raster/r.colors/Makefile 2013-06-18 23:57:08 UTC (rev 56787)
@@ -15,13 +15,13 @@
# Insert thumbnail previews
r.colors.tmp.html: $(BIN)/r.colors$(EXE) thumbnails.py
$(call htmldesc,$<,$@)
- sed 's!^<DD><b>\([a-z0-9._]*\)</b>:!<DD><img width="80" height="12" src="Colortable_\1.png"> <b>\1</b>:!' "$@" > "$@.tmp"
+ sed 's!^<dd><b>\([a-z0-9._]*\)</b>:!<dd><img width="80" height="12" src="Colortable_\1.png"> <b>\1</b>:!' "$@" > "$@.tmp"
mv -f "$@.tmp" "$@"
$(MAKE) thumbnails
r3.colors.tmp.html: $(BIN)/r3.colors$(EXE) thumbnails.py
mv -f "$@.tmp" "$@"
$(MAKE) thumbnails
Modified: grass/trunk/raster/r.colors/thumbnails.py
--- grass/trunk/raster/r.colors/thumbnails.py 2013-06-18 15:04:30 UTC (rev 56786)
+++ grass/trunk/raster/r.colors/thumbnails.py 2013-06-18 23:57:08 UTC (rev 56787)
@@ -1,4 +1,16 @@
#!/usr/bin/env python
+# thumbnails.py: Create thumbnail sample images of the various GRASS color rules
+# AUTHOR: Python version by Glynn Clements
+# Earlier Bourne script version by Hamish Bowman,
+# http://grasswiki.osgeo.org/wiki/Talk:Color_tables
+# (C) 2009-2013 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
import sys
import os
@@ -134,7 +146,8 @@
else:
lines, cols = None, None
grass.run_command("r.colors", map = grad, color = table, quiet = True)
- grass.run_command("d.colortable", flags = 'n', map = grad, lines = lines, cols = cols, quiet = True)
+ grass.run_command("d.colortable", flags = 'n', map = grad,
+ lines = lines, cols = cols, quiet = True)
outfile = os.path.join(output_dir, "Colortable_%s.png" % table)
convert_and_rotate(tmp_img, outfile, discrete)
