[GRASS-SVN] r56790 - grass/branches/develbranch_6/gui/wxpython/location_wizard
svn_grass at osgeo.org
Tue Jun 18 22:58:22 PDT 2013
Author: hamish
Date: 2013-06-18 22:58:22 -0700 (Tue, 18 Jun 2013)
New Revision: 56790
grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py
present estimated +proj4 terms for Georef'd files and WKT creation options
Modified: grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py
--- grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py 2013-06-19 04:52:34 UTC (rev 56789)
+++ grass/branches/develbranch_6/gui/wxpython/location_wizard/wizard.py 2013-06-19 05:58:22 UTC (rev 56790)
@@ -225,7 +225,7 @@
"georeferenced data file"))
self.radio4 = wx.RadioButton(parent = self, id = wx.ID_ANY,
label = _("Read projection and datum terms from a "
- "WKT or PRJ file"))
+ "Well Known Text (WKT) .prj file"))
self.radio5 = wx.RadioButton(parent = self, id = wx.ID_ANY,
label = _("Specify projection and datum terms using custom "
"PROJ.4 parameters"))
@@ -1182,12 +1182,12 @@
for setting coordinate system parameters"""
def __init__(self, wizard, parent):
- TitledPage.__init__(self, wizard, _("Select WKT or PRJ file"))
+ TitledPage.__init__(self, wizard, _("Select Well Known Text (WKT) .prj file"))
self.wktfile = ''
# create controls
- self.lfile= self.MakeLabel(_("WKT or PRJ file:"))
+ self.lfile= self.MakeLabel(_("WKT .prj file:"))
self.tfile = self.MakeTextCtrl(size = (300,-1))
self.bbrowse = self.MakeButton(_("Browse"))
@@ -1239,7 +1239,7 @@
def OnBrowse(self, event):
"""!Choose file"""
dlg = wx.FileDialog(self,
- message = _("Select WKT or PRJ file"),
+ message = _("Select Well Known Text (WKT) .prj file"),
defaultDir = os.getcwd(),
wildcard = "PRJ files (*.prj)|*.prj|Files (*.*)|*.*",
style = wx.OPEN)
@@ -1656,28 +1656,39 @@
dtrans = self.parent.datumtrans
global coordsys
- if coordsys in ('proj', 'epsg'):
+ if coordsys in ('proj', 'epsg', 'wkt', 'file'):
+ extra_opts = {}
+ extra_opts['location'] = 'location'
+ extra_opts['getErrorMsg'] = True
+ extra_opts['read'] = True
if coordsys == 'proj':
addl_opts = {}
if len(datum) > 0:
- addl_opts['datum'] = '%s' % datum
- addl_opts['datumtrans'] = dtrans
+ extra_opts['datum'] = '%s' % datum
+ extra_opts['datumtrans'] = dtrans
ret, projlabel, err = RunCommand('g.proj',
flags = 'jf',
proj4 = proj4string,
- location = location,
- getErrorMsg = True,
- read = True,
- **addl_opts)
+ **extra_opts)
elif coordsys == 'epsg':
flags = 'jft',
epsg = epsgcode,
datumtrans = dtrans,
- read = True)
+ **extra_opts)
+ elif coordsys == 'file':
+ ret, projlabel, err = RunCommand('g.proj',
+ flags = 'jft',
+ georef = self.parent.filepage.georeffile,
+ **extra_opts)
+ elif coordsys == 'wkt':
+ flags = 'jft',
+ wkt = self.parent.wktpage.wktfile,
+ **extra_opts)
finishButton = wx.FindWindowById(wx.ID_FORWARD)
if ret == 0:
@@ -1699,23 +1710,30 @@
label = ''
- label = 'EPSG code %s (%s)' % (self.parent.epsgpage.epsgcode, self.parent.epsgpage.epsgdesc)
+ label = 'EPSG code %s (%s)' % (self.parent.epsgpage.epsgcode,
+ self.parent.epsgpage.epsgdesc)
label = 'matches file %s' % self.parent.filepage.georeffile
- self.lproj4string.SetLabel("")
label = 'matches file %s' % self.parent.wktpage.wktfile
elif coordsys == 'proj':
label = ('%s, %s %s' % (projdesc, datumdesc, ellipsedesc))
elif coordsys == 'xy':
label = ('XY coordinate system (not projected).')
elif coordsys == 'custom':
label = _("custom")
- combo_str = self.parent.custompage.customstring + self.parent.custompage.custom_dtrans_string
+ combo_str = self.parent.custompage.customstring + \
self.lproj4string.SetLabel(('%s' % combo_str.replace(' +', os.linesep + '+')))
self.lprojection.SetLabel(label)
def OnFinish(self, event):
dlg = wx.MessageDialog(parent = self.wizard,
@@ -1763,7 +1781,8 @@
# define wizard pages
- self.wizard = WizardWithHelpButton(parent, id = wx.ID_ANY, title = _("Define new GRASS Location"),
+ self.wizard = WizardWithHelpButton(parent, id = wx.ID_ANY,
+ title = _("Define new GRASS Location"),
bitmap = wizbmp)
self.wizard.Bind(wiz.EVT_WIZARD_HELP, self.OnHelp)
