[GRASS-SVN] r56794 - grass/branches/develbranch_6/lib/python
svn_grass at osgeo.org
Wed Jun 19 04:28:42 PDT 2013
Author: hamish
Date: 2013-06-19 04:28:42 -0700 (Wed, 19 Jun 2013)
New Revision: 56794
grass/branches/develbranch_6/lib/python/core.py
add usage example for find_program, note that the exe needs to return with a non-zero exit code (merge from trunk)
Modified: grass/branches/develbranch_6/lib/python/core.py
--- grass/branches/develbranch_6/lib/python/core.py 2013-06-19 11:23:34 UTC (rev 56793)
+++ grass/branches/develbranch_6/lib/python/core.py 2013-06-19 11:28:42 UTC (rev 56794)
@@ -971,11 +971,25 @@
def find_program(pgm, args = []):
"""!Attempt to run a program, with optional arguments.
+ You must call the program in a way that will return a successful
+ exit code. For GRASS modules this means you need to pass it some
+ valid CLI option, like "--help". For other programs a common
+ valid do-little option is "--version".
+ Example:
+ @code
+ >>> grass.find_program('r.sun', ['help'])
+ True
+ >>> grass.find_program('gdalwarp', ['--version'])
+ True
+ @endcode
@param pgm program name
@param args list of arguments
@return False if the attempt failed due to a missing executable
+ or non-zero return code
@return True otherwise
nuldev = file(os.devnull, 'w+')
