[GRASS-SVN] r56807 - in grass/trunk: raster/r.colors tools vector/v.colors
Wed Jun 19 16:34:55 PDT 2013
Author: hamish
Date: 2013-06-19 16:34:55 -0700 (Wed, 19 Jun 2013)
New Revision: 56807
Added:
   grass/trunk/tools/thumbnails.py
Removed:
   grass/trunk/raster/r.colors/thumbnails.py
   grass/trunk/vector/v.colors/thumbnails.py
   grass/trunk/raster/r.colors/Makefile
   grass/trunk/vector/v.colors/Makefile
move thumbnails.py to common dir, fix v.colors html page insertion
Modified: grass/trunk/raster/r.colors/Makefile
--- grass/trunk/raster/r.colors/Makefile	2013-06-19 23:23:03 UTC (rev 56806)
+++ grass/trunk/raster/r.colors/Makefile	2013-06-19 23:34:55 UTC (rev 56807)
@@ -13,20 +13,20 @@
 default: multi
 # Insert thumbnail previews
-r.colors.tmp.html: $(BIN)/r.colors$(EXE) thumbnails.py
+r.colors.tmp.html: $(BIN)/r.colors$(EXE) thumbnails
 	$(call htmldesc,$<,$@)
 	sed 's!^<dd><b>\([a-z0-9._]*\)</b>:!<dd><img width="80" height="12" src="Colortable_\1.png"> <b>\1</b>:!' "$@" > "$@.tmp"
 	mv -f "$@.tmp" "$@"
 	$(MAKE) thumbnails
-r3.colors.tmp.html: $(BIN)/r3.colors$(EXE) thumbnails.py
+r3.colors.tmp.html: $(BIN)/r3.colors$(EXE) thumbnails
 	mv -f "$@.tmp" "$@"
 	$(MAKE) thumbnails
 thumbnails: $(BIN)/r.mapcalc$(EXE)
-	-$(call run_grass, ./thumbnails.py)
+	-$(call run_grass, $(GRASS_HOME)/tools/thumbnails.py)
 $(BIN)/r.mapcalc$(EXE):
 	$(MAKE) -C ../r.mapcalc
Deleted: grass/trunk/raster/r.colors/thumbnails.py
--- grass/trunk/raster/r.colors/thumbnails.py	2013-06-19 23:23:03 UTC (rev 56806)
+++ grass/trunk/raster/r.colors/thumbnails.py	2013-06-19 23:34:55 UTC (rev 56807)
@@ -1,201 +0,0 @@
-#!/usr/bin/env python
-# thumbnails.py: Create thumbnail sample images of the various GRASS color rules
-#  AUTHOR: Python version by Glynn Clements
-#      Earlier Bourne script version by Hamish Bowman,
-#      http://grasswiki.osgeo.org/wiki/Talk:Color_tables
-#   (C) 2009-2013 by the GRASS Development Team
-#       This program is free software under the GNU General Public
-#       License (>=v2). Read the file COPYING that comes with GRASS
-#       for details.
-import sys
-import os
-import atexit
-import string
-import array
-import grass.script as grass
-tmp_img = None
-tmp_grad_abs = None
-tmp_grad_rel = None
-height = 85
-width = 15
-def cleanup():
-    if tmp_img:
-        grass.try_remove(tmp_img)
-    if tmp_grad_rel:
-        grass.run_command('g.remove', rast = tmp_grad_rel, quiet = True)
-    if tmp_grad_abs:
-        grass.run_command('g.remove', rast = tmp_grad_abs, quiet = True)
-# def rotate(src, dst):
-#     grass.call(["convert", "-rotate", "90", src, dst])
-def read_ppm(src):
-    fh = open(src, "rb")
-    text = fh.read()
-    fh.close()
-    i = 0
-    j = text.find('\n', i)
-    if text[i:j] != 'P6':
-        raise IOError
-    i = j + 1
-    w, h = text[i:j].split()
-    if int(w) != width or int(h) != height:
-        raise IOError
-    i = j + 1
-    maxval = text[i:j]
-    if int(maxval) != 255:
-        raise IOError
-    i = j + 1
-    return array.array('B', text[i:])
-def write_ppm(dst, data):
-    w = height
-    h = width
-    fh = open(dst, "wb")
-    fh.write("P6\n%d %d\n%d\n" % (w, h, 255))
-    data.tofile(fh)
-    fh.close()
-def rotate_ppm(srcd):
-    dstd = array.array('B', len(srcd) * '\0')
-    for y in xrange(height):
-        for x in xrange(width):
-            for c in xrange(3):
-                dstd[(x * height + (height - 1 - y)) * 3 + c] = srcd[(y * width + x) * 3 + c]
-    return dstd
-def flip_ppm(srcd):
-    stride = width * 3
-        dy = (height - 1 - y)
-        dstd[dy * stride:(dy + 1) * stride] = srcd[y * stride:(y + 1) * stride]
-    return dstd
-def ppmtopng(dst, src):
-    if grass.find_program("g.ppmtopng"):
-        grass.run_command('g.ppmtopng', input = src, output = dst, quiet = True)
-    elif grass.find_program("pnmtopng"):
-        fh = open(dst, 'wb')
-        grass.call(["pnmtopng", src], stdout = fh)
-        fh.close()
-    elif grass.find_program("convert"):
-        grass.call(["convert", src, dst])
-    else:
-        grass.fatal(_("Cannot find g.ppmtopng, pnmtopng or convert"))
-def convert_and_rotate(src, dst, flip = False):
-    ppm = read_ppm(src)
-    if flip:
-        ppm = flip_ppm(ppm)
-    ppm = rotate_ppm(ppm)
-    write_ppm(tmp_img, ppm)
-    ppmtopng(dst, tmp_img)
-def make_gradient(path):
-    fh = open(path)
-    text = fh.read()
-    fh.close()
-    lines = text.splitlines()
-    records = list()
-    for line in lines:
-        if line.startswith("#"):
-            # skip comments
-            continue
-        records.append(line.split())
-    records = [record for record in records if record[0] != 'nv' and record[0] != 'default']
-    relative = False
-    absolute = False
-    for record in records:
-        if record[0].endswith("%"):
-            relative = True
-            record[0] = record[0].rstrip("%")
-        else:
-            absolute = True
-    if absolute:
-        if relative:
-            minval = -0.04
-            maxval = 0.04
-        else:
-            minval = float(records[0][0])
-            maxval = float(records[-1][0])
-            maxval = min(maxval, 2500000)
-        grad = tmp_grad_abs
-        grass.mapcalc("$grad = if(row()==1, float($min), float($max))",
-        	      grad = tmp_grad_abs, min = minval, max = maxval, quiet = True)
-    else:
-        grad = tmp_grad_rel
-    return grad
-def make_image(output_dir, table, grad, discrete = False):
-    if discrete:
-        lines, cols = height, 1
-    else:
-        lines, cols = None, None
-    grass.run_command("r.colors", map = grad, color = table, quiet = True)
-    grass.run_command("d.colortable", flags = 'n', map = grad,
-                      lines = lines, cols = cols, quiet = True)
-    outfile = os.path.join(output_dir, "Colortable_%s.png" % table)
-    convert_and_rotate(tmp_img, outfile, discrete)
-def main():
-    global tmp_img, tmp_grad_abs, tmp_grad_rel
-    os.environ['GRASS_OVERWRITE'] = '1'
-    color_dir = os.path.join(os.environ['GISBASE'], "etc", "colors")
-    output_dir = os.path.join(os.environ['GISBASE'], "docs", "html")
-    if not os.path.exists(output_dir):
-        os.makedirs(output_dir)
-    pid = os.getpid()
-    tmp_grad_abs = "tmp_grad_abs_%d" % pid
-    tmp_grad_rel = "tmp_grad_rel_%d" % pid
-    tmp_img = grass.tempfile() + ".ppm"
-    os.environ['GRASS_WIDTH'] = '%d' % width
-    os.environ['GRASS_HEIGHT'] = '%d' % height
-    os.environ['GRASS_FRAME'] = '%f,%f,%f,%f' % (0,height,0,width)
-    os.environ['GRASS_PNGFILE'] = tmp_img
-    os.environ['GRASS_TRUECOLOR'] = 'TRUE'
-    os.environ['GRASS_PNG_READ'] = 'FALSE'
-    os.environ['GRASS_PNG_MAPPED'] = 'FALSE'
-    os.environ['GRASS_TRANSPARENT'] = 'FALSE'
-    os.environ['GRASS_BACKGROUNDCOLOR'] = 'ffffff'
-    os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
-    for var in ['GRASS_LINE_WIDTH', 'GRASS_ANTIALIAS']:
-        if var in os.environ:
-            del os.environ[var]
-    grass.use_temp_region()
-    grass.run_command('g.region', rows = 100, cols = 100)
-    grass.mapcalc("$grad = row()/1.0", grad = tmp_grad_rel, quiet = True)
-    for table in os.listdir(color_dir):
-        path = os.path.join(color_dir, table)
-        grad = make_gradient(path)
-        make_image(output_dir, table, grad)
-    grass.mapcalc("$grad = row()", grad = tmp_grad_abs, quiet = True)
-    for table in ['grey.eq', 'grey.log', 'random']:
-        make_image(output_dir, table, tmp_grad_abs, True)
-if __name__ == "__main__":
-    atexit.register(cleanup)
-    main()
Copied: grass/trunk/tools/thumbnails.py (from rev 56805, grass/trunk/raster/r.colors/thumbnails.py)
--- grass/trunk/tools/thumbnails.py	                        (rev 0)
+++ grass/trunk/tools/thumbnails.py	2013-06-19 23:34:55 UTC (rev 56807)
@@ -0,0 +1,201 @@
+#!/usr/bin/env python
+# thumbnails.py: Create thumbnail sample images of the various GRASS color rules
+#  AUTHOR: Python version by Glynn Clements
+#      Earlier Bourne script version by Hamish Bowman,
+#      http://grasswiki.osgeo.org/wiki/Talk:Color_tables
+#   (C) 2009-2013 by the GRASS Development Team
+#       This program is free software under the GNU General Public
+#       License (>=v2). Read the file COPYING that comes with GRASS
+#       for details.
+import sys
+import os
+import atexit
+import string
+import array
+import grass.script as grass
+tmp_img = None
+tmp_grad_abs = None
+tmp_grad_rel = None
+height = 85
+width = 15
+def cleanup():
+    if tmp_img:
+        grass.try_remove(tmp_img)
+    if tmp_grad_rel:
+        grass.run_command('g.remove', rast = tmp_grad_rel, quiet = True)
+    if tmp_grad_abs:
+        grass.run_command('g.remove', rast = tmp_grad_abs, quiet = True)
+# def rotate(src, dst):
+#     grass.call(["convert", "-rotate", "90", src, dst])
+def read_ppm(src):
+    fh = open(src, "rb")
+    text = fh.read()
+    fh.close()
+    i = 0
+    j = text.find('\n', i)
+    if text[i:j] != 'P6':
+        raise IOError
+    i = j + 1
+    w, h = text[i:j].split()
+    if int(w) != width or int(h) != height:
+        raise IOError
+    i = j + 1
+    maxval = text[i:j]
+    if int(maxval) != 255:
+        raise IOError
+    i = j + 1
+    return array.array('B', text[i:])
+def write_ppm(dst, data):
+    w = height
+    h = width
+    fh = open(dst, "wb")
+    fh.write("P6\n%d %d\n%d\n" % (w, h, 255))
+    data.tofile(fh)
+    fh.close()
+def rotate_ppm(srcd):
+    dstd = array.array('B', len(srcd) * '\0')
+    for y in xrange(height):
+        for x in xrange(width):
+            for c in xrange(3):
+                dstd[(x * height + (height - 1 - y)) * 3 + c] = srcd[(y * width + x) * 3 + c]
+    return dstd
+def flip_ppm(srcd):
+    stride = width * 3
+        dy = (height - 1 - y)
+        dstd[dy * stride:(dy + 1) * stride] = srcd[y * stride:(y + 1) * stride]
+    return dstd
+def ppmtopng(dst, src):
+    if grass.find_program("g.ppmtopng"):
+        grass.run_command('g.ppmtopng', input = src, output = dst, quiet = True)
+    elif grass.find_program("pnmtopng"):
+        fh = open(dst, 'wb')
+        grass.call(["pnmtopng", src], stdout = fh)
+        fh.close()
+    elif grass.find_program("convert"):
+        grass.call(["convert", src, dst])
+    else:
+        grass.fatal(_("Cannot find g.ppmtopng, pnmtopng or convert"))
+def convert_and_rotate(src, dst, flip = False):
+    ppm = read_ppm(src)
+    if flip:
+        ppm = flip_ppm(ppm)
+    ppm = rotate_ppm(ppm)
+    write_ppm(tmp_img, ppm)
+    ppmtopng(dst, tmp_img)
+def make_gradient(path):
+    fh = open(path)
+    text = fh.read()
+    fh.close()
+    lines = text.splitlines()
+    records = list()
+    for line in lines:
+        if line.startswith("#"):
+            # skip comments
+            continue
+        records.append(line.split())
+    records = [record for record in records if record[0] != 'nv' and record[0] != 'default']
+    relative = False
+    absolute = False
+    for record in records:
+        if record[0].endswith("%"):
+            relative = True
+            record[0] = record[0].rstrip("%")
+        else:
+            absolute = True
+    if absolute:
+        if relative:
+            minval = -0.04
+            maxval = 0.04
+        else:
+            minval = float(records[0][0])
+            maxval = float(records[-1][0])
+            maxval = min(maxval, 2500000)
+        grad = tmp_grad_abs
+        grass.mapcalc("$grad = if(row()==1, float($min), float($max))",
+        	      grad = tmp_grad_abs, min = minval, max = maxval, quiet = True)
+    else:
+        grad = tmp_grad_rel
+    return grad
+def make_image(output_dir, table, grad, discrete = False):
+    if discrete:
+        lines, cols = height, 1
+    else:
+        lines, cols = None, None
+    grass.run_command("r.colors", map = grad, color = table, quiet = True)
+    grass.run_command("d.colortable", flags = 'n', map = grad,
+                      lines = lines, cols = cols, quiet = True)
+    outfile = os.path.join(output_dir, "Colortable_%s.png" % table)
+    convert_and_rotate(tmp_img, outfile, discrete)
+def main():
+    global tmp_img, tmp_grad_abs, tmp_grad_rel
+    os.environ['GRASS_OVERWRITE'] = '1'
+    color_dir = os.path.join(os.environ['GISBASE'], "etc", "colors")
+    output_dir = os.path.join(os.environ['GISBASE'], "docs", "html")
+    if not os.path.exists(output_dir):
+        os.makedirs(output_dir)
+    pid = os.getpid()
+    tmp_grad_abs = "tmp_grad_abs_%d" % pid
+    tmp_grad_rel = "tmp_grad_rel_%d" % pid
+    tmp_img = grass.tempfile() + ".ppm"
+    os.environ['GRASS_WIDTH'] = '%d' % width
+    os.environ['GRASS_HEIGHT'] = '%d' % height
+    os.environ['GRASS_FRAME'] = '%f,%f,%f,%f' % (0,height,0,width)
+    os.environ['GRASS_PNGFILE'] = tmp_img
+    os.environ['GRASS_TRUECOLOR'] = 'TRUE'
+    os.environ['GRASS_PNG_READ'] = 'FALSE'
+    os.environ['GRASS_PNG_MAPPED'] = 'FALSE'
+    os.environ['GRASS_TRANSPARENT'] = 'FALSE'
+    os.environ['GRASS_BACKGROUNDCOLOR'] = 'ffffff'
+    os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+    for var in ['GRASS_LINE_WIDTH', 'GRASS_ANTIALIAS']:
+        if var in os.environ:
+            del os.environ[var]
+    grass.use_temp_region()
+    grass.run_command('g.region', rows = 100, cols = 100)
+    grass.mapcalc("$grad = row()/1.0", grad = tmp_grad_rel, quiet = True)
+    for table in os.listdir(color_dir):
+        path = os.path.join(color_dir, table)
+        grad = make_gradient(path)
+        make_image(output_dir, table, grad)
+    grass.mapcalc("$grad = row()", grad = tmp_grad_abs, quiet = True)
+    for table in ['grey.eq', 'grey.log', 'random']:
+        make_image(output_dir, table, tmp_grad_abs, True)
+if __name__ == "__main__":
+    atexit.register(cleanup)
+    main()
Modified: grass/trunk/vector/v.colors/Makefile
--- grass/trunk/vector/v.colors/Makefile	2013-06-19 23:23:03 UTC (rev 56806)
+++ grass/trunk/vector/v.colors/Makefile	2013-06-19 23:34:55 UTC (rev 56807)
@@ -12,14 +12,14 @@
 default: cmd
-v.colors.tmp.html: $(BIN)/v.colors$(EXE) thumbnails.py
+v.colors.tmp.html: $(BIN)/v.colors$(EXE) thumbnails
-	sed 's!^<DD><b>\([a-z0-9.]*\)</b>:!<DD><img width="80" height="12" src="Colortable_\1.png"> <b>\1</b>:!' "$@" > "$@.tmp"
+	sed 's!^<dd><b>\([a-z0-9.]*\)</b>:!<dd><img width="80" height="12" src="Colortable_\1.png"> <b>\1</b>:!' "$@" > "$@.tmp"
 	mv -f "$@.tmp" "$@"
 	$(MAKE) thumbnails
 .PHONY: thumbnails
Deleted: grass/trunk/vector/v.colors/thumbnails.py
--- grass/trunk/vector/v.colors/thumbnails.py	2013-06-19 23:23:03 UTC (rev 56806)
+++ grass/trunk/vector/v.colors/thumbnails.py	2013-06-19 23:34:55 UTC (rev 56807)
@@ -1,201 +0,0 @@
-#       for details.
-import sys
-import os
-import atexit
-import string
-import array
-tmp_img = None
-height = 85
-width = 15
-def cleanup():
-    if tmp_img:
-    if tmp_grad_rel:
-    if tmp_grad_abs:
-def read_ppm(src):
-    text = fh.read()
-    fh.close()
-    i = 0
-        raise IOError
-    i = j + 1
-        raise IOError
-    i = j + 1
-        raise IOError
-    i = j + 1
-    w = height
-    h = width
-    data.tofile(fh)
-    fh.close()
-    return dstd
-    return dstd
-        fh.close()
-    else:
-    if flip:
-    fh = open(path)
-    text = fh.read()
-    fh.close()
-    records = list()
-            # skip comments
-            continue
-    relative = False
-    absolute = False
-            relative = True
-        else:
-            absolute = True
-    if absolute:
-        if relative:
-            minval = -0.04
-            maxval = 0.04
-        else:
-    else:
-    return grad
-    if discrete:
-    else:
-def main():
-    pid = os.getpid()
-    main()
