[GRASS-SVN] r56815 - in grass/branches/releasebranch_6_4/gui/wxpython: . core wxplot
svn_grass at osgeo.org
Thu Jun 20 02:10:57 PDT 2013
Author: lucadelu
Date: 2013-06-20 02:10:57 -0700 (Thu, 20 Jun 2013)
New Revision: 56815
grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py
grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py
grass/branches/releasebranch_6_4/gui/wxpython/wxplot/profile.py
fix string format for more arguments
Modified: grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py
--- grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py 2013-06-20 09:01:35 UTC (rev 56814)
+++ grass/branches/releasebranch_6_4/gui/wxpython/core/utils.py 2013-06-20 09:10:57 UTC (rev 56815)
@@ -850,8 +850,10 @@
try:
k, v = map(lambda x: x.strip(), line.split(' ', 1)[1].split('=', 1))
except StandardError, e:
- sys.stderr.write(_("%s: line skipped - unable to parse '%s'\n"
- "Reason: %s\n") % (envFile, line, e))
+ sys.stderr.write(_("%(env)s: line skipped - unable to parse "
+ "Reason: %(e)s\n") % {'env': envFile,
+ 'line': line, 'e': e})
lineSkipped.append(line)
continue
if k in environ:
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py 2013-06-20 09:01:35 UTC (rev 56814)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gis_set.py 2013-06-20 09:10:57 UTC (rev 56815)
@@ -380,8 +380,8 @@
try:
key, val = line.split(":", 1)
except ValueError, e:
- sys.stderr.write(_('Invalid line in GISRC file (%s):%s\n' % \
- (e, line)))
+ sys.stderr.write(_('Invalid line in GISRC file (%(e)s):%(l)s\n' % \
+ {'e': e, 'l': line}))
grassrc[key.strip()] = DecodeString(val.strip())
finally:
rc.close()
Modified: grass/branches/releasebranch_6_4/gui/wxpython/wxplot/profile.py
--- grass/branches/releasebranch_6_4/gui/wxpython/wxplot/profile.py 2013-06-20 09:01:35 UTC (rev 56814)
+++ grass/branches/releasebranch_6_4/gui/wxpython/wxplot/profile.py 2013-06-20 09:10:57 UTC (rev 56815)
@@ -353,8 +353,9 @@
fd = open(pfile[-1], "w")
except IOError, e:
GError(parent = self,
- message = _("Unable to open file <%s> for writing.\n"
- "Reason: %s") % (pfile[-1], e))
+ message = _("Unable to open file <%(file)s> for "
+ "writing.\nReason: %(e)s") % {'file': pfile[-1],
+ 'e': e})
dlg.Destroy()
return
@@ -365,7 +366,8 @@
dlg.Destroy()
if pfile:
- message = _("%d files created:\n%s") % (len(pfile), '\n'.join(pfile))
+ message = _("%(l)d files created:\n%(p)s") % {'l': len(pfile),
+ 'p':'\n'.join(pfile)}
else:
message = _("No files generated.")
