[GRASS-SVN] r56845 - grass/trunk/lib/python/script
svn_grass at osgeo.org
Thu Jun 20 11:05:29 PDT 2013
Author: glynn
Date: 2013-06-20 11:05:29 -0700 (Thu, 20 Jun 2013)
New Revision: 56845
grass/trunk/lib/python/script/core.py
Revert r56800
Modified: grass/trunk/lib/python/script/core.py
--- grass/trunk/lib/python/script/core.py 2013-06-20 16:03:37 UTC (rev 56844)
+++ grass/trunk/lib/python/script/core.py 2013-06-20 18:05:29 UTC (rev 56845)
@@ -1233,29 +1233,20 @@
name = fs[0]
return name
-# find a program (replacement for "which")
-# from http://hg.python.org/cpython/file/6860263c05b3/Lib/shutil.py#l1068
-# see ticket #2008
-def find_program(cmd, mode=os.F_OK | os.X_OK, path=None):
- """Given a command, mode, and a PATH string, return the path which
- conforms to the given mode on the PATH, or None if there is no such
- file.
- `mode` defaults to os.F_OK | os.X_OK. `path` defaults to the result
- of os.environ.get("PATH"), or can be overridden with a custom search
- path.
+def find_program(pgm, args = []):
+ """!Attempt to run a program, with optional arguments.
+ You must call the program in a way that will return a successful
+ exit code. For GRASS modules this means you need to pass it some
+ valid CLI option, like "--help". For other programs a common
+ valid do-little option is "--version".
Example:
@code
- >>> find_program('r.sun') # doctest: +ELLIPSIS
- '.../bin/r.sun'
- >>> bool(find_program('ls'))
+ >>> grass.find_program('r.sun', ['help'])
True
- >>> bool(find_program('gdalwarp'))
+ >>> grass.find_program('gdalwarp', ['--version'])
True
@endcode
@param pgm program name
@@ -1265,57 +1256,18 @@
or non-zero return code
@return True otherwise
- # Check that a given file can be accessed with the correct mode.
- # Additionally check that `file` is not a directory, as on Windows
- # directories pass the os.access check.
- def _access_check(fn, mode):
- return (os.path.exists(fn) and os.access(fn, mode)
- and not os.path.isdir(fn))
- # If we're given a path with a directory part, look it up directly rather
- # than referring to PATH directories. This includes checking relative to
- # the current directory, e.g. ./script
- if os.path.dirname(cmd):
- if _access_check(cmd, mode):
- return cmd
- return None
- if path is None:
- path = os.environ.get("PATH", os.defpath)
- if not path:
- return None
- path = path.split(os.pathsep)
- if sys.platform == "win32":
- # The current directory takes precedence on Windows.
- if not os.curdir in path:
- path.insert(0, os.curdir)
- # PATHEXT is necessary to check on Windows.
- pathext = os.environ.get("PATHEXT", "").split(os.pathsep)
- # See if the given file matches any of the expected path extensions.
- # This will allow us to short circuit when given "python.exe".
- # If it does match, only test that one, otherwise we have to try
- # others.
- if any(cmd.lower().endswith(ext.lower()) for ext in pathext):
- files = [cmd]
+ nuldev = file(os.devnull, 'w+')
+ try:
+ ret = call([pgm] + args, stdin = nuldev, stdout = nuldev, stderr = nuldev)
+ if ret == 0:
+ found = True
else:
- files = [cmd + ext for ext in pathext]
- else:
- # On other platforms you don't have things like PATHEXT to tell you
- # what file suffixes are executable, so just pass on cmd as-is.
- files = [cmd]
+ found = False
+ except:
+ found = False
+ nuldev.close()
- seen = set()
- for dir in path:
- normdir = os.path.normcase(dir)
- if not normdir in seen:
- seen.add(normdir)
- for thefile in files:
- name = os.path.join(dir, thefile)
- if _access_check(name, mode):
- return name
- return None
+ return found
# try to remove a file, without complaints
