[GRASS-SVN] r56856 - grass-addons/grass7/raster/r.hazard.flood
svn_grass at osgeo.org
Thu Jun 20 19:55:40 PDT 2013
Author: hamish
Date: 2013-06-20 19:55:40 -0700 (Thu, 20 Jun 2013)
New Revision: 56856
grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py
sync with grass6 version
Modified: grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py
--- grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py 2013-06-21 02:55:25 UTC (rev 56855)
+++ grass-addons/grass7/raster/r.hazard.flood/r.hazard.flood.py 2013-06-21 02:55:40 UTC (rev 56856)
@@ -51,9 +51,9 @@
import grass.script as grass
except:
try:
- from grass.script import core as grass
+ from grass.script import core as grass
except:
- sys.exit( "grass.script can't be imported.")
+ sys.exit("grass.script can't be imported.")
if not os.environ.has_key("GISBASE"):
print "You must be in GRASS GIS to run this program."
@@ -61,9 +61,9 @@
def main():
- #### check for r.area
- if not grass.find_program('r.area'):
- grass.fatal(_("'r.area' program not found, install it first:") +
+ #### check if we have the r.area addon
+ if not grass.find_program('r.area', ['help']):
+ grass.fatal(_("The 'r.area' module was not found, install it first:") +
"\n" +
"g.extension r.area")
@@ -138,7 +138,7 @@
grass.run_command('g.remove', rast = 'r_flood_th')
grass.run_command('g.remove', rast = 'r_flood')
- grass.run_command('g.message' , message = 'Done!')
+ grass.message(_('Done.'))
if __name__ == "__main__":
options, flags = grass.parser()
