[GRASS-SVN] r56879 - grass/trunk/lib/python/temporal
Sat Jun 22 07:28:16 PDT 2013
Author: huhabla
Date: 2013-06-22 07:28:16 -0700 (Sat, 22 Jun 2013)
New Revision: 56879
   grass/trunk/lib/python/temporal/abstract_dataset.py
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
Using Pythons abstract base class to define abstract classes and methods.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py	2013-06-22 11:10:25 UTC (rev 56878)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py	2013-06-22 14:28:16 UTC (rev 56879)
@@ -11,15 +11,6 @@
 >>> import grass.temporal as tgis
 >>> ad = AbstractDataset()
->>> ad.reset(ident="soil at PERMANENT")
-Traceback (most recent call last):
-  File "/usr/lib/python2.7/doctest.py", line 1289, in __run
-    compileflags, 1) in test.globs
-  File "<doctest __main__[2]>", line 1, in <module>
-    ad.reset(ident="soil at PERMANENT")
-  File "AbstractDataset.py", line 53, in reset
-    raise ImplementationError("This method must be implemented in the subclasses")
-ImplementationError: 'This method must be implemented in the subclasses'
 @endcode
@@ -32,6 +23,7 @@
 import uuid
 import copy
+from abc import ABCMeta, abstractmethod
 from temporal_extent import *
 from spatial_extent import *
 from metadata import *
@@ -53,6 +45,9 @@
 class AbstractDataset(SpatialTopologyDatasetConnector, TemporalTopologyDatasetConnector):
     """!This is the base class for all datasets
        (raster, vector, raster3d, strds, stvds, str3ds)"""
+    __metaclass__ = ABCMeta
     def __init__(self):
         SpatialTopologyDatasetConnector.__init__(self)
         TemporalTopologyDatasetConnector.__init__(self)
@@ -140,13 +135,26 @@
         if self.is_spatial_topology_build():
             self.print_spatial_topology_shell_info()
+    @abstractmethod
     def reset(self, ident):
         """!Reset the internal structure and set the identifier
+            This method creates the dataset specific internal objects
+            that store the base information, the spatial and temporal extent
+            and the metadata. It must be implemented in the dataset
+            specific subclasses. This is the code for the
+            vector dataset:
+            self.base = VectorBase(ident=ident)
+            self.absolute_time = VectorAbsoluteTime(ident=ident)
+            self.relative_time = VectorRelativeTime(ident=ident)
+            self.spatial_extent = VectorSpatialExtent(ident=ident)
+            self.metadata = VectorMetadata(ident=ident)
            @param ident The identifier of the dataset that  "name at mapset" or in case of vector maps "name:layer at mapset"
+    @abstractmethod
     def get_type(self):
         """!Return the type of this class as string
@@ -154,24 +162,24 @@
            @return "vect", "rast", "rast3d", "stvds", "strds" or "str3ds"
+    @abstractmethod
     def get_new_instance(self, ident):
         """!Return a new instance with the type of this class
            @param ident The identifier of the new dataset instance
            @return A new instance with the type of this object
+    @abstractmethod
     def spatial_overlapping(self, dataset):
         """!Return True if the spatial extents overlap
            @param dataset The abstract dataset to check spatial overlapping
            @return True if self and the provided dataset spatial overlap
+    @abstractmethod
     def spatial_intersection(self, dataset):
         """!Return the spatial intersection as spatial_extent
            object or None in case no intersection was found.
@@ -179,8 +187,8 @@
            @param dataset The abstract dataset to intersect with
            @return The intersection spatial extent
+    @abstractmethod
     def spatial_union(self, dataset):
         """!Return the spatial union as spatial_extent
            object or None in case the extents does not overlap or meet.
@@ -188,16 +196,16 @@
            @param dataset The abstract dataset to create a union with
            @return The union spatial extent
+    @abstractmethod
     def spatial_disjoint_union(self, dataset):
         """!Return the spatial union as spatial_extent object.
+    @abstractmethod
     def spatial_relation(self, dataset):
         """!Return the spatial relationship between self and dataset
@@ -205,21 +213,20 @@
            @return The spatial relationship as string
+    @abstractmethod
     def print_info(self):
         """!Print information about this class in human readable style"""
+    @abstractmethod
     def print_shell_info(self):
         """!Print information about this class in shell style"""
+    @abstractmethod
     def print_self(self):
         """!Print the content of the internal structure to stdout"""
     def set_id(self, ident):
+        """!Set the identifier of the dataset"""
         self.base.set_id(ident)
         self.temporal_extent.set_id(ident)
         self.spatial_extent.set_id(ident)
@@ -456,14 +463,6 @@
             dbif.close()
         return statement
-    def set_time_to_absolute(self):
-        """!Set the temporal type to absolute"""
-        self.base.set_ttype("absolute")
-    def set_time_to_relative(self):
-        """!Set the temporal type to relative"""
-        self.base.set_ttype("relative")
     def is_time_absolute(self):
         """!Return True in case the temporal type is absolute
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2013-06-22 11:10:25 UTC (rev 56878)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2013-06-22 14:28:16 UTC (rev 56879)
@@ -5,11 +5,6 @@
 Temporal GIS related functions to be used in temporal GIS Python library package.
-Usage:
->>> import grass.temporal as tgis
->>> amd = tgis.AbstractMapDataset()
 (C) 2008-2011 by the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
@@ -41,9 +36,13 @@
         - Abstract methods that must be implemented in the map specific
           subclasses
     def __init__(self):
         AbstractDataset.__init__(self)
+    @abstractmethod
     def get_new_stds_instance(self, ident):
         """!Return a new space time dataset instance that store maps with the
            type of this map object (rast, rast3d or vect)
@@ -51,9 +50,8 @@
            @param ident The identifier of the space time dataset
            @return The new space time dataset instance
-            "This method must be implemented in the subclasses")
+    @abstractmethod
     def get_stds_register(self):
         """!Return the space time dataset register table name
@@ -63,9 +61,8 @@
             @return The name of the stds register table
+    @abstractmethod
     def set_stds_register(self, name):
         """!Set the space time dataset register table name.
@@ -74,8 +71,6 @@
            @param name The name of the register table
     def check_resolution_with_current_region(self):
         """!Check if the raster or voxel resolution is
@@ -94,48 +89,42 @@
+    @abstractmethod
     def has_grass_timestamp(self):
         """!Check if a grass file based time stamp exists for this map.
             @return True is the grass file based time stamped exists for this
                     map
+    @abstractmethod
     def write_timestamp_to_grass(self):
         """!Write the timestamp of this map into the map metadata
            in the grass file system based spatial database.
+    @abstractmethod
     def remove_timestamp_from_grass(self):
         """!Remove the timestamp from the grass file
+    @abstractmethod
     def map_exists(self):
         """!Return True in case the map exists in the grass spatial database
            @return True if map exists, False otherwise
+    @abstractmethod
     def read_info(self):
         """!Read the map info from the grass file system based database and
            store the content into a dictionary
+    @abstractmethod
     def load(self):
         """!Load the content of this object from the grass
            file system based database"""
     def _convert_timestamp(self):
         """!Convert the valid time into a grass datetime library
@@ -211,6 +200,14 @@
         return self.base.get_layer()
+    def print_self(self):
+        """!Print the content of the internal structure to stdout"""
+        self.base.print_self()
+        self.temporal_extent.print_self()
+        self.spatial_extent.print_self()
+        self.metadata.print_self()
         """!Print information about this object in human readable style"""
@@ -324,6 +321,14 @@
         self.write_timestamp_to_grass()
         return AbstractDataset.update_all(self, dbif, execute)
+    def set_time_to_absolute(self):
+        """!Set the temporal type to absolute"""
+        self.base.set_ttype("absolute")
+    def set_time_to_relative(self):
+        """!Set the temporal type to relative"""
+        self.base.set_ttype("relative")
     def set_absolute_time(self, start_time, end_time=None, timezone=None):
         """!Set the absolute time with start time and end time
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-06-22 11:10:25 UTC (rev 56878)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2013-06-22 14:28:16 UTC (rev 56879)
@@ -32,20 +32,14 @@
        database, like the computation of the temporal and spatial extent as
        well as the collecting of metadata.
     def __init__(self, ident):
         self.reset(ident)
         self.map_counter = 0
-    def get_new_map_instance(self, ident=None):
-        """!Return a new instance of a map which is associated
-           with the type of this object
-           @param ident The unique identifier of the new object
     def create_map_register_name(self):
         """!Create the name of the map register table of this space time
             dataset
@@ -62,13 +56,21 @@
                 self.base.get_mapset() + "_" + \
                 self.get_new_map_instance(None).get_type() + "_register"
+    @abstractmethod
+    def get_new_map_instance(self, ident=None):
+        """!Return a new instance of a map which is associated
+           with the type of this object
+           @param ident The unique identifier of the new object
+    @abstractmethod
     def get_map_register(self):
         """!Return the name of the map register table
            @return The map register table name
+    @abstractmethod
     def set_map_register(self, name):
         """!Set the name of the map register table
@@ -80,8 +82,6 @@
@@ -124,7 +124,7 @@
         """!Set the initial values of the space time dataset
             In addition the command creation string is generated
-            an inerted into the metadata object.
+            an inserted into the metadata object.
             This method only modifies this object and does not commit
             the modifications to the temporal database.
@@ -140,9 +140,9 @@
         if temporal_type == "absolute":
-            self.set_time_to_absolute()
         elif temporal_type == "relative":
-            self.set_time_to_relative()
         else:
             core.fatal(_("Unknown temporal type \"%s\"") % (temporal_type))
@@ -262,9 +262,9 @@
             core.fatal(_("Wrong granularity: \"%s\"") % str(granularity))
         else:
