[GRASS-SVN] r56885 - grass/trunk/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Sun Jun 23 04:16:23 PDT 2013
Author: zarch
Date: 2013-06-23 04:16:23 -0700 (Sun, 23 Jun 2013)
New Revision: 56885
grass/trunk/lib/python/pygrass/modules/interface/parameter.py
Fix Parameter class to manage float range and remove unnecessary hide attribute '_type'.
Modified: grass/trunk/lib/python/pygrass/modules/interface/parameter.py
--- grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2013-06-23 03:37:20 UTC (rev 56884)
+++ grass/trunk/lib/python/pygrass/modules/interface/parameter.py 2013-06-23 11:16:23 UTC (rev 56885)
@@ -26,7 +26,6 @@
if diz['type'] in GETTYPE:
self.type = GETTYPE[diz['type']]
self.typedesc = diz['type']
- self._type = GETTYPE[diz['type']]
else:
raise TypeError('New type: %s, ignored' % diz['type'])
@@ -46,10 +45,10 @@
self.values = range(int(range_min), int(range_max) + 1)
self.isrange = diz['values'][0]
else:
- self.values = [self._type(i) for i in diz['values']]
+ self.values = [self.type(i) for i in diz['values']]
self.isrange = False
except TypeError:
@@ -57,10 +56,10 @@
if 'default' in diz:
if self.multiple or self.keydescvalues:
- self.default = [self._type(v)
+ self.default = [self.type(v)
for v in diz['default'].split(',')]
else:
- self.default = self._type(diz['default'])
+ self.default = self.type(diz['default'])
self._value = self.default
else:
self.default = None
@@ -83,15 +82,22 @@
if isinstance(value, list) or isinstance(value, tuple):
# check each value
- self._value = [self._type(val) for val in value]
+ self._value = [self.type(val) for val in value]
else:
str_err = 'The Parameter <%s> does not accept multiple inputs'
raise TypeError(str_err % self.name)
elif self.typedesc == 'all':
self._value = value
- elif isinstance(value, self._type):
+ elif isinstance(value, self.type):
if hasattr(self, 'values'):
- if value in self.values:
+ if self.type is float:
+ if self.values[0] <= value <= self.values[-1]:
+ self._value = value
+ else:
+ err_str = 'The Parameter <%s>, must be: %g<=value<=%g'
+ raise ValueError(err_str % (self.name, self.values[0],
+ self.values[-1]))
+ elif value in self.values:
self._value = value
else:
raise ValueError('The Parameter <%s>, must be one of: %r' %
