[GRASS-SVN] r56888 - in grass/trunk/lib/python/pygrass: . shell
    svn_grass at osgeo.org
    Sun Jun 23 12:13:27 PDT 2013
Author: zarch
Date: 2013-06-23 12:13:27 -0700 (Sun, 23 Jun 2013)
New Revision: 56888
Added:
   grass/trunk/lib/python/pygrass/shell/
   grass/trunk/lib/python/pygrass/shell/Makefile
   grass/trunk/lib/python/pygrass/shell/__init__.py
   grass/trunk/lib/python/pygrass/shell/conversion.py
   grass/trunk/lib/python/pygrass/shell/show.py
   grass/trunk/lib/python/pygrass/Makefile
   grass/trunk/lib/python/pygrass/__init__.py
Add support for ipython notebook.
Modified: grass/trunk/lib/python/pygrass/Makefile
--- grass/trunk/lib/python/pygrass/Makefile	2013-06-23 19:08:13 UTC (rev 56887)
+++ grass/trunk/lib/python/pygrass/Makefile	2013-06-23 19:13:27 UTC (rev 56888)
@@ -10,7 +10,7 @@
 MODULES = errors functions orderdict
-CLEAN_SUBDIRS = modules raster vector gis tests
+CLEAN_SUBDIRS = modules raster vector gis shell tests
 PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
 PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
@@ -20,6 +20,7 @@
 	-$(MAKE) -C raster || echo $(CURDIR)/raster >> $(ERRORLOG)
 	-$(MAKE) -C vector || echo $(CURDIR)/vector >> $(ERRORLOG)
 	-$(MAKE) -C gis || echo $(CURDIR)/gis >> $(ERRORLOG)
+	-$(MAKE) -C shell || echo $(CURDIR)/shell >> $(ERRORLOG)
 	-$(MAKE) -C tests || echo $(CURDIR)/tests >> $(ERRORLOG)
 $(PYDIR):
Modified: grass/trunk/lib/python/pygrass/__init__.py
--- grass/trunk/lib/python/pygrass/__init__.py	2013-06-23 19:08:13 UTC (rev 56887)
+++ grass/trunk/lib/python/pygrass/__init__.py	2013-06-23 19:13:27 UTC (rev 56888)
@@ -15,3 +15,4 @@
 import raster
 import vector
 import modules
+import shell
Added: grass/trunk/lib/python/pygrass/shell/Makefile
--- grass/trunk/lib/python/pygrass/shell/Makefile	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/shell/Makefile	2013-06-23 19:13:27 UTC (rev 56888)
@@ -0,0 +1,32 @@
+MODULE_TOPDIR = ../../../..
+include $(MODULE_TOPDIR)/include/Make/Other.make
+include $(MODULE_TOPDIR)/include/Make/Python.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
+PYDIR = $(ETC)/python
+GDIR = $(PYDIR)/grass
+PGDIR = $(GDIR)/pygrass
+DSTDIR= $(PGDIR)/shell
+MODULES = conversion show
+PYFILES := $(patsubst %,$(DSTDIR)/%.py,$(MODULES) __init__)
+PYCFILES := $(patsubst %,$(DSTDIR)/%.pyc,$(MODULES) __init__)
+default: $(PYFILES) $(PYCFILES) $(GDIR)/__init__.py $(GDIR)/__init__.pyc
+$(PYDIR):
+	$(MKDIR) $@
+$(GDIR): | $(PYDIR)
+	$(MKDIR) $@
+$(DSTDIR): | $(GDIR)
+	$(MKDIR) $@
+$(DSTDIR)/%: % | $(DSTDIR)
+	$(INSTALL_DATA) $< $@
+#doxygen:
+DOXNAME = pythonpygrass
Added: grass/trunk/lib/python/pygrass/shell/__init__.py
--- grass/trunk/lib/python/pygrass/shell/__init__.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/shell/__init__.py	2013-06-23 19:13:27 UTC (rev 56888)
@@ -0,0 +1,8 @@
+# -*- coding: utf-8 -*-
+Created on Sun Jun 23 15:06:46 2013
+ at author: pietro
+import conversion
Added: grass/trunk/lib/python/pygrass/shell/conversion.py
--- grass/trunk/lib/python/pygrass/shell/conversion.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/shell/conversion.py	2013-06-23 19:13:27 UTC (rev 56888)
@@ -0,0 +1,102 @@
+Created on Sun Jun 23 13:40:19 2013
+ at author: pietro
+dcont = """    <tr>
+      <td>{key}</td>
+      <td>{value}</td>
+    </tr>"""
+def dict2html(dic, keys=None, border='',
+              kfmt='%s', kdec='', kfun=None,
+              vfmt='%s', vdec='', vfun=None):
+    """Return a html repr of a dictionary.
+    Parameters
+    dic: dictionary, required
+        Dictionary or object with `keys` and `items` methods
+    keys: iterable, optional
+        Iterable objectwith only the keys that we want to display
+    border: string, optional
+        Could be: "0", "1", etc.
+    kfmt: string, optional
+        String to format the key string (i.e. "%r", etc.)
+    kdec: string, optional
+        String to decorate the key (i.e. "b", "i", etc.)
+    vfmt: string, optional
+        String to format the value string (i.e. "%r", etc.)
+    vdec: string, optional
+        String to decorate the value (i.e. "b", "i", etc.)
+    Examples
+        >>> dic = {'key 0': 0, 'key 1': 1}
+        >>> print dict2html(dic)
+        <table>
+            <tr>
+              <td>key 0</td>
+              <td>0</td>
+            </tr>
+            <tr>
+              <td>key 1</td>
+              <td>1</td>
+            </tr>
+        </table>
+        >>> print dict2html(dic, border="1")
+        <table border='1'>
+            <tr>
+              <td>key 0</td>
+              <td>0</td>
+            </tr>
+            <tr>
+              <td>key 1</td>
+              <td>1</td>
+            </tr>
+        </table>
+        >>> print dict2html(dic, kdec='b', vfmt='%05d', vdec='i')
+        <table>
+            <tr>
+              <td><b>key 0</b></td>
+              <td><i>00000</i></td>
+            </tr>
+            <tr>
+              <td><b>key 1</b></td>
+              <td><i>00001</i></td>
+            </tr>
+        </table>
+        >>> dic = {'key 0': (2, 3), 'key 1': (10, 5)}
+        >>> print dict2html(dic, kdec='b', vdec='i',
+        ...                 vfun=lambda x: "%d<sup>%.1f</sup>" % x)
+        <table>
+            <tr>
+              <td><i>2<sup>3.0</sup></i></td>
+            </tr>
+            <tr>
+              <td><i>10<sup>5.0</sup></i></td>
+            </tr>
+        </table>
+    def fun(x):
+        return x
+    keys = keys if keys else sorted(dic.keys())
+    header = "<table border=%r>" % border if border else "<table>"
+    kd = "<%s>%s</%s>" % (kdec, kfmt, kdec) if kdec else kfmt
+    vd = "<%s>%s</%s>" % (vdec, vfmt, vdec) if vdec else vfmt
+    kfun = kfun if kfun else fun
+    vfun = vfun if vfun else fun
+    content = [dcont.format(key=kd % kfun(k), value=vd % vfun(dic[k]))
+               for k in keys]
+    return '\n'.join([header, ] + content + ['</table>', ])
Added: grass/trunk/lib/python/pygrass/shell/show.py
--- grass/trunk/lib/python/pygrass/shell/show.py	                        (rev 0)
+++ grass/trunk/lib/python/pygrass/shell/show.py	2013-06-23 19:13:27 UTC (rev 56888)
@@ -0,0 +1,13 @@
+Created on Sun Jun 23 19:58:54 2013
+ at author: pietro
+import io
+def raw_figure(figpath):
+    with io.OpenWrapper(figpath, mode='rb') as data:
+        res = data.read()
+    return res
