[GRASS-SVN] r56895 - in grass/trunk/lib/python/pygrass: . raster
svn_grass at osgeo.org
Sun Jun 23 13:03:26 PDT 2013
Author: zarch
Date: 2013-06-23 13:03:26 -0700 (Sun, 23 Jun 2013)
New Revision: 56895
grass/trunk/lib/python/pygrass/functions.py
grass/trunk/lib/python/pygrass/raster/abstract.py
Add '_repr_html_' to raster Info and RasterAbstract, add r_export to functions, and fix some indent in the the docstring.
Modified: grass/trunk/lib/python/pygrass/functions.py
--- grass/trunk/lib/python/pygrass/functions.py 2013-06-23 20:00:59 UTC (rev 56894)
+++ grass/trunk/lib/python/pygrass/functions.py 2013-06-23 20:03:26 UTC (rev 56895)
@@ -204,3 +204,15 @@
else:
poi.attrs.commit()
return True
+def r_export(rast, output='', fmt='png', **kargs):
+ from grass.pygrass.modules import Module
+ if rast.exist():
+ output = output if output else "%s_%s.%s" % (rast.name, rast.mapset,
+ fmt)
+ Module('r.out.%s' % fmt, input=rast.fullname(), output=output,
+ overwrite=True, **kargs)
+ return output
+ else:
+ raise ValueError('Raster map does not exist.')
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py 2013-06-23 20:00:59 UTC (rev 56894)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py 2013-06-23 20:03:26 UTC (rev 56895)
@@ -19,6 +19,8 @@
from grass.pygrass import functions
from grass.pygrass.gis.region import Region
from grass.pygrass.errors import must_be_open
+from grass.pygrass.shell.conversion import dict2html
+from grass.pygrass.shell.show import raw_figure
# import raster classes
@@ -142,8 +144,19 @@
tbres=self.tbres, zone=self.zone,
proj=self.proj, min=self.min, max=self.max)
+ def keys(self):
+ return ['name', 'mapset', 'rows', 'cols', 'north', 'south',
+ 'east', 'west', 'top', 'bottom', 'nsres', 'ewres', 'tbres',
+ 'zone', 'proj', 'min', 'max']
+ def items(self):
+ return [(k, self.__getattribute__(k)) for k in self.keys()]
+ def _repr_html_(self):
+ return dict2html(dict(self.items()), keys=self.keys(),
+ border='1', kdec='b')
class RasterAbstractBase(object):
"""Raster_abstract_base: The base class from which all sub-classes
inherit. It does not implement any row or map access methods:
@@ -249,7 +262,6 @@
name = property(fget=_get_name, fset=_set_name)
@must_be_open
def _get_cats_title(self):
return self.cats.title
@@ -293,15 +305,18 @@
"""Return a constructor of the class"""
return (self.__getitem__(irow) for irow in xrange(self._rows))
+ def _repr_png_(self):
+ return raw_figure(functions.r_export(self))
def exist(self):
"""Return True if the map already exist, and
- set the mapset if were not set.
+ set the mapset if were not set.
- call the C function `G_find_raster`.
+ call the C function `G_find_raster`. ::
- >>> ele = RasterAbstractBase('elevation')
- >>> ele.exist()
- True
+ >>> ele = RasterAbstractBase('elevation')
+ >>> ele.exist()
+ True
if self.name:
if self.mapset == '':
@@ -313,11 +328,11 @@
return False
def is_open(self):
- """Return True if the map is open False otherwise
+ """Return True if the map is open False otherwise. ::
- >>> ele.is_open()
- False
+ >>> ele.is_open()
+ False
return True if self._fd is not None and self._fd >= 0 else False
@@ -342,11 +357,11 @@
return "{name}@{mapset}".format(name=self.name, mapset=self.mapset)
def name_mapset(self, name=None, mapset=None):
- """Return the full name of the Raster
+ """Return the full name of the Raster. ::
- >>> ele.name_mapset()
- 'elevation at PERMANENT'
+ >>> ele.name_mapset()
+ 'elevation at PERMANENT'
if name is None:
