[GRASS-SVN] r56908 - grass/branches/develbranch_6/imagery/i.landsat.toar
svn_grass at osgeo.org
Mon Jun 24 08:55:02 PDT 2013
Author: mmetz
Date: 2013-06-24 08:55:02 -0700 (Mon, 24 Jun 2013)
New Revision: 56908
grass/branches/develbranch_6/imagery/i.landsat.toar/landsat.c
grass/branches/develbranch_6/imagery/i.landsat.toar/landsat.h
grass/branches/develbranch_6/imagery/i.landsat.toar/landsat_met.c
grass/branches/develbranch_6/imagery/i.landsat.toar/landsat_set.c
grass/branches/develbranch_6/imagery/i.landsat.toar/local_proto.h
grass/branches/develbranch_6/imagery/i.landsat.toar/main.c
i.landsat.toar: sync to trunk
Modified: grass/branches/develbranch_6/imagery/i.landsat.toar/landsat.c
--- grass/branches/develbranch_6/imagery/i.landsat.toar/landsat.c 2013-06-24 15:51:50 UTC (rev 56907)
+++ grass/branches/develbranch_6/imagery/i.landsat.toar/landsat.c 2013-06-24 15:55:02 UTC (rev 56908)
@@ -63,7 +63,8 @@
cos_v = (double)(cos(D2R * (lsat->number < 4 ? 9.2 : 8.2)));
/** Global irradiance on the sensor.
- Radiance to reflectance coefficient, only NO thermal bands.
+ Radiance to reflectance coefficient, only NO thermal bands.
+ K1 and K2 variables are also utilized as thermal constants
if (lsat->band[i].thermal == 0) {
switch (method) {
Modified: grass/branches/develbranch_6/imagery/i.landsat.toar/landsat.h
--- grass/branches/develbranch_6/imagery/i.landsat.toar/landsat.h 2013-06-24 15:51:50 UTC (rev 56907)
+++ grass/branches/develbranch_6/imagery/i.landsat.toar/landsat.h 2013-06-24 15:55:02 UTC (rev 56908)
@@ -37,7 +37,7 @@
char thermal; /* Flag to thermal band */
double gain, bias; /* Gain and Bias of sensor */
double K1, K2; /* Thermal calibration or
- Rad2Ref constants */
+ Rad2Ref constants */
} band_data;
@@ -51,6 +51,8 @@
double dist_es; /* Distance Earth-Sun */
double sun_elev; /* Sun elevation */
+ double sun_az; /* Sun Azimuth */
+ double time; /* Image Acquisition Time */
char sensor[10]; /* Type of sensor: MSS, TM, ETM+, OLI/TIRS */
int bands; /* Total number of bands */
Modified: grass/branches/develbranch_6/imagery/i.landsat.toar/landsat_met.c
--- grass/branches/develbranch_6/imagery/i.landsat.toar/landsat_met.c 2013-06-24 15:51:50 UTC (rev 56907)
+++ grass/branches/develbranch_6/imagery/i.landsat.toar/landsat_met.c 2013-06-24 15:55:02 UTC (rev 56908)
@@ -1,6 +1,6 @@
-#include<stdio.h>
-#include<stdlib.h>
-#include<string.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
#include <math.h>
#include <grass/gis.h>
@@ -29,10 +29,11 @@
void get_metformat(const char metadata[], char *key, char value[])
int i = 0;
- char *ptr = strstr(metadata, key);
+ char *ptrmet = strstr(metadata, key);
+ char *ptr;
- if (ptr != NULL) {
- ptr = strstr(ptr, " VALUE ");
+ if (ptrmet != NULL) {
+ ptr = strstr(ptrmet, " VALUE ");
if (ptr != NULL) {
while (*ptr++ != '=') ;
while (*ptr <= ' ')
@@ -128,6 +129,11 @@
G_warning
("Using production date from the command line 'product_date'");
+ get_mtldata(mtldata, "SUN_AZIMUTH", value);
+ lsat->sun_az = atof(value);
+ if (lsat->sun_az == 0.)
+ G_warning("Sun azimuth is %f", lsat->sun_az);
get_mtldata(mtldata, "SUN_ELEVATION", value);
if (value[0] == '\0') {
get_mtldata(mtldata, "SolarElevation", value);
@@ -136,6 +142,17 @@
if (lsat->sun_elev == 0.)
G_warning("Sun elevation is %f", lsat->sun_elev);
+ get_mtldata(mtldata, "SCENE_CENTER_TIME", value);
+ if (value[0] == '\0') {
+ get_mtldata(mtldata, "SCENE_CENTER_SCAN_TIME", value);
+ /* Remove trailing 'z'*/
+ value[strlen(value) - 1]='\0';
+ /* Cast from hh:mm:ss into hh.hhh*/
+ G_llres_scan(value, &lsat->time);
+ if (lsat->time == 0.)
+ G_warning("Time is %f", lsat->time);
/* Fill the data with the basic/default sensor parameters */
switch (lsat->number) {
case 1:
@@ -321,8 +338,8 @@
get_mtldata(mtldata, "EARTH_SUN_DISTANCE", value);
if (value[0] != '\0') {
lsat->dist_es = atof(value);
- G_verbose_message(1,
- "ESUN evaluate from REFLECTANCE_ADDITIVE_FACTOR_BAND of the metadata file");
+ G_verbose_message
+ ("ESUN evaluate from REFLECTANCE_ADDITIVE_FACTOR_BAND of the metadata file");
Modified: grass/branches/develbranch_6/imagery/i.landsat.toar/landsat_set.c
--- grass/branches/develbranch_6/imagery/i.landsat.toar/landsat_set.c 2013-06-24 15:51:50 UTC (rev 56907)
+++ grass/branches/develbranch_6/imagery/i.landsat.toar/landsat_set.c 2013-06-24 15:55:02 UTC (rev 56908)
@@ -1,6 +1,6 @@
-#include<stdio.h>
-#include<stdlib.h>
-#include<string.h>
+#include <stdio.h>
#include <math.h>
@@ -15,7 +15,7 @@
/* green, red, near infrared, near infrared */
int band[] = { 1, 2, 3, 4 };
- int code[] = { 4, 5, 6, 7 }; /* corrected for MSS4 y MSS5 to 1,2,3,4 */
+ int code[] = { 4, 5, 6, 7 }; /* corrected for MSS4 and MSS5 to 1,2,3,4 */
double wmin[] = { 0.5, 0.6, 0.7, 0.8 };
double wmax[] = { 0.6, 0.7, 0.8, 1.1 };
/* original: 79x57, now all 60 m */
@@ -65,11 +65,11 @@
int i;
- /* blue, green red, near infrared, shortwave IR, thermal IR, shortwave IR, panchromatic */
+ /* blue, green, red, near infrared, shortwave IR, thermal IR, shortwave IR, panchromatic */
int band[] = { 1, 2, 3, 4, 5, 6, 6, 7, 8 };
int code[] = { 1, 2, 3, 4, 5, 61, 62, 7, 8 };
- double wmin[] = { 0.450, 0.525, 0.630, 0.75, 1.55, 10.40, 2.09, 0.52 };
- double wmax[] = { 0.515, 0.605, 0.690, 0.90, 1.75, 12.50, 2.35, 0.90 };
+ double wmin[] = { 0.450, 0.525, 0.630, 0.75, 1.55, 10.40, 10.40, 2.09, 0.52 };
+ double wmax[] = { 0.515, 0.605, 0.690, 0.90, 1.75, 12.50, 12.50, 2.35, 0.90 };
/* 30, 30, 30, 30, 30, 60 (after Feb. 25, 2010: 30), 30, 15 */
strcpy(lsat->sensor, "ETM+");
@@ -95,12 +95,8 @@
* cirrus, thermal infrared (TIR) 1, TIR 2 */
int band[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 };
int code[] = { 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 };
- double wmin[] =
- { 0.433, 0.450, 0.525, 0.630, 0.845, 1.560, 2.100, 0.500, 1.360, 10.3,
-11.5 };
- double wmax[] =
- { 0.453, 0.515, 0.600, 0.680, 0.885, 1.660, 2.300, 0.680, 1.390, 11.3,
-12.5 };
+ double wmin[] = { 0.433, 0.450, 0.525, 0.630, 0.845, 1.560, 2.100, 0.500, 1.360, 10.3, 11.5 };
+ double wmax[] = { 0.453, 0.515, 0.600, 0.680, 0.885, 1.660, 2.300, 0.680, 1.390, 11.3, 12.5 };
/* 30, 30, 30, 30, 30, 30, 30, 15, 30, 100, 100 */
strcpy(lsat->sensor, "OLI/TIRS");
@@ -559,17 +555,20 @@
void set_LDCM(lsat_data * lsat)
int i, j;
- double julian, *lmax, *lmin;
+ double *lmax, *lmin;
/* Spectral radiances at detector */
+ /* uncorrected values */
double Lmax[][11] = {
- {0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0.} // <<<<<<<<<<<<<< valores incorrectos
+ {0., 0., 0., 0., 0., 0., 0., 0., 0., 0., 0.}
double Lmin[][11] = {
/* Solar exoatmospheric spectral irradiances */
- double esun[] = { 2062., 21931., 1990., 1688., 1037., 268.6, 94.6, 1892., 399.0, 0., 0. }; // <<<<<<<<<<<<<< estimados
+ /* estimates */
+ double esun[] = { 2062., 21931., 1990., 1688., 1037., 268.6, 94.6, 1892., 399.0, 0., 0. };
lmax = Lmax[0];
lmin = Lmin[0];
Modified: grass/branches/develbranch_6/imagery/i.landsat.toar/local_proto.h
--- grass/branches/develbranch_6/imagery/i.landsat.toar/local_proto.h 2013-06-24 15:51:50 UTC (rev 56907)
+++ grass/branches/develbranch_6/imagery/i.landsat.toar/local_proto.h 2013-06-24 15:55:02 UTC (rev 56908)
@@ -19,5 +19,4 @@
void set_LDCM(lsat_data *);
#endif
Modified: grass/branches/develbranch_6/imagery/i.landsat.toar/main.c
--- grass/branches/develbranch_6/imagery/i.landsat.toar/main.c 2013-06-24 15:51:50 UTC (rev 56907)
+++ grass/branches/develbranch_6/imagery/i.landsat.toar/main.c 2013-06-24 15:55:02 UTC (rev 56908)
@@ -174,7 +174,7 @@
atmo->key = "rayleigh";
atmo->type = TYPE_DOUBLE;
atmo->required = NO;
- atmo->description = _("Rayleigh atmosphere (diffuse sky irradiance)"); /* scattering coefficient? */
+ atmo->label = _("Rayleigh atmosphere (diffuse sky irradiance)"); /* scattering coefficient? */
atmo->description = _("Required only if 'method' is DOS3");
atmo->answer = "0.0";
atmo->guisection = _("Settings");
@@ -183,7 +183,7 @@
frad = G_define_flag();
frad->key = 'r';
frad->description =
- _("Output at-sensor radiance instead reflectance for all bands");
+ _("Output at-sensor radiance instead of reflectance for all bands");
named = G_define_flag();
named->key = 'n';
@@ -229,7 +229,7 @@
rayleigh = atof(atmo->answer);
/* Data from metadata file */
- /* Unnecessary because G_zero filled, but by sanity */
+ /* Unnecessary because G_zero filled, but for sanity */
lsat.flag = NOMETADATAFILE;
if (met != NULL) {
lsat.flag = METADATAFILE;
@@ -367,7 +367,7 @@
/* Mode of DN */
h_max = 0L;
- for (j = lsat.band[i].qcalmin; j < 241; j++) { /* Exclude ptentially saturated < 240 */
+ for (j = lsat.band[i].qcalmin; j < 241; j++) { /* Exclude potentially saturated < 240 */
/* G_debug(5, "%d-%ld", j, hist[j]); */
if (hist[j] > h_max) {
h_max = hist[j];
