[GRASS-SVN] r56941 - in grass/trunk: gui/wxpython gui/wxpython/core gui/wxpython/dbmgr gui/wxpython/gmodeler gui/wxpython/gui_core gui/wxpython/iclass gui/wxpython/lmgr gui/wxpython/location_wizard gui/wxpython/mapdisp gui/wxpython/mapswipe gui/wxpython/modules gui/wxpython/psmap gui/wxpython/rlisetup gui/wxpython/scripts gui/wxpython/vdigit gui/wxpython/web_services lib/init
Wed Jun 26 15:25:33 PDT 2013
Author: hamish
Date: 2013-06-26 15:25:33 -0700 (Wed, 26 Jun 2013)
New Revision: 56941
   grass/trunk/gui/wxpython/core/globalvar.py
   grass/trunk/gui/wxpython/core/menutree.py
   grass/trunk/gui/wxpython/core/toolboxes.py
   grass/trunk/gui/wxpython/core/utils.py
   grass/trunk/gui/wxpython/dbmgr/base.py
   grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py
   grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
   grass/trunk/gui/wxpython/gis_set.py
   grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
   grass/trunk/gui/wxpython/gui_core/forms.py
   grass/trunk/gui/wxpython/gui_core/goutput.py
   grass/trunk/gui/wxpython/gui_core/query.py
   grass/trunk/gui/wxpython/gui_core/treeview.py
   grass/trunk/gui/wxpython/iclass/frame.py
   grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
   grass/trunk/gui/wxpython/lmgr/frame.py
   grass/trunk/gui/wxpython/location_wizard/dialogs.py
   grass/trunk/gui/wxpython/mapdisp/frame.py
   grass/trunk/gui/wxpython/mapdisp/main.py
   grass/trunk/gui/wxpython/mapdisp/overlays.py
   grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
   grass/trunk/gui/wxpython/modules/mcalc_builder.py
   grass/trunk/gui/wxpython/modules/vclean.py
   grass/trunk/gui/wxpython/psmap/g.gui.psmap.py
   grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
   grass/trunk/gui/wxpython/rlisetup/wizard.py
   grass/trunk/gui/wxpython/scripts/vkrige.py
   grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
   grass/trunk/gui/wxpython/web_services/cap_interface.py
   grass/trunk/gui/wxpython/web_services/widgets.py
   grass/trunk/gui/wxpython/wxgui.py
   grass/trunk/lib/init/grass.py
avoid repetition in PYTHONPATH
Modified: grass/trunk/gui/wxpython/core/globalvar.py
--- grass/trunk/gui/wxpython/core/globalvar.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/core/globalvar.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -27,7 +27,9 @@
 from core.debug import Debug
-sys.path.append(os.path.join(ETCDIR, "python"))
+if os.path.join(ETCDIR, "python") not in sys.path:
+    sys.path.append(os.path.join(ETCDIR, "python"))
 from grass.script.core import get_commands
Modified: grass/trunk/gui/wxpython/core/menutree.py
--- grass/trunk/gui/wxpython/core/menutree.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/core/menutree.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -43,7 +43,10 @@
 import wx
 if __name__ == '__main__':
-    sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
+    gui_wx_path = os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython')
+    if gui_wx_path not in sys.path:
+        sys.path.append(gui_wx_path)
 from core.treemodel import TreeModel, ModuleNode
 from core.settings import UserSettings
@@ -217,7 +220,9 @@
         elif arg in ('manager', 'modeler', 'psmap'):
             menu = arg
-    sys.path.append(os.path.join(os.getenv("GISBASE"), "etc", "gui", "wxpython"))
     # FIXME: cross-dependencies
     if menu == 'manager':
Modified: grass/trunk/gui/wxpython/core/toolboxes.py
--- grass/trunk/gui/wxpython/core/toolboxes.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/core/toolboxes.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -32,7 +32,9 @@
 from core.globalvar import ETCWXDIR
 from core.utils import GetSettingsPath
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/core/utils.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -22,7 +22,8 @@
 import inspect
 from core.globalvar import ETCDIR
 from grass.script import core as grass
 from grass.script import task as gtask
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/dbmgr/base.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -33,7 +33,10 @@
 import types
 if __name__ == "__main__":
-    sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
 from core import globalvar
 import wx
 import wx.lib.mixins.listctrl as listmix
Modified: grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py
--- grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -37,7 +37,9 @@
 import grass.script as grass
-sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
+gui_wx_path = os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython')
+if gui_wx_path not in sys.path:
 from dbmgr.manager import AttributeManager
Modified: grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
--- grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -28,7 +28,10 @@
 import sys
 import wx
Modified: grass/trunk/gui/wxpython/gis_set.py
--- grass/trunk/gui/wxpython/gis_set.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/gis_set.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -33,7 +33,10 @@
 gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
 import wx
Modified: grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
--- grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -42,7 +42,9 @@
 from core.giface import StandaloneGrassInterface
 from core.globalvar import CheckWxVersion
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/gui_core/forms.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -66,7 +66,8 @@
 else:
     wxbase = os.path.join(gisbase, 'etc', 'gui', 'wxpython')
-sys.path.append(wxbase)
+if wxbase not in sys.path:
+    sys.path.append(wxbase)
 import wx
@@ -480,6 +481,7 @@
         self.Bind(wx.EVT_MENU, self.OnCancel, id=wx.ID_CLOSE)
         accelTableList = [(wx.ACCEL_NORMAL, wx.WXK_ESCAPE, wx.ID_CLOSE)]
         accelTableList = [(wx.ACCEL_CTRL, ord('Q'), wx.ID_CLOSE)]
+        # TODO: bind Ctrl-t for tile windows here (trac #2004)
         if self.get_dcmd is not None: # A callback has been set up
             btn_apply = wx.Button(parent = self.panel, id = wx.ID_APPLY)
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -23,7 +23,9 @@
 import sys
 import textwrap
 import wx
 from   wx import stc
Modified: grass/trunk/gui/wxpython/gui_core/query.py
--- grass/trunk/gui/wxpython/gui_core/query.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/gui_core/query.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -18,7 +18,9 @@
 import wx
 from gui_core.treeview import TreeListView
 from core.treemodel import TreeModel, DictNode
Modified: grass/trunk/gui/wxpython/gui_core/treeview.py
--- grass/trunk/gui/wxpython/gui_core/treeview.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/gui_core/treeview.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -25,7 +25,9 @@
 import wx.gizmos as gizmos
 from core.globalvar import hasAgw
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/iclass/frame.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -23,7 +23,10 @@
 import tempfile
 import wx
Modified: grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
--- grass/trunk/gui/wxpython/iclass/g.gui.iclass.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/iclass/g.gui.iclass.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -56,7 +56,9 @@
+    wxbase = os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython')
+    if wxbase not in sys.path:
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/lmgr/frame.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -37,7 +37,9 @@
 except ImportError:
     import wx.lib.flatnotebook   as FN
-sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
+if os.path.join(globalvar.ETCDIR, "python") not in sys.path:
+    sys.path.append(os.path.join(globalvar.ETCDIR, "python"))
 from core.gcmd             import RunCommand, GError, GMessage, GException
Modified: grass/trunk/gui/wxpython/location_wizard/dialogs.py
--- grass/trunk/gui/wxpython/location_wizard/dialogs.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/location_wizard/dialogs.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -24,7 +24,9 @@
 import wx.lib.scrolledpanel as scrolled
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -31,8 +31,10 @@
 import wx
 import wx.aui
-sys.path.append(os.path.join(globalvar.ETCWXDIR, "icons"))
+if os.path.join(globalvar.ETCWXDIR, "icons") not in sys.path:
+    sys.path.append(os.path.join(globalvar.ETCWXDIR, "icons"))
 from core.render        import Map
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/mapdisp/main.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -30,7 +30,10 @@
 import sys
 import wx
Modified: grass/trunk/gui/wxpython/mapdisp/overlays.py
--- grass/trunk/gui/wxpython/mapdisp/overlays.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/mapdisp/overlays.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -25,9 +25,9 @@
         self._pdcType = 'image'
         self._propwin = None
         self._defaultAt = ''
-        self._cmd = None  # to be set by user
+        self._cmd = None   # to be set by user
         self._name = None  # to be defined by subclass
-        self._id = None  # to be defined by subclass
+        self._id = None    # to be defined by subclass
     def SetCmd(self, cmd):
         hasAt = False
@@ -103,7 +103,7 @@
         self._overlay = self._renderer.AddOverlay(id = self._id, ltype = self._name,
                                                   command = self.cmd, active = False,
                                                   render = False, hidden = True)
-        # check if successfull
+        # check if successful
     def _update(self):
         self._renderer.ChangeOverlay(id = self._id, command = self._cmd,
Modified: grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
--- grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -54,7 +54,9 @@
Modified: grass/trunk/gui/wxpython/modules/mcalc_builder.py
--- grass/trunk/gui/wxpython/modules/mcalc_builder.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/modules/mcalc_builder.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -24,7 +24,9 @@
 from core.gcmd        import GError, RunCommand
Modified: grass/trunk/gui/wxpython/modules/vclean.py
--- grass/trunk/gui/wxpython/modules/vclean.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/modules/vclean.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -21,7 +21,9 @@
Modified: grass/trunk/gui/wxpython/psmap/g.gui.psmap.py
--- grass/trunk/gui/wxpython/psmap/g.gui.psmap.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/psmap/g.gui.psmap.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -40,7 +40,9 @@
+wxbase = os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython')
 from psmap.frame        import PsMapFrame
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -33,7 +33,9 @@
 import  wx
Modified: grass/trunk/gui/wxpython/rlisetup/wizard.py
--- grass/trunk/gui/wxpython/rlisetup/wizard.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/rlisetup/wizard.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -23,7 +23,9 @@
 import sys
 import os
-sys.path.append(os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython'))
 import wx
 import wx.wizard as wiz
Modified: grass/trunk/gui/wxpython/scripts/vkrige.py
--- grass/trunk/gui/wxpython/scripts/vkrige.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/scripts/vkrige.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -34,7 +34,8 @@
 ### wxGUI imports
 GUIModulesPath = os.path.join(os.getenv("GISBASE"), "etc", "gui", "wxpython")
-sys.path.append(GUIModulesPath)
+if GUIModulesPath not in sys.path:
+    sys.path.append(GUIModulesPath)
 from gui_core import gselect
Modified: grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
--- grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -39,7 +39,9 @@
 import wx
 from mapdisp.frame import MapFrame
Modified: grass/trunk/gui/wxpython/web_services/cap_interface.py
--- grass/trunk/gui/wxpython/web_services/cap_interface.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/web_services/cap_interface.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -25,7 +25,8 @@
 import sys
 WMSLibPath = os.path.join(os.getenv("GISBASE"), "etc", "r.in.wms")
-sys.path.append(WMSLibPath)
+if WMSLibPath not in sys.path:
+    sys.path.append(WMSLibPath)
 from wms_cap_parsers import WMSCapabilitiesTree, \
                             WMTSCapabilitiesTree, \
Modified: grass/trunk/gui/wxpython/web_services/widgets.py
--- grass/trunk/gui/wxpython/web_services/widgets.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/web_services/widgets.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -44,7 +44,9 @@
-sys.path.append(os.path.join(os.getenv("GISBASE"), "etc", "r.in.wms"))
+rinwms_path = os.path.join(os.getenv("GISBASE"), "etc", "r.in.wms")
+if rinwms_path not in sys.path:
+    sys.path.append(rinwms_path)
 from wms_base import WMSDriversInfo
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/gui/wxpython/wxgui.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -23,7 +23,10 @@
 import getopt
 import wx
 try:
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py	2013-06-26 21:29:36 UTC (rev 56940)
+++ grass/trunk/lib/init/grass.py	2013-06-26 22:25:33 UTC (rev 56941)
@@ -611,8 +611,12 @@
        os.F_OK):
                             fatal(_("Failed to create new location. The " \
                                     "location <%s> already exists." % location_name))
-                        sys.path.append(gfile('etc', 'python'))
+                        if gfile('etc', 'python') not in sys.path:
+                            sys.path.append(gfile('etc', 'python'))
                         try:
                             if geofile and geofile.find('EPSG:') > -1:
                                 epsg = geofile.split(':', 1)[1]
