[GRASS-SVN] r56943 - grass/trunk
svn_grass at osgeo.org
Thu Jun 27 05:30:48 PDT 2013
Author: mmetz
Date: 2013-06-27 05:30:48 -0700 (Thu, 27 Jun 2013)
New Revision: 56943
grass/trunk/aclocal.m4
grass/trunk/configure
enable AIX shared libs
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4 2013-06-27 12:24:54 UTC (rev 56942)
+++ grass/trunk/aclocal.m4 2013-06-27 12:30:48 UTC (rev 56943)
@@ -596,9 +596,18 @@
# NOTE: do we need to support aix < 6 ?
LIBS="$LIBS -lc"
SHLIB_CFLAGS=""
+ LDFLAGS=""
+ if test "$GCC" = "yes" ; then
+ SHLIB_CFLAGS="-fPIC"
+ SHLIB_LD="$CC -shared"
+ LD_SEARCH_FLAGS='-Wl,-bsvr4,-R,${LIB_RUNTIME_DIR}'
+ else
+ # assume xlc
+ SHLIB_CFLAGS="-qmkshrobj"
+ fi
SHLIB_SUFFIX=".so"
- LDFLAGS=""
- LD_SEARCH_FLAGS='-L${LIB_RUNTIME_DIR}'
LD_LIBRARY_PATH_VAR="LIBPATH"
GRASS_NEEDS_EXP_FILE=1
GRASS_EXPORT_FILE_SUFFIX='${LIB_VER}.exp'
Modified: grass/trunk/configure
--- grass/trunk/configure 2013-06-27 12:24:54 UTC (rev 56942)
+++ grass/trunk/configure 2013-06-27 12:30:48 UTC (rev 56943)
@@ -1613,9 +1613,18 @@
LIBS="$LIBS -lc"
SHLIB_CFLAGS=""
+ LDFLAGS=""
+ else
+ # assume xlc
+ fi
SHLIB_SUFFIX=".so"
- LDFLAGS=""
@@ -2331,7 +2340,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2335: checking for additional include dirs" >&5
+echo "configure:2344: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2354,7 +2363,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2358: checking for additional library dirs" >&5
+echo "configure:2367: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2388,7 +2397,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2392: checking for a BSD compatible install" >&5
+echo "configure:2401: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2441,7 +2450,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:2445: checking for $ac_word" >&5
+echo "configure:2454: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2472,13 +2481,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2476: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2485: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 2482 "configure"
+#line 2491 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2489,7 +2498,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2493: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2514,7 +2523,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2518: checking for $ac_word" >&5
+echo "configure:2527: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2554,7 +2563,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2558: checking for $ac_word" >&5
+echo "configure:2567: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2585,7 +2594,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2589: checking for $ac_word" >&5
+echo "configure:2598: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2623,7 +2632,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2627: checking for $ac_word" >&5
+echo "configure:2636: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2652,7 +2661,7 @@
-echo "configure:2656: checking for $ac_word" >&5
+echo "configure:2665: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2683,7 +2692,7 @@
-echo "configure:2687: checking for $ac_word" >&5
+echo "configure:2696: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2712,7 +2721,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2716: checking for $ac_word" >&5
+echo "configure:2725: checking for $ac_word" >&5
case "$PERL" in
@@ -2743,7 +2752,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2747: checking how to run the C preprocessor" >&5
+echo "configure:2756: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2756,13 +2765,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2760 "configure"
+#line 2769 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2766: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2775: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2773,13 +2782,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2777 "configure"
+#line 2786 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2783: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2792: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2790,13 +2799,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2794 "configure"
+#line 2803 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2800: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2809: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2820,10 +2829,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2824: checking for ANSI C header files" >&5
+echo "configure:2833: checking for ANSI C header files" >&5
-#line 2827 "configure"
+#line 2836 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2831,7 +2840,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2835: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2844: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2848,7 +2857,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2852 "configure"
+#line 2861 "configure"
#include <string.h>
EOF
@@ -2866,7 +2875,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2870 "configure"
+#line 2879 "configure"
#include <stdlib.h>
EOF
@@ -2887,7 +2896,7 @@
else
-#line 2891 "configure"
+#line 2900 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2898,7 +2907,7 @@
exit (0); }
EOF
-if { (eval echo configure:2902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2925,15 +2934,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2929: checking for $ac_hdr" >&5
+echo "configure:2938: checking for $ac_hdr" >&5
-#line 2932 "configure"
+#line 2941 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2937: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2946: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2962,15 +2971,15 @@
do
-echo "configure:2966: checking for $ac_hdr" >&5
+echo "configure:2975: checking for $ac_hdr" >&5
-#line 2969 "configure"
+#line 2978 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2974: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2983: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2999,15 +3008,15 @@
do
-echo "configure:3003: checking for $ac_hdr" >&5
+echo "configure:3012: checking for $ac_hdr" >&5
-#line 3006 "configure"
+#line 3015 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3011: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3020: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3036,15 +3045,15 @@
do
-echo "configure:3040: checking for $ac_hdr" >&5
+echo "configure:3049: checking for $ac_hdr" >&5
-#line 3043 "configure"
+#line 3052 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3048: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3057: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3073,15 +3082,15 @@
do
-echo "configure:3077: checking for $ac_hdr" >&5
+echo "configure:3086: checking for $ac_hdr" >&5
-#line 3080 "configure"
+#line 3089 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3085: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3094: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3107,10 +3116,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3111: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3120: checking whether time.h and sys/time.h may both be included" >&5
-#line 3114 "configure"
+#line 3123 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3119,7 +3128,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3123: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3132: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3139,10 +3148,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3143: checking for off_t" >&5
+echo "configure:3152: checking for off_t" >&5
-#line 3146 "configure"
+#line 3155 "configure"
#if STDC_HEADERS
@@ -3169,10 +3178,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3173: checking for uid_t in sys/types.h" >&5
+echo "configure:3182: checking for uid_t in sys/types.h" >&5
-#line 3176 "configure"
+#line 3185 "configure"
EOF
@@ -3200,10 +3209,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3204: checking return type of signal handlers" >&5
+echo "configure:3213: checking return type of signal handlers" >&5
-#line 3207 "configure"
+#line 3216 "configure"
#include <signal.h>
@@ -3220,7 +3229,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3224: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3233: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3238,10 +3247,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3242: checking for Cygwin environment" >&5
+echo "configure:3251: checking for Cygwin environment" >&5
-#line 3245 "configure"
+#line 3254 "configure"
int main() {
@@ -3252,7 +3261,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3256: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3265: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3270,10 +3279,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3274: checking for $ac_func" >&5
+echo "configure:3283: checking for $ac_func" >&5
-#line 3277 "configure"
+#line 3286 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3296,7 +3305,7 @@
; return 0; }
EOF
-if { (eval echo configure:3300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3322,10 +3331,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3326: checking for $ac_func" >&5
+echo "configure:3335: checking for $ac_func" >&5
-#line 3329 "configure"
+#line 3338 "configure"
@@ -3348,7 +3357,7 @@
; return 0; }
EOF
-if { (eval echo configure:3352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3374,10 +3383,10 @@
for ac_func in drand48
do
-echo "configure:3378: checking for $ac_func" >&5
+echo "configure:3387: checking for $ac_func" >&5
-#line 3381 "configure"
+#line 3390 "configure"
@@ -3400,7 +3409,7 @@
; return 0; }
EOF
-if { (eval echo configure:3404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3426,10 +3435,10 @@
for ac_func in putenv setenv
do
-echo "configure:3430: checking for $ac_func" >&5
+echo "configure:3439: checking for $ac_func" >&5
-#line 3433 "configure"
+#line 3442 "configure"
@@ -3452,7 +3461,7 @@
; return 0; }
EOF
-if { (eval echo configure:3456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3478,10 +3487,10 @@
for ac_func in nanosleep
do
-echo "configure:3482: checking for $ac_func" >&5
+echo "configure:3491: checking for $ac_func" >&5
-#line 3485 "configure"
+#line 3494 "configure"
@@ -3504,7 +3513,7 @@
; return 0; }
EOF
-if { (eval echo configure:3508: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3529,13 +3538,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3533: checking whether setpgrp takes no argument" >&5
+echo "configure:3542: checking whether setpgrp takes no argument" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3539 "configure"
+#line 3548 "configure"
#ifdef HAVE_UNISTD_H
@@ -3555,7 +3564,7 @@
EOF
-if { (eval echo configure:3559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3583,16 +3592,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3587: checking for long long int" >&5
+echo "configure:3596: checking for long long int" >&5
-#line 3589 "configure"
+#line 3598 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3596: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3605: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -3612,7 +3621,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3616: checking for W11" >&5
+echo "configure:3625: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3640,7 +3649,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3644: checking for X" >&5
+echo "configure:3653: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3700,12 +3709,12 @@
# First, try using that file with no special directory specified.
-#line 3704 "configure"
+#line 3713 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3709: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3718: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3774,14 +3783,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3778 "configure"
+#line 3787 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3886,17 +3895,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3890: checking whether -R must be followed by a space" >&5
+echo "configure:3899: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3893 "configure"
+#line 3902 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3912,14 +3921,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3916 "configure"
+#line 3925 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3951,13 +3960,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3955: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3964: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3961 "configure"
+#line 3970 "configure"
@@ -3968,7 +3977,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3989,13 +3998,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3993: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:4002: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 3999 "configure"
+#line 4008 "configure"
@@ -4006,7 +4015,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:4010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4034,10 +4043,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4038: checking for gethostbyname" >&5
+echo "configure:4047: checking for gethostbyname" >&5
-#line 4041 "configure"
+#line 4050 "configure"
which can conflict with char gethostbyname(); below. */
@@ -4060,7 +4069,7 @@
; return 0; }
EOF
-if { (eval echo configure:4064: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4080,13 +4089,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4084: checking for gethostbyname in -lnsl" >&5
+echo "configure:4093: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4090 "configure"
+#line 4099 "configure"
@@ -4097,7 +4106,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4126,10 +4135,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4130: checking for connect" >&5
+echo "configure:4139: checking for connect" >&5
-#line 4133 "configure"
+#line 4142 "configure"
which can conflict with char connect(); below. */
@@ -4152,7 +4161,7 @@
; return 0; }
EOF
-if { (eval echo configure:4156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4172,13 +4181,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4176: checking for connect in -lsocket" >&5
+echo "configure:4185: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4182 "configure"
+#line 4191 "configure"
@@ -4189,7 +4198,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4212,10 +4221,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4216: checking for remove" >&5
+echo "configure:4225: checking for remove" >&5
-#line 4219 "configure"
+#line 4228 "configure"
which can conflict with char remove(); below. */
@@ -4238,7 +4247,7 @@
; return 0; }
EOF
-if { (eval echo configure:4242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4258,13 +4267,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4262: checking for remove in -lposix" >&5
+echo "configure:4271: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4268 "configure"
+#line 4277 "configure"
@@ -4275,7 +4284,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4298,10 +4307,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4302: checking for shmat" >&5
+echo "configure:4311: checking for shmat" >&5
-#line 4305 "configure"
+#line 4314 "configure"
which can conflict with char shmat(); below. */
@@ -4324,7 +4333,7 @@
; return 0; }
EOF
-if { (eval echo configure:4328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4344,13 +4353,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4348: checking for shmat in -lipc" >&5
+echo "configure:4357: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4354 "configure"
+#line 4363 "configure"
@@ -4361,7 +4370,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4393,13 +4402,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4397: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4406: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4403 "configure"
+#line 4412 "configure"
@@ -4410,7 +4419,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4450,12 +4459,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4454: checking for library containing cuserid" >&5
+echo "configure:4463: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4459 "configure"
+#line 4468 "configure"
@@ -4466,7 +4475,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4477,7 +4486,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4481 "configure"
+#line 4490 "configure"
@@ -4488,7 +4497,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4492: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4514,10 +4523,10 @@
for ac_func in asprintf
do
-echo "configure:4518: checking for $ac_func" >&5
+echo "configure:4527: checking for $ac_func" >&5
-#line 4521 "configure"
+#line 4530 "configure"
@@ -4540,7 +4549,7 @@
; return 0; }
EOF
-if { (eval echo configure:4544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4567,10 +4576,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4571: checking for atan" >&5
+echo "configure:4580: checking for atan" >&5
-#line 4574 "configure"
+#line 4583 "configure"
which can conflict with char atan(); below. */
@@ -4593,7 +4602,7 @@
; return 0; }
EOF
-if { (eval echo configure:4597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4611,13 +4620,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4615: checking for atan in -lm" >&5
+echo "configure:4624: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4621 "configure"
+#line 4630 "configure"
@@ -4628,7 +4637,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4655,10 +4664,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4659: checking for dlsym" >&5
+echo "configure:4668: checking for dlsym" >&5
-#line 4662 "configure"
+#line 4671 "configure"
which can conflict with char dlsym(); below. */
@@ -4681,7 +4690,7 @@
; return 0; }
EOF
-if { (eval echo configure:4685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4699,13 +4708,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4703: checking for dlsym in -ldl" >&5
+echo "configure:4712: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4709 "configure"
+#line 4718 "configure"
@@ -4716,7 +4725,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4743,10 +4752,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4747: checking for iconv" >&5
+echo "configure:4756: checking for iconv" >&5
-#line 4750 "configure"
+#line 4759 "configure"
which can conflict with char iconv(); below. */
@@ -4769,7 +4778,7 @@
; return 0; }
EOF
-if { (eval echo configure:4773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4787,13 +4796,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4791: checking for iconv in -liconv" >&5
+echo "configure:4800: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4797 "configure"
+#line 4806 "configure"
@@ -4804,7 +4813,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4823,13 +4832,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4827: checking for iconv in -lgiconv" >&5
+echo "configure:4836: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4833 "configure"
+#line 4842 "configure"
@@ -4840,7 +4849,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4859,10 +4868,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4863: checking for libiconv" >&5
+echo "configure:4872: checking for libiconv" >&5
-#line 4866 "configure"
+#line 4875 "configure"
which can conflict with char libiconv(); below. */
@@ -4885,7 +4894,7 @@
; return 0; }
EOF
-if { (eval echo configure:4889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -4903,13 +4912,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4907: checking for libiconv in -liconv" >&5
+echo "configure:4916: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4913 "configure"
+#line 4922 "configure"
@@ -4920,7 +4929,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4939,13 +4948,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4943: checking for libiconv in -lgiconv" >&5
+echo "configure:4952: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4949 "configure"
+#line 4958 "configure"
@@ -4956,7 +4965,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4993,10 +5002,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4997: checking for socket" >&5
+echo "configure:5006: checking for socket" >&5
-#line 5000 "configure"
+#line 5009 "configure"
which can conflict with char socket(); below. */
@@ -5019,7 +5028,7 @@
; return 0; }
EOF
-if { (eval echo configure:5023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5037,13 +5046,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5041: checking for socket in -lsocket" >&5
+echo "configure:5050: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5047 "configure"
+#line 5056 "configure"
@@ -5054,7 +5063,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5102,7 +5111,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5106: checking for location of zlib includes" >&5
+echo "configure:5115: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5128,15 +5137,15 @@
do
-echo "configure:5132: checking for $ac_hdr" >&5
+echo "configure:5141: checking for $ac_hdr" >&5
-#line 5135 "configure"
+#line 5144 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5140: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5170,7 +5179,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5174: checking for location of zlib library" >&5
+echo "configure:5183: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5195,13 +5204,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5199: checking for deflate in -lz" >&5
+echo "configure:5208: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5205 "configure"
+#line 5214 "configure"
@@ -5212,7 +5221,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5260,7 +5269,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5264: checking for location of External PROJ.4 includes" >&5
+echo "configure:5273: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5286,15 +5295,15 @@
do
-echo "configure:5290: checking for $ac_hdr" >&5
+echo "configure:5299: checking for $ac_hdr" >&5
-#line 5293 "configure"
+#line 5302 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5298: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5307: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5331,7 +5340,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5335: checking External PROJ.4 version" >&5
+echo "configure:5344: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5339,7 +5348,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 5343 "configure"
+#line 5352 "configure"
#include <stdio.h>
@@ -5351,7 +5360,7 @@
EOF
-if { (eval echo configure:5355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5376,7 +5385,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5380: checking for location of External PROJ.4 library" >&5
+echo "configure:5389: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5401,13 +5410,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5405: checking for pj_get_def in -lproj" >&5
+echo "configure:5414: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5411 "configure"
+#line 5420 "configure"
@@ -5418,7 +5427,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5452,7 +5461,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5456: checking for location of External PROJ.4 data files" >&5
+echo "configure:5465: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5476,14 +5485,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5480: checking for epsg" >&5
+echo "configure:5489: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5487: checking for $PROJSHARE/epsg" >&5
+echo "configure:5496: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -5515,7 +5524,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5519: checking for $ac_word" >&5
+echo "configure:5528: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5555,7 +5564,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5559: checking whether to use regex" >&5
+echo "configure:5568: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5575,7 +5584,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5579: checking for location of regex includes" >&5
+echo "configure:5588: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5601,15 +5610,15 @@
do
-echo "configure:5605: checking for $ac_hdr" >&5
+echo "configure:5614: checking for $ac_hdr" >&5
-#line 5608 "configure"
+#line 5617 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5613: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5622: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5643,7 +5652,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5647: checking for location of regex library" >&5
+echo "configure:5656: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5668,10 +5677,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5672: checking for regcomp" >&5
+echo "configure:5681: checking for regcomp" >&5
-#line 5675 "configure"
+#line 5684 "configure"
which can conflict with char regcomp(); below. */
@@ -5694,7 +5703,7 @@
; return 0; }
EOF
-if { (eval echo configure:5698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5721,13 +5730,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5725: checking for regcomp in -lregex" >&5
+echo "configure:5734: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5731 "configure"
+#line 5740 "configure"
@@ -5738,7 +5747,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5788,7 +5797,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5792: checking whether to use Readline" >&5
+echo "configure:5801: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5809,7 +5818,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5813: checking for location of Readline includes" >&5
+echo "configure:5822: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5835,15 +5844,15 @@
do
-echo "configure:5839: checking for $ac_hdr" >&5
+echo "configure:5848: checking for $ac_hdr" >&5
-#line 5842 "configure"
+#line 5851 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5847: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5879,15 +5888,15 @@
do
-echo "configure:5883: checking for $ac_hdr" >&5
+echo "configure:5892: checking for $ac_hdr" >&5
-#line 5886 "configure"
+#line 5895 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5891: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5921,7 +5930,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5925: checking for location of Readline library" >&5
+echo "configure:5934: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5946,13 +5955,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5950: checking for readline in -lreadline" >&5
+echo "configure:5959: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 5956 "configure"
+#line 5965 "configure"
@@ -5963,7 +5972,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:5967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5998,13 +6007,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6002: checking for add_history in -lhistory" >&5
+echo "configure:6011: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6008 "configure"
+#line 6017 "configure"
@@ -6015,7 +6024,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6057,7 +6066,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6061: checking whether to use GDAL" >&5
+echo "configure:6070: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6075,7 +6084,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:6079: checking for $ac_word" >&5
+echo "configure:6088: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6130,14 +6139,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6134 "configure"
+#line 6143 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6146,14 +6155,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6150 "configure"
+#line 6159 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6185,7 +6194,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6189: checking whether to use libLAS" >&5
+echo "configure:6198: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6202,7 +6211,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6206: checking for $ac_word" >&5
+echo "configure:6215: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6250,14 +6259,14 @@
LIBS="$LIBS $LIBLAS_LIBS"
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6254 "configure"
+#line 6263 "configure"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6265,14 +6274,14 @@
rm -rf conftest*
-#line 6269 "configure"
+#line 6278 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6304,7 +6313,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6308: checking whether to use NetCDF" >&5
+echo "configure:6317: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -6321,7 +6330,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:6325: checking for $ac_word" >&5
+echo "configure:6334: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -6368,14 +6377,14 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6372 "configure"
+#line 6381 "configure"
#include <netcdf.h>
int main() {
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:6379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6383,14 +6392,14 @@
rm -rf conftest*
-#line 6387 "configure"
+#line 6396 "configure"
#include <netcdf.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6394: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -6421,7 +6430,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6425: checking whether to use GEOS" >&5
+echo "configure:6434: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -6439,7 +6448,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6443: checking for $ac_word" >&5
+echo "configure:6452: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6487,15 +6496,15 @@
do
-echo "configure:6491: checking for $ac_hdr" >&5
+echo "configure:6500: checking for $ac_hdr" >&5
-#line 6494 "configure"
+#line 6503 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6499: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6508: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6534,13 +6543,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6538: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6547: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6544 "configure"
+#line 6553 "configure"
@@ -6551,7 +6560,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6564: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6595,7 +6604,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6599: checking whether to use TIFF" >&5
+echo "configure:6608: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6615,7 +6624,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6619: checking for location of TIFF includes" >&5
+echo "configure:6628: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6641,15 +6650,15 @@
do
-echo "configure:6645: checking for $ac_hdr" >&5
+echo "configure:6654: checking for $ac_hdr" >&5
-#line 6648 "configure"
+#line 6657 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6653: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6683,7 +6692,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6687: checking for location of TIFF library" >&5
+echo "configure:6696: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6714,13 +6723,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6718: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6727: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6724 "configure"
+#line 6733 "configure"
@@ -6731,7 +6740,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6750,13 +6759,13 @@
-echo "configure:6754: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6763: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 6760 "configure"
+#line 6769 "configure"
@@ -6767,7 +6776,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6771: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6786,13 +6795,13 @@
-echo "configure:6790: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6799: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 6796 "configure"
+#line 6805 "configure"
@@ -6803,7 +6812,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6822,13 +6831,13 @@
-echo "configure:6826: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6835: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6832 "configure"
+#line 6841 "configure"
@@ -6839,7 +6848,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6858,13 +6867,13 @@
-echo "configure:6862: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6871: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 6868 "configure"
+#line 6877 "configure"
@@ -6875,7 +6884,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6894,13 +6903,13 @@
-echo "configure:6898: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6907: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6904 "configure"
+#line 6913 "configure"
@@ -6911,7 +6920,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6930,13 +6939,13 @@
-echo "configure:6934: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6943: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6940 "configure"
+#line 6949 "configure"
@@ -6947,7 +6956,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6966,13 +6975,13 @@
-echo "configure:6970: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6979: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6976 "configure"
+#line 6985 "configure"
@@ -6983,7 +6992,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7081,7 +7090,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7085: checking whether to use PNG" >&5
+echo "configure:7094: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7100,7 +7109,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7104: checking for location of PNG includes" >&5
+echo "configure:7113: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7126,15 +7135,15 @@
do
-echo "configure:7130: checking for $ac_hdr" >&5
+echo "configure:7139: checking for $ac_hdr" >&5
-#line 7133 "configure"
+#line 7142 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7138: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7168,7 +7177,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7172: checking for location of PNG library" >&5
+echo "configure:7181: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7193,13 +7202,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7197: checking for png_read_image in -lpng" >&5
+echo "configure:7206: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7203 "configure"
+#line 7212 "configure"
@@ -7210,7 +7219,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7252,7 +7261,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7256: checking whether to use PostgreSQL" >&5
+echo "configure:7265: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7279,7 +7288,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7283: checking for location of PostgreSQL includes" >&5
+echo "configure:7292: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7305,15 +7314,15 @@
do
-echo "configure:7309: checking for $ac_hdr" >&5
+echo "configure:7318: checking for $ac_hdr" >&5
-#line 7312 "configure"
+#line 7321 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7317: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7326: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7351,7 +7360,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7355: checking for location of PostgreSQL library" >&5
+echo "configure:7364: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7380,13 +7389,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7384: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7393: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7390 "configure"
+#line 7399 "configure"
@@ -7397,7 +7406,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7416,13 +7425,13 @@
-echo "configure:7420: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7429: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7426 "configure"
+#line 7435 "configure"
@@ -7433,7 +7442,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7452,13 +7461,13 @@
-echo "configure:7456: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7465: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7462 "configure"
+#line 7471 "configure"
@@ -7469,7 +7478,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7488,13 +7497,13 @@
-echo "configure:7492: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7501: checking for PQsetdbLogin in -lpq" >&5
ac_save_LIBS="$LIBS"
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7498 "configure"
+#line 7507 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7505,7 +7514,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7562,13 +7571,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7566: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7575: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7572 "configure"
+#line 7581 "configure"
@@ -7579,7 +7588,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7601,13 +7610,13 @@
-echo "configure:7605: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7614: checking for PQcmdTuples in -lpq" >&5
-#line 7611 "configure"
+#line 7620 "configure"
@@ -7618,7 +7627,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7661,7 +7670,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7665: checking whether to use MySQL" >&5
+echo "configure:7674: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7681,7 +7690,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7685: checking for location of MySQL includes" >&5
+echo "configure:7694: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7707,15 +7716,15 @@
do
-echo "configure:7711: checking for $ac_hdr" >&5
+echo "configure:7720: checking for $ac_hdr" >&5
-#line 7714 "configure"
+#line 7723 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7728: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7752,7 +7761,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7756: checking for location of MySQL library" >&5
+echo "configure:7765: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7783,13 +7792,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7787: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7796: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7793 "configure"
+#line 7802 "configure"
@@ -7800,7 +7809,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7813: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7819,13 +7828,13 @@
-echo "configure:7823: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7832: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7829 "configure"
+#line 7838 "configure"
@@ -7836,7 +7845,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7849: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7855,13 +7864,13 @@
-echo "configure:7859: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7868: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7865 "configure"
+#line 7874 "configure"
@@ -7872,7 +7881,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7891,13 +7900,13 @@
-echo "configure:7895: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7904: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7901 "configure"
+#line 7910 "configure"
@@ -7908,7 +7917,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7921: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7927,13 +7936,13 @@
-echo "configure:7931: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7940: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7937 "configure"
+#line 7946 "configure"
@@ -7944,7 +7953,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7963,13 +7972,13 @@
-echo "configure:7967: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7976: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7973 "configure"
+#line 7982 "configure"
@@ -7980,7 +7989,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7999,13 +8008,13 @@
-echo "configure:8003: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8012: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8009 "configure"
+#line 8018 "configure"
@@ -8016,7 +8025,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8035,13 +8044,13 @@
-echo "configure:8039: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8048: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8045 "configure"
+#line 8054 "configure"
@@ -8052,7 +8061,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8065: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8142,7 +8151,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8146: checking for $ac_word" >&5
+echo "configure:8155: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8191,10 +8200,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8195: checking for mysql_server_init" >&5
+echo "configure:8204: checking for mysql_server_init" >&5
-#line 8198 "configure"
+#line 8207 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -8220,7 +8229,7 @@
; return 0; }
EOF
-if { (eval echo configure:8224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8272,7 +8281,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8276: checking whether to use SQLite" >&5
+echo "configure:8285: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8292,7 +8301,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8296: checking for location of SQLite includes" >&5
+echo "configure:8305: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8318,15 +8327,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8322: checking for $ac_hdr" >&5
+echo "configure:8331: checking for $ac_hdr" >&5
-#line 8325 "configure"
+#line 8334 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8330: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8339: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8369,7 +8378,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8373: checking for location of SQLite library" >&5
+echo "configure:8382: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8398,13 +8407,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8402: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8411: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8408 "configure"
+#line 8417 "configure"
@@ -8415,7 +8424,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8419: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8428: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8434,13 +8443,13 @@
-echo "configure:8438: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8447: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8444 "configure"
+#line 8453 "configure"
@@ -8451,7 +8460,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8455: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8470,13 +8479,13 @@
-echo "configure:8474: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8483: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8480 "configure"
+#line 8489 "configure"
@@ -8487,7 +8496,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8506,13 +8515,13 @@
-echo "configure:8510: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8519: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8516 "configure"
+#line 8525 "configure"
@@ -8523,7 +8532,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8536: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8592,7 +8601,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8596: checking whether to use FFMPEG" >&5
+echo "configure:8605: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8612,7 +8621,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8616: checking for location of FFMPEG includes" >&5
+echo "configure:8625: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8638,15 +8647,15 @@
do
-echo "configure:8642: checking for $ac_hdr" >&5
+echo "configure:8651: checking for $ac_hdr" >&5
-#line 8645 "configure"
+#line 8654 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8650: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8659: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8682,15 +8691,15 @@
do
-echo "configure:8686: checking for $ac_hdr" >&5
+echo "configure:8695: checking for $ac_hdr" >&5
-#line 8689 "configure"
+#line 8698 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8703: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8726,15 +8735,15 @@
do
-echo "configure:8730: checking for $ac_hdr" >&5
+echo "configure:8739: checking for $ac_hdr" >&5
-#line 8733 "configure"
+#line 8742 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8738: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8747: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8777,7 +8786,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8781: checking for location of FFMPEG library" >&5
+echo "configure:8790: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8804,13 +8813,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8808: checking for av_free in -lavutil" >&5
+echo "configure:8817: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8814 "configure"
+#line 8823 "configure"
@@ -8821,7 +8830,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8834: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8840,13 +8849,13 @@
-echo "configure:8844: checking for av_free in -lavutil" >&5
+echo "configure:8853: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8850 "configure"
+#line 8859 "configure"
@@ -8857,7 +8866,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8870: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8902,13 +8911,13 @@
echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8906: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8915: checking for avcodec_register in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 8912 "configure"
+#line 8921 "configure"
@@ -8919,7 +8928,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8938,13 +8947,13 @@
-echo "configure:8942: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8951: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8948 "configure"
+#line 8957 "configure"
@@ -8955,7 +8964,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8968: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9000,13 +9009,13 @@
echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:9004: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9013: checking for avformat_alloc_context in -lavformat" >&5
ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 9010 "configure"
+#line 9019 "configure"
@@ -9017,7 +9026,7 @@
avformat_alloc_context()
; return 0; }
EOF
-if { (eval echo configure:9021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9036,13 +9045,13 @@
-echo "configure:9040: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:9049: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9046 "configure"
+#line 9055 "configure"
@@ -9053,7 +9062,7 @@
; return 0; }
EOF
-if { (eval echo configure:9057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9112,7 +9121,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9116: checking whether to use OpenGL" >&5
+echo "configure:9125: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9146,7 +9155,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9150: checking for location of OpenGL includes" >&5
+echo "configure:9159: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9172,15 +9181,15 @@
do
-echo "configure:9176: checking for $ac_hdr" >&5
+echo "configure:9185: checking for $ac_hdr" >&5
-#line 9179 "configure"
+#line 9188 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9184: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9214,7 +9223,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9218: checking for location of OpenGL library" >&5
+echo "configure:9227: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9243,13 +9252,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9247: checking for glBegin in -lGL" >&5
+echo "configure:9256: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9253 "configure"
+#line 9262 "configure"
@@ -9260,7 +9269,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9279,13 +9288,13 @@
-echo "configure:9283: checking for glBegin in -lGL" >&5
+echo "configure:9292: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9289 "configure"
+#line 9298 "configure"
@@ -9296,7 +9305,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9315,13 +9324,13 @@
-echo "configure:9319: checking for glBegin in -lGL" >&5
+echo "configure:9328: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9325 "configure"
+#line 9334 "configure"
@@ -9332,7 +9341,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9345: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9351,13 +9360,13 @@
-echo "configure:9355: checking for glBegin in -lGL" >&5
+echo "configure:9364: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9361 "configure"
+#line 9370 "configure"
@@ -9368,7 +9377,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9381: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9430,13 +9439,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9434: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9443: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9440 "configure"
+#line 9449 "configure"
@@ -9447,7 +9456,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9466,13 +9475,13 @@
-echo "configure:9470: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9479: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9476 "configure"
+#line 9485 "configure"
@@ -9483,7 +9492,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9530,10 +9539,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9534: checking for glXCreatePbuffer" >&5
+echo "configure:9543: checking for glXCreatePbuffer" >&5
-#line 9537 "configure"
+#line 9546 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -9556,7 +9565,7 @@
; return 0; }
EOF
-if { (eval echo configure:9560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9593,10 +9602,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9597: checking for glXCreateGLXPixmap" >&5
+echo "configure:9606: checking for glXCreateGLXPixmap" >&5
-#line 9600 "configure"
+#line 9609 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9619,7 +9628,7 @@
; return 0; }
EOF
-if { (eval echo configure:9623: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9632: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9662,7 +9671,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9666: checking for location of OpenGL framework" >&5
+echo "configure:9675: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9686,15 +9695,15 @@
do
-echo "configure:9690: checking for $ac_hdr" >&5
+echo "configure:9699: checking for $ac_hdr" >&5
-#line 9693 "configure"
+#line 9702 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9698: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9707: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9730,10 +9739,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9734: checking for glBegin" >&5
+echo "configure:9743: checking for glBegin" >&5
-#line 9737 "configure"
+#line 9746 "configure"
which can conflict with char glBegin(); below. */
@@ -9756,7 +9765,7 @@
; return 0; }
EOF
-if { (eval echo configure:9760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9769: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9793,10 +9802,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9797: checking for gluBeginCurve" >&5
+echo "configure:9806: checking for gluBeginCurve" >&5
-#line 9800 "configure"
+#line 9809 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9819,7 +9828,7 @@
; return 0; }
EOF
-if { (eval echo configure:9823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9867,7 +9876,7 @@
-echo "configure:9871: checking for location of OpenGL includes" >&5
+echo "configure:9880: checking for location of OpenGL includes" >&5
@@ -9893,15 +9902,15 @@
do
-echo "configure:9897: checking for $ac_hdr" >&5
+echo "configure:9906: checking for $ac_hdr" >&5
-#line 9900 "configure"
+#line 9909 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9905: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9914: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9935,7 +9944,7 @@
-echo "configure:9939: checking for location of OpenGL library" >&5
+echo "configure:9948: checking for location of OpenGL library" >&5
@@ -9960,18 +9969,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9964: checking for OpenGL library" >&5
+echo "configure:9973: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9968 "configure"
+#line 9977 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -9995,18 +10004,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9999: checking for GLU library" >&5
+echo "configure:10008: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 10003 "configure"
+#line 10012 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:10010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10055,7 +10064,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10059: checking whether to use ODBC" >&5
+echo "configure:10068: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -10074,7 +10083,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10078: checking for location of ODBC includes" >&5
+echo "configure:10087: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10100,15 +10109,15 @@
do
-echo "configure:10104: checking for $ac_hdr" >&5
+echo "configure:10113: checking for $ac_hdr" >&5
-#line 10107 "configure"
+#line 10116 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10112: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10121: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10142,7 +10151,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10146: checking for location of ODBC library" >&5
+echo "configure:10155: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10167,13 +10176,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10171: checking for SQLConnect in -lodbc" >&5
+echo "configure:10180: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 10177 "configure"
+#line 10186 "configure"
@@ -10184,7 +10193,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10209,13 +10218,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10213: checking for SQLConnect in -liodbc" >&5
+echo "configure:10222: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 10219 "configure"
+#line 10228 "configure"
@@ -10226,7 +10235,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10251,11 +10260,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10255: checking for ODBC library" >&5
+echo "configure:10264: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 10259 "configure"
+#line 10268 "configure"
#include <windows.h>
#include <sql.h>
@@ -10263,7 +10272,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:10267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10312,7 +10321,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10316: checking whether to use FFTW" >&5
+echo "configure:10325: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -10331,7 +10340,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10335: checking for location of FFTW includes" >&5
+echo "configure:10344: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10357,15 +10366,15 @@
do
-echo "configure:10361: checking for $ac_hdr" >&5
+echo "configure:10370: checking for $ac_hdr" >&5
-#line 10364 "configure"
+#line 10373 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10378: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10393,15 +10402,15 @@
do
-echo "configure:10397: checking for $ac_hdr" >&5
+echo "configure:10406: checking for $ac_hdr" >&5
-#line 10400 "configure"
+#line 10409 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10405: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10429,15 +10438,15 @@
do
-echo "configure:10433: checking for $ac_hdr" >&5
+echo "configure:10442: checking for $ac_hdr" >&5
-#line 10436 "configure"
+#line 10445 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10441: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10450: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10483,7 +10492,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10487: checking for location of FFTW library" >&5
+echo "configure:10496: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10508,13 +10517,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10512: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10521: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10518 "configure"
+#line 10527 "configure"
@@ -10525,7 +10534,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:10529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10550,13 +10559,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10554: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10563: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 10560 "configure"
+#line 10569 "configure"
@@ -10567,7 +10576,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10592,13 +10601,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10596: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10605: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10602 "configure"
+#line 10611 "configure"
@@ -10609,7 +10618,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10622: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10666,7 +10675,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10670: checking whether to use BLAS" >&5
+echo "configure:10679: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10687,7 +10696,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10691: checking for location of BLAS includes" >&5
+echo "configure:10700: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10707,7 +10716,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10711: checking for location of BLAS library" >&5
+echo "configure:10720: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10733,15 +10742,15 @@
do
-echo "configure:10737: checking for $ac_hdr" >&5
+echo "configure:10746: checking for $ac_hdr" >&5
-#line 10740 "configure"
+#line 10749 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10745: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10776,13 +10785,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10780: checking for dnrm2_ in -lblas" >&5
+echo "configure:10789: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 10786 "configure"
+#line 10795 "configure"
@@ -10793,7 +10802,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10797: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10812,13 +10821,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10816: checking for dnrm2_ in -lblas" >&5
+echo "configure:10825: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10822 "configure"
+#line 10831 "configure"
@@ -10829,7 +10838,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10833: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10873,13 +10882,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10877: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10886: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 10883 "configure"
+#line 10892 "configure"
@@ -10890,7 +10899,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:10894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10905,13 +10914,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10909: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10918: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 10915 "configure"
+#line 10924 "configure"
@@ -10922,7 +10931,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10937,13 +10946,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10941: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10950: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10947 "configure"
+#line 10956 "configure"
@@ -10954,7 +10963,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:10958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10967: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11000,16 +11009,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11004: checking for sgemm in $vlib_flags" >&5
+echo "configure:11013: checking for sgemm in $vlib_flags" >&5
-#line 11006 "configure"
+#line 11015 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:11013: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -11027,13 +11036,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11031: checking for sgemm_ in -lblas" >&5
+echo "configure:11040: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 11037 "configure"
+#line 11046 "configure"
@@ -11044,7 +11053,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11048: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11059,13 +11068,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11063: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11072: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 11069 "configure"
+#line 11078 "configure"
@@ -11076,7 +11085,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:11080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11091,13 +11100,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11095: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11104: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 11101 "configure"
+#line 11110 "configure"
@@ -11108,7 +11117,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11121: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11142,13 +11151,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11146: checking for acosp in -lsunmath" >&5
+echo "configure:11155: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 11152 "configure"
+#line 11161 "configure"
@@ -11159,7 +11168,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:11163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11174,13 +11183,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11178: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11187: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 11184 "configure"
+#line 11193 "configure"
@@ -11191,7 +11200,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11195: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11221,13 +11230,13 @@
# Generic BLAS library
-echo "configure:11225: checking for sgemm_ in -lblas" >&5
+echo "configure:11234: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 11231 "configure"
+#line 11240 "configure"
@@ -11238,7 +11247,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11277,7 +11286,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11281: checking whether to use LAPACK" >&5
+echo "configure:11290: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -11302,7 +11311,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11306: checking for location of LAPACK includes" >&5
+echo "configure:11315: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11322,7 +11331,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11326: checking for location of LAPACK library" >&5
+echo "configure:11335: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11348,15 +11357,15 @@
do
-echo "configure:11352: checking for $ac_hdr" >&5
+echo "configure:11361: checking for $ac_hdr" >&5
-#line 11355 "configure"
+#line 11364 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11360: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11388,10 +11397,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11392: checking for dsegv_" >&5
+echo "configure:11401: checking for dsegv_" >&5
-#line 11395 "configure"
+#line 11404 "configure"
which can conflict with char dsegv_(); below. */
@@ -11414,7 +11423,7 @@
; return 0; }
EOF
-if { (eval echo configure:11418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -11441,13 +11450,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11445: checking for desgv_ in -llapack" >&5
+echo "configure:11454: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 11451 "configure"
+#line 11460 "configure"
@@ -11458,7 +11467,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:11462: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11471: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11490,13 +11499,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11494: checking for dgesv_ in -llapack" >&5
+echo "configure:11503: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 11500 "configure"
+#line 11509 "configure"
@@ -11507,7 +11516,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11526,13 +11535,13 @@
-echo "configure:11530: checking for dgesv_ in -llapack" >&5
+echo "configure:11539: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11536 "configure"
+#line 11545 "configure"
@@ -11543,7 +11552,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11599,7 +11608,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11603: checking whether to use Cairo" >&5
+echo "configure:11612: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11631,7 +11640,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11635: checking for location of cairo includes" >&5
+echo "configure:11644: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11657,15 +11666,15 @@
do
-echo "configure:11661: checking for $ac_hdr" >&5
+echo "configure:11670: checking for $ac_hdr" >&5
-#line 11664 "configure"
+#line 11673 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11678: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11701,7 +11710,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11705: checking for location of cairo library" >&5
+echo "configure:11714: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11721,7 +11730,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11725: checking for cairo linking flags" >&5
+echo "configure:11734: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11737,10 +11746,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11741: checking for cairo_create" >&5
+echo "configure:11750: checking for cairo_create" >&5
-#line 11744 "configure"
+#line 11753 "configure"
which can conflict with char cairo_create(); below. */
@@ -11763,7 +11772,7 @@
; return 0; }
EOF
-if { (eval echo configure:11767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -11797,10 +11806,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11801: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11810: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11804 "configure"
+#line 11813 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -11823,7 +11832,7 @@
; return 0; }
EOF
-if { (eval echo configure:11827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -11856,10 +11865,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11860: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11869: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11863 "configure"
+#line 11872 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -11882,7 +11891,7 @@
; return 0; }
EOF
-if { (eval echo configure:11886: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -11924,7 +11933,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11928: checking whether to use FreeType" >&5
+echo "configure:11937: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -11943,7 +11952,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11947: checking for location of FreeType includes" >&5
+echo "configure:11956: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11969,15 +11978,15 @@
do
-echo "configure:11973: checking for $ac_hdr" >&5
+echo "configure:11982: checking for $ac_hdr" >&5
-#line 11976 "configure"
+#line 11985 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11981: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11990: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12011,7 +12020,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12015: checking for location of FreeType library" >&5
+echo "configure:12024: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12036,13 +12045,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12040: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12049: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 12046 "configure"
+#line 12055 "configure"
@@ -12053,7 +12062,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:12057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12094,7 +12103,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12098: checking whether to use NLS" >&5
+echo "configure:12107: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -12114,10 +12123,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12118: checking for gettext" >&5
+echo "configure:12127: checking for gettext" >&5
-#line 12121 "configure"
+#line 12130 "configure"
which can conflict with char gettext(); below. */
@@ -12140,7 +12149,7 @@
; return 0; }
EOF
-if { (eval echo configure:12144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12153: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -12158,13 +12167,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12162: checking for gettext in -lintl" >&5
+echo "configure:12171: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 12168 "configure"
+#line 12177 "configure"
@@ -12175,7 +12184,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:12179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12210,7 +12219,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12214: checking whether to use C++" >&5
+echo "configure:12223: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -12226,7 +12235,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:12230: checking for $ac_word" >&5
+echo "configure:12239: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12255,7 +12264,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12259: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12268: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12266,12 +12275,12 @@
cat > conftest.$ac_ext << EOF
-#line 12270 "configure"
+#line 12279 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:12275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -12297,19 +12306,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12301: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12310: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12306: checking whether we are using GNU C++" >&5
+echo "configure:12315: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12313: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12322: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -12327,7 +12336,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12331: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12340: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12365,7 +12374,7 @@
'void exit (int);'
do
-#line 12369 "configure"
+#line 12378 "configure"
#include <stdlib.h>
$ac_declaration
@@ -12373,7 +12382,7 @@
exit (42);
; return 0; }
EOF
-if { (eval echo configure:12377: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12386: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -12383,14 +12392,14 @@
fi
rm -f conftest*
cat > conftest.$ac_ext <<EOF
-#line 12387 "configure"
+#line 12396 "configure"
#include "confdefs.h"
$ac_declaration
int main() {
exit (42);
; return 0; }
EOF
-if { (eval echo configure:12394: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12403: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
break
else
@@ -12419,7 +12428,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12423: checking whether to use openDWG" >&5
+echo "configure:12432: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12439,7 +12448,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12443: checking for location of openDGW includes" >&5
+echo "configure:12452: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12465,15 +12474,15 @@
do
-echo "configure:12469: checking for $ac_hdr" >&5
+echo "configure:12478: checking for $ac_hdr" >&5
-#line 12472 "configure"
+#line 12481 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12477: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12486: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12507,7 +12516,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12511: checking for location of openDWG library" >&5
+echo "configure:12520: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12548,7 +12557,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12552: checking whether to use POSIX threads" >&5
+echo "configure:12561: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12568,7 +12577,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12572: checking for location of POSIX threads includes" >&5
+echo "configure:12581: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12594,15 +12603,15 @@
do
-echo "configure:12598: checking for $ac_hdr" >&5
+echo "configure:12607: checking for $ac_hdr" >&5
-#line 12601 "configure"
+#line 12610 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12606: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12615: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12636,7 +12645,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12640: checking for location of POSIX threads library" >&5
+echo "configure:12649: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12661,10 +12670,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12665: checking for pthread_create" >&5
+echo "configure:12674: checking for pthread_create" >&5
-#line 12668 "configure"
+#line 12677 "configure"
which can conflict with char pthread_create(); below. */
@@ -12687,7 +12696,7 @@
; return 0; }
EOF
-if { (eval echo configure:12691: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12700: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12714,13 +12723,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12718: checking for pthread_create in -lpthread" >&5
+echo "configure:12727: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpthread $LIBS"
-#line 12724 "configure"
+#line 12733 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12731,7 +12740,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12735: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12781,7 +12790,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12785: checking whether to use OpenMP" >&5
+echo "configure:12794: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12802,7 +12811,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12806: checking for location of OpenMP includes" >&5
+echo "configure:12815: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12828,15 +12837,15 @@
do
-echo "configure:12832: checking for $ac_hdr" >&5
+echo "configure:12841: checking for $ac_hdr" >&5
-#line 12835 "configure"
+#line 12844 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12840: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12849: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12874,7 +12883,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12878: checking for location of OpenMP library" >&5
+echo "configure:12887: checking for location of OpenMP library" >&5
case "$with_openmp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12899,10 +12908,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12903: checking for GOMP_parallel_start" >&5
+echo "configure:12912: checking for GOMP_parallel_start" >&5
-#line 12906 "configure"
+#line 12915 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12925,7 +12934,7 @@
; return 0; }
EOF
-if { (eval echo configure:12929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12952,13 +12961,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12956: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12965: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 12962 "configure"
+#line 12971 "configure"
@@ -12969,7 +12978,7 @@
; return 0; }
EOF
-if { (eval echo configure:12973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13042,7 +13051,7 @@
echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:13046: checking whether to use OpenCL" >&5
+echo "configure:13055: checking whether to use OpenCL" >&5
echo "$ac_t"""$with_opencl"" 1>&6
case "$with_opencl" in
"no") USE_OPENCL= ;;
@@ -13062,7 +13071,7 @@
echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:13066: checking for location of OpenCL includes" >&5
+echo "configure:13075: checking for location of OpenCL includes" >&5
case "$with_opencl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -13089,15 +13098,15 @@
do
-echo "configure:13093: checking for $ac_hdr" >&5
+echo "configure:13102: checking for $ac_hdr" >&5
-#line 13096 "configure"
+#line 13105 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13101: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13110: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13137,10 +13146,10 @@
LIBS="-framework OpenCL $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:13141: checking for clGetPlatformInfo" >&5
+echo "configure:13150: checking for clGetPlatformInfo" >&5
-#line 13144 "configure"
+#line 13153 "configure"
which can conflict with char clGetPlatformInfo(); below. */
@@ -13163,7 +13172,7 @@
; return 0; }
EOF
-if { (eval echo configure:13167: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_clGetPlatformInfo=yes"
else
@@ -13202,15 +13211,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13206: checking for $ac_hdr" >&5
+echo "configure:13215: checking for $ac_hdr" >&5
-#line 13209 "configure"
+#line 13218 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13214: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13223: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13243,7 +13252,7 @@
# With OpenCL library directory
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13247: checking for location of OpenCL library" >&5
+echo "configure:13256: checking for location of OpenCL library" >&5
case "$with_opencl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13267,13 +13276,13 @@
echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13271: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13280: checking for clGetPlatformInfo in -lOpenCL" >&5
ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
LIBS="-lOpenCL $LIBS"
-#line 13277 "configure"
+#line 13286 "configure"
@@ -13284,7 +13293,7 @@
clGetPlatformInfo()
; return 0; }
EOF
-if { (eval echo configure:13288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13344,7 +13353,7 @@
fi
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13348: checking for special C compiler options needed for large files" >&5
+echo "configure:13357: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13352,7 +13361,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13356 "configure"
+#line 13365 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13368,7 +13377,7 @@
; return 0; }
EOF
-if { (eval echo configure:13372: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13381: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13377,7 +13386,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13381 "configure"
+#line 13390 "configure"
@@ -13393,7 +13402,7 @@
; return 0; }
EOF
-if { (eval echo configure:13397: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13406: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13420,11 +13429,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13424: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13433: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13428 "configure"
+#line 13437 "configure"
@@ -13440,14 +13449,14 @@
; return 0; }
EOF
-if { (eval echo configure:13444: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13453: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 13451 "configure"
+#line 13460 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13465,7 +13474,7 @@
; return 0; }
EOF
-if { (eval echo configure:13469: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13478: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13491,11 +13500,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13495: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13504: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13499 "configure"
+#line 13508 "configure"
@@ -13511,14 +13520,14 @@
; return 0; }
EOF
-if { (eval echo configure:13515: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13524: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13522 "configure"
+#line 13531 "configure"
#define _LARGE_FILES 1
@@ -13536,7 +13545,7 @@
; return 0; }
EOF
-if { (eval echo configure:13540: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13549: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13562,25 +13571,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13566: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13575: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13570 "configure"
+#line 13579 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13577: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13586: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13584 "configure"
+#line 13593 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13589,7 +13598,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13593: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13602: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13621,25 +13630,25 @@
ac_save_cflags=${CFLAGS}
CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13625: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13634: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13629 "configure"
+#line 13638 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13636: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13645: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13643 "configure"
+#line 13652 "configure"
#include <stdio.h>
@@ -13648,7 +13657,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13652: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13661: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13678,18 +13687,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13682: checking for fseeko" >&5
+echo "configure:13691: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13686 "configure"
+#line 13695 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13702: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13706,10 +13715,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13710: checking if system supports Large Files at all" >&5
+echo "configure:13719: checking if system supports Large Files at all" >&5
-#line 13713 "configure"
+#line 13722 "configure"
#include <stdio.h>
@@ -13741,7 +13750,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13745: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13754: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13772,7 +13781,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13776: checking whether to use wxWidgets" >&5
+echo "configure:13785: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -13793,7 +13802,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13797: checking for $ac_word" >&5
+echo "configure:13806: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -13841,7 +13850,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13845: checking wxWidgets version" >&5
+echo "configure:13854: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -13864,15 +13873,15 @@
do
-echo "configure:13868: checking for $ac_hdr" >&5
+echo "configure:13877: checking for $ac_hdr" >&5
-#line 13871 "configure"
+#line 13880 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13876: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13885: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
