[GRASS-SVN] r56948 - grass/branches/releasebranch_6_4/scripts/i.spectral
svn_grass at osgeo.org
Sat Jun 29 00:14:17 PDT 2013
Author: hamish
Date: 2013-06-29 00:14:17 -0700 (Sat, 29 Jun 2013)
New Revision: 56948
grass/branches/releasebranch_6_4/scripts/i.spectral/i.spectral
backport some bug fixes from devbr6
Modified: grass/branches/releasebranch_6_4/scripts/i.spectral/i.spectral
--- grass/branches/releasebranch_6_4/scripts/i.spectral/i.spectral 2013-06-28 13:35:20 UTC (rev 56947)
+++ grass/branches/releasebranch_6_4/scripts/i.spectral/i.spectral 2013-06-29 07:14:17 UTC (rev 56948)
@@ -27,7 +27,7 @@
#%option
#% key: group
#% type: string
-#% gisprompt: old,group
+#% gisprompt: old,group,group
#% description: Group input
#% required : no
#%end
@@ -42,7 +42,7 @@
#%option
#% key: output
#% type: string
-#% gisprompt: output
+#% gisprompt: new,file,file
#% description: Write output to PNG image
#% multiple : no
#% required : no
@@ -57,7 +57,7 @@
#%end
#%flag
#%key: c
-#%description: Label with coordinates instead of numbering
+#%description: Show pick coordinates instead of numbering in the legend
#%end
if test "$GISBASE" = ""; then
@@ -83,12 +83,16 @@
exit 1
fi
# setting environment, so that awk works properly in all languages
unset LC_ALL
LC_NUMERIC=C
export LC_NUMERIC
+if [ `d.mon -L | grep -w '^x[0-9]' | grep -vc 'not running'` -eq 0 ] ; then
+ g.message -e "No graphics device open (requires d.mon X-windows display)"
+ exit 1
+fi
TMP1="`g.tempfile pid=$$`"
TMP2="`g.tempfile pid=$$`"
@@ -105,33 +109,16 @@
fi
if [ $GIS_FLAG_I -eq 0 ] ; then
+ # Parse the group listing and set the x-axis labels as the map names
+ RASTERMAPS=`i.group -g group="$GIS_OPT_GROUP" | tr '\n' ',' | sed -e 's/,$//'`
+ NUMBANDS=`i.group -g group="$GIS_OPT_GROUP" | wc -l`
- # ## PARSES THE GROUP FILES - gets rid of ugly header info from group list output
- i.group group=$GIS_OPT_GROUP -l | sed 's+ in + +g' | grep "group" -v | grep "\-\-\-\-$" -v > "$TMP2"
- as=0
- lists=""
- xlabels=""
- ass=0
- for i in $( cat "$TMP2" ); do
- er=`expr $as % 2`
- as=`expr $as + 1`
- if [ "$er" -eq "0" ]; then
- ass=`expr $ass + 1`
- if [ "$as" -eq "1" ]; then
- lists=$i
- xlabels="'$i' 1"
- else
- lists=$lists,$i
- xlabels="$xlabels, '$i' $ass"
- fi
- fi
- done
+ xlabels=`i.group -g group="$GIS_OPT_GROUP" | cut -f1 -d'@' | \
+ sed -e "s/^\|$/'/g" | awk '{print $1,NR ","}' | tr '\n' ' ' | \
+ sed -e 's/, $//'`
-NUMBANDS=$ass
-RASTERMAPS="$lists"
-# ## get data from list of files and set the x-axis labels
else
+ ## get data from list of files and set the x-axis labels
RASTERMAPS="$GIS_OPT_RASTER"
news=`echo $GIS_OPT_RASTER | sed 's+,+ +g'`
as=0
@@ -152,18 +139,10 @@
#RASTERMAPS=`echo $RASTERMAPS | sed 's+ $++g' | sed 's+ +,+g'`
if [ "$GIS_FLAG_M" -eq "0" ]; then
- if [ `d.mon -L | grep -v 'not running' | wc -l | awk '{print $1}'` -eq 2 ] ; then
- g.message -e "No graphic device open (d.mon)"
- exit 1
- fi
- d.where -1 | r.what input=$RASTERMAPS > "$TMP1"
+ d.where -1 | r.what input="$RASTERMAPS" null=0 > "$TMP1"
else
asss=0
- exit 1
- fi
- d.where | r.what input=$RASTERMAPS > "$TMP1"
+ d.where | r.what input="$RASTERMAPS" null=0 > "$TMP1"
cat "$TMP1" > tmper
rm -f "$TMP1"
for asas in $(cat "tmper"); do
@@ -230,7 +209,7 @@
# build gnuplot script
if [ -n "$GIS_OPT_OUTPUT" ] ; then
- echo "set term png large" >> spectrum.gnuplot
+ echo "set term png truecolor large size 825,550" >> spectrum.gnuplot
echo "set output '$GIS_OPT_OUTPUT'" >> spectrum.gnuplot
fi
echo "set xtics ($xlabels)" >> spectrum.gnuplot
@@ -240,6 +219,7 @@
echo "set xrange [0:$xrange]" >> spectrum.gnuplot
echo "set noclabel" >> spectrum.gnuplot
echo "set xlabel 'Bands'" >> spectrum.gnuplot
+echo "set xtics rotate by -40" >> spectrum.gnuplot
echo "set ylabel 'DN Value'" >> spectrum.gnuplot
## if more then 2 points we can draw an interpolated spline:
@@ -261,13 +241,13 @@
if [ "$i" -eq "1" ]
then
if [ $GIS_FLAG_C -eq 0 ] ; then
- str="plot 'data_$i' title '$i'"
+ str="plot 'data_$i' title 'Pick $i'"
else
str="plot 'data_$i' title '${COORD[$i]}'"
fi
else
- str=$str",'data_$i' title '$i'"
+ str=$str",'data_$i' title 'Pick $i'"
else
str=$str",'data_$i' title '${COORD[$i]}'"
fi
